> Вышел новый Keil для 51 семейства, Вер. 8.05f
GPP
сообщение Jan 10 2007, 12:18
Из: г.Киев
Пользователь №: 101
C51 Version 8.06 Release
[Device Support]
Infineon XC800 Devices: added debugging and flash programming support for new Infineon XC800 devices (XC866-1FR, XC856) with ULINK and Infineon DAS server.
Enhanced: Infineon XC800 startup code START_XC.A51 V1.02 that supports pdata addressing (C51: USING PDATA VARIABLES ON INFINEON XC800).
SST SmartCards:
[Device Simulation]
Corrected: interrupt vector for 2nd UART on Philips P89LPC952 was incorrectly configured in simulator and target dialog.
Enhanced: VTREG PPAGE is initialized to 0 on all Philips LPC900 devices to allow simulation of MOVX @Ri without configuration.
Corrected: a problem with AT89S8252 EEPROM simulation.
Corrected: a problem with the baudrate generation on Atmel devices with X2 feature (the baudrate was displayed incorrect).
Corrected: a problem with code banking on Mentor M8051EW core.
[Cx51 Compiler]
Corrected: code that is not used (i.e. with macros) is removed, even when it creates other side effects.
Corrected: unexpected error message for syntactical correct statement.
struct st2 { unsigned char uc1; unsigned char uc2; };
struct st1 { struct st2 st2; unsigned char u1; unsigned char u2; };
struct st1 st;
void main (void) {
(&st.st2)->uc1 = 0; // gives error, but should be Ok.
[ULINK and ULINK2 Support]
Added: support for ULINK2 for the Infineon XC800 and ST uPSD series.
Added: device support for Infineon XC886, XC888, and XC856.
Sasok
сообщение Jan 10 2007, 12:36
Пользователь №: 63
Дай ссылку, по этой ничего нет https://www.keil.com/update/sw/c51/8.06 и по этой тоже https://www.keil.com/update/sw/c51/8.05f
GPP
сообщение Jan 10 2007, 12:53
Из: г.Киев
Пользователь №: 101
Отправил в личку.
VAHOO
сообщение Jan 10 2007, 20:04
Пользователь №: 8 834
мне тоже дай пожалуйста newhdd@yandex.ru ,
и откудо найти лекарство????
Прошивка это душа микроконтроллера!
Pretorianec
сообщение Jan 15 2007, 11:22
Пользователь №: 13 317
Ссылочку, если можно...
И Если есть у кого лекарство, дайте плз =)
K_AV
сообщение Jan 18 2007, 15:32
Пользователь №: 19 667
у кого нет доступа на местный FTP - такое же лекарство лежит (пока) в файлообменнике на САХАРЕ.
Написано, что оно для uVision v.3.2 - но для v.3.50 (такая версия указана в С51 v.8.06) подошло.
vladnick
сообщение Jan 19 2007, 11:52
Пользователь №: 5 442
Если можно, дайте ссылочку.
K_AV
сообщение Jan 19 2007, 16:12
А тебе-то какую ссылочку... На местном FTP имеется (в \upload\). Вчера вечером, по крайней мере, лежало все одной кучкой.
ivstech
сообщение Jan 19 2007, 20:36
Пользователь №: 12 860
На сахаре как называется? Посмотрел, вроде нет там такого. А с FTP скачать не могу, нет доступа в свои. ivstech(сбк)yandex.ru
K_AV
сообщение Jan 20 2007, 10:11
Keil_lic-v3.2.rar это там называется. Плохо смотрел.
vladnick
сообщение Jan 20 2007, 20:00
Спасибо. Не посмотрел.java script:emoticon(':smile3046:', 'smid_24')
Bovolk
сообщение Jan 22 2007, 21:13
Из: Украина/Киев
Пользователь №: 20 145
Триал на 51 скачал с сайта Keil, где-то 20 Мег. Этот "Keil_lic-v3.2.rar" к нему подойдет? Или мне нужно не триал? Тогда, дайте ссылочку, пожалуйста? bovolk(на)hotmail(тчк)com. Спасибо!
Сообщение отредактировал Bovolk - Jan 22 2007, 21:26
Bovolk
сообщение Jan 23 2007, 17:44
Из: Украина/Киев
Почему-то подумал, что нужна Full версия. Проект от 2-й версии отлично скомпилировался. Компилятор лишь понаходил больше предупреждений, которые легко вычистил.
Arsenal_PC
сообщение Feb 27 2007, 09:22
Пользователь №: 25 701
на ихнем сайте-нужна не майлбоксовая почта. такой у меня нет!
Поделитесь ссылочкой, аль самим файлом! keil c51
Сообщение отредактировал Arsenal_PC - Feb 27 2007, 09:36
LMT
сообщение Feb 28 2007, 20:37
Пользователь №: 25 599
Arsenal_PC
Я на майл.ру бота заводил и выкачивал, Keil uV ARM toolchain правда. Всё там можно.
А ссылки постоянной на keil.com быть не может. Они там "динамические" все нынче.
RSS Текстовая версия Сейчас: 27th July 2025 - 20:24
Страница сгенерированна за 0.01484 секунд с 7
