4 страниц V  < 1 2 3 4 >
> как работать с IAP?
bigarmer
сообщение Feb 7 2009, 07:32
Сообщение #16
Пользователь №: 42 221
CODE
===========IAP.C=============
#include "IAP.h"
#define IAP_CLK Fcclk
#define IAP_LOCATION 0x7FFFFFF1
unsigned long command[5] = {0,0,0,0,0};
unsigned long result[3]= {0,0,0};
* Function Name: IAP_PrepareSec
* Parameters: unsigned long StartSecNum -- Start Sector Number
* unsigned long EndSecNum -- End Sector Number
* Return: unsigned long -- Status Code
* Description: This command must be executed before executing "Copy RAM to Flash" or
* "Erase Sector(s)" command.
unsigned long IAP_PrepareSec (unsigned long StartSecNum, unsigned long EndSecNum)
if (EndSecNum < StartSecNum)
return IAP_STA_INVALD_PARAM;
command[0] = IAP_CMD_PrepareSec;
command[1] = StartSecNum;
command[2] = EndSecNum;
iap_entry(command, result);
return result[0];
* Function Name: IAP_CopyRAMToFlash
* Parameters: unsigned long dst -- Destination Flash address, should be a 256 byte boundary.
* unsigned long src -- Source RAM address, should be a word boundary
* unsigned long number -- 256 | 512 |1024 |4096
* Description: This command is used to program the flash memory.
unsigned long IAP_CopyRAMToFlash (unsigned long dst, unsigned long src,
unsigned long number)
command[0] = IAP_CMD_CopyRAMToFlash;
command[1] = dst;
command[2] = src;
command[3] = number;
command[4] = IAP_CLK / 1000; // Fcclk in KHz
return result[0];
* Function Name: IAP_EraseSec
* Description: This command is used to erase a sector or multiple sectors of on-chip Flash
* memory.
unsigned long IAP_EraseSec (unsigned long StartSecNum, unsigned long EndSecNum)
command[0] = IAP_CMD_EraseSec;
command[3] = IAP_CLK / 1000;
return result[0];
* Function Name: IAP_BlankChkSec
* Description: This command is used to blank check a sector or mutilple sectors of on-chip
* Flash memory.
unsigned long IAP_BlankChkSec (unsigned long StartSecNum, unsigned long EndSecNum,
unsigned long * pResult)
command[0] = IAP_CMD_BlankChkSec;
if (result[0] == IAP_STA_SECTOR_NOT_BLANK)
*pResult = result[0];
*(pResult+1) = result[1];
return result[0];
* Function Name: IAP_ReadParID
* Parameters: unsigned long * PartID
* Description: This command is used to read the part identification number.
unsigned long IAP_ReadParID (unsigned long * PartID)
command[0] = IAP_CMD_ReadParID;
*PartID = result[1];
return result[0];
* Function Name: IAP_ReadBootVer
* Parameters: char * MajorVer
* char * MinorVer
* Description: This command is used to read the boot code version number.
unsigned long IAP_ReadBootVer (unsigned long * MajorVer, unsigned long * MinorVer)
command[0] = IAP_CMD_ReadBootVer;
*MajorVer = (result[1] & 0xff00)>>8;
*MinorVer = result[1] & 0xff;
return result[0];
* Function Name: IAP_Compare
* unsigned long number -- Should be in mutilple of 4
* Description: This command is used to compary the memory contents at two locations.
* NOTE: Compary result may not be correct when source or destination address contains
* any of the first 64 bytes starting from address zero. First 64 bytes can be re-mapped
* to RAM.
