> Cortex от Cypress
Axel
сообщение Jun 21 2009, 18:52
Пользователь №: 1 188
В конце года Cypress обещает новые PSoCи с Cortex'ом. Параметры и набор периферии выглядят прилично:
Features
�� 32-bit ARM Cortex-M3 CPU Core
�� Flash program memory, up to 256 KB (100,000 write cycles)
�� Up to 64 KB SRAM memory
�� 2 KB EEPROM memory, 1 million cycles, 20 year retention
�� Low voltage, ultra low power
�� Wide operating voltage range: 1.7V to 5.5V
�� High efficiency boost from 0.5V
�� 500 μA at 1 MHz, 2 mA at 6 MHz
�� Four sleep modes including:
• 300 nA hibernate mode with RAM retention
• 2 μA sleep mode with real time clock, low voltage reset
interrupt, and watchdog timeout
�� Versatile IO system
�� 28 to 72 IO (62 GPIO, 8 SIO, 2 USBIO)
�� Any GPIO to any digital or analog peripheral routability
�� 1.2 to 5.5V interface voltages
�� Maskable, independent IRQ on any pin or port
�� Schmitt trigger TTL inputs
�� LCD direct drive up to 46x16 segments
�� All GPIO configurable as open drain high/low, pull up/down,
high Z, or strong output
�� Configurable GPIO pin state at power on reset (POR)
�� 25 mA sink on SIO
�� Digital peripherals
�� 16 to 24 programmable PLD-based Universal Digital Blocks
(UDB)
�� Full CAN 2.0b 16 RX, 8 TX buffers
�� Full-Speed (FS) USB 2.0 12 Mbps peripheral
�� Up to four 16-bit configurable timer/counter/PWM blocks
�� Library of standard peripherals
• 8, 16, 24, and 32-bit timers, counters, and PWMs
• SPI, UART, I2C™
• Many others available in catalog
�� Library of advanced peripherals
• Cyclic Redundancy Check (CRC)
• Pseudo Random Sequence (PRS) generator
• LIN Bus 2.0
• Quadrature decoder
�� Custom peripheral creation using Verilog
�� Analog peripherals
�� 0.2% internal voltage reference across -40°C to 85°C
�� Configurable Delta-Sigma ADC with 12 to 20-bit resolution
• Sample rates up to 192 ksps
• Programmable gain stage: x0.25 to x16
• 12-bit mode, 192 ksps, 70 dB SNR, 1.5 bit INL/DNL
• 16-bit mode, 48 ksps, 90 dB SNR, 1 bit INL/DNL
�� Two SAR ADCs, each 12-bit at 1 Msps
�� 80 MHz, 24-bit fixed point digital filter block (DFB) to
implement FIR and IIR filters
�� Up to four 8 MHz, 8-bit V/IDACs, configurable up to 12 bits
�� Four comparators with 30 ns response time
�� Four uncommitted opamps with 25 mA drive capability
�� Up to four switch capacitor blocks configurable to:
• Analog mixer
• Transimpedance amplifier
• Programmable gain amplifier x1 to x50
Даташит есть (preliminary). Выложить не могу laughing.gif , но желающим вышлю.
- Axel   Cortex от Cypress   Jun 21 2009, 18:52
- - oll   Цитата(Axel @ Jun 21 2009, 23:52) Даташит...   Jun 22 2009, 03:50
|- - -=Sergei=-   Цитата(oll @ Jun 22 2009, 07:50) надо - o...   Jun 22 2009, 06:18
|- - etoja   А почему на их сайте ничего нет? Одни 8-битники. A...   Jun 22 2009, 07:30
- - sensor_ua   Интересно было бы ознакомиться sensorua[!]gmai...   Jun 22 2009, 05:18
- - Rst7   Интересно. Если можно - rst7.cbsie[ю]gmail.com Кс...   Jun 22 2009, 05:34
- - zltigo   Цитата(Axel @ Jun 21 2009, 21:52) ...   Jun 22 2009, 06:02
|- - sergvks   Цитата(zltigo @ Jun 22 2009, 10:02) Чисты...   Jun 22 2009, 06:15
- - proba   значит будут делать, http://www.msc-ge.com/frame/e...   Jun 22 2009, 07:54
|- - etoja   Цитата(proba @ Jun 22 2009, 11:54) значит...   Jun 22 2009, 09:40
- - MrYuran   Давно интересует вопрос, насколько качественная ан...   Jun 22 2009, 08:16
|- - Altemir   Цитата(MrYuran @ Jun 22 2009, 12:16) Давн...   Jun 23 2009, 13:49
- - Axel   Информация достоверная, можно сказать из первых ру...   Jun 22 2009, 11:25
|- - miv   Цитата(Axel @ Jun 22 2009, 15:25) Информа...   Jun 22 2009, 11:57
- - sensor_ua   Нашлась такая инфа https://materials.proxyvote.com...   Jun 22 2009, 13:05
|- - etoja   Так анонс этой микросхемы приведён в годовом отчё...   Jun 22 2009, 13:57
- - VAI   И я хотел бы ознакомится с даташитом. v572028(соба...   Jun 23 2009, 04:30
- - Dog Pawlowa   По некоторой информации, образцы кристаллов CY8C55...   Oct 21 2009, 08:23
- - QED   Цитата(Dog Pawlowa @ Oct 21 2009, 10:23) ...   Oct 21 2009, 09:40
- - Dog Pawlowa   Итак, лежат у меня две платки для сайпрессовского ...   Dec 2 2009, 17:15
RSS Текстовая версия Сейчас: 21st July 2025 - 16:17
Страница сгенерированна за 0.01368 секунд с 7
