> GCC: Как подключить файл-таблицу в ПЗУ
MaxiMuz
сообщение Sep 24 2012, 18:08
Из: Волгоград
Пользователь №: 56 658
Доброго времяни суток!
Использую GCC 4.3.3. Имеется обьемная таблица , ну к примеру в 16тиричных кодах. Как не вписывая ее в листинг , вживить в код программы. И каким образом получать к ней доступ?
Есть ли такая возможность ?
2 страниц V  < 1 2
Ответов (15 - 24)
MaxiMuz
сообщение Sep 29 2012, 14:20
Сообщение #16
Из: Волгоград
Показываю:
# MCU name
MCU = attiny13
# Processor frequency.
F_CPU = 8000000
# Output format. (can be srec, ihex, binary)
FORMAT = ihex
# Target file name (without extension).
TARGET = BDateToFlsh
# Object files directory
#     To put object files in current directory, use a dot (.), do NOT make
#     this an empty or blank macro!
OBJDIR = .
# List C source files here. (C dependencies are automatically generated.)
SRC = $(TARGET).c
# List C++ source files here. (C dependencies are automatically generated.)
CPPSRC =
# List Assembler source files here.
ASRC = asmBDateToFlsh.S
# Optimization level, can be [0, 1, 2, 3, s].
#     0 = turn off optimization. s = optimize for size.
#     (Note: 3 is not always the best optimization level. See avr-libc FAQ.)
OPT = s
# Debugging format.
#     Native formats for AVR-GCC's -g are dwarf-2 [default] or stabs.
#     AVR Studio 4.10 requires dwarf-2.
#     AVR [Extended] COFF format requires stabs, plus an avr-objcopy run.
DEBUG = dwarf-2
# List any extra directories to look for include files here.
#     Each directory must be seperated by a space.
#     Use forward slashes for directory separators.
#     For a directory that has spaces, enclose it in quotes.
EXTRAINCDIRS =
# Compiler flag to set the C Standard level.
CSTANDARD = -std=gnu99
# Place -D or -U options here for C sources
CDEFS = -DF_CPU=$(F_CPU)UL
# Place -D or -U options here for ASM sources
ADEFS = -DF_CPU=$(F_CPU)
# Place -D or -U options here for C++ sources
CPPDEFS = -DF_CPU=$(F_CPU)UL
#---------------- Compiler Options C ----------------
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS)
CFLAGS += -O$(OPT)
CFLAGS += -funsigned-char
CFLAGS += -funsigned-bitfields
CFLAGS += -fpack-struct
CFLAGS += -fshort-enums
CFLAGS += -Wall
CFLAGS += -Wstrict-prototypes
CFLAGS += -Wa,-adhlns=$(<:%.c=$(OBJDIR)/%.lst)
CFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
CFLAGS += $(CSTANDARD)
#---------------- Compiler Options C++ ----------------
CPPFLAGS = -g$(DEBUG)
CPPFLAGS += $(CPPDEFS)
CPPFLAGS += -O$(OPT)
CPPFLAGS += -funsigned-char
CPPFLAGS += -funsigned-bitfields
CPPFLAGS += -fpack-struct
CPPFLAGS += -fshort-enums
CPPFLAGS += -fno-exceptions
CPPFLAGS += -Wall
CPPFLAGS += -Wundef
CPPFLAGS += -Wa,-adhlns=$(<:%.cpp=$(OBJDIR)/%.lst)
CPPFLAGS += $(patsubst %,-I%,$(EXTRAINCDIRS))
