4 страниц V  < 1 2 3 4 >
> проблема USB cy7c68013a, инициализация устройства
-=HermiT=-
сообщение Nov 25 2008, 11:37
Сообщение #31
Из: Belarus
Пользователь №: 11 540
В документе FX2 TechRefManual.pdf написано:
The USB 2.0 Specification requires that high-speed (480 Mbit/sec) devices must also be capable
of enumerating at full-speed (12 Mbit/s). In fact, all high-speed devices begin the enumeration process
in full-speed mode; devices switch to high-speed operation only after the host and device
have agreed to operate at high speed. The high-speed negotiation process occurs during USB
reset, via the “Chirp” protocol described in Chapter 7 of the USB 2.0 Specification.
(что за “Chirp” protocol я там так и не нашел). Но зато в 7 главе есть следующее:
7.5 USB Bus Reset
The host signals a USB Bus Reset by driving an SE0 state (both D+ and D- data lines low) for a
minimum of 10 ms. The FX2 senses this condition, requests the USB Interrupt (INT2), and supplies
the interrupt vector for a USB Reset. After a USB bus reset, the following occurs:
• Toggle bits are cleared to 0.
• The device address is reset to zero.
• If the Default USB Device is active, the USB configuration and alternate settings are reset
to zero.
• The FX2 will renegotiate with the host for high-speed (480 Mbps) mode.
Казалось бы то, что надо.
Вставил команду:
DeviceIoControl        (FX2Device,
                                IOCTL_Ezusb_RESET,
                                NULL,
                                0,
                                NULL,
                                0,
                                (unsigned long *)&nBytes,
                                NULL);
Но она никак не повлияла
-=HermiT=-
сообщение Nov 25 2008, 14:51
Сообщение #32
Из: Belarus
Проблема решилась с помощью использования асинхронного ввода вывода.
Использовал драйвер CyUSB.sys
Код фактически такой же, как в документе CyAPI.pdf на странице 6 (2.1 BeginDataXfer( ))
OVERLAPPED in6OvLap1, in8OvLap1, in6OvLap2, in8OvLap2, in6OvLap3, in8OvLap3, in6OvLap4, in8OvLap4;
in6OvLap1.hEvent = CreateEvent(NULL, false, false, "CYUSB_IN61");
UCHAR *inContext61 = BulkInEpt6->BeginDataXfer(buf[0], 1024, &in6OvLap1);
BulkInEpt6->WaitForXfer(&in6OvLap1, 10000);
BulkInEpt6->FinishDataXfer(buf[0], 1024, &in6OvLap1, inContext61);
CloseHandle(in6OvLap1.hEvent);
AndreyS
сообщение Nov 25 2008, 17:46
Сообщение #33
Пользователь №: 2 276
Добрый день.
Ну для начала внимательно смотрим на то что написано. Вами указано именно ссылка на главу 7 USB2.0 спецификации, а не пользовательской инструкции FX2.
Ну а если вы там почитаете внимательно, то там идет описание выхода устройства на High speed режим.
И самое главное. Если у вас хост не high speed, то FX2 не перейдет на бфструю скорость. И наоборот. Если у вас хост 2.0, то несущая у вас будет с FX2 именно 480Мбит. Даже если вы скажете FX2, что работатете на full speed (пропускная способность кончно упадет, но несущая будет 480МГц).
В свое время пытался из-за глюков (потеря данных, периодическое пропадание устройства в системе) на плохом кабеле, но с хостом USB2.0 заставить всеми силами FX2 перейти на несущую 12мбит. Но без отключения хаба 2.0 в компе этого не происходит. И виноват в этом Chirp протокол smile.gif Он работает на нижнем уровне и на него нет возможности повлиять со стороны FX2.
Удачи.
-=HermiT=-
сообщение Nov 26 2008, 12:16
Сообщение #34
Из: Belarus
smile.gif да точно, я как-то даже и не заметил.
Спасибо за ответ. Спецификацию изучу
Konst_777
сообщение Nov 26 2008, 19:14
Сообщение #35
Пользователь №: 5 644
В разделе "3.1 Disabling High-speed Chirp via EEPROM Config Byte" документа "Migrating From EZ-USB FX2™ to EZ-USB FX2LP™" (fx2_to_fx2lp.pdf) описано, как заставить FX2/FX2LP работать на Full Speed с High Speed хостом.
