Поменяю Mini2440 + 3.5" LCD на STM32F412G-DISCO или NUCLEO-F412ZG
или продам за 2500 р
Спецификация на семейство ниже, по сабжу на картинках/
Девайс не эксплуатировался.
Specification
Dimension: 100 x 100 mm
CPU: 400 MHz Samsung S3C2440 ARM926T (max freq. 533 MHz)
RAM: 64 MB, 32 bit Bus
Flash: up to 1GB NAND Flash
EEPROM: 256 Byte (I2C)
Ext. Memory: SD-Card socket
Serial Ports: 1x DB9 connector (RS232), total: 3x serial port connectors
USB: 1x USB-A Host 1.1, 1x USB-B Device 1.1
Audio Output: 3.5 mm stereo jack
Audio Input: Connector + Condenser microphone
Ethernet: RJ-45 10/100M (DM9000)
RTC: Real Time Clock with battery (CR1220)
Beeper: PWM buzzer
Camera: 20 pin (2.0 mm) Camera interface
LCD Interface: 41 pin connector for FriendlyARM Displays and VGA Board
User Inputs: 6x push buttons and 1x A/D pot
User Outputs: 4x LEDs
Expansion: 40 pin System Bus, 34 pin GPIO, 10 pin Buttons (2.0 mm)
Debug: 10 pin JTAG (2.0 mm)
Power: regulated 5V (DC-Plug: 1.35mm inner x 3.5mm outer diameter)
Power Consumption: Mini2440: 0.3 A, Mini2440 + 3.5" LCD: 0.6 A, Mini2440 + 7" LCD: 1 A
OS Support
Windows CE 5 and 6
Linux
