> Посылка по CAN в STM32F3
Jenya7
сообщение Aug 17 2018, 09:56
Пользователь №: 71 075
Настраиваю CAN
CODE
void CAN_Setup(void)
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
CAN_InitTypeDef CAN_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
/* CAN GPIOs configuration **************************************************/
/* Enable GPIO clock */
RCC->AHBENR |= RCC_AHBPeriph_GPIOB;
/* Connect CAN pins to AF9 */
GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_9);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_9);
/* Configure CAN RX and TX pins */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8| GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
/* NVIC configuration *******************************************************/
NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX1_IRQn;
/* CAN configuration ********************************************************/
/* Enable CAN clock */
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
// CAN cell init
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = DISABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
/* CAN Baudrate = 1MBps (CAN clocked at 36 MHz) */
CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq;
CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
CAN_InitStructure.CAN_Prescaler = 2;
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
//CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq;
//CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq;
//CAN_InitStructure.CAN_Prescaler = 39;
//CAN_InitStructure.CAN_SJW = 2;
CAN_Init(CANx, &CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 0;
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
/* Enable FIFO 0 message pending Interrupt */
CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
/* Enable FIFO 1 message pending Interrupt */
CAN_ITConfig(CANx, CAN_IT_FMP1, ENABLE);
Посылаю
    TxMessage.StdId = ( (0x100 *(i+1)) + CAN_COM_WHO_IS);
    TxMessage.DLC = 1;
    TxMessage.RTR = CAN_RTR_DATA;
    TxMessage.IDE = CAN_ID_STD;
     CAN_Transmit(CAN1, &TxMessage);
В функции посылки - все мейлбоксы заняты - я попадаю в transmit_mailbox = CAN_TxStatus_NoMailBox;
CODE
uint8_t CAN_Transmit(CAN_TypeDef* CANx, CanTxMsg* TxMessage)
uint8_t transmit_mailbox = 0;
/* Check the parameters */
assert_param(IS_CAN_ALL_PERIPH(CANx));
assert_param(IS_CAN_IDTYPE(TxMessage->IDE));
assert_param(IS_CAN_RTR(TxMessage->RTR));
assert_param(IS_CAN_DLC(TxMessage->DLC));
/* Select one empty transmit mailbox */
if ((CANx->TSR&CAN_TSR_TME0) == CAN_TSR_TME0)
else if ((CANx->TSR&CAN_TSR_TME1) == CAN_TSR_TME1)
transmit_mailbox = 1;
else if ((CANx->TSR&CAN_TSR_TME2) == CAN_TSR_TME2)
transmit_mailbox = 2;
else
if (transmit_mailbox != CAN_TxStatus_NoMailBox)
/* Set up the Id */
CANx->sTxMailBox[transmit_mailbox].TIR &= TMIDxR_TXRQ;
if (TxMessage->IDE == CAN_Id_Standard)
assert_param(IS_CAN_STDID(TxMessage->StdId));
CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->StdId << 21) | \
TxMessage->RTR);
else
assert_param(IS_CAN_EXTID(TxMessage->ExtId));
CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->ExtId << 3) | \
TxMessage->IDE | \
TxMessage->RTR);
/* Set up the DLC */
TxMessage->DLC &= (uint8_t)0x0000000F;
CANx->sTxMailBox[transmit_mailbox].TDTR &= (uint32_t)0xFFFFFFF0;
CANx->sTxMailBox[transmit_mailbox].TDTR |= TxMessage->DLC;
/* Set up the data field */
CANx->sTxMailBox[transmit_mailbox].TDLR = (((uint32_t)TxMessage->Data[3] << 24) |
((uint32_t)TxMessage->Data[2] << 16) |
((uint32_t)TxMessage->Data[1] << 8) |
((uint32_t)TxMessage->Data[0]));
CANx->sTxMailBox[transmit_mailbox].TDHR = (((uint32_t)TxMessage->Data[7] << 24) |
((uint32_t)TxMessage->Data[6] << 16) |
((uint32_t)TxMessage->Data[5] << 8) |
((uint32_t)TxMessage->Data[4]));
/* Request transmission */
CANx->sTxMailBox[transmit_mailbox].TIR |= TMIDxR_TXRQ;
return transmit_mailbox;
Если принимающая сторона не приняла мейлбокс он не освободился ?
Сообщение отредактировал IgorKossak - Aug 19 2018, 20:06
Причина редактирования: [codebox] для длинного кода, [code] - для короткого!
2 страниц V  < 1 2
Ответов (15 - 20)
Jenya7
сообщение Sep 21 2018, 07:21
Сообщение #16
фигня какая то с этим КАНом.