Можно так: подключиться с разрешенным “Chirp”, затем проанализировать, если в течении определенного времени хост не присваивает адрес FX2/FX2LP, хотя VBUS присутствует, то FX2/FX2LP устанавливает в "1" бит 1 недокументированного регистра CT1 и переподключается к USB.
Дальше: наличие сбоев обмена анализировать по регистрам USBERRIE, USBERRIRQ, ERRCNTLIM, CLRERRCNT. Если число сбоев больше допустимого, то опять таки, переключить FX2/FX2LP в режим Full Speed.
-=HermiT=-
сообщение Nov 27 2008, 07:04
Сообщение #36
Из: Belarus
В общем на этом грабли на пути достижения высокой скорости передачи не закончились.
Пытался передать на компьютер 32 МБ. Попытался на 40.9 МБ/с - не получилось. Пришлось понизить скорость заполнения pipes. Стабильной передачи удалось добиться на скорости примерно 11.7 МБ/с.
Дальнейшие эксперименты показали, что на скорости 40,9 МБ/с нормально передается около 1020 кБ, бОльшие объемы информации на такой скорости компьютер не успевает принимать.
Проверил программу на нескольких компьютерах. Там где система была послабее, не удавалось достичь и скорости 6 МБ/с.
При этом программа грузит два ядра процессора практически на 100%.
Вот код
        const int kmax = 1023;//8192;//65536;
        const int kmax_2 = kmax / 2;
        char *buf = new char[kmax * 1024];
        OVERLAPPED in6OvLap[kmax_2], in8OvLap[kmax_2];
        for (int i = 0; i < kmax_2; i++)
                in6OvLap[i].hEvent = CreateEvent(NULL, false, false, NULL);
                in8OvLap[i].hEvent = CreateEvent(NULL, false, false, NULL);
        // BeginDataXfer
        UCHAR *inContext6[kmax_2];
        UCHAR *inContext8[kmax_2];
                int i_base = 2 * i * 1024;
                UCHAR *buf2 = buf + i_base;
                UCHAR *buf3 = buf + i_base + 1024;
                inContext6[i] = BulkInEpt6->BeginDataXfer(buf2, 1024 , &in6OvLap[i]);
                inContext8[i] = BulkInEpt8->BeginDataXfer(buf3, 1024 , &in8OvLap[i]);
        // WaitForXfer
                BulkInEpt6->WaitForXfer(&in6OvLap[i], 10000);
                BulkInEpt8->WaitForXfer(&in8OvLap[i], 10000);
        // FinishDataXfer
                BulkInEpt6->FinishDataXfer(buf2, 1024 , &in6OvLap[i], inContext6[i]);
                BulkInEpt8->FinishDataXfer(buf3, 1024 , &in8OvLap[i], inContext8[i]);
        // CloseHandle
                CloseHandle(in6OvLap[i].hEvent);
                CloseHandle(in8OvLap[i].hEvent);
                delete [] buf;
Сообщение отредактировал -=HermiT=- - Nov 27 2008, 07:08
AndreyS
сообщение Nov 29 2008, 20:24
Сообщение #37
Добрый день.
Огромное спасибо за ссылку. Этот документ я не читал.
Удачи.
AndreyS
сообщение Dec 2 2008, 20:46
Сообщение #38
Добрый день.
Нашел этот документ, но в нем нет адреса этого регистра, в даташите об этом регистре тоже ничего нет.
Нашел хидер с перечнем недокументированных регистров ( в том числе и адрес этого пресловутого CT1). Но возник резонный вопрос, а дока по ним есть?? smile.gif Я что-то не нашел.
Сообщение отредактировал AndreyS - Dec 2 2008, 20:47
Удачи.
Konst_777
сообщение Dec 3 2008, 18:59
Сообщение #39
Цитата(AndreyS @ Dec 3 2008, 00:46) *
Добрый день.
Я и не искал. Поскольку прочитал в "FX2regs.h", что:
/ Debug/Test
// The following registers are for Cypress's internal testing purposes only.
