3 страниц V  < 1 2 3
> Светомузыка на AVR
Petrovich
сообщение Mar 13 2010, 18:13
Сообщение #31
Из: Днепропетровск
Пользователь №: 5 658
MPLABC30ComboAcad_v3_12 нормально компилируется
erroca
сообщение Mar 27 2010, 19:31
Сообщение #32
Пользователь №: 43 754
mojet pomojecte ....
A file Color.h ,dojen bit' pustoy ili .... ???
CODE
Color.c: In function 'main':
Color.c:77: warning: implicit declaration of function 'Set_Pot'
Color.c:116: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:64: warning: unused variable 'y'
Color.c:64: warning: unused variable 'x'
Color.c: In function 'Menu_Config':
Color.c:227: warning: array subscript has type 'char'
Color.c:229: warning: array subscript has type 'char'
Color.c:229: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:235: warning: array subscript has type 'char'
Color.c:237: warning: array subscript has type 'char'
Color.c:238: warning: array subscript has type 'char'
Color.c:240: warning: array subscript has type 'char'
Color.c:241: warning: array subscript has type 'char'
Color.c:243: warning: array subscript has type 'char'
Color.c:245: warning: array subscript has type 'char'
Color.c:246: warning: array subscript has type 'char'
Color.c:254: warning: array subscript has type 'char'
Color.c:268: warning: array subscript has type 'char'
Color.c:271: warning: pointer targets in passing argument 1 of 'print' differ in signedness
Color.c:272: warning: array subscript has type 'char'
Color.c:274: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:280: warning: array subscript has type 'char'
Color.c:282: warning: array subscript has type 'char'
Color.c:283: warning: array subscript has type 'char'
Color.c:285: warning: array subscript has type 'char'
Color.c:286: warning: array subscript has type 'char'
Color.c:288: warning: array subscript has type 'char'
Color.c:290: warning: array subscript has type 'char'
Color.c:291: warning: array subscript has type 'char'
Color.c:294: warning: array subscript has type 'char'
Color.c:296: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:312: warning: array subscript has type 'char'
Color.c:326: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:331: warning: array subscript has type 'char'
Color.c:331: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:334: warning: array subscript has type 'char'
Color.c:335: warning: array subscript has type 'char'
Color.c:356: warning: array subscript has type 'char'
Color.c:362: warning: array subscript has type 'char'
Color.c: In function 'View_List_Config':
Color.c:390: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:391: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:392: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:393: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:394: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:395: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:396: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:402: warning: pointer targets in passing argument 1 of 'print' differ in signedness
Color.c: In function 'View_Edit_Menu':
Color.c:414: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:415: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:416: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c:417: warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness
Color.c: In function 'Load_Const_Time':
Color.c:435: warning: array subscript has type 'char'
Color.c:433: warning: unused variable 'i'
Color.c: In function 'Load_Correct_Ampl_Freq':
Color.c:452: warning: array subscript has type 'char'
Color.c: In function 'Load_Shift':
Color.c:469: warning: array subscript has type 'char'
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=30F4012 -c -
D__DEBUG "DataEEPROM.s" -o"DataEEPROM.o" C:\Soft -Wa,--defsym=__DEBUG=1
pic30-coff-gcc.exe: C:\Soft: linker input file unused because linking not done
Executing: "C:\Program Files\Microchip\MPLAB C30\bin\pic30-gcc.exe" -mcpu=30F4012 -x c -c
"DELAY.C" -o"DELAY.o" -D__DEBUG -g -Wall
"FIR.c" -o"FIR.o" -D__DEBUG -g -Wall
C:\Users\VRL\AppData\Local\Temp/ccBiwPw7.s: Assembler messages:
C:\Users\VRL\AppData\Local\Temp/ccBiwPw7.s:7357: Error: invalid attribute combination for .ydata
C:\Users\VRL\AppData\Local\Temp/ccBiwPw7.s:7357: Error: Attributes for section '.ydata' conflict
with implied attributes
Halting build on first failure as requested.
Модератор. В данном разделе форума язык общения - русский. Потрудитесь сами до публикации своих сообщений перевести их с транслита на русский язык. Оправдываться отсутствием русификации клавиатуры или кириллицы на компьютере не нужно. Есть он-лайновые Интернет-сервисы типа http://www.translit.ru/ .
Сообщение отредактировал rezident - Mar 27 2010, 21:36
Причина редактирования: Оформление цитаты.
Petrovich
сообщение Mar 29 2010, 11:46
Сообщение #33
Из: Днепропетровск
Чем компилируете?
erroca
сообщение Mar 31 2010, 07:27
Сообщение #34
Цитата(Petrovich @ Mar 29 2010, 14:46) *
Чем компилируете?
Mplab c30_3.12
А фаил color.h, пустоу, так должно быть ?
Petrovich
сообщение Apr 9 2010, 07:28
Сообщение #35
Из: Днепропетровск
Цитата(erroca @ Mar 31 2010, 10:42) *
Mplab c30_3.12
Да, он пустой. Если хотите, могу выслать мой компилятор с которым все копмпилируется
Кстати, на варнинги внимания не обращайте.
erroca
сообщение Apr 10 2010, 11:58
Сообщение #36
Да, если вам не трудно...
Спасибо за помощь !
Petrovich
сообщение Apr 14 2010, 17:56
Сообщение #37
Из: Днепропетровск
Спасибо за помощь !
Куда слать то??
erroca
сообщение Apr 21 2010, 11:22
Сообщение #38
Цитата(Petrovich @ Apr 14 2010, 21:11) *
Куда слать то??
vinokurr@yahoo.com
vxzxc
сообщение Apr 28 2010, 10:34
Сообщение #39
Пользователь №: 15 007
кто нибудь работал с LM4970?
третий день бьюсь, не могу понять в чем дело.
ШИМ на выходе идет с паузами, т.е., например, 5мс идет правильный ШИМ(заполнение соответствует действительности), потом 5мс линия подтянута к +5V, потом опять правильный ШИМ, и тд.
что за фигня?
Сообщение отредактировал vxzxc - Apr 28 2010, 10:58
Petrovich
сообщение Apr 30 2010, 06:02
Сообщение #40
Из: Днепропетровск
Цитата(erroca @ Apr 21 2010, 14:22) *
vinokurr@yahoo.com
Отправил
erroca
сообщение May 2 2010, 14:08
Сообщение #41
Цитата(Petrovich @ Apr 30 2010, 09:02) *
Отправил
Спасибо !!!!
erroca
сообщение May 2 2010, 15:23
Сообщение #42
Отправил
не хватает 7-й части архива !!!!
Petrovich
сообщение May 3 2010, 13:37
Сообщение #43
Из: Днепропетровск
От меня ушло все... странно...
3 страниц V  < 1 2 3
RSS Текстовая версия Сейчас: 2nd September 2025 - 06:23
Страница сгенерированна за 0.01602 секунд с 7
