> EPSC
artem79
сообщение Jan 15 2010, 10:06
Из: Казань
Пользователь №: 24 091
Добрый день.
Сталкнулся с проблемой загрузки программы во флаш.
Имеется след. система. EP2C5 - SRAM - EPCS. в качестве памяти программ используется SRAM. В отладчике все работает.
Пытаюсь загрузить во флэш через flash-programmer выдает следующее:
CODE
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd H:/Nios_60/software/count_binary_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="H:/Nios_60/nios_uart.sof" --outp
ut="nios_uart.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=nios_
uart.opt H:/Nios_60/nios_uart.sof nios_uart.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 73 megabytes
Info: Processing ended: Fri Jan 15 12:40:07 2010
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:05
Info: Command: quartus_cpf --no_banner --convert nios_uart.pof nios_uart.rpd
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Fri Jan 15 12:40:16 2010
Info: Elapsed time: 00:00:08
Info: Total CPU time (on all processors): 00:00:07
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00201000 --sidp=0x0
0202068 --id=477433320 --timestamp=1263547010 --instance=0 "nios_uart.flash"
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00202068: verified
No EPCS layout data - looking for section [EPCS-EF3013]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="nios_uart.flash" --input="count_
binary_0.elf" --output="epcs_flash_controller_0.flash"
# Programming flash with the project
0202068 --id=477433320 --timestamp=1263547010 --instance=0 "epcs_flash_controlle
r_0.flash"
Такое ощущение что флэшку не видит. Может кто сталкивался????? Работаю в QuartusII 9.0.
Сообщение отредактировал Omen_13 - Jan 19 2010, 20:31
Причина редактирования: Оформление
3 страниц V  < 1 2 3 >
Ответов (15 - 29)
artem79
сообщение Jan 26 2010, 10:39
Сообщение #16
Из: Казань
Цитата(vadimuzzz @ Jan 26 2010, 13:36) *
непонятно.. надо как-нибудь дамп sram сделать после подачи питания. память on-chip или внешняя?
внешняя - sram.
при отладке из ниоса нареканий не было.
vadimuzzz
сообщение Jan 26 2010, 10:46
Сообщение #17
Пользователь №: 6 988
Цитата(artem79 @ Jan 26 2010, 16:39) *
внешняя - sram.
это не очень показательно, в пошаговом режиме некоторые проблемы с времянками можно проскочить. я бы прицепил к ниосу сигнал-тап www.altera.com/literature/an/an446.pdf посмотреть, чем он занимается. туда же добавить шину к sram. больше ничего на ум не приходит.
Stewart Little
сообщение Jan 26 2010, 10:51
Сообщение #18
Лентяй
Пользователь №: 843
Цитата(vadimuzzz @ Jan 26 2010, 11:44) *
[EPCS-EF3013] # EPCS4N
sector_size = 65536
sector_count = 4
Пара вопросов (для общего развития):
Откуда EF3013? У EPSC4 silicon id = 0x12...
Чтобы слова не расходились с делом, нужно молчать и ничего не делать...
vadimuzzz
сообщение Jan 26 2010, 10:59
Сообщение #19
sector_count = 8, может поэтому и не работает
была вроде партия lead-free, китайцы наверное http://hi.baidu.com/jthustei/blog/item/50b...df277fb5b7.html
на ниосфоруме тоже пробегало
artem79
сообщение Jan 26 2010, 11:19
Сообщение #20
Из: Казань
нет. все равно не работает.
Stewart Little
сообщение Jan 26 2010, 11:25
Сообщение #21
Лентяй
Пользователь №: 843
Для быстрой проверки сделайте маленькую тестовую программку (подергать лапкой, например), и разместите ее в On-Chip RAM (со всеми изменениями в SOPC'е и BSP).
Посмотрим, как после этого будет грузиться.
artem79
сообщение Jan 26 2010, 11:51
Сообщение #22
Из: Казань
Все заработало! Последняя причина была в подключении банков SRAM. При загрузке из NIOS работало, а при загрузки из EPCS нет. Поправил, все стало нормально.
Reanimator++
сообщение Apr 13 2011, 10:46
Сообщение #23
Из: Волгоград
Пользователь №: 12 763
Осваиваю Flash Programmer.
Собственно сначала наткнулся на такую же ошибку как и в этом топике - см скриншот.
Создание текстового файлика как описал ув. vadimuzz помогло и flash programmer начал что-то записывать.
Попробовал добавить .sof файл и записать его с нулевым смещением. Программер его успешно прошил. Передергиваю питание - nios-а не видно.
Прошиваю этот же .sof с помощью Quartus II Programmer-a (предварительно сконвертировав в .jic) - передергиваю питание - nios видно.
Что я делаю не так? Вроде в Flash Programmer-е особо и кнопок-то нету чтобы перепутать.
vadimuzzz
сообщение Apr 13 2011, 12:57
Сообщение #24
1. давайте выхлоп флеш-программера с ключом -debug
2. надо сделать дампы флешки после прошивания через флеш-програмер и через jic.
на всякий случай сообщите версии софта
Reanimator++
сообщение Apr 13 2011, 13:21
Сообщение #25
Из: Волгоград
9.1 SP2
1. Выхлоп Flash Programmer-а, добавил еще ключ --verify на всяк.
