3 страниц V   1 2 3 >
> Alwinner A13 не стартует с SD-карты, Отладочная плата A13-olinuxino
__inline__
сообщение Mar 30 2018, 13:15
Пользователь №: 99 126
Здравствуйте!
Начал осваивать Allwinner A13 и пока безуспешно. Использую отладочную плату "A13-olinuxino", загрузиться хочу с SD карты (4 ГБ класс скорости 4).
Компилятор arm-none-eabi , исходник программы ниже, мигает светодиодом на порте G 9 (штатный порт на отладочной плате со светодиодом):
CODE
#define uint32_t unsigned long int
#define CCMBase 0x01C20000 //clock module
#define Def_APB0_Gating CCMBase + 0x68
//#define Def_APB0_Gating 0x01C20068
#define GPIOBase 0x01C20800
#define GPIOIncrement 0x24
#define ALLWINNER_GPIO_A GPIOBase
#define ALLWINNER_GPIO_B GPIOBase + (1*GPIOIncrement)
#define ALLWINNER_GPIO_C GPIOBase + (2*GPIOIncrement)
#define ALLWINNER_GPIO_D GPIOBase + (3*GPIOIncrement)
#define ALLWINNER_GPIO_E GPIOBase + (4*GPIOIncrement)
#define ALLWINNER_GPIO_F GPIOBase + (5*GPIOIncrement)
#define ALLWINNER_GPIO_G GPIOBase + (6*GPIOIncrement)
#define ALLWINNER_GPIO_H GPIOBase + (7*GPIOIncrement)
#define ALLWINNER_GPIO_I GPIOBase + (8*GPIOIncrement)
#define Port_CFG0 0x00 //pin direction and function 0 to 7
#define Port_CFG1 0x04 //pin direction and function 8 to 15
#define Port_CFG2 0x08 //pin direction and function 16 to 24
#define Port_CFG3 0x0C //pin direction and function 25 to 32
#define Port_DAT 0x10
#define Port_DRV0 0x14
#define Port_DRV1 0x18
#define Port_PUL0 0x1C
void main(void)
int i;
int j;
int foo;
uint32_t *portGConfig;
uint32_t *portGData;
uint32_t *APB0Gating;
//setup pointers for registers
portGConfig = (uint32_t *)(ALLWINNER_GPIO_G + Port_CFG1);
portGData = (uint32_t *)(ALLWINNER_GPIO_G + Port_DAT);
APB0Gating = (uint32_t *)(Def_APB0_Gating);
//enable clocking for GPIO
*APB0Gating |= 0x0020;
//configure port G pin 9 to output
*portGConfig |= 0x10;
//set output to on
*portGData |= 0x0200;
Loop:
foo = 0;
for (j = 0; j < 100; j++)
//toggle output
*portGData ^= 0x0200;
foo=j;
for (i = 0; i < 30000000; i++)
if(i>10)
foo++;
goto Loop;
Файл линковщика:
MEMORY
RAM (XRW) : ORIGIN = 0x00000000, LENGTH = 0x00004000 /* 16 KB */
SECTIONS
.start    : { *(.start)    } > RAM
.text     : { *(.text)     } > RAM
.bss      : { *(.bss)      } > RAM
.fill     :
  FILL(0x00);
  . = ORIGIN(RAM) + LENGTH(RAM) - 1;
  BYTE(0x00);
} > RAM
/DISCARD/ : { *(.dynstr*)  }
/DISCARD/ : { *(.dynamic*) }
/DISCARD/ : { *(.plt*)     }
/DISCARD/ : { *(.interp*)  }
/DISCARD/ : { *(.gnu*)     }
/DISCARD/ : { *(.note*)    }
ассемблерный листинг:
test.elf:     file format elf32-littlearm
Disassembly of section .text.startup:
00000000 <main>:
   0:    e59f3030     ldr    r3, [pc, #48]; 38 <main+0x38>
   4:    e5932068     ldr    r2, [r3, #104]; 0x68
   8:    e3822020     orr    r2, r2, #32
   c:    e5832068     str    r2, [r3, #104]; 0x68
  10:    e59328dc     ldr    r2, [r3, #2268]; 0x8dc
  14:    e3822010     orr    r2, r2, #16
  18:    e58328dc     str    r2, [r3, #2268]; 0x8dc
  1c:    e59328e8     ldr    r2, [r3, #2280]; 0x8e8
  20:    e3822c02     orr    r2, r2, #512; 0x200
  24:    e58328e8     str    r2, [r3, #2280]; 0x8e8
  28:    e59f300c     ldr    r3, [pc, #12]; 3c <main+0x3c>
  2c:    e2533001     subs    r3, r3, #1
  30:    1afffffd     bne    2c <main+0x2c>
