> Описание стека на Verilog, подскажите что не так
Consigliere
сообщение Mar 13 2008, 07:27
Пользователь №: 35 869
Идея в том, чтоб описать 8-битный стек, запись и чтение производится с помощью управляющего сигнала "wr"
module stack(out_stack, in_stack);
    output [7:0] out_stack;
    input [7:0] in_stack;
    wire st0 [7:0],
    st1 [7:0],
    st2 [7:0],
    st3 [7:0],
    st4 [7:0],
    st5 [7:0],
    st6 [7:0],
    st7 [7:0];
    wire wr;
    always in_stack
    if (wr)
        st7 = st6;
        st6 = st5;
        st5 = st4;
        st4 = st3;
        st3 = st2;
        st2 = st1;
        st1 = st0;
        st0 = in_stack;
endmodule
при компиляции выдает данное сообщение
# Pass 1. Scanning modules hierarchy.
# Error: VCP2000 stack.v : (20, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (21, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (22, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (23, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (24, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (25, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Error: VCP2000 stack.v : (26, 8): Syntax error. Unexpected token: =. Expected tokens: '#' , '(' , ':' , 'delay' , ',' ... .
# Warning: VCP2515 stack.v : (21, 1): Undefined module: st4 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (20, 1): Undefined module: st5 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (23, 1): Undefined module: st2 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (22, 1): Undefined module: st3 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (26, 1): Undefined module: in_stack was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (25, 1): Undefined module: st0 was used. Port connection rules will not be checked at such instantiations.
# Warning: VCP2515 stack.v : (24, 1): Undefined module: st1 was used. Port connection rules will not be checked at such instantiations.
# Compile failure 7 Errors 7 Warnings Analysis time : 0[s].
# done
не могу понять что я делаю не так...
Заранее спасибо за помощь.)
если не туда разместил тему перенесите пожалуйста в нужный раздел форума
3 страниц V  < 1 2 3 >
Ответов (15 - 29)
CaPpuCcino
сообщение Mar 14 2008, 21:59
Сообщение #16
тоже уже Гуру
Из: Кёлн - Санкт-Петербург
Пользователь №: 5 973
Цитата(yuri_d @ Mar 14 2008, 23:52) *
Всё здорово, вот только не соответствует условиям задачи sad.gif Зачем использовать bit, class? Ведь это уже не Verilog (ни 1995, ни 2001), а System Verilog.
В результате у преподавателя может появиться подозрение и в результате такое решение выйдет боком автору темы.
текущий стандарт верилог 1364-2005. bit легко заменяется на reg. ну, и потом, пока чуваки договорятся, что такое стэк, семестр подойдёт к концу
И снова на арене цирка - дрессированные клоуны!! Оказываем консультации по электронике за симпу круглосуточно.
Consigliere
сообщение Mar 15 2008, 14:22
Сообщение #17
XVR, вобщем как выяснилось, смысл был не совсем тот.
Поправки:
1. Сама шина I2C со стеком не работает. Работает через устройство управления стеком.
2. Необходимо спроектировать это устройство. Взаимодействие с шиной и со стеком. Порядок такой: проверка адреса(берем из шины), совпадает -> проверка команды read/write -> соответственно действие если read то отправляем на стек сигнал rd, для получения информации и сдвига стека, если write, то берем информацию из шины, сдвигаем стек и записываем. Запись и чтение между устройством управления и стеком производятся через 2 буфера(в качестве них выбраны регистры), т.е. один на чтение, второй на запись (не совсем понятна конечно эта идея, зачем оно надо).
Описание стека было удовлетворительно, т.е. зачет. На данный момент поставлена задача разработать устройство управления. Я пока что не думал, идей нет. Планирую завтра заняться этим, соответственно сообщу.
По Вашему предложению: 1. Адрес в обменах по I2C игнорируется, направление обмена определяется битом R/W в первом байте - получается, что нетsmile.gif
2. Размер стека - 8 байт - да.
3. Обмен со стеком поддерживается только побайтовый (1 байт за один цикл шины I2C) - не совсем понятна идея, если смысл в том что за 1 такт только заполняется 1 ячейка стека, то да.
4. Запись в стек производится только при наличие в нем свободного места, данные для записи берутся из байта данных (2й байт цикла записи шины I2C) - изначально он пуст. Думаю просто переполнение не будет допускаться.
5. Запрос записи подтверждается ACK в адресном цикле шины I2C только при наличии свободного места в стеке - не до конца понимаю этот процессsad.gif
6. Чтение из стека производится только в случае непустого стека в первом байте ответа цикла чтения по I2C - естественно что пустую информацию брать не целесообразно.
7. Запрос чтения подтверждается ACK в адресном цикле шины I2C только при наличии данных в стеке - аналогично не понимаю, как при записиsad.gif
XVR
сообщение Mar 15 2008, 20:11
Сообщение #18
Из: Химки
Пользователь №: 26 847
Поправки:
Это устройство включает непосредственно стек, или сам стек это еще одно устройство?
