> Cyclone III, Поделитесь информацией...
MobyDick
сообщение Oct 18 2006, 14:15
Из: г. Пенза
Пользователь №: 8 530
Насколько я знаю, Альтера планирует выпустить Cyclone III в первой половине 2007-го.
Они будут выполнены по 65-нм технологии.
А предполагаются ли какие-то изменения в архитектуре?
Diramo
сообщение Feb 15 2007, 03:50
Пользователь №: 11 957
По Вашей просьбе - хелп, взятый из Q7. Там есть кой-какая информация о Cyclone-3.
An Altera device family designed as a cost-effective solution for data path applications. The Cyclone III device architecture supports M9K memory blocks to implement single-port, dual-port, and true dual-port memory, and high-speed interfaces to external memory devices such as single data rate (SDR) SDRAM, double data rate (DDR) SDRAM, double data rate II (DDR-II) SDRAM and quad data rate II (QDR-II) SRAM. Cyclone III devices also contain embedded multiplier blocks that enable efficient implementation of high-performance filters and multipliers.
Cyclone III devices provide up to four PLLs per device, which provide advanced multiplication, programmable duty cycle, phase shifting, programmable bandwidth, manual clock switchover, clock outputs driving all networks, and normal and zero delay buffer modes. Cyclone III devices also provide up to 20 global clock lines that drive the global clock network throughout the entire device.
Cyclone III devices support numerous single-ended and differential I/O standards, including 1.2V CMOS, 1.5V CMOS, 1.5 V HSTL Class I & II, 1.8V CMOS, 2.5V CMOS, 2.5 V SSTL Class I & II, 3V CMOS, 3V LVTTL, 3V PCI/PCI-X, Differential HSTL-12 Class I & II, Differential HSTL-15 Class I & II, Differential HSTL-18 Class I & II, Differential SSTL-2 Class I & II, Differential SSTL-18 Class I & II, LVPECL (only on GCLK locations), HSTL-12 Class I & II, HSTL-15 Class I & II, HSTL-18 Class I & II, LVCMOS, LVDS, LVTTL, mini-LVDS (output only), PPDS (output only, RSDS (output only), SSTL-2 Class I & II, and SSTL-18 Class I & II. Dual-purpose clock (DPCLK) pins are used for delayed clocking for DQS and for high-fanout PCI signals. Differential HSTL and SSTL outputs are only supported on PLLCLKOUTs. Differential HSTL and SSTL inputs use VREF input buffers and are supported only on clock inputs.
The memory blocks of a Cyclone III device can implement shift registers and various types of memory with or without parity bits, including dual-port, true dual-port RAM single-port RAM; ROM; FIFO buffers; and shift registers. Also, clock delay can be controlled dynamically in Cyclone III devices.
Cyclone III devices have 10 or 20 global clock networks, which can be driven by dedicated clock input pins, PLL counter outputs, dual purpose clock input pins, or non-peripheral logic.
You can use device migration to transfer a design between Cyclone III devices with equivalent pin-outs, while maintaining the same board layout and pin assignments.
Сообщение отредактировал Diramo - Feb 15 2007, 03:59
Tornado-Alex
сообщение Feb 15 2007, 08:43
Пользователь №: 20 363
Сомневаюсь, что они сумеют приступить к серии в первой половине, разве что будут доступны инженерные образцы, т.к. в сентябре-октябре они только проводили опрос пожеланий к новому циклону.
Серьёзных изменений не предвидится, будет увеличено количество входов CLK, PLLных выходов, снижено энергопотребление примерно на 20-25%, увеличено быстродействие процентов на 10%, ну и разумеется будет увеличена ёмкость.
Styv
сообщение Feb 15 2007, 11:51
Пользователь №: 504
А можно поинтересоваться: где Вы взяли хелп на Q7?
Diramo
сообщение Feb 16 2007, 04:10
В Квартусовом рассаднике появился файл с именем OXztCNZHGjMs5sm9dNAI размером около 1.3 гига. Правда, на следующий день он исчез, но мне и этого хватило. Под этим именем скрывался самораспаковывающийся архив, который, собственно, и являлся Q7. А хелп взят оттуда smile.gif
Styv
сообщение Feb 16 2007, 09:31
Пользователь №: 504
А поделиться какнибудь можно?
CoreA
сообщение Mar 4 2007, 00:50
Пользователь №: 5 518
Не спешите, ребята из Альтеры клепают билды круглосуточно, пропуская даже сервис-паки. На сегодня уже существует версия 7.1 билд 124.
100 билдов за полмесяца и 2 за 2 часа - абсолютный рекорд.
Прикрепленный файл  QuartusIIv.7.1b124.pdf ( 114.75 килобайт ) Кол-во скачиваний: 266
uStick
сообщение Mar 19 2007, 15:07
Пользователь №: 18 581
На сайте альтеры кое-какие доки уже появляются, даже ссылка появилась на страницу Cyclone III, правда пока не работает...
А софт отсюда можно всегда слить: ftp://ftp.altera.com/outgoing/release
vetal
сообщение Mar 26 2007, 11:54
Из: Россия, СПб
Пользователь №: 553
На сайте altera появилась инфа о стоимость ep3c25!!!!!
Для сравнения:
EP2C20Q240C8 42.70000 (LE- 18,752; M4K - 52; mult - 26)
EP3C25Q240C8NES 42.56000 (LE - 24,624; M9K -66; mult - 66; )
Можно плясать - новые чипы стоят дешевле на 14 центов blink.gif (шутка biggrin.gif)
Diramo
сообщение Mar 27 2007, 07:35
Arrow Electronics уже принимает заказы на почти все объявленные чипы Cyclone III. Цены пока не вывесили. Поставка начнется во второй половине апреля.
Сообщение отредактировал Diramo - Mar 27 2007, 07:46
slog
сообщение Aug 13 2007, 07:45
Пользователь №: 11 489
И когда же (и где) будут доступны Cyclone III в QFP144 ?
А то уже хочу, но пока говорят нету.
В действительности всё не так, как на самом деле.
vetal
сообщение Aug 13 2007, 08:06
Из: Россия, СПб
Пользователь №: 553
так доступны вроде EP3C25E144C8NES. срок поставки 2-3 недели.
Adlex
сообщение Aug 13 2007, 08:18
Пользователь №: 7 451
сайт фирмы ЭФО:
http://altera.ru/cgi-bin/price/price
slog
сообщение Aug 13 2007, 09:57
2-3 недели у них это EP2C, про EP3C не известно, пока есть только цена в прайсе. EP3C25E144C8NES это ES - Engineering Samples. А мне хочется EP3C5E144C8N. По слухам будут к октябрю в Гамме.
Tornado-Alex
сообщение Aug 13 2007, 10:53
Будут в Гамме, будут и в ЭФО
только вот не рановато ли?
Если не использовать мегафункции, то можно, а если использовать, то ловить чьи то баги (ИМХО)
RSS Текстовая версия Сейчас: 19th July 2025 - 16:39
Страница сгенерированна за 0.01502 секунд с 7