  34:    eafffffb     b    28 <main+0x28>
мейк-скрипт:
arm-none-eabi-gcc     -Os -march=armv7-a -std=c99 -marm -fpic -Wall -fno-common -fno-builtin -ffreestanding -nostdinc -nostdlib -fno-strict-aliasing -mno-thumb-interwork -fno-stack-protector -fno-toplevel-reorder -Wstrict-prototypes -Wno-format-nonliteral -Wno-format-security -c test.c -o test.o
arm-none-eabi-ld      -T test.lds -M -o test.elf test.o
arm-none-eabi-objdump -D test.elf > test.asm
arm-none-eabi-objcopy -O binary test.elf test.bin
mksunxiboot.exe test.bin test-sd.bin
Для создания загрузочного образа использую программу с аргументами: mksunxiboot.exe test.bin test-sd.bin
С помощью дискового редактора копирую весь образ на 16-й сектор карты памяти (это смещение 8кБ от начала).
Карта памяти отформатирована в винде. Первые сектора - ДОСовский загрузчик-заглушка .
Из ассемблерного листинга видно что программа идет с адреса 0, как требуется в A13.
Хедер вроде тоже с верной контрольной суммой.
Стек инитится BROM-ом (при старте) SP=0x7FF8
Вставляю карту в одладочную плату, подаю питание (внешний БП 6V 2A) - и ничего не горит.
Пожалуйста, помогите разобраться, чего не хватает и что не так?
Весь проект прилагаю, мейк-файлы, скрипты и утилиты там же.
P.S.
Звонил светодиод и ножку контроллера - контакт есть, диод зажигается от тестера.
Объявил переменные volatile, не помогло:
CODE
void main(void)
volatile int i;
volatile int j;
volatile int foo;
volatile uint32_t *portGConfig;
volatile uint32_t *portGData;
volatile uint32_t *APB0Gating;
portGConfig = (volatile uint32_t *)(ALLWINNER_GPIO_G + Port_CFG1);
portGData = (volatile uint32_t *)(ALLWINNER_GPIO_G + Port_DAT);
APB0Gating = (volatile uint32_t *)(Def_APB0_Gating);
//set output to on
Loop:
foo = 0;
//toggle output
foo=j;
if(i>10)
foo++;
goto Loop;
00000000 <main>:
0: e59f3094 ldr r3, [pc, #148]; 9c <main+0x9c>
4: e24dd010 sub sp, sp, #16
8: e5932068 ldr r2, [r3, #104]; 0x68
c: e3822020 orr r2, r2, #32
10: e5832068 str r2, [r3, #104]; 0x68
14: e59328dc ldr r2, [r3, #2268]; 0x8dc
18: e3822010 orr r2, r2, #16
1c: e58328dc str r2, [r3, #2268]; 0x8dc
20: e59328e8 ldr r2, [r3, #2280]; 0x8e8
24: e3822c02 orr r2, r2, #512; 0x200
28: e58328e8 str r2, [r3, #2280]; 0x8e8
2c: e3a02000 mov r2, #0
30: e58d200c str r2, [sp, #12]
34: e58d2008 str r2, [sp, #8]
38: e59d2008 ldr r2, [sp, #8]
3c: e3520063 cmp r2, #99; 0x63
40: cafffff9 bgt 2c <main+0x2c>
44: e59328e8 ldr r2, [r3, #2280]; 0x8e8
48: e2222c02 eor r2, r2, #512; 0x200
4c: e58328e8 str r2, [r3, #2280]; 0x8e8
50: e59d2008 ldr r2, [sp, #8]
54: e58d200c str r2, [sp, #12]
58: e3a02000 mov r2, #0
5c: e58d2004 str r2, [sp, #4]
60: e59d1004 ldr r1, [sp, #4]
64: e59f2034 ldr r2, [pc, #52]; a0 <main+0xa0>
68: e1510002 cmp r1, r2
6c: ca000007 bgt 90 <main+0x90>
70: e59d2004 ldr r2, [sp, #4]
74: e352000a cmp r2, #10
78: c59d200c ldrgt r2, [sp, #12]
7c: c2822001 addgt r2, r2, #1
80: c58d200c strgt r2, [sp, #12]
84: e59d2004 ldr r2, [sp, #4]
88: e2822001 add r2, r2, #1
8c: eafffff2 b 5c <main+0x5c>
90: e59d2008 ldr r2, [sp, #8]
94: e2822001 add r2, r2, #1
98: eaffffe5 b 34 <main+0x34>
9c: 01c20000 biceq r0, r2, r0
a0: 01c9c37f biceq ip, r9, pc, ror r3
Сообщение отредактировал IgorKossak - Mar 30 2018, 14:33
Причина редактирования: [codebox] для длинного кода. [code]-для короткого!!!