[NiosII EDS]$ $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "D:/Projects/Vezuviy/C
ontroller_New/fpga/software/test_bsp/flash/controller_epcs_flash_controller.fla
sh" --base=0x2001800 --epcs --sidp=0x20022A0 --id=0x514AFF4A --timestamp=129657
8400 --device=1 --instance=0 '--cable=USB-Blaster [USB-0]' --program --verbose
--debug
Reading override file "d:/altera/91/nios2eds/bin/nios2-flash-override.txt"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Reading System ID at address 0x020022A0: verified
Processor data bus width is 32 bits
Looking for EPCS registers at address 0x02001800 (with 32bit alignment)
  Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
  Not here: reserved fields are non-zero
Looking for EPCS registers at address 0x02001900 (with 32bit alignment)
  Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C
Looking for EPCS registers at address 0x02001A00 (with 32bit alignment)
  Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
  Valid registers found
EPCS signature is 0x12
EPCS identifier is 0xEF3013
Using EPCS size information from section [EPCS-EF3013]
Device size is 512KByte (4Mbit)
Erase regions are:
  offset  0: 8 x 64K
EPCS status is 0x00
              : Checksumming existing contents
00000000      : Verifying existing contents
00000000      : Needs erase then program
00010000      : Verifying existing contents
00010000      : Needs erase then program
00020000      : Verifying existing contents
00020000      : Needs erase then program
00000000      : Reading existing contents
00010000      : Reading existing contents
00020000      : Reading existing contents
Checksummed/read 62kB in 3.1s
00000000 ( 0%): Erasing
00010000 (33%): Erasing
00020000 (66%): Erasing
Erased 192kB in 0.4s (480.0kB/s)
00000000 ( 0%): Programming
00010000 (33%): Programming
00020000 (66%): Programming
Programmed 131KB +61KB in 7.6s (25.2KB/s)
Did not attempt to verify device contents
2. Делать дамп флешки через .jic пока не умею ) умею только делать .jic для прошивки через convert programming files.
3. Проверил чтение-запись во флешку из программы Nios-а с помощью стандартных функций alt_read_flash, alt_write_flash - все пишется/читается правильно.
vadimuzzz
сообщение Apr 13 2011, 13:37
Сообщение #26
так, логи чистые.
дамп можно слить так:
nios2-flash-programmer --epcs --base=0x2001800 --read=dump.flash
можно и квартусовским программером
Stewart Little
сообщение Apr 13 2011, 13:40
Сообщение #27
Лентяй
Пользователь №: 843
Вектор сброса проца куда указывает?
Должен указывать на epcs_flash_controller.
Reanimator++
сообщение Apr 13 2011, 19:18
Сообщение #28
Из: Волгоград
Ок, попробуем дампы сравнить с помощью Flash Programmer-a.
До вектора сброса дело не доходит (он стоит на SDRAM), я пока хочу добиться только чтобы железо само заливалось (ну в смысле прошивка плис, sof). Работы программы Nios-a (elf) при старте я пока не добиваюсь, это будет следующий этап sm.gif Программу пока запускаю из среды Nios IDE (Run as Nios II Hardware).
Reanimator++
сообщение Apr 14 2011, 07:16
Сообщение #29
Из: Волгоград
Сравнил дампы флеши после работы Quartus II Programmer-a и Nios II Flash Programmer-a. Они разные, причем совсем разные. Ни одного одинакового байта, близок только размер заполненного пространства. Вложил дампы, включая выхлоп sof2flash, хотя не думаю что вам это интересно.
Полагаю, что докапываться до Flash Programmer-a нет смысла, он свою работу выполняет - читает, пишет, проверяет.
Видимо, нужно смотреть раньше - неверный результат преобразования sof2flash.
Вот его лог.
[NiosII EDS]$ sof2flash --input="D:/Projects/Vezuviy/Controller_New/fpga/contro
ller.sof" --output="D:/Projects/Vezuviy/Controller_New/fpga/software/test_bsp/f
lash/controller_epcs_flash_controller.flash" --epcs --verbose
14.04.2011 11:11:36 - (FINE) sof2flash: Starting
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=D:/Pr
ojects/Vezuviy/Controller_New/fpga/software/test_bsp/flash/controller_epcs_flash
_controller.opt D:/Projects/Vezuviy/Controller_New/fpga/controller.sof D:/Projec
ts/Vezuviy/Controller_New/fpga/software/test_bsp/flash/controller_epcs_flash_con
troller.pof
    Info: Peak virtual memory: 72 megabytes
    Info: Processing ended: Thu Apr 14 11:11:38 2011
    Info: Elapsed time: 00:00:02
    Info: Total CPU time (on all processors): 00:00:01
Info: Command: quartus_cpf --no_banner --convert D:/Projects/Vezuviy/Controller_
New/fpga/software/test_bsp/flash/controller_epcs_flash_controller.pof D:/Project
s/Vezuviy/Controller_New/fpga/software/test_bsp/flash/controller_epcs_flash_cont
roller.rpd
    Info: Peak virtual memory: 70 megabytes
    Info: Processing ended: Thu Apr 14 11:11:40 2011
    Info: Total CPU time (on all processors): 00:00:02
14.04.2011 11:11:40 - (FINE) sof2flash: Done
Я пока до конца не понимаю как работает эта утилита, но видно что она вызывает Convert_programming_files, и меня смущает атрибут --device=EPCS128 в вызове, хотя у меня стоит EPCS4...
Или еще варианты?
vadimuzzz
сообщение Apr 14 2011, 07:42
Сообщение #30
что-то это мне напоминает:
http://electronix.ru/forum/index.php?showtopic=77486 //см. в конце треда
http://www.alteraforum.com/forum/showthread.php?t=22441
...и еще:
http://electronix.ru/forum/index.php?showtopic=74308
http://electronix.ru/redirect.php?http://w...ead.php?t=21386
RSS Текстовая версия Сейчас: 21st July 2025 - 22:16
Страница сгенерированна за 0.01515 секунд с 7