Прием на мастере и слейве одинаковый
void USB_LP_CAN1_RX0_IRQHandler(void)
     can_params.message_received = 1;
     can_params.fifo_num = CAN_FIFO0;
      CAN_Receive(CANx, CAN_FIFO0, &RxMessage);
посылка тоже
uint8_t CAN_TX(uint8_t mot_id, uint8_t opcode, uint8_t *data, uint32_t data_size)
     uint8_t mailbox_num;
     TxMessage.IDE = CAN_ID_EXT;
     TxMessage.ExtId = (opcode << 8) | mot_id;
     if (data_size > 8)
         data_size = 8;
     TxMessage.DLC = data_size;
     memcpy(&TxMessage.Data[0], data, data_size);
     mailbox_num = CAN_Transmit(CANx, &TxMessage);
     return mailbox_num;
мастер посылает
void main (void)
{    while(1)
          CAN_TX(100, MASTER_COM_WHO_IS, can_data_buf, 0);
я вижу четкий прием
void CAN_TX_Slave(uint32_t opcode)
          switch (opcode)
             //я сюда попадаю
             case CAN_COM_WHO_IS :
                 size = 0;
                             //посылка ответа
                  CAN_TX(motor_sys_params.mot_id, CAN_COM_I_AM, data, 0);
             break;
но мастер в прерывание приема не заходит. я ставлю паузу на мастере - и тогда он заходит в прерывание приема.
это что мастер должен освободить шину чтоб получить ответ?
в какой то момент на слейве вдруг TEC = 0xFF REC = 0xFF и он отсыхает несмотря на то что CAN1->BTR |= CAN_BTR_SILM;
Подключил слейв к USB-CAN Plus - это ж просто праздник какой то. посылка прием - все в порядке. почему два камня не могут договориться между собой?
Сообщение отредактировал Jenya7 - Sep 21 2018, 08:33
esaulenka
сообщение Sep 21 2018, 13:04
Сообщение #17
Из: Маськва
Пользователь №: 35 877
Не, я понимаю, что читать спецификации не модно, если можно фигачить код и писать вопросы в интернетах...
Но, всё-таки
1) чем вы руководствовались при запуске непрерывной передачи без малейших пауз?
2) слышали ли вы что-то о ACK'ах в кан-шине? И если да, то задумывались ли, кто же будет их выдавать?
Тут обсуждается творческий порыв, а не соответствие каким-либо стандартам ©
Jenya7
сообщение Sep 21 2018, 13:49
Сообщение #18
Но, всё-таки
вобще то на вехнем уровне я жду ответа от слейва. а кроме того USB-CAN Plus молотит тоже без перерыва однако с ним все нормально.
насчет ACK'а я не понял из документации. это же происходит на автоматическом уровне.
и вообще можно без туманностей и напыщенности? а так по нашему по бразильски по человечески.
я помню был проект. правда на TI Delfino. но там пять узлов молотили каждый как бог на душу положит без согласований и арбитражей. и ничего. все получали свои пакеты и я не помню чтоб КАН когда то отсох.
Сообщение отредактировал Jenya7 - Sep 21 2018, 14:12
Alechek
сообщение Sep 21 2018, 14:17
Сообщение #19
Из: Челябинск
Пользователь №: 10 882
По-человечески - возьмите осциллограф или хотя бы лог. анализатор типа клон Saleae Logic.
Возмущений много, а схемы подключения - 0.
Где анализ целостности сигналов?
То что принял один - не значит, что примет другой!
ФИЗИЧЕСКИ что на линии?
UPD: Так еще и линия 1 Мбит!
Откуда тактирование? Кварц или RC?
Скорость пробовали уменьшать?
с BTR регистром пробовали играться?
Jenya7
сообщение Sep 21 2018, 14:26
Сообщение #20
осциллограф показывает обычные пакеты. когда есть ошибки USB-CAN Plus сигнализирует.
ну я вообще то вижу правильные данные при принятии. а что 1 Мбит это большая нагрузка на линию?
тактирование внешний кварц. а BTR с ST примеров. они точно лучше меня знают как его выставлять.
Сообщение отредактировал Jenya7 - Sep 21 2018, 14:40
Jenya7
сообщение Sep 28 2018, 07:53
Сообщение #21
ОК. вроде заработало.
настраиваю маску на слейве
    CAN_FilterInitStructure.CAN_FilterIdLow = 0x0064;
    CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x00FF;
мастер посылает
TxMessage.ExtId = (opcode << 8) | 0х64;
однако слейв не принимает. без маски и фильтра принимает.
Сообщение отредактировал Jenya7 - Sep 28 2018, 07:59
2 страниц V  < 1 2
RSS Текстовая версия Сейчас: 2nd September 2025 - 18:50
Страница сгенерированна за 0.01456 секунд с 7
