> strex/b/h
IgorKossak
сообщение Mar 13 2012, 08:58
Шаман
Из: Киев, Украина
Пользователь №: 221
Может уже где то проскакивало, но поиском не нашёл.
Что касается:
Цитата(klen @ Nov 29 2011, 00:05) *
/tmp/cc7ETq9C.s:508: Error: registers may not be the same -- `strexb r0,r0,[r1]'
/tmp/cc7ETq9C.s:533: Error: registers may not be the same -- `strexh r0,r0,[r1]'
на CodeSourcery рекомендуют сделать следующее:
Question
When compiling applications that contain or use the Cortex Microcontroller Software Interface Standard e.g. CMSIS (http://www.onarm.com/cmsis/) you may receive the following errors:
/tmp/ccaxp69S.s: Assembler messages:
/tmp/ccaxp69S.s:463: Error: registers may not be the same -- `strexb r0,r0,[r1]'
/tmp/ccaxp69S.s:488: Error: registers may not be the same -- `strexh r0,r0,[r1]'
How do I fix these "registers may not be the same" errors? Where do they come from?
Answer
Some versions of the CMSIS contain invalid inline assembly of the following form:
uint32_t __STREXB(uint8_t value, uint8_t *addr)
uint32_t result=0;
asm volatile ("strexb %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
return(result);
The first constraint =r on variable result is not correct, it should be =&r to indicate that the two registers used should not be the same e.g. early-clobber (this is required by the ARM Instruction Set Architecture).
To fix the error you must locate the invalid inline assembly and change the =r to =&r for the result register variable.
Often it is difficult to determine which source file was used to generate /tmp/ccaxp69S.s, to help with that problem add -save-temps to the compiler invocation to save the intermediate output to the current directory for your review.
This entry was last updated on 8 February 2012.
Т. е. сваливают всё не на компилятор, а на неграмотную строку в инлайн ассемблере. Может это и правильно?
Проверил их свежим тулчейном - работает.
PS Проверял только на старых проектах с CMSISv1.3
ReAl
сообщение Mar 13 2012, 09:52
Нечётный пользователь.
Из: Бровари, Україна
Пользователь №: 5 417
В комплекте с тем, что раздаёт NXP для LPC
* @file     core_cmInstr.h
* @brief    CMSIS Cortex-M Core Instruction Access Header File
* @version  V2.01
* @date     06. December 2010
Для IAR так вообще, выходит, сразу неправильно написано:
#elif (defined (__ICCARM__)) /*---------------- ICC Compiler ---------------------*/
/* IAR iccarm specific functions */
static uint32_t __STREXW(uint32_t value, volatile uint32_t *addr)
  __ASM("strex r0, r0, [r1]");
Для gcc надо править:
#elif (defined (__GNUC__)) /*------------------ GNU Compiler ---------------------*/
/* GNU gcc specific functions */
__attribute__( ( always_inline ) ) static __INLINE uint32_t __STREXB(uint8_t value, volatile uint8_t *addr)
   uint32_t result;
   __ASM volatile ("strexb %0, %2, [%1]" : "=r" (result) : "r" (addr), "r" (value) );
   return(result);
klen
сообщение Mar 14 2012, 06:36
бессмертным стать можно тремя способами
Пользователь №: 16 912
мы тут это уже проходили. смысл в том что ассемблер ругается на два одинаковых операнда, а в доке на кортекс сказано что это в даном случае возможно. поэтому cmsis прав. я правил as (убирал условие которое приводит к ошике по ситуации с двумя одинаковыми операндами) и выкладывал здесь выше сборку в которой ассемблер проглатывал код.
так что да, кто не хочет заморачиватся с тулсами - проще инлайн асм strbex и иже с ними порпавить в cmsis на использование трех операндов а не двух.
для конкретности отмечу - это косяг не gcc а binutils ( а именно ассемблера)
Сергей Борщ
сообщение Mar 14 2012, 07:01
Из: Рига, Латвия
Пользователь №: 17 095
QUOTE (klen @ Mar 14 2012, 08:36) *
Где-то мне попадалось объяснение, со ссылками на доку от кортексов, что binutils таки прав, а неправ cmsis. Чуть ли не багтрекере binutils. Постараюсь найти позже.
klen
сообщение Mar 14 2012, 07:25
давайте разбиратся с пристрастием. я помню - читал доку на http://infocenter.arm.com что можно таки strexb rX,rX, [rY].... а теперь еще раз освежаем в памяти и видим:
http://infocenter.arm.com/help/topic/com.a...a/BABFFBJB.html
вот цитата
Restrictions
In these instructions:
do not use PC
do not use SP for Rd and Rt
for STREX, Rd must be different from both Rt and Rn
the value of offset must be a multiple of four in the range 0-1020.
из чего я делаю вывод что : то что запершено для STREX не запрещено для STREXB !! ну явно то не написано что для STREXB нельзя...
в свежих CMSIS всетаки все версии иструкции закодены с разными регистрами.
вывод такой что CMSIS был с ошибками а binutils правильный НО для всех STREXB STREH пережимает ограничения на операнды также как и для STREX
может в описании ограничений на операнды имеется ввиду что STREX это = (STREX,STREXH,STREXB). тогда это явно надо писать а то я че угодно могу тогда домыслить.
и еще для раздумий... strexb r0, r0, [r1] у меня при тестах работало sm.gif ревизия ядра с ошибками???? laughing.gif
Сергей Борщ
сообщение Mar 14 2012, 07:40
Из: Рига, Латвия
QUOTE (klen @ Mar 14 2012, 09:25) *
Я так глубоко не копал. Наткнулся, записал на корочку, пошел дальше. Вот это сообщение (развязка в ответе на него): http://sources.redhat.com/ml/binutils/2011-09/msg00128.html
AHTOXA
сообщение Mar 14 2012, 09:08
фанат дивана
Из: Уфа
Пользователь №: 29 684
Я именно так и понял.
Кстати, сейчас попробовал kgp 20110328 + CMSIS от 19. July 2011, и получил:
strex    r2, r2, [ip]
Получается, у меня kgp как раз с исправлениями, а CMSIS - ещё нет?
Так не помогает, нужно: "=&r" (result).
IgorKossak
сообщение Mar 14 2012, 09:33
Шаман
Из: Киев, Украина
Пользователь №: 221
Отделил от темы про KGP.
ReAl
сообщение Mar 15 2012, 09:33
Ну так я и привёл две цитаты из файла, чтобы показать, что его нужно править :-)
AHTOXA
сообщение Mar 15 2012, 11:30
фанат дивана
Из: Уфа
RSS Текстовая версия Сейчас: 25th July 2025 - 22:49
Страница сгенерированна за 0.01464 секунд с 7