unsigned long IAP_Compare (unsigned long dst, unsigned long src,
unsigned long number, unsigned long *offset)
command[0] = IAP_CMD_Compare;
command[1] = dst;
command[2] = src;
if (result[0] == IAP_STA_COMPARE_ERROR)
*offset = result[1];
return result[0];
void IAP_ReinvokeISP(void)
command[0] = IAP_CMD_REINVOKEISP;
iap_entry(command, result);;
===========IAP.H=============
#ifndef __IAP_H
#define __IAP_H
/* IAP Command */
#define IAP_CMD_PrepareSec 50 //select sector
#define IAP_CMD_CopyRAMToFlash 51 //copy data from ram to flash
#define IAP_CMD_EraseSec 52 //erase sector
#define IAP_CMD_BlankChkSec 53 //check if sector is blank
#define IAP_CMD_ReadParID 54 //read chip ID
#define IAP_CMD_ReadBootVer 55 //read BOOT version
#define IAP_CMD_Compare 56 //compare
#define IAP_CMD_REINVOKEISP 57 //reinvoke ISP command
/* IAP Status Codes */
#define IAP_STA_CMD_SUCCESS 0
#define IAP_STA_INVALID_COMMAND 1
#define IAP_STA_SRC_ADDR_ERROR 2
#define IAP_STA_DST_ADDR_ERROR 3
#define IAP_STA_SRC_ADDR_NOT_MAPPED 4
#define IAP_STA_DST_ADDR_NOT_MAPPED 5
#define IAP_STA_COUNT_ERROR 6
#define IAP_STA_INVALID_SECTOR 7
#define IAP_STA_SECTOR_NOT_BLANK 8
#define IAP_STA_SECTOR_NOT_PREPARED_FOR_WRITE_OPERATION 9
#define IAP_STA_COMPARE_ERROR 10
#define IAP_STA_BUSY 11
#define IAP_STA_INVALD_PARAM 12
extern unsigned long IAP_PrepareSec (unsigned long, unsigned long);
extern unsigned long IAP_CopyRAMToFlash (unsigned long dst, unsigned long src,
unsigned long number);
extern unsigned long IAP_EraseSec (unsigned long StartSecNum, unsigned long EndSecNum);
extern unsigned long IAP_BlankChkSec (unsigned long StartSecNum, unsigned long EndSecNum,
unsigned long * pResult);
extern unsigned long IAP_ReadParID (unsigned long * PartID);
extern unsigned long IAP_ReadBootVer (unsigned long * MajorVer, unsigned long * MinorVer);
extern unsigned long IAP_Compare (unsigned long dst, unsigned long src,
unsigned long number, unsigned long *offset);
extern void IAP_ReinvokeISP(void);
#endif
TanT
сообщение Feb 18 2009, 12:27
Сообщение #17
Из: Россия->Омск
Пользователь №: 11 210
Позвольте задать вопрос в этой теме касаемо IAP. В мануале на LPC2378, который использую, написанно чёрным по-нерусски: "Up to 512 kB on-chip Flash Program Memory with In-System Programming (ISP) and In-Application Programming (IAP) capabilities. Single Flash sector or full-chip erase in 400 ms and 256 bytes programming in 1 ms". То есть для стирания !одного! или !всех! секторов без разницы надо 400 мс, а для записи 4кб=256*16=16мс? а сколько надо для подготовки сектора к записи и стиранию, и сравнения двух секторов? по этим операциям временных рамок не нашёл.
Если вы не можете объяснить что-то шестилетнему ребенку, значит, вы сами этого не понимаете.
Альберт Эйнштейн
zltigo
сообщение Feb 18 2009, 18:16
Сообщение #18
Из: Riga, Latvia
Пользователь №: 1 244
D
В миллисекундном измерении приблизительно "нисколько".
А это вообще бесполезность - сами можете сравнить - за сколько сравните, за столько и будет.
TanT
сообщение Feb 19 2009, 05:49
Сообщение #19
Из: Россия->Омск
Я так и думал smile.gif . А касаемо стирания одного сектора? "Single Flash sector or full-chip erase in 400 ms "
И вообще имеет смысл каждый раз чистить сектор перед употреблением? То есть, не правильно выразился, какова вероятность ошибочной записи сектора без его предворительного стирания?
Альберт Эйнштейн
MrYuran
сообщение Feb 19 2009, 06:06
Сообщение #20
Беспросветный оптимист
Из: Н.Новгород
Пользователь №: 33 646
Такя же, как и вероятность записи единицы на место записанного ранее нуля. То есть, не так выразился, записать можно только ноль на месте единицы, для обратной записи нужно стирание
TanT
сообщение Feb 19 2009, 06:45
Сообщение #21
Из: Россия->Омск
Глупый вопрос, blush.gif Следующий раз буду внимательнее слушать старших товарищей.
