> Сложносоставное УГО
djs_13
сообщение Mar 24 2017, 11:28
Пользователь №: 86 024
Необходимо сделать сложносоставное уго на микросхему, состоит из 4х вентелей. Символ нарисовал 1, в Part сделал 4 gate. неподключенные символы вывел отдельно.
при упаковке проекта выдает следующее
Checking for value differences between non-null symbol properties and PartsDB properties,
but only for those properties checked off in the Property Definition Editor
Checking the validity of the packaging of prepackaged schematic
symbols. Only the first error in symbols having the same
Reference Designator will be reported.
PDB ERROR: Pin number 7 is found multiple times in the
Component mapping section, thereby making it a common pin.
It is also a supply/no connect pin either by its own pin property
or by its presence in a gate with supply/no connect pins.
A supply/no connect pin is an implied common pin to all of the
logical gates of a part and cannot also be defined as an explicit common pin
on part number 533LA3.
If a Parts DataBase other than the local one is corrected,
please be sure to run Packager in the overwrite mode or
Forward Annotation in the 'Replace Local Parts' mode. Otherwise, be
sure not to use these modes or the corrections will be lost.
Что я делаю не так?
RSS Текстовая версия Сейчас: 18th July 2025 - 08:05
Страница сгенерированна за 0.01365 секунд с 7