#---------------- Assembler Options ----------------
#  -Wa,...:   tell GCC to pass this to the assembler.
#  -adhlns:   create listing
#  -gstabs:   have the assembler create line number information; note that
#             for use in COFF files, additional information about filenames
#             and function names needs to be present in the assembler source
#             files -- see avr-libc docs [FIXME: not yet described there]
#  -listing-cont-lines: Sets the maximum number of continuation lines of hex
#       dump that will be displayed for a given single line of source input.
ASFLAGS = $(ADEFS) -Wa,-adhlns=$(<:%.S=$(OBJDIR)/%.lst),-gstabs,--listing-cont-lines=100
#---------------- Library Options ----------------
# Minimalistic printf version
PRINTF_LIB_MIN = -Wl,-u,vfprintf -lprintf_min
# Floating point printf version (requires MATH_LIB = -lm below)
PRINTF_LIB_FLOAT = -Wl,-u,vfprintf -lprintf_flt
# If this is left blank, then it will use the Standard printf version.
PRINTF_LIB =
# Minimalistic scanf version
SCANF_LIB_MIN = -Wl,-u,vfscanf -lscanf_min
# Floating point + %[ scanf version (requires MATH_LIB = -lm below)
SCANF_LIB_FLOAT = -Wl,-u,vfscanf -lscanf_flt
# If this is left blank, then it will use the Standard scanf version.
SCANF_LIB =
MATH_LIB = -lm
# List any extra directories to look for libraries here.
EXTRALIBDIRS =
#---------------- External Memory Options ----------------
# 64 KB of external RAM, starting after internal RAM (ATmega128!),
# used for variables (.data/.bss) and heap (malloc()).
# only used for heap (malloc()).
EXTMEMOPTS =
#---------------- Linker Options ----------------
#  -Wl,...:     tell GCC to pass this to linker.
#    -Map:      create map file
#    --cref:    add cross reference to  map file
LDFLAGS = -Wl,-Map=$(TARGET).map,--cref,-gc-sections
LDFLAGS += $(EXTMEMOPTS)
LDFLAGS += $(patsubst %,-L%,$(EXTRALIBDIRS))
LDFLAGS += $(PRINTF_LIB) $(SCANF_LIB) $(MATH_LIB)
#LDFLAGS += -T linker_script.x
#---------------- Programming Options (avrdude) ----------------
AVRDUDE_PROGRAMMER = ponyser
AVRDUDE_PORT = com1    # programmer connected to serial device
AVRDUDE_WRITE_FLASH = -U flash:w:$(TARGET).hex
AVRDUDE_FLAGS = -p $(MCU) -P $(AVRDUDE_PORT) -c $(AVRDUDE_PROGRAMMER)
AVRDUDE_FLAGS += $(AVRDUDE_NO_VERIFY)
AVRDUDE_FLAGS += $(AVRDUDE_VERBOSE)
AVRDUDE_FLAGS += $(AVRDUDE_ERASE_COUNTER)
#---------------- Debugging Options ----------------
DEBUG_MFREQ = $(F_CPU)
DEBUG_UI = insight
DEBUG_BACKEND = avarice
GDBINIT_FILE = __avr_gdbinit
# When using avarice settings for the JTAG
JTAG_DEV = /dev/com1
# Debugging port used to communicate between GDB / avarice / simulavr.
DEBUG_PORT = 4242
# Debugging host used to communicate between GDB / avarice / simulavr, normally
#     just set to localhost unless doing some sort of crazy debugging when
#     avarice is running on a different computer.
DEBUG_HOST = localhost
# Define programs and commands.
SHELL = sh
CC = avr-gcc
OBJCOPY = avr-objcopy
OBJDUMP = avr-objdump
SIZE = avr-size
AR = avr-ar rcs
NM = avr-nm
AVRDUDE = avrdude
REMOVE = rm -f
REMOVEDIR = rm -rf
COPY = cp
WINSHELL = cmd
# Define Messages
# English
MSG_ERRORS_NONE = Errors: none
MSG_BEGIN = -------- begin --------
MSG_END = --------  end  --------
MSG_SIZE_BEFORE = Size before:
MSG_SIZE_AFTER = Size after:
MSG_COFF = Converting to AVR COFF:
MSG_EXTENDED_COFF = Converting to AVR Extended COFF:
MSG_FLASH = Creating load file for Flash:
MSG_EEPROM = Creating load file for EEPROM:
MSG_EXTENDED_LISTING = Creating Extended Listing:
MSG_SYMBOL_TABLE = Creating Symbol Table:
MSG_LINKING = Linking:
MSG_COMPILING = Compiling C:
MSG_COMPILING_CPP = Compiling C++:
MSG_ASSEMBLING = Assembling:
MSG_CLEANING = Cleaning project:
MSG_CREATING_LIBRARY = Creating library:
#$(OBJCOPY) --rename-section .data=.progmem.data,contents,alloc,load,readonly,data -I binary -O elf32-avr Glue.bin Glue.o
