> Вопрос про phy ethernet, stm32f407 + KSZ8873
Granadoespada
сообщение Sep 5 2016, 12:49
Пользователь №: 89 981
Здравствуйте! Есть микроконтроллер и phy KSZ8873 делаю инициализацию пинов
CODE
void eth_gpio_config()
GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_GPIOB |
RCC_AHB1Periph_GPIOC, ENABLE);
/* Configure PA2 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
//GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_ETH);
/* Configure PC1, PC2 and PC3 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource2, GPIO_AF_ETH);
/* Configure PB5, PB8, PB11, PB12 and PB13 as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_11 |
GPIO_Pin_12 | GPIO_Pin_13;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource11, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource12, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource13, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_3;
// GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource0, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource3, GPIO_AF_ETH);
/* Configure PB10 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
// GPIO_ResetBits(GPIOB, GPIO_Pin_10); /* FIXME: fucking workaround */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource10, GPIO_AF_ETH);
/* Configure PC3 as input */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource3, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource7, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5;
GPIO_PinAFConfig(GPIOC, GPIO_PinSource4, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOC, GPIO_PinSource5, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1;
GPIO_PinAFConfig(GPIOB, GPIO_PinSource0, GPIO_AF_ETH);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource1, GPIO_AF_ETH);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
GPIO_PinAFConfig(GPIOA, GPIO_PinSource8, GPIO_AF_MCO);
дальше идет конфигурация MAC_DMA
CODE
void eth_mac_dma_config()
ETH_InitTypeDef ETH_InitStructure;
/* Enable SYSCFG clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Включение частот ETHERNET */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_ETH_MAC | RCC_AHB1Periph_ETH_MAC_Tx |
RCC_AHB1Periph_ETH_MAC_Rx, ENABLE);
/* MII/RMII Media interface selection --------------------------------------*/
SYSCFG_ETH_MediaInterfaceConfig(SYSCFG_ETH_MediaInterface_MII);
RCC_MCO1Config(RCC_MCO1Source_HSE, RCC_MCO1Div_1);
SYSCFG_CompensationCellCmd(ENABLE);
/* Перзагрузка ETHERNET на шине AHB */
ETH_DeInit();
/* Программная перезагрузка */
ETH_SoftwareReset();
/* Ожидание программной перезагрузки */
while(ETH_GetSoftwareResetStatus() == SET);
/* Настройка ETHERNET */
ETH_StructInit(&ETH_InitStructure);
/* Настройка параметров MAC */
ETH_InitStructure.ETH_AutoNegotiation = ETH_AutoNegotiation_Enable;
ETH_InitStructure.ETH_LoopbackMode = ETH_LoopbackMode_Disable;
ETH_InitStructure.ETH_RetryTransmission = ETH_RetryTransmission_Disable;
ETH_InitStructure.ETH_AutomaticPadCRCStrip = ETH_AutomaticPadCRCStrip_Disable;
ETH_InitStructure.ETH_ReceiveAll = ETH_ReceiveAll_Disable;
ETH_InitStructure.ETH_BroadcastFramesReception = ETH_BroadcastFramesReception_Enable;
ETH_InitStructure.ETH_PromiscuousMode = ETH_PromiscuousMode_Disable;
ETH_InitStructure.ETH_MulticastFramesFilter = ETH_MulticastFramesFilter_Perfect;
ETH_InitStructure.ETH_UnicastFramesFilter = ETH_UnicastFramesFilter_Perfect;
ETH_InitStructure.ETH_ChecksumOffload = ETH_ChecksumOffload_Enable;
/* Настройка параметров DMA */
ETH_InitStructure.ETH_DropTCPIPChecksumErrorFrame = ETH_DropTCPIPChecksumErrorFrame_Enable;
ETH_InitStructure.ETH_ReceiveStoreForward = ETH_ReceiveStoreForward_Enable;
ETH_InitStructure.ETH_TransmitStoreForward = ETH_TransmitStoreForward_Enable;
ETH_InitStructure.ETH_Speed = ETH_Speed_100M;
ETH_InitStructure.ETH_ForwardErrorFrames = ETH_ForwardErrorFrames_Disable;
ETH_InitStructure.ETH_ForwardUndersizedGoodFrames = ETH_ForwardUndersizedGoodFrames_Disable;
ETH_InitStructure.ETH_SecondFrameOperate = ETH_SecondFrameOperate_Enable;
ETH_InitStructure.ETH_AddressAlignedBeats = ETH_AddressAlignedBeats_Enable;
ETH_InitStructure.ETH_FixedBurst = ETH_FixedBurst_Enable;
ETH_InitStructure.ETH_RxDMABurstLength = ETH_RxDMABurstLength_32Beat;
ETH_InitStructure.ETH_TxDMABurstLength = ETH_TxDMABurstLength_32Beat;
ETH_InitStructure.ETH_DMAArbitration = ETH_DMAArbitration_RoundRobin_RxTx_2_1;
/* Применение настроек Ethernet */
ETH_Init(&ETH_InitStructure, PHY_ADDRESS);
/* Включение прерываний Ethernet Rx */
ETH_DMAITConfig(ETH_DMA_IT_NIS | ETH_DMA_IT_R, ENABLE);
Почему то не может выйти из функции ожидания программной перезагрузки while(ETH_GetSoftwareResetStatus() == SET).