Устройство (равно как и все остальные) рекомендуется делать синхронным, т.к. почти все современные схемы синхронные.
С этим как раз все просто - гораздо проще сделать 2 раздельные однонаправленные шины, чем одну двунаправленную, к которой понадобятся дополнительные сигналы для управления направлением передачи данных. Кроме того, во многих FPGA просто нет внутренних шин с 3мя состояниями.
По Вашему предложению: 1. Адрес в обменах по I2C игнорируется, направление обмена определяется битом R/W в первом байте - получается, что нет smile.gif
Это не существенно, добавится один компаратор на адрес.
В смысле не поддерживается обмен пакетами данных по I2C - только побайтово (1 байт за один полный цикл обмена)
Кем не будет допускаться? И что делать контроллеру стека, если оно все же произошло?
5. Запрос записи подтверждается ACK в адресном цикле шины I2C только при наличии свободного места в стеке - не до конца понимаю этот процесс sad.gif
Обмен по шине I2C подтверждается адресуемым устройством в цикле передачи адреса. Имеется в виду, что данное устройство не будет подтверждать обмен (т.е. мастер I2C просто не увидит устройства на шине), если оно (устройство) не может обслужить запрос на чтение или запись.
Имеется в виду, что при попытке чтения из пустого стека устройство вообще ничего делать не будет, альтернативой может являться чтение нуля (например)
В общем вырисовываются такие сигналы в интерфейсе:
  1. input clk - Системный клок
  2. input enable - Обращение к контролеру стека
  3. input write - Цикл записи (1-запись, 0-чтение)
  4. output full - Признак заполненности стека
  5. output empty - Признак пустоты стека
  6. input [7:0] in_data - Шина записи
  7. output [7:0] out_data - Шина чтения
CaPpuCcino
сообщение Mar 15 2008, 21:11
Сообщение #19
тоже уже Гуру
господа, не пора ли переместиться в соответствующий раздел форума?
Форум разработчиков электроники - Electronics developers forum > Программируемая логика (ПЛИС) - Programmable Logic (FPGA,CPLD, PLD) > Языки проектирования на ПЛИС - FPGA programming languages
Consigliere
сообщение Mar 16 2008, 08:35
Сообщение #20
полагаю что это еще одно устройство
полностью согласен
так и задумывалось, дело в том что сигналы rd, wr, передаются не по шинам передачи данных, а по отдельными служебными сигналами, не знаю есть ли такое понятие, но смысл в этом.
т.е. если у нас стек может хранить слова размером 8 байт, то необходимо будет 8 циклов? Расскажите почему Вы предпочли такой вариант, а не все сразу?
при моделировании не будет допускаться, если вдруг быть наверно не можетsmile.gif
И тогда у нас данный цикл не завершится никогда что ли? Непосредственно в шине I2C
предпочтительнее лучше чтение нуля
Если на участке шина - контроллер, то согласен.
по поводу контроллера есть такая идея:
output [7:0] to_bus - данные передающиеся шине из стека
output [7:0] to_stack - данные из шины на запись в стек
output rd - сигнал управления стеком(на считывание)
output wr - сигнал управления (на запись)
input [7:0] from_bus - данные из шины
input [7:0] from_stack - данные из стека
впервую очередь проверяем from_bus, сверяем адрес, если подходит то начинаем считывать команду wr/rd и отправляем сигнал wr/rd, для подготовки стека к записи/чтению, затем непосредственно передача данных.
XVR
сообщение Mar 17 2008, 08:46
Сообщение #21
Из: Химки
Т.е. предполагается 3 устройства (I2C контролер, контролер стека, стек)? В таком случае одно из этих устройств лишнее - просто набор проводов
полностью согласен
Не совсем понимаю, что такое 'шина передачи данных', но если под этим понимается 3х стабильная двунаправленная шина, то вне зависимости от того, как передаются сигналы rd & wr в данном дезайне такая шина будет лишним усложнением.
Да
Это сложнее реализовать
Завершится, но master, начавший цикл, получит ошибку обмена.
Ок, это даже проще
Похоже на набор проводов smile.gif Или это имеется в виду контролер I2C?
Слишком усложнено. Все сравнения адресов и машинерия с I2C шиной должна остаться внутри I2C контролера. Наружу нужно выдать уже голые команды чтения и записи в стек. Интерфейс будет один в один совпадать с интерфейсом стека (за исключением направления сигналов - оно будет противоположным)
Если сделать отдельно интерфейс к I2C и потом его пристыковывать к стеку, через еще один модуль, то придется реализовавать более-менее полноценную имплементацию протокола I2C со всеми ACK/NAK, подсчетом принятых и переданных байтов, т.к. цепи генерации ACK будут находится в другом модуле и придется всю эту логику протаскивать через интерфейсы 2х модулей. При этом реально это все будет не нужно, т.к. пользователь у шины I2C в вашем случае один, и набор требований у него фиксированный, т.ч. можно сделать под него урезанную имплементацию I2C
PS. Реализация стека здесь тривиальная, по сравнению с реализацией I2C контролера.