# Define all object files.
OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o)
# Define all listing files.
LST = $(SRC:%.c=$(OBJDIR)/%.lst) $(CPPSRC:%.cpp=$(OBJDIR)/%.lst) $(ASRC:%.S=$(OBJDIR)/%.lst)
# Compiler flags to generate dependency files.
GENDEPFLAGS = -MMD -MP -MF .dep/$(@F).d
# Combine all necessary flags and optional flags.
# Add target processor to flags.
ALL_CFLAGS = -mmcu=$(MCU) -I. $(CFLAGS) $(GENDEPFLAGS)
ALL_CPPFLAGS = -mmcu=$(MCU) -I. -x c++ $(CPPFLAGS) $(GENDEPFLAGS)
ALL_ASFLAGS = -mmcu=$(MCU) -I. -x assembler-with-cpp $(ASFLAGS)
# Creating Object file from Bin file
#$(OBJDIR)/%.o : %.bin
#    @echo Converting $<
#    @$(OBJCOPY) -I binary -O elf32-avr \
#    --rename-section .data=.progmem.data,contents,alloc,load,readonly,data \
#    --redefine-sym _binary_$*_bin_start=$* \
#    --redefine-sym _binary_$*_bin_end=$*_end \
#    --redefine-sym _binary_$*_bin_size=$*_size_sym \
#    @echo "extern const char" $(*)"[] PROGMEM;" > $(*).h
#    @echo "extern const char" $(*)_end"[] PROGMEM;" >> $(*).h
#    @echo "extern const char" $(*)_size_sym"[];" >> $(*).h
#    @echo "#define $(*)_size ((int)$(*)_size_sym)" >> $(*).h
# Default target.
all: begin gccversion sizebefore build sizeafter end
# Change the build target to build a HEX file or a library.
build: elf hex eep lss sym
#build: lib
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
LIBNAME=lib$(TARGET).a
lib: $(LIBNAME)
# Eye candy.
# AVR Studio 3.x does not check make's exit code but relies on
# the following magic strings to be generated by the compile job.
begin:
    @echo
    @echo $(MSG_BEGIN)
end:
    @echo $(MSG_END)
    @echo
# Display size of file.
HEXSIZE = $(SIZE) --target=$(FORMAT) $(TARGET).hex
ELFSIZE = $(SIZE) --mcu=$(MCU) --format=avr $(TARGET).elf
sizebefore:
    @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_BEFORE); $(ELFSIZE); \
    2>/dev/null; echo; fi
sizeafter:
    @if test -f $(TARGET).elf; then echo; echo $(MSG_SIZE_AFTER); $(ELFSIZE); \
# Display compiler version information.
gccversion :
    @$(CC) --version
# Program the device.
program: $(TARGET).hex $(TARGET).eep
    $(AVRDUDE) $(AVRDUDE_FLAGS) $(AVRDUDE_WRITE_FLASH) $(AVRDUDE_WRITE_EEPROM)
# Generate avr-gdb config/init file which does the following:
#     define the reset signal, load the target file, connect to target, and set
#     a breakpoint at main().
gdb-config:
    @$(REMOVE) $(GDBINIT_FILE)
    @echo define reset >> $(GDBINIT_FILE)
    @echo SIGNAL SIGHUP >> $(GDBINIT_FILE)
    @echo end >> $(GDBINIT_FILE)
    @echo file $(TARGET).elf >> $(GDBINIT_FILE)
    @echo target remote $(DEBUG_HOST):$(DEBUG_PORT)  >> $(GDBINIT_FILE)
ifeq ($(DEBUG_BACKEND),simulavr)
    @echo load  >> $(GDBINIT_FILE)
endif
    @echo break main >> $(GDBINIT_FILE)
debug: gdb-config $(TARGET).elf
ifeq ($(DEBUG_BACKEND), avarice)
    @echo Starting AVaRICE - Press enter when "waiting to connect" message displays.