Однако, всё таки кто-нибудь сможет ответить на вопрос: сколько требуется времени для стирания одного сектора по IAP для LPC2378?
Альберт Эйнштейн
MikePic
сообщение Feb 19 2009, 07:11
Сообщение #22
Пользователь №: 22 054
TanT
А просто взять и измерить?
1. Таймером - считать значение до входа в процедуру стирания, считать значение после выхода, вывести в UART разницу
2. Осциллом - установить пин из 0 в 1 до входа, из 1 в 0 после выхода
zltigo
сообщение Feb 19 2009, 09:59
Сообщение #23
Из: Riga, Latvia
Зачем? Получить некое конкретное зачение для данного чипа в данный момент времени? Что будет у другого экземпляра? Что будет после 1000 стираний? Производитель документирует 400 - их и нужно придерживаться.
TanT
сообщение Feb 19 2009, 10:04
Сообщение #24
Из: Россия->Омск
Игорь, простите, конечно, настырность, но эти милисекунды очень критичны. Развейте наконец мои сомнения. Сколько времени требуется для стирания одного сектора? А десяти?
Альберт Эйнштейн
zltigo
сообщение Feb 19 2009, 10:33
Сообщение #25
Из: Riga, Latvia
Столько, сколько Вы прочитали в документации - любое стирание хоть чипа, хоть одного сектора 400ms. Десять секторов последовательно - в десять раз больше одного сектора. Любые надежды на ускорение и из последствия на Вашей совести. Когда-то давно давно еще на LPC2114 измерения делал - результаты где-то в глубинах форума должны быть. Время стирания помнится много меньше 400ms ну и что? Хотите занятся радиолюбительством? - Измеряйте и занимайтесь sad.gif
TanT
сообщение Feb 19 2009, 11:22
Сообщение #26
Из: Россия->Омск
Спасибо большое, именно это хотел услышать.
А радиолюбительством я вроде и не собирался заниматься, не тот случай. wink.gif
Альберт Эйнштейн
HARMHARM
сообщение Feb 19 2009, 11:41
Сообщение #27
читатель даташитов
Из: Днепропетровск
Пользователь №: 21 999
Если уж хочется что-то поделать пока идет стирание, можно разместить функцию в RAM. Если нужны прерывания - мапировать векторы в RAM и разместить в RAM обработчики. У меня так сбрасывается внешний вочдог пока идет стирание.
Denisvak
сообщение Feb 24 2009, 14:18
Сообщение #28
Пользователь №: 15 038
Позвольте задать вопрос в этой же теме дабы не создавать новой.
Собираюсь писать свой загрузчик под LPC21хх через модуль IAP.
Состоит из программы ПК и программы для контроллер. ПО на ПК будет принимать прошивку в в виде hex файла и отправлять контроллеру через хх интерфейс, допусти 232. Надо ли мне как-то преобразовывать в другой формат прежде чем писать прошивку во флеш, или хватит просто класть по нужным адресам?
Ещё вопрос по созданию проектов в IAR
Бутлодер должен висеть в самом начале флеша(первые 4кб), и запускаться первым затем передавать управление основной программе функцией ((void (*)())0x1000)();
Основная программа расположена с адреса 0x1000. Как в данном случае должна происходить работа прерываний для этих разный областей.
etoja
сообщение Feb 24 2009, 15:18
Сообщение #29
Пользователь №: 1 952
Прилагаю подробную инструкцию по IAP для использования с компилятором Crossworks.
Извиняюсь перед автором этого документа, что не записал его адрес в интернете.
Denisvak
сообщение Feb 24 2009, 16:26
Сообщение #30
Вопрос по прерываниям в основной программой. Если я линкеру укажу файлик "LPC2148_flash.xcl" в котором ручками поправлю начало флеш
-DROMSTART=00001000
вместо
-DROMSTART=00000040
и прерывания
-Z(CODE)INTVEC=00001000-0000103f
вместо
-Z(CODE)INTVEC=00000000-0000003f
будут ли корректно работать прерывания? Камешек lpc2148
Всем спасибо.
RSS Текстовая версия Сейчас: 1st September 2025 - 05:09
Страница сгенерированна за 0.01504 секунд с 7
