Как остановить двигающийся автомобиль?, - бесконтакным способом - |
(30 - 44)
Jan 23 2012, 22:43
Из: albuquerque, nm
Пользователь №: 51 763
DESTOTM Direct Electromagnetic STOpper
DESTO is an advanced non-lethal device (Active Denial System) realized by SELEX Sistemi Integrati to stop and neutralize advancing adversary from relatively long range by cripping the electrical parts of engines with an elctromagnetic wave.
DESTO can contrast the approach of non authorized vehicles to restricted zones like critical infrastructures, military zone entries, oil platforms, and even checkpoints. DESTO operates by destroying or temporarily shutting down the electronic components of on-board engines, nor protected or previously shielded without harming occupants. DESTO is also able to stop UAV (Unmanned Aerial Vehicle), missiles and IED (Improvised Explosive Devices) to protect personnel and in general critical infrastructures from possible threats. It is expected to save countless lives by providing a way to stop individuals without causing injury, before a deadly confrontation develops.
These features show a very high potential for DESTO in halting pirate vessels, a crucial problem that is worsening and makes commercial navigation less safer and expensive. In fact piracy statistics point to a significant increase in attacks by pirates in the last two years. In terms of safety, reported acts of piracy committed up to late 2010 have included 219 pirate attacks, 49 vessels seized 115 vessels boarded, 31 vessels hijacked, seeing a total of 1016 crew members taken hostage, and nine killed. The total cost of piracy, including ransoms, insurance, military presence is currently estimated to be more than 10 billion $.
DESTO.pdf ( 1.53 мегабайт )
Guest_@Ark_*
Jan 24 2012, 05:39
Guests
Цитата DESTO ... Теперь понятно, почему словосочетание "британские ученые", давно стало нарицательным.
Apr 18 2012, 20:51
Из: Воронеж
Пользователь №: 53 299
На эту тему литература же есть, например, А. И. Куприянов, Радиоэлектронная борьба. Силовое поражение радиоэлектронных систем.
Guest_@Ark_*
Apr 18 2012, 20:54
Guests
Цитата ... Силовое поражение радиоэлектронных систем. Угу. А там подраздел: "Глушение ДВС с помощью микроволн", дописанный британскими учеными.
Сообщение отредактировал @Ark - Apr 18 2012, 23:08
Apr 19 2012, 18:58
Пользователь №: 71 231
Есть спец. установки (как в сериале китовые войны), генерируют звук чуть выше болевого порога. Соответственно если поставить такую на дорогу, то чем ближе к нему подъезжает машина, тем больнее водителю. Дальше он сам примет разумное решение и всё останется целым. А если не примет, то адо настроить частоту колебаний в резонанс с автомобильной... чтоб она сломалась  Еще можно сделать генератор ван де граафа, и шибать молнией по машине. Но проще всего сделать сеть из нейлона с крючками и бросить на дорогу, сеть замотается на колеса и остановить даже многотонную фуру без особых повреждений.
Сообщение отредактировал kadet.89 - Apr 19 2012, 19:03
Apr 20 2012, 15:30
Из: Где то в Европе!
Пользователь №: 8 919
Цитата(Nixon @ Apr 20 2012, 16:28)  И все же мой вариант самый надежный  ---------------------- А какая при этом енергия выделиться ? С такм же успехом можно на автомобиль бетонный блок "уронить" !
Apr 21 2012, 05:03
Цитата(VCO @ Apr 21 2012, 05:50)  Стоп! Это же злостный  на такую сурьёзную тему. Напомню название: Как остановить двигающийся автомобиль?, - бесконтакным способом -А Вы предлагаете контактный способ! Лучшие умы планеты думают, а Вы - издеваетесь! Стыдно, Самоделкин, стыдно должно быть Вам... Во всяком деле нужен сурьёз!!!...  Я же не предлягаю бетонный блок бросать на авто ,просто если воздействовать как написано выше импульсом света такой мощности последсвия будут равносильны ! Так что если хотите остановить авто то думайте куда потратить( или как её забрать) ту кин енергию которая при этом выделиться !