    @$(WINSHELL) /c start avarice --jtag $(JTAG_DEV) --erase --program --file \
    $(TARGET).elf $(DEBUG_HOST):$(DEBUG_PORT)
    @$(WINSHELL) /c pause
else
    @$(WINSHELL) /c start simulavr --gdbserver --device $(MCU) --clock-freq \
    $(DEBUG_MFREQ) --port $(DEBUG_PORT)
endif
    @$(WINSHELL) /c start avr-$(DEBUG_UI) --command=$(GDBINIT_FILE)
# Convert ELF to COFF for use in debugging / simulating in AVR Studio or VMLAB.
COFFCONVERT = $(OBJCOPY) --debugging
COFFCONVERT += --change-section-address .data-0x800000
COFFCONVERT += --change-section-address .bss-0x800000
COFFCONVERT += --change-section-address .noinit-0x800000
COFFCONVERT += --change-section-address .eeprom-0x810000
coff: $(TARGET).elf
    @echo
    @echo $(MSG_COFF) $(TARGET).cof
    $(COFFCONVERT) -O coff-avr $< $(TARGET).cof
extcoff: $(TARGET).elf
    @echo
    @echo $(MSG_EXTENDED_COFF) $(TARGET).cof
    $(COFFCONVERT) -O coff-ext-avr $< $(TARGET).cof
# Create final output files (.hex, .eep) from ELF output file.
%.hex: %.elf
    @echo
    @echo $(MSG_FLASH) $@
    $(OBJCOPY) -O $(FORMAT) -R .eeprom -R .fuse -R .lock -R .signature $< $@
%.eep: %.elf
    @echo
    @echo $(MSG_EEPROM) $@
    -$(OBJCOPY) -j .eeprom --set-section-flags=.eeprom="alloc,load" \
    --change-section-lma .eeprom=0 --no-change-warnings -O $(FORMAT) $< $@ || exit 0
# Create extended listing file from ELF output file.
%.lss: %.elf
    @echo
    @echo $(MSG_EXTENDED_LISTING) $@
    $(OBJDUMP) -h -S -z $< > $@
# Create a symbol table from ELF output file.
%.sym: %.elf
    @echo
    @echo $(MSG_SYMBOL_TABLE) $@
    $(NM) -n $< > $@
# Create library from object files.
.SECONDARY : $(TARGET).a
.PRECIOUS : $(OBJ)
%.a: $(OBJ)
    @echo
    @echo $(MSG_CREATING_LIBRARY) $@
    $(AR) $@ $(OBJ)
# Link: create ELF output file from object files.
.SECONDARY : $(TARGET).elf
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
    @echo
    @echo $(MSG_LINKING) $@
    $(CC) $(ALL_CFLAGS) $^ --output $@ $(LDFLAGS)
