CAN не принимает данные.
У меня внешний кристал 10М. Поэтому
/* PLL configuration: PLLCLK = HSE * 7 = 70 MHz */
RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLMULL7);
Исходя из этого настраиваю CAN baud rate 125kBit
CODE
static void CAN_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
/* CAN GPIOs configuration **************************************************/
/* Enable GPIO clock */
RCC_AHBPeriphClockCmd(CAN_GPIO_CLK, ENABLE);
/* Connect CAN pins to AF7 */
GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_RX_SOURCE, CAN_AF_PORT);
GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_TX_SOURCE, CAN_AF_PORT);
/* Configure CAN RX and TX pins */
GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN | CAN_TX_PIN;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
/* NVIC configuration *******************************************************/
NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* CAN configuration ********************************************************/
/* Enable CAN clock */
RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE);
/* CAN register init */
CAN_DeInit(CANx);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
//70 / ((3+7+10) * 28) = 125000
CAN_InitStructure.CAN_SJW = 3;
CAN_InitStructure.CAN_BS1 = 10;
CAN_InitStructure.CAN_BS2 = 7;
CAN_InitStructure.CAN_Prescaler = 28;
CAN_Init(CANx, &CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 0;
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
/* Transmit Structure preparation
TxMessage.StdId = 0x321;
TxMessage.ExtId = 0x01;
TxMessage.RTR = CAN_RTR_DATA;
TxMessage.IDE = CAN_ID_STD;
TxMessage.DLC = 1; */
/* Enable FIFO 0 message pending Interrupt */
CAN1->IER |= CAN_IER_FMPIE0 | CAN_IER_ERRIE | CAN_IER_BOFIE | CAN_IER_EPVIE;
//CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
Запускаю утилиту CAN Monitor и посылаю пакет. На скопе вижу сигнал а прерывание не происходит.
CODE
void USB_LP_CAN1_RX0_IRQHandler(void)
//FIFO Overrun error
if (CAN1->RF0R & CAN_RF0R_FOVR0)
CAN1->RF0R &= ~CAN_RF0R_FOVR0;
CAN1->RF0R |= CAN_RF0R_RFOM0; /* release FIFO */
return;
//FIFO Full - ready to read data
if (CAN1->RF0R & CAN_RF0R_FULL0)
CAN1->RF0R &= ~CAN_RF0R_FULL0;
can_idx=0;
while (CAN1->RF0R & CAN_RF0R_FMP0)
memcpy(can_rx_packet+can_idx, (uint8_t *) &CAN1->sFIFOMailBox[0].RDLR, 4);
can_idx += 4;
memcpy(can_rx_packet+can_idx, (uint8_t *) &CAN1->sFIFOMailBox[0].RDHR, 4);
can_idx += 4;
CAN1->RF0R |= CAN_RF0R_RFOM0; /* release FIFO to read next message */
data_ready = 1;
Где может быть проблема?
Сообщение отредактировал IgorKossak - May 5 2016, 08:18
Причина редактирования: [codebox] для длинного кода. [code]-для короткого!!!