aaarrr
сообщение Mar 30 2018, 13:40
Пользователь №: 1 448
Попробуйте сначала этот бинарник из-под u-boot'а запустить с любого адреса. Версию с volatile, конечно, т.к. первый вариант ничем мигать не может точно.
__inline__
сообщение Mar 30 2018, 14:24
может быть проблема в этом:
sudo dd if=bin/release.bin of=/dev/sdb bs=1024 seek=8
И почему bs=1024, когда сектор карты 512 байт? И что мне вместо sudo в винде использовать? Пока пишу дисковым редактором на 16-й сектор карты памяти.
С uboot пока бесполезно, нету под рукой RS232 <=> UART
Может всё-же проверяет карту и если там упоминание о винде(первые 2 сектора), то не грузится?
aaarrr
сообщение Mar 30 2018, 14:31
Это просто удобный способ задать смещение: 8 * 1K нагляднее, чем 16 * 512. К размеру сектора отношения не имеет.
Надо завести, без UART никак.
Содержимое первых секторов ему безразлично.
__inline__
сообщение Mar 30 2018, 15:03
Ещё один момент: на отладочной плате A13-Olinuxino не установлена NAND-Flash микросхема, и перемычка (SMD) замкнута: NCE_NAND_E - это Chip Enable как я понимаю. Может процессор пытается с неё загрузиться и перемычку надо разомкнуть, чтоб с SD карты пошла загрузка? Если да, прийдётся скальпелем резать потому что перемычка замкнута печатным проводником, а не резистором
aaarrr
сообщение Mar 30 2018, 15:08
Allwinner'ы грузятся с нулевой SD карты при любых условиях, она первая в списке загрузки.
mantech
сообщение Mar 30 2018, 20:11
Из: Киров
Пользователь №: 73 143
Первые сектора резервируются под бут рекорд, например, если используете сд карту как загрузчик и ФС одновременно.
Не дадите ссылочки на компиляторы, ИДЕ и пр. инструменты, которые используете, тоже попробовать хочется, но с настройками гнушных программ туговато crying.gif
__inline__
сообщение Mar 31 2018, 05:01
Приобрёл адаптер RS232 <>UART.
К какому UART цепляться к UART1 или UART0 ? На линиях UART0 сидит карта SD - конфликт?
Формат данных: 115200, 8 , N, 1?
Для убута надо: u-boot-sunxi-with-spl.bin или 2 файла: sunxi-spl.bin и u-boot.img - бинарников не нашёл, только огромный tar.gz который надо самому собирать и компилить.
Поделитесь плиз SPL и U-Boot-ом для A13 пожалуйста.
А то чувствую себя застрявшим уже 2й день..
Сообщение отредактировал __inline__ - Mar 31 2018, 05:02
__inline__
сообщение Mar 31 2018, 06:50
Взял spl и u-boot отсюдова: http://dl.linux-sunxi.org/users/amery/sunxi-3.0/latest/
Архив: a13_olinuxino_hwpack.tar.xz
Закатал spl с 16-го сектор а карты, u-boot с 64-го сектора.