Может кто сможет подсказать что делаю не так?
За ранее спасибо.
Сообщение отредактировал IgorKossak - Sep 5 2016, 15:13
Причина редактирования: [codebox] для длинного кода. [code]-для короткого!!!
3 страниц V  < 1 2 3
Ответов (30 - 41)
scifi
сообщение Sep 6 2016, 13:35
Сообщение #31
Пользователь №: 25 136
Цитата(Granadoespada @ Sep 6 2016, 16:29) *
Если это так то у меня тактирующий сигнал не приходит.
У вас, видимо, MII. Но, я думаю, можно смело предположить, что, как и в случае с RMII, MAC из сброса не выйдет.
Что нужно сделать что бы он был?
Искать ошибки проектирования и/или брак платы и монтажа.
Integro
сообщение Sep 6 2016, 13:43
Сообщение #32
Пользователь №: 54 460
Цитата(Granadoespada @ Sep 6 2016, 16:35) *
А если PHY не делает 25 MHz?
Теперь нужно проверить все напряжения на PHY и клок самого PHY. От чего тактируется PHY?
Granadoespada
сообщение Sep 6 2016, 13:50
Сообщение #33
PHY тактируется от по MCO от микроконтроллера HSE 25MHz
Integro
сообщение Sep 6 2016, 14:07
Сообщение #34
и...? Частота в норме?
scifi
Сообщение #35
Есть тысяча и один способ накосячить. Например, на PHY может быть подан сигнал сброса. Ну и остальные 1000 вариантов laughing.gif
Granadoespada
сообщение Sep 6 2016, 14:11
Сообщение #36
Частота в норме. Сигнал сброса буду проверять.
scifi
сообщение Sep 6 2016, 14:17
Сообщение #37
Кстати, схему кто рисовал? KSZ8873 может работать в разных режимах, там нельзя просто всё бросить в кучу и рассчитывать, что оно заработает. Как бы требуется понимание того, как это работает. Впрочем, это никогда не вредно.
Granadoespada
сообщение Sep 7 2016, 05:26
Сообщение #38
Схему делал человек, который в этом разбирается. Он делал связку stm32f103 + KSZ8873. Взяли данное устройство и на том устройстве тактирующий сигнал от PHY приходит скорее всего причина в отсутсвии сигнала от PHY. Сейчас будем выяснять почему он не приходит.
Всем большое спасибо за помощь. Как будет результат то сразу отпишусь.
Integro
сообщение Sep 7 2016, 07:05
Сообщение #39
Если схема включения уже отлажена, я бы порекомендовал в N-ый раз проверить инициализацию пинов и режим работы (MII\RMII)!
Granadoespada
сообщение Sep 7 2016, 09:57
Сообщение #40
Вроде заработало! передача осуществляется.
iosifk
сообщение Sep 7 2016, 10:06
Сообщение #41
Из: спб
Пользователь №: 8 369
И в чем же дело было?
www.iosifk.narod.ru
Granadoespada
сообщение Sep 7 2016, 10:20
Сообщение #42
от PHY не приходил тактирующий сигнал на микроконтроллер, из за того что подтянули данный выход PHY к земле.
3 страниц V  < 1 2 3
RSS Текстовая версия Сейчас: 20th July 2025 - 10:42
Страница сгенерированна за 0.01497 секунд с 7
