Доброго времени суток всем!
У меня есть отладочная плата с процессором AM1808 (http://www.starterkit.ru/html/index.php?name=shop&op=view&id=70&word=AM1808). На процессоре установлен Linux (2.6.37). Не получается завести GPIO
Вот что я делаю:
CODE
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/gpio.h>
#include <mach/da8xx.h>
#include <mach/mux.h>
#define GPIO_BA 0x01E26000 // GPIO Base Address
#define MDCTL3_GPIO_CTRL 0x01E27A0C
#define MDSTAT3_GPIO_STAT 0x01E2780C
#define PINMUX13_ADDR 0x01C14154
#define REV_ID_ADDR 0x01C14000
#define MAP_BASE GPIO_BA
#define MAP_SIZE 4096Ul
#define MAP_MASK (MAP_SIZE - 1)
#define GPIO_BINTEN *(int*)(mapped_base+0x08)
#define GPIO_DIR01 *(int*)(mapped_base+0x88)
#define GPIO_OUT_DATA01 *(int*)(mapped_base+0x8C)
#define GPIO_SET_DATA01 *(int*)(mapped_base+0x90)
#define GPIO_CLR_DATA01 *(int*)(mapped_base+0x94)
MODULE_LICENSE("GPL");
static int My_module_init(void)
int *mapped_base, *mapped_base1, *mapped_base2, *mapped_base3;
int RevID_val = 0;
int tmp1 = 0, tmp2 = 0;
int k;
printk(KERN_ALERT "module initialization.\n");
// Прочитаем статус модуля GPIO
mapped_base1 = ioremap_nocache(MDSTAT3_GPIO_STAT, 16);
printk(KERN_ALERT "MDSTAT3_GPIO_STAT mapped 0x%08x\n", mapped_base1);
tmp2 = *(int*)mapped_base1;
printk(KERN_ALERT "MDSTAT3_GPIO_STAT has %08X\n", tmp2);
// Тактируем GPIO
mapped_base = ioremap_nocache(MDCTL3_GPIO_CTRL, 16);
printk(KERN_ALERT "MDCTL3_GPIO_CTRL mapped 0x%08x\n", mapped_base);
*(int*)mapped_base = 0x80000003;
tmp1 = *(int*)mapped_base;
printk(KERN_ALERT "In MDCTL3_GPIO_CTRL was written %08X\n", tmp1);
// Настраиваем GP6[12], GP6[11], GP6[9], GP6[8] на вывод
mapped_base2 = ioremap_nocache(PINMUX13_ADDR, 16);
printk(KERN_ALERT "PINMUX13_ADDR mapped 0x%08x\n", mapped_base2);
*(int*)mapped_base2 = 0x88088000;
tmp1 = *(int*)mapped_base2;
printk(KERN_ALERT "In PinMux13 was written %08X\n", tmp1);
mapped_base = ioremap_nocache(MAP_BASE & ~MAP_MASK, MAP_SIZE);
if (mapped_base == (void *)-1) printk(KERN_ALERT "Memory mapping error.\n");
mapped_base+=(MAP_BASE & MAP_MASK);
printk(KERN_ALERT "Target address mapped 0x%08x-->0x%08x\n",(int) MAP_BASE,(int)mapped_base);
GPIO_DIR01 = 0x0; // set pin fuction is output
tmp1 = GPIO_DIR01;
printk(KERN_ALERT "GPIO_DIR01<-%08X, tmp1);
for (k =0; k<1000; k++)
GPIO_SET_DATA01 = 0xffffffff; // pin high
GPIO_CLR_DATA01 = 0xffffffff; // pin low
iounmap(MDSTAT3_GPIO_STAT);
iounmap(MDCTL3_GPIO_CTRL);
iounmap(PINMUX13_ADDR);
iounmap(REV_ID_ADDR);
iounmap(MAP_BASE & ~MAP_MASK);
return 0;
static void My_module_exit(void) {
printk(KERN_ALERT "module exit.\n");
module_init(My_module_init);
module_exit(My_module_exit);
после подгрузки модуля вижу следующее (с добавлением некоторые отладочных сообщений):
# insmod main.ko
[ 87.361992] module initialization.
[ 87.365819] MDSTAT3_GPIO_STAT mapped 0xfee2780c
[ 87.377593] MDSTAT3_GPIO_STAT has 00001E03
[ 87.383010] MDCTL3_GPIO_CTRL mapped 0xfee27a0c
[ 87.387521] In MDCTL3_GPIO_CTRL was written 80000003
[ 87.394612] MDSTAT3_GPIO_STAT now is 00001E03
[ 87.405230] PINMUX13_ADDR mapped 0xfec14154
[ 87.410760] In PinMux13 was written 88088000
[ 87.415130] Original REVID = 0x4E840102, readed RevID_val = 0x4e840102
[ 87.438598] Target address mapped 0x01e26000-->0xfee26000
[ 87.444099] GPIO_DIR01<-00000000
Может, кто-нибудь подскажет, что я делаю не так?.. Или ещё что-то необходимо сделать?
