> XC8+PIC16+I2C
animal
сообщение May 29 2014, 07:09
Из: Нижний Новгород
Пользователь №: 34 535
Добрый день, господа! Прошу Вашей помощи.
#include <../../../../../../../../include/xc.h>
#include <../../../../../../include/pic16f1518.h>
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
// CONFIG1
#pragma config FOSC = INTOSC    // Oscillator Selection (INTOSC oscillator: I/O function on CLKIN pin)
#pragma config WDTE = OFF       // Watchdog Timer Enable (WDT disabled)
#pragma config PWRTE = OFF      // Power-up Timer Enable (PWRT disabled)
#pragma config MCLRE = OFF      // MCLR Pin Function Select (MCLR/VPP pin function is digital input)
#pragma config CP = OFF         // Flash Program Memory Code Protection (Program memory code protection is disabled)
#pragma config BOREN = OFF      // Brown-out Reset Enable (Brown-out Reset disabled)
#pragma config CLKOUTEN = OFF   // Clock Out Enable (CLKOUT function is disabled. I/O or oscillator function on the CLKOUT pin)
#pragma config IESO = OFF       // Internal/External Switchover (Internal/External Switchover mode is disabled)
#pragma config FCMEN = ON       // Fail-Safe Clock Monitor Enable (Fail-Safe Clock Monitor is enabled)
// CONFIG2
#pragma config WRT = OFF        // Flash Memory Self-Write Protection (Write protection off)
#pragma config VCAPEN = OFF     // Voltage Regulator Capacitor Enable bit (VCAP pin function disabled)
#pragma config STVREN = OFF      // Stack Overflow/Underflow Reset Enable (Stack Overflow or Underflow will cause a Reset)
#pragma config BORV = LO        // Brown-out Reset Voltage Selection (Brown-out Reset Voltage (Vbor), low trip point selected.)
#pragma config LPBOR = OFF      // Low-Power Brown Out Reset (Low-Power BOR is disabled)
#define _XTAL_FREQ 16000000
#define __delay_ms(x) _delay((unsigned long)((x)*(_XTAL_FREQ/4000.0)))
unsigned char Tmp;
main(void)
{   OSCCON = 0b01111010;        // Internal OSC @ 16MHz
    SSPCON1=0b00101000;         //I2C master
    SSPCON3bits.SDAHT = 1;      // Minimum of 300 ns hold time on SDA
                                // after the falling edge of SCL
    SSPSTAT=0b10000000;         //slew rate control disabled
    SSPADD=0x27;                //100 kHz
    SSPIF = 0;                  // Clear the serial port interrupt flag
    BCLIF = 0;                  // Clear the bus coll interrupt flag
    BCLIE = 1;                  // Enable bus collision interrupts
    SSPIE = 1;                  // Enable serial port interrupts
    PEIE = 1;                   // Enable peripheral interrupts
    GIE = 1;                    // Enable global interrupts
    PORTC = 0x00;               // Clear PORTC
    LATC = 0x00;                // Clear PORTC latches
    TRISC = 0b00011000;         // Set RC3, RC4 as inputs for I2C
    PORTB=0x00;
    LATB=0x00;
    TRISB=0x00;
    __delay_ms(100);
do{
   SSPCON2bits.SEN = 1;      // set start bit
   SSPBUF=0x30;
   do{}while(!SSPIF);
   SSPIF=0;
  //  SSPBUF=0x55;
//  do{}while(!SSPIF);
  //  SSPIF=0;
    SSPCON2bits.PEN = 1;       // set stop bit
    PORTBbits.RB5=1;
    __delay_ms(100);
    PORTBbits.RB5=0;
    __delay_ms(100);
}while(1);
На RB5 - светодиод. Без строчек с SSP все мигает. При загрузке приведенного кода мигания нет. При запуске в отладке с PicKit3 происхдят "перескоки" на начало программы (даже если в теле программы про SSP только одна строчка старт-бита). Контроллер PIC16F1518, XC8 1.31, MPLAB-X 1.9, код слизан с AN734. Пните пожалуйста в нужном направлении. sad.gif
Voldemari4
сообщение May 29 2014, 07:30
Пользователь №: 81 582
У вас разрешены прерывания, а где обработчик прерываний?