# Compile: create object files from C source files.
$(OBJDIR)/%.o : %.c
    @echo
    @echo $(MSG_COMPILING) $<
    $(CC) -c $(ALL_CFLAGS) $< -o $@
# Compile: create object files from C++ source files.
$(OBJDIR)/%.o : %.cpp
    @echo
    @echo $(MSG_COMPILING_CPP) $<
    $(CC) -c $(ALL_CPPFLAGS) $< -o $@
# Compile: create assembler files from C source files.
%.s : %.c
    $(CC) -S $(ALL_CFLAGS) $< -o $@
# Compile: create assembler files from C++ source files.
%.s : %.cpp
    $(CC) -S $(ALL_CPPFLAGS) $< -o $@
# Assemble: create object files from assembler source files.
$(OBJDIR)/%.o : %.S
    @echo
    @echo $(MSG_ASSEMBLING) $<
    $(CC) -c $(ALL_ASFLAGS) $< -o $@
# Create preprocessed source for use in sending a bug report.
%.i : %.c
    $(CC) -E -mmcu=$(MCU) -I. $(CFLAGS) $< -o $@
# Target: clean project.
clean: begin clean_list end
clean_list :
    @echo
    @echo $(MSG_CLEANING)
    $(REMOVE) $(TARGET).hex
    $(REMOVE) $(TARGET).eep
    $(REMOVE) $(TARGET).cof
    $(REMOVE) $(TARGET).elf
    $(REMOVE) $(TARGET).map
    $(REMOVE) $(TARGET).sym
    $(REMOVE) $(TARGET).lss
    $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.o)
    $(REMOVE) $(SRC:%.c=$(OBJDIR)/%.lst)
    $(REMOVE) $(SRC:.c=.s)
    $(REMOVE) $(SRC:.c=.d)
    $(REMOVE) $(SRC:.c=.i)
    $(REMOVEDIR) .dep
# Create object files directory
$(shell mkdir $(OBJDIR) 2>/dev/null)
# Include the dependency files.
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
# Listing of phony targets.
.PHONY : all begin finish end sizebefore sizeafter gccversion \
build elf hex eep lss sym coff extcoff \
clean clean_list program debug gdb-config
ReAl
сообщение Sep 29 2012, 21:44
Сообщение #17
Нечётный пользователь.
Из: Бровари, Україна
Пользователь №: 5 417
Ну так Glue.o нигде не прописан как нужный в проекте.
Если он лежит в $(OBJDIR) то можно так добавить (и можно правило раскомментировать для создания .o из .bin)
OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o) $(OBJDIR)/Glue.o
Или завести BINSRC (ну вот такие вот «исходники» :-) ) и обрабатывать аналогично остальным
# перечислить все бинарные, которые нужно перегнать в OBJ
BINSRC = Glue.bin Glue2.bin
OBJ = $(SRC:%.c=$(OBJDIR)/%.o) $(CPPSRC:%.cpp=$(OBJDIR)/%.o) $(ASRC:%.S=$(OBJDIR)/%.o) $(BINSRC:%.bin=$(OBJDIR)/%.o)
p.s. А портянку можно было и в codebox завернуть
MaxiMuz
сообщение Sep 30 2012, 07:47
Сообщение #18
Из: Волгоград
Да, я не указал, правило приведенное мной выше из мануала по WinAVR - не работает !
Также я отдельной строкой прописывал : "$(OBJCOPY) --rename-section .data=.progmem.data,contents,alloc,load,readonly,data -I binary -O elf32-avr Glue.bin Glue.o"
- тоже самое , обьектник не появлялся.
Согласен с вами , вчера полдня на это убил ....... но "мы легких путей не ищем" .....
XVR
сообщение Sep 30 2012, 10:20
Сообщение #19
Из: Химки
Пользователь №: 26 847
Разумеется - вы в половине мест обратные слеши в конце срок забыли написать
И не появится. make не строит файлов, которые никому не нужны. А ваш .o из .bin (судя по вашему Makefile'у) никому не нужен.
Добавьте Glue.o в список объектников, как ReAl советовал.
Для начала можно явно добавить - OBJ += Glue.o после его начального присваивания
MaxiMuz
сообщение Oct 17 2012, 11:50
Сообщение #20
Из: Волгоград
Нет ни какой реакции ...
XVR
сообщение Oct 17 2012, 15:43
Сообщение #21
Из: Химки
Значит не туда добавили - показывайте Makefile после добавления
Владивольт
сообщение Oct 17 2012, 21:38
Сообщение #22
Пользователь №: 55 490
Цитата(_Артём_ @ Sep 25 2012, 20:18) *
Данные можно выделить в отдельный файл, который ничего кроме таблицы не будет содержать - читабельность не пострадает.
