Closed TopicStart new topic
ek74
сообщение Jun 14 2007, 09:53
Из: г. Саратов
Пользователь №: 7 351
На сайте STMicroelectronics появилась информация о новом семействе STM32 с ядром Cortex-M3.
■ Core
– ARM 32-bit Cortex-M3TM CPU
– 36 MHz, 45 DMips with 1.25 DMips/MHz (STM32F101x)
– 72 MHz, 90 DMips with 1.25 DMips/MHz (STM32F103x)
– Single-cycle multiplication and hardware division for computational acceleration
■ Memories
– From 32 Kbytes to 128 Kbytes Flash memory
– From 6 Kbytes to 16 Kbytes SRAM (STM32F101x)
– From 6 Kbytes to 20 Kbytes SRAM (STM32F103x)
– Multi-boot capability
■ Clock, Reset and Supply Management
– 2.0 to 3.6V application supply and I/Os
– Internal regulator for core supply
– Embedded high-speed quartz oscillator from 4 to 16 MHz
– Power on / power down reset (POR/PDR), programmable voltage detector (PVD), brown-out detector
– Embedded RTC oscillator running from external 32 kHz crystal
– Internal factory-trimmed RC running at 8 MHz
– Internal RC running at 32 kHz
– Embedded PLL for CPU clock
– Real-Time Clock with calibration capability for precise clock-calendar function
■ Low Power
– 3 power saving modes: SLEEP, STOP and STANDBY with automatic wake up
– VBAT supply for RTC and backup registers
■ Nested Interrupt Controller
– Superior multiple vector interrupt handling
– 43 maskable interrupt channels (not including the 16 interrupt lines of Cortex-M3)
– Very low latency interrupt processing down to 6 CPU cycles with tail-chaining
■ Debug Mode
– Serial wire debug (SWD) and JTAG interfaces
– Serial wire viewer
– 8 hardware breakpoints
■ DMA
– 7-channel DMA controller
– Circular buffer management
– Peripherals supported: timers, ADC, SPI, I2C and USART
■ 12-bit A/D Converter (16-channel) (STM32F101x)
■ 2 x 12-bit A/D Converters (16-channel) (STM32F103x)
– Sampling frequency up to 1 MHz
– Conversion range: 0 to 3.6V
– Auto-calibration
– Auto-scan mode
– Temperature sensor
■ Up to 80 Fast I/O Ports
– 32/49/80 multifunctional bidirectional 5V-tolerant I/Os
– All mappable on 16 external interrupts
– Up to 80 ports with external interrupt capability
– Possibility of locking the I/O in chosen alternate function configuration
– Atomic read/modify/write operations
– I/Os on APB2 with up to 18 MHz toggling speed (STM32F103x)
■ Up to 6 Timers (STM32F101x)
■ Up to 7 Timers (STM32F103x)
– Up to 3 synchronizable 16-bit timers, each with up to 4 channels used for input captures/output compares, PWM or pulse counter
– 16-bit 6-channel advanced control timer, configurable with up to 4 channels for input capture/output compare (STM32F103x)
– 2 x 16-bit watchdog timers (Independent and Window)
– SysTick timer: a 24-bit down counter with auto reload capability with programmable clock source for timebase functions
■ Up to 7 Communication Interfaces (STM32F101x)
■ Up to 9 Communication Interfaces (STM32F103x)
– Up to 2 x I2C interfaces (SMBus/PMBus)
– Up to 3 USARTs asynchronous serial interfaces (2.25 MBit/s), providing Smart Card ISO7816 interface, LIN master slave capability, IrDA capability, Modem control
– Up to 2 SPI synchronous serial interfaces (18 Mbit/s)
– CAN interface (2.0B Active) (STM32F103x)
– USB 2.0 full speed interface (STM32F103x)
■ Operating Temp.: -40 to +85 °C / -40 to +105 °C
■ Packages: LQFP48, LQFP64, LQFP100, BGA100
etoja
сообщение Jun 15 2007, 03:28
Пользователь №: 1 952
Это то, что нужно. Интересно, когда это появится в продаже?
Dron_Gus
сообщение Jun 18 2007, 12:16
Пользователь №: 1 861
Это что так жестко отлаживать то?
Если сверху смотреть, то сбоку кажется, что снизу ничего не видно.
Angle
сообщение Sep 2 2008, 07:08
Из: Екатеринбург
Пользователь №: 29 638
Nested Interrupt Controller означает аппаратную поддержку вложенных прерываний, которой, например, нет в ARM7 контроллерах от Atmel и NXP, правильно я понимаю?
Сообщение отредактировал Angle - Sep 2 2008, 07:09
KRS
сообщение Sep 2 2008, 07:26
Пользователь №: 555
Да там очень удобная поддержка. Да и вообще архитектура с системной точки зрения очень сильно отличаеется (можно даже сказать совсем другая) от ARM7/ARM9.
Лучше всего Вам почитать Cortex-M3 Technical Reference Manual он доступен
http://infocenter.arm.com/help/topic/com.a...m3_r1p1_trm.pdf
aaarrr
сообщение Sep 2 2008, 07:29
Пользователь №: 1 448
Поддержка аппаратная, но по сути делает почти то же самое, что и asm-wrapper'ы для поддержки вложенности на ARM7 с VIC/AIC. The Nested Vectored Interrupt Controller (NVIC).
dch
сообщение Sep 2 2008, 09:00
Из: 141070 г. Королев МО, улица Горького 39-121
Пользователь №: 661
я дернулся образцы заказать, отказали. Надо будет попробовать дилерам местным отписать, вдруг получится.
Шаманъ
сообщение Sep 2 2008, 09:17
Пользователь №: 39 839
http://imrad.kiev.ua/search.shtml?qs=stm32&query=any
dch
сообщение Sep 2 2008, 09:58
Пользователь №: 661
гривна то дорогая, это не совсем задаром
Shuuura
сообщение Sep 29 2008, 12:42
Пользователь №: 7 902
Подскажите какой из чипов STM32 на сегодня получается самый дешевый и доставаемый (массовый). Например sam7s64 зачастую получатся дешевле чем sam7s32 только за счет того что из поставщики закупают большими партиями.
Dir
сообщение Oct 4 2008, 21:03
Пользователь №: 1 830
Не самые доставаемые на сегодняшний момент, но, наверное, самыми дешевыми будут недавно выпущенные Low-desity access line STM32F101x4/6 и Low-desity USB access line STM32F102x4/6 c флешем 16 и 32кб. Похоже, что с их выпуском 32-битники будут использовать где попало.
Dog Pawlowa
сообщение Oct 5 2008, 18:16
Пользователь №: 18 823
Не сочтите за рекламу, но дилеры Arrow в нашей деревне ведут активную наступательную политику. Завалили образцами - некогда проверят.
Кстати, при загрузке программы под IAR'ом в 5.20 в старую ревизию кристалла тут же вываливается ссылка на страницу ST с предложением даже старткит заменить, не говоря уже об устаревших ревизиях чипов.
Уходя, оставьте свет...
RSS Текстовая версия Сейчас: 23rd June 2025 - 23:09
Страница сгенерированна за 0.02884 секунд с 7