A. Fig Lee
сообщение May 29 2014, 07:34
Из: далека
Пользователь №: 36 467
Именно. Обработчика нет.
2. А что, так можно:
GIE = 1; //?
и компайлер понимает?
Я думал что только
INTCONbits.GIE=1;
и так далее..
Верить нельзя никому, даже себе. Мне - можно.
Voldemari4
сообщение May 29 2014, 07:40
Цитата(A. Fig Lee @ May 29 2014, 16:44) *
А что, так можно:
GIE = 1; //?
Я думал что только
INTCONbits.GIE=1;
Все биты прописаны через #define в заголовочном файле для контроллера. Вот пример для PIC24
/* INTCON2 */
#define _INT0EP INTCON2bits.INT0EP
#define _INT1EP INTCON2bits.INT1EP
#define _INT2EP INTCON2bits.INT2EP
#define _DISI INTCON2bits.DISI
#define _ALTIVT INTCON2bits.ALTIVT
A. Fig Lee
сообщение May 29 2014, 08:43
Из: далека
А.. интересненько.. Не, пожалуй, с битами лучше. Нагляднее.
animal
сообщение May 29 2014, 08:46
Из: Нижний Новгород
добавил:
void interrupt isr(void)
{   if (SSPIF)
    {   Tmp=1;
        SSPIF=0;
    if (BCLIF)
    {   Tmp=1;
        BCLIF=0;
и изменил:
   do{}while(SSPCON2bits.SEN);
   SSPBUF=0x30;
   do{}while(!Tmp);
   Tmp=0;
Мыргает. На строке do{}while(SSPCON2bits.SEN) возникает BusCollision (вижу в режиме отладки PicKitом). sad.gif и на ногах SCL SDA ничего не происходит. Старта нет, посылки нет. Пинайте дальше. sm.gif Возможно что-то с конфигурацией не так, но она полностью слизана из апноута и на CCS старт и посылка адреса присутствовала.
A. Fig Lee
сообщение May 29 2014, 08:58
Из: далека
Ну если бас коллижн, значит там уже "0" на той ноге. Я так понимаю.
Резисторы подтяжки на + стоят?
Че вольтметр показывает ДО старта?
animal
сообщение May 30 2014, 01:32
Из: Нижний Новгород
Резисторы подтяжки стоят на килооом на плюс.
На выводах всегда +5. Не проскакивает ни импульса (следит осцил в режиме выборки).
Далее код на CCS:
#BYTE SSPCON1=0x0215
#BYTE SSPSTAT=0x0214
#BYTE SSPADD=0x0212
#BYTE SSPCON2=0x0216
#BYTE SSPCON3=0x0217
#BYTE SSPBUF=0x0211
#BYTE PIR1=0x0011
#BYTE PIE1=0x0091
#BYTE PIR2=0x0012
#BYTE PIE2=0x0092
#INT_SSP
void ssp_interrupts()
{   Tmp_SSP=TRUE;
    clear_interrupt(INT_SSP);
#INT_BUSCOL
void ssp_collision()
{   Tmp_BUSCOL=TRUE;
    clear_interrupt(INT_BUSCOL);
    output_high(PIN_B5);
void main()
{setup_oscillator(OSC_16MHZ|OSC_INTRC);
SSPCON3=0b00001000;
SSPSTAT=0b10000000;//slew rate control disabled
bit_set(PIE1,3);//SSPIE=1 interrupt enable
bit_set(PIE2,3);//BCLIE=1 interrupt bus collision enable
enable_interrupts(GLOBAL);
delay_ms (500);
do{
    bit_set(SSPCON2,0); //start SEN=1
    do{}while(bit_test(SSPCON2,0));
    SSPBUF=0x08;
    do{}while(!Tmp_SSP); //SSPIF=? (interrupt=?)
    Tmp_SSP=0;
    SSPBUF=0x55;
    do{}while(Tmp_SSP); //SSPIF=? (interrupt=?)
    Tmp_SSP=0;
    bit_set(SSPCON2,2); //stop bit
    delay_us(100);
}while(TRUE);
}//main
Код на CCS дает старт бит и посылку байта адреса, затем повтор.