Consigliere
сообщение Mar 17 2008, 10:25
Сообщение #22
3 устройства:шина I2C, контроллер стека, стекsmile.gif
я тоже не понимаю что такое 3х стабильныя двунаправленная шинаsmile.gif хорошо попробую выразиться иначе. Эти сигналы wr/rd идут по 2м отдельным каналам(не каналы передачи данных которые по 8байт передают с шины в стек, а отдельные)
ок
скорее подразумевался как контролеер между стеком и шиной, не знаю как правильнее будет его назвать
хорошо, я просто еще не думал над реализацией шины, с этим у меня наиболее тяжко. Если при ее реализации возможно будет сделать все эти проверки, то согласен с Вашим вариантом.
если под пользователем подразумевается стек, то он не одинsmile.gif чтоб показать полноценную работу I2C с адресацией и прочим, будет несколько стеков.
XVR
сообщение Mar 17 2008, 17:05
Сообщение #23
Из: Химки
Цитата(Consigliere @ Mar 17 2008, 13:25) *
3 устройства:шина I2C, контроллер стека, стек smile.gif
Предлагаю объединить контролер стека с самим стеком, ибо я не предсталяю их отдельной реализации. Они и вместе вряд ли займут более 10 строк кода
я тоже не понимаю что такое 3х стабильныя двунаправленная шина smile.gif хорошо попробую выразиться иначе. Эти сигналы wr/rd идут по 2м отдельным каналам(не каналы передачи данных которые по 8байт передают с шины в стек, а отдельные)
Хм. До сих пор я считал, что это очевидно. Кроме того, я слабо представляю, как их можно сделать иначе 05.gif
если под пользователем подразумевается стек, то он не один smile.gif чтоб показать полноценную работу I2C с адресацией и прочим, будет несколько стеков.
Этого в оригинальном задании не было. Других добавлений, кроме нескольких стеков, не предвидится? wacko.gif
А как вы собираетесь общаться с I2C шиной без контролера?
Consigliere
сообщение Mar 17 2008, 17:30
Сообщение #24
хорошо, попробовать можно.
ну как иначе, это же не будет у нас в реальной плисине или другом физическом устройстве, это лишь код, так что предлагаю снять этот вопрос. можно описать хоть шиной, хоть двумя отдельными каналами мне кажется
я тоже не знал этого до пятницы, в пятницу виделся с преподавателем, забыл добавить в том посте, сорри. Вроде не предвидится
с шиной без контроллера, хм.. ну просто задаешь в тест-бенче воздействия и все, так не прокатит?
дело в том что из за малых знаний и опыта, у меня нет возможности полноценно дискутировать, а жальsad.gif
XVR
сообщение Mar 18 2008, 08:39
Сообщение #25
Из: Химки
Код предполагается синтезируемый или это чисто поведенческая модель? Если первое, то надо считать, что это может быть реальной плисиной smile.gif
Я имел в виду контролер между физическими выводами I2C (SDC,SDA) и контролером стека. Или шину I2C тоже предполагается сделать на поведенческом уровне (т.е. без выводов вообще smile.gif )?
дело в том что из за малых знаний и опыта, у меня нет возможности полноценно дискутировать, а жаль sad.gif
Опыт - дело наживное
Consigliere
сообщение Mar 18 2008, 12:44
Сообщение #26
все только на поведенческом уровнеsmile.gif просто описаниеsmile.gif и временные диаграммыsmile.gif
XVR
сообщение Mar 18 2008, 13:25
Сообщение #27
Из: Химки
Цитата(Consigliere @ Mar 18 2008, 15:44) *
все только на поведенческом уровне smile.gif просто описание smile.gif и временные диаграммы smile.gif
Как предполагается задавать шину I2C - как ноги SDC/SDA или как абстрактый модуль с каким угодно интерфейсом не подключенный вообще ни к чему?
Consigliere
сообщение Mar 18 2008, 14:26
Сообщение #28
на счет этого не знаю, но предполагаю что абстрактный модуль, ну максимум на бумагеsmile.gif
XVR
сообщение Mar 18 2008, 17:03
Сообщение #29
Из: Химки
Цитата(Consigliere @ Mar 18 2008, 17:26) *
на счет этого не знаю, но предполагаю что абстрактный модуль, ну максимум на бумаге smile.gif
Ну тогда вообще проблем никаких - подключить модуль стека прямо к проводам и формировать на них необходимые сигналы.
Consigliere
сообщение Mar 20 2008, 07:03
Сообщение #30
я пока что заболел, лежу с температурой, как только поправлюсь сразу сообщу:-(
RSS Текстовая версия Сейчас: 27th July 2025 - 14:45
Страница сгенерированна за 0.01517 секунд с 7