Скачал терминалку, при включенни питания на плату, валят несколько нулей, причем независимо от того стоит SD карта или нет. Если что-то послать, в ответ идут снова нули.
Подключился к UART1.
Соединение прямое: TX allwinner => TX адаптера RS232-UART, RX alwinner => RX адаптера. Питание 3,3V с платы на адаптер, GND вместе.
Бред идёт какой-то в общем:
WinXP, в биосе порт включен (COM1 0x2F8)
Jury093
сообщение Mar 31 2018, 08:35
Пользователь №: 13 050
обычно практикуется RX оборудования на TX адаптера и наоборот
а вы в архив "только огромный tar.gz" заглядывали? может там есть готовые бинарники?
и по начальному сообщению - цифры в адресах и битовых полях вроде правильные, поищите еще, может не хватает общего разрешения работы gpio, помимо клоков и работы с битами
и лучше не "мигать" светиком, а выставить в "1", тогда не будет неоднозначности. загорелся - значит прога стартовала
и еще, к вашей плате должен быть набор бинарников (ищите у производителя), накидайте на SD и запускайте с адаптером, буковки побегут, будете двигаться дальше..
__inline__
сообщение Mar 31 2018, 11:06
Я много вариантов перепробовал: и с мигающим диодом и не с мигающим. Ничего не работает.
И ссылку давал постом выше на тот Spl и u-boot, там ясно написано что он для olinuxino-A13. Заливал и SPL и U-boot - результат один - ничерта ничего не работает.
А те нули которые в терминале - разобрался, это наводка по воздуху, что доказывает, что UART1 не заводится, значит с SD-карты u-boot не грузится.
Много перепробовал готовых образов - ничего вообще не запускается и в терминале не бежит.
Пробовал ещё это:
http://radiokot.ru/articles/59/
там готовый бинарник есть, он тоже не пошёл.
Всё тоже самое пробовал на другой отладке - A13-SOM - результат такой же (точнее -без результата).
Могут ли быть проблемы с SD-картой? У меня SDmicro 4GB с классом 4.
Просто складывается впечатление, что приобрёл кирпичи, в Терраэлектронике, кстати, брал обе платы (Olinuxino и SOM) - напаяно дерьмовым образом - куча флюса оставлено и контроллер криво запаян как будто дрожащей рукой кто-то паял (неровности на контактах)
Никто не ковырял Alwinner-ы ? Мне одному выпала такая участь?
Сообщение отредактировал __inline__ - Mar 31 2018, 11:09
aaarrr
сообщение Mar 31 2018, 11:59
И "ковыряли" и свои изделия проектировали.
Это -
проверили?
Jury093
сообщение Mar 31 2018, 12:24
страничка от олимекса подойдет?
https://www.olimex.com/wiki/Bare_Metal_programming_A13
там вроде пошагово расписано, чего и как ставить..
кстати, и для проблемы ТС есть абзац:
GPIO issue
The above code works but the LED only turns on if printf is used. This appears to be caused by compiling optimization.
Not sure how to fix this with the u boot make files however the make file in the following section has optimization turned down to allow the GPIO setting to not be compiled out.
я бы попробовал вместо -Os написать -O0
aaarrr
сообщение Mar 31 2018, 12:32
Все проблемы и так видны в листинге. Первый вариант - "без volatile" - неработоспособен, второй на вид должен работать.
mantech
сообщение Mar 31 2018, 13:17
Из: Киров
GPIO issue
Ну не фанат я линукса, почему и спрашиваю, что под винду надобно...
На счет -Оs - тут правда, раз на такую засаду еще на АВРках напоролся...
На счет сд карты - такие карты должны работать, если сама карта живая, конечно, как-то на планшете перешивал тоже 4 гига.
В таком случае надо было покупать вместе с линукс-картой олимекса, она там за несколько евро продается, и сразу можно было проверить кирпич или нет...
3 страниц V   1 2 3 >
RSS Текстовая версия Сейчас: 21st August 2025 - 16:43
Страница сгенерированна за 0.01834 секунд с 7