Запуск отладки на PickKit3 не показателен. Отладка на коде CCS тоже приводит к "перескоку" выполнения со строки do{}while(!Tmp_SSP); //после посылки адреса. Реально-же, байты адреса следуют друг за другом (без паузы в полсекунды).
И, да, в программе на XC8, прерывания по BUSCOL на самом деле не происходит. Но на выводах все равно +5 и тишина...
Voldemari4
сообщение May 30 2014, 02:20
Ваша программа может зависать на циклах while. Все таки внутри цикла стоит сделать счетчик и выход через некоторое время в случае зависания. Попробуйте еще вместо ожидания флага прерывания после передачи поставить ожидание сброса бита SSPSTATbits.BF. И еще зачем вам прерывание void ssp_interrupts()?
animal
сообщение May 30 2014, 02:31
Из: Нижний Новгород
CCS-ный код приведен для примера, что MSSP контроллера признаки жизни подает и с пайкой ничего не напутано. Сконцентрировать внимание хотелось бы именно на XC8, так как планирую на него перейти. Проблема в том, что на XC8 MSSP признаки жизни вообще не подает.
П.С.: Экспресс-опрос присутствующих. А на чем программируете Вы? И на чем, по вашему мнению, программирует большинство микрочиповцев?
A. Fig Lee
сообщение May 30 2014, 07:10
Из: далека
Я на XC8.
Вот выжимка из рабочего кода PIC18F14K50:
void Init()
    SSPADD = 29; //48 MHz PLL, 12 MHz crystal
    SSPCON1bits.SSPM = 0x08;
    SSPCON1bits.SSPEN = 1;
    // Enable priority interrupt
    RCONbits.IPEN = 1;
    INTCONbits.GIEL = 1;
    INTCONbits.GIEH = 1;
   IPR1bits.SSPIP = 0;
   PIE1bits.SSPIE = 1;
inline void I2C_wait()
    while (PIR1bits.SSPIF == 0);
uint8_t I2C_read(uint8_t addr) {
    uint8_t ret = 0xDD;
    //START
    I2C_wait();
    //Device address
    SSPBUF = I2C_ADDR;
    I2C_wait();
    //Device memory address
    SSPBUF = addr;
    I2C_wait();
    //Repeated start
    SSPCON2bits.RSEN = 1;
    I2C_wait();
    //Device address with READ bit on
    SSPBUF = I2C_ADDR | 0x01;
    I2C_wait();
    //enable read
    SSPCON2bits.RCEN = 1;
    I2C_wait();
    SSPCON2bits.ACKDT = 0;
    SSPCON2bits.ACKEN = 1;
    ret = SSPBUF;
    I2C_wait();
    I2C_wait();
    ret =  SSPBUF;
    I2C_wait();
    I2C_wait();
    SSPCON2bits.ACKDT = 1;
    ret =  SSPBUF;
    I2C_wait();
    ret = SSPBUF;
    return ret;
void interrupt low_priority LowPriorityInterrupt()
   if (PIR1bits.SSPIF) {
       PIR1bits.SSPIF = 0;
       //i2c_interrupt();
animal
сообщение May 30 2014, 07:54
Из: Нижний Новгород
За выжимку спасибо. Я, хоть тресни, не вижу ошибки в коде. Модуль MSSP не подает вообще ни импульса. Конфигурацию проверил десять раз уже. Не могу понять где ошибка...
Сообщение отредактировал animal - May 30 2014, 07:55
A. Fig Lee
сообщение May 30 2014, 08:32
Из: далека
Аналоговый блок есть там, отключен?
А просто можками подергать/почитать - работает?
animal
сообщение May 30 2014, 08:55
Из: Нижний Новгород
Добавил : ADCON0bits.ADON=0; //ADC disable
Нет изменений.
На CCS+MPLABX даже пытается I2С работать. Ноги точно рабочие.
A. Fig Lee
сообщение May 30 2014, 09:34
Из: далека
Остается сравнить состояния регистров до I2C START в CCS и XC8
RSS Текстовая версия Сейчас: 2nd September 2025 - 18:03
Страница сгенерированна за 0.01507 секунд с 7
