> Mega16 + COM, Помогите "подружить" Meg`у и COM
mdn
сообщение Mar 13 2008, 11:29
Пользователь №: 35 876
Есть проблемка, надо подключить Mega16 к ПК через COM
Имеется Mega16(кварц 7,372)+MAX232+COM
Текст программы:
This program was produced by the
CodeWizardAVR V1.23.6a Standard
Automatic Program Generator
Chip type : ATmega16
Program type : Application
Clock frequency : 7,372000 MHz
Memory model : Small
Internal SRAM size : 1024
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
#include <delay.h>
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART Receiver buffer
#define RX_BUFFER_SIZE 8
char rx_buffer[RX_BUFFER_SIZE];
unsigned char rx_wr_index,rx_rd_index,rx_counter;
// This flag is set on USART Receiver buffer overflow
bit rx_buffer_overflow;
// USART Receiver interrupt service routine
#pragma savereg-
interrupt [USART_RXC] void uart_rx_isr(void)
char status,data;
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#endasm
status=UCSRA;
data=UDR;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer[rx_wr_index]=data;
if (++rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
if (++rx_counter == RX_BUFFER_SIZE)
rx_counter=RX_BUFFER_SIZE;
rx_buffer_overflow=1;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter==0);
data=rx_buffer[rx_rd_index];
if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
#asm("cli")
--rx_counter;
#asm("sei")
return data;
#pragma used-
#endif
// USART Transmitter buffer
#define TX_BUFFER_SIZE 8
char tx_buffer[TX_BUFFER_SIZE];
unsigned char tx_wr_index,tx_rd_index,tx_counter;
// USART Transmitter interrupt service routine
#pragma savereg-
interrupt [USART_TXC] void uart_tx_isr(void)
#asm
push r26
push r27
push r30
push r31
in r26,sreg
push r26
#endasm
if (tx_counter)
--tx_counter;
UDR=tx_buffer[tx_rd_index];
if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
#asm
pop r26
out sreg,r26
pop r31
pop r30
pop r27
pop r26
#endasm
#pragma savereg+
// Write a character to the USART Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter == TX_BUFFER_SIZE);
if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0))
tx_buffer[tx_wr_index]=c;
if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
#asm("cli")
++tx_counter;
#asm("sei")
else UDR=c;
#pragma used-
#endif
// Standard Input/Output functions
#include <stdio.h>
// Declare your global variables here
void main(void)
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func0=Out Func1=Out Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In
// State0=0 State1=0 State2=T State3=T State4=T State5=T State6=T State7=T
PORTA=0x00;
DDRA=0x03;
// Port B initialization
// Func0=Out Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In
// State0=0 State1=T State2=T State3=T State4=T State5=T State6=T State7=T
PORTB=0x00;
DDRB=0x01;
// Port C initialization
// Func0=In Func1=In Func2=In Func3=In Func4=In Func5=In Func6=In Func7=In
// State0=T State1=T State2=T State3=T State4=T State5=T State6=T State7=T
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
GICR=0x00;
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud rate: 9600
UCSRA=0x00;
UCSRB=0xD8;
UCSRC=0x86;
UBRRL=0x2F;
UBRRH=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
// Analog Comparator Output: Off
ACSR=0x80;
SFIOR=0x00;
// Global enable interrupts
#asm("sei")
while (1)
putchar('G');
delay_ms(1000);
// Place your code here
В ответ приходят символы C0 (H(HEX).
При изменении программы на
while (1)
char ch;
ch=getchar();
delay_ms(1000);
putchar(ch);
delay_ms(500);
При посылке любого символа в ответ приходит опять только C0
Может кто сталкивался, помогите....
Polaris
сообщение Mar 13 2008, 11:39
Пользователь №: 11 964
Чем шьете мегу? Стоит проверить, как там фузы выставлены. Это самая первая по популярности ошибка, не связанная с аппаратной частью. Если стоит внутренний генератор на 1МГц, то может слать искаженную информацию.
defunct
сообщение Mar 13 2008, 11:42
кекс
Пользователь №: 12 326
Несоответвие скорости.
Проверяйте Fuses (на предмет работы меги от внутреннего генератора 1Mhz) и UBRR.
galjoen
сообщение Mar 13 2008, 12:14
Из: Чебоксары (Россия)
Пользователь №: 27 640
+1
У вас скорость приёмника в в 7 раз больше скорости передатчика. Из-за этого стартовый бит передатчика =0 воспринимается приёмником как 1 стартовый бит =0 и 6 бит данных =0. А потом идет бит данных =1. Он принимается как 7 бит =1. Отсюда 2 старших бита =1 и стоповый бит =1 и дальше ещё 4 бита как пауза между байтами.
Дон Амброзио
сообщение Mar 13 2008, 13:08
Группа: Участник*
Пользователь №: 34 947
Цитата(mdn @ Mar 13 2008, 14:29) *
Текст программы
Тут посмотриТЕ http://electronix.ru/forum/index.php?showtopic=44373
После устранения бага в программе она стала работать....хуже
hd44780
сообщение Mar 13 2008, 14:18
Из: Донецк, ДНР
Пользователь №: 7 980
Были похожие грабли при включении девайса в COM-порты доп адаптера (в моем случае на чипе NetMos9835CV).
Когда включил в COM-порт материнки заработал как часы.
В чем причина не пойму и по сей день.
Кстати мой UPS Back-UPS тоже не пашет на доп. портах.
Модем и кассовый аппарат работают везде.
Темные электронные силы не иначе.
И на фига производители чипсетов избавляются от COM-портов?
Чтобы возить такого пассажира, необходим лимузин другого класса.
(с) Мария Эдуарда
RSS Текстовая версия Сейчас: 3rd September 2025 - 13:39
Страница сгенерированна за 0.01389 секунд с 7