это предложение потерялось за борьбой с makefile'ом
uint8_t tabl[] PROGMEM = {
#include "table.csv"
#define TRUE (4==(2*2))
SyncLair
сообщение Oct 17 2012, 22:00
Сообщение #23
Пользователь №: 69 197
Поддерживаю а файл table.csv генерируйте с помошью чего угодно
table.csv: какой_то_исходник
чего-угодно какой_то_исходник
файл_с_прогмемом:table.csv
Сообщение отредактировал SyncLair - Oct 17 2012, 22:02
MaxiMuz
сообщение Oct 23 2012, 12:27
Сообщение #24
Из: Волгоград
Со вставкой текста в PROGMEM все ясно. И всеже как это работает на уровне сбрщика, хочется разобраться.
Вот мой makefile. Всего лишь раскоментированна строчка переименования секции
и добавлен параметр
OBJ += Glue.o
# MCU name
MCU = attiny13
F_CPU = 8000000
FORMAT = ihex
OBJDIR = .
SRC = $(TARGET).c
CPPSRC =
OPT = s
# Debugging format.
DEBUG = dwarf-2
EXTRAINCDIRS =
CFLAGS = -g$(DEBUG)
CFLAGS += $(CDEFS)
CFLAGS += -O$(OPT)
CFLAGS += -Wall
CPPFLAGS += -Wall
CPPFLAGS += -Wundef
PRINTF_LIB =
SCANF_LIB =
MATH_LIB = -lm
EXTRALIBDIRS =
EXTMEMOPTS =
DEBUG_UI = insight
DEBUG_PORT = 4242
SHELL = sh
CC = avr-gcc
SIZE = avr-size
AR = avr-ar rcs
NM = avr-nm
AVRDUDE = avrdude
REMOVE = rm -f
REMOVEDIR = rm -rf
COPY = cp
WINSHELL = cmd
# Define Messages
# English
OBJ += Glue.o
# Default target.
#build: lib
elf: $(TARGET).elf
hex: $(TARGET).hex
eep: $(TARGET).eep
lss: $(TARGET).lss
sym: $(TARGET).sym
lib: $(LIBNAME)
# Eye candy.
begin:
    @echo
    @echo $(MSG_BEGIN)
end:
    @echo $(MSG_END)
    @echo
sizebefore:
sizeafter:
gccversion :
    @$(CC) --version
gdb-config:
endif
else
endif
coff: $(TARGET).elf
    @echo
    @echo
%.hex: %.elf
    @echo
%.eep: %.elf
    @echo
%.lss: %.elf
    @echo
%.sym: %.elf
    @echo
    $(NM) -n $< > $@
.PRECIOUS : $(OBJ)
%.a: $(OBJ)
    @echo
    $(AR) $@ $(OBJ)
.PRECIOUS : $(OBJ)
%.elf: $(OBJ)
    @echo
$(OBJDIR)/%.o : %.c
    @echo
    @echo
%.s : %.c
%.s : %.cpp
$(OBJDIR)/%.o : %.S
    @echo
%.i : %.c
clean_list :
    @echo
    $(REMOVEDIR) .dep
ReAl
сообщение Oct 23 2012, 16:12
Сообщение #25
и добавлен параметр
OBJ += Glue.o
Да непонятки-то не с уровнем сборщика, а с уровнем makefile, как там и что работает.
Объектник лучше добавлять в тот же каталог, где и остальные
OBJ += $(OBJDIR)/Glue.o
тем более, что закомментированное правило «Creating Object file from Bin file» именно на такой obj и ссылается. Сама строка OBJ += находится там, где надо.
А вот строка, отбитая вылазящими за правый край экрана восклицательным знаками -- там ни к чему. Оттуда уберите.
Гораздо ниже, где-то в окрестности «# Compile: create object files from C++ source files.» добавьте
    $(OBJCOPY) --rename-section .data=.progmem.data,contents,alloc,load,readonly,data -I binary -O elf32-avr $< $@
Или перенесите туда и раскомментируйте тот блок «Creating Object file from Bin file»
Имея в списке $(OBJDIR)/Glue.o make сам разберётся, что его можно сделать из Glue.bin, так как файлов Glue.c Glue.cpp в проекте нет.
2 страниц V  < 1 2
RSS Текстовая версия Сейчас: 20th July 2025 - 19:42
Страница сгенерированна за 0.01553 секунд с 7