// These registers are not documented in the datasheet or the Technical Reference
// Manual as they were not designed for end user application usage
EXTERN xdata volatile BYTE DBUG              _AT_ 0xE6F8;  // Debug
EXTERN xdata volatile BYTE TESTCFG           _AT_ 0xE6F9;  // Test configuration
EXTERN xdata volatile BYTE USBTEST           _AT_ 0xE6FA;  // USB Test Modes
EXTERN xdata volatile BYTE CT1               _AT_ 0xE6FB;  // Chirp Test--Override
EXTERN xdata volatile BYTE CT2               _AT_ 0xE6FC;  // Chirp Test--FSM
EXTERN xdata volatile BYTE CT3               _AT_ 0xE6FD;  // Chirp Test--Control Signals
EXTERN xdata volatile BYTE CT4               _AT_ 0xE6FE;  // Chirp Test--Inputs
Если есть большое желание узнать, как использовать эти регистры, то можно попробовать пообщаться с техподдержкой Cypress. Отвечают они всегда быстро, но, бывает, что результат общения - нулевой.
AndreyS
сообщение Dec 3 2008, 20:48
Сообщение #40
Спасибо. Было просто любопытно.
Удачи.
MegaElektronik
сообщение Dec 5 2008, 07:07
Сообщение #41
Из: Нижний Новгород
Пользователь №: 34 339
Помогите пожалуйста!
Проблемма:
Имеется CY7C68013A. Написаны дескрипторы и т.д. система определяет USB audio device, как и требовалось, а конкретнее USB Speaker. Драйвер стандартный используется. Тип передачи изохронный. Так вот пытаюсь в него передать данные например Winamp-ом и смотру как данные идут в настройке драйвера выхода (DirectSound вкладка статус), а он пишет что отправил 1280байт (примерно) и стоит. В чем может быть проблемма? В программе для контроллера в функции TD Pool в регистры пишется EP2BCH=0, а EP2BCL=0x80.
Чать кода привожу..
void TD_Poll(void) // Called repeatedly while the device is idle
// Audio control action
if( !(EP2CS & bmEPEMPTY) ) //EP2CS & bmEPFULL ) // Is there something available
IOB = EP2FIFOBUF[0];
EP2BCH = 0;
EP2BCL = 0x80; // Rearm endpoint buffer
Может кто делал такое и кусочком исходника поделится?
Помогите!!! Уже неделю бьюсь.
Vix
сообщение Dec 5 2008, 07:17
Сообщение #42
Пользователь №: 6 281
Итак, снова о CodeGear 2007 и Builder6.
Исключительную ситуацию в CodeGear 2007 вызывают следующие коды
1) ... = new CCyUSBDevice(...);
2) USBDevice->Open(...);
Чтобы использовать CyAPI в CodeGear 2007, необходимо написать простую DLL в Builder6.
В DLL передается VID & PID, а возвращается указатель на CCyUSBDevice. Далее работаем с CyAPI как обычно.
Пример функции из DLL
extern "C" __declspec(dllexport) CCyUSBDevice* IUSBDeviceOpen(int VID,int PID){
CCyUSBDevice *USBDevice = new CCyUSBDevice(NULL);
int i;
int USBDevCount = USBDevice->DeviceCount();
if (USBDevCount == 0) return NULL;
for (i = 0; i < USBDevCount; i++)
USBDevice->Open(i);
if((USBDevice->VendorID == VID) && (USBDevice->ProductID == PID))
break;
if(i == USBDevCount) return NULL;//"No USB device found";
if(!USBDevice->EndPoints)
USBDevice->ReConnect();
return NULL;
return USBDevice;
Если нужна готовая DLL (со стандартным GUID), могу выложить.
J2post
сообщение Dec 10 2008, 12:20
Сообщение #43
Из: Томск
Пользователь №: 16 049
int i;
USBDevice->Open(i);
break;
return NULL;
return USBDevice;
Очень интересует такой вопрос, а для VC будет работать эта DLL написанная в Borlande??????????
Vix
сообщение Dec 10 2008, 12:32
Сообщение #44
Маловероятно. Пробуйте. А лучше в более старой студии создайте аналогичную DLL.
Прикрепленный файл  USB_CY_DLL.zip ( 158.58 килобайт ) Кол-во скачиваний: 38
J2post
сообщение Dec 10 2008, 12:38
Сообщение #45
Из: Томск
Ого как оперативно, спасибо за такое внимание.
Вообще у меня следующая проблема, не знаю как прикрутить эту библиотеку к компилятору MinGW (осваиваю Qt4), есть вариант написать СОМ обьект, но не хочется заморачиваться. Как думаете что поможет в моем случае?
RSS Текстовая версия Сейчас: 20th July 2025 - 02:02
Страница сгенерированна за 0.01505 секунд с 7
