Господа, вышел новый 3 Hotfix. |
(45 - 59)
Sep 13 2010, 07:44
Пользователь №: 58 959
Вышел новый HOTFIX VERSION: SPB16.30.016 Цитата DATE: 09-10-2010 HOTFIX VERSION: 016 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 810479 FSP DESIGN_SETTINGS Not able to connect some peripheral signals to FPGA manually 604662 VLS-L VIA When changing Rows/Columns values in Edit Via Properties form, different value are assigned. 747191 PSPICE AA_SENS Pspice crashes when starting Advance Analysis 756103 CONCEPT_HDL ARCHIVER Archiver does not include all the Parts when design blocks are copied from one location to another 758487 APD 3D_VIEWER package substrate (BGA) outline should be on a separate layer, not on bottom conductor layer. 764417 APD EDIT_ETCH Routing with Diagonal entry (45 degree) to Constraint Regions does not work 766409 PSPICE PROBE Copy to Clipboard changes the label text colors 784577 CONCEPT_HDL COMP_BROWSER SingleclickAdd 'true' places does not pick the correct version 784814 SIP_LAYOUT ASSY_RULE_CHECK accuracy of acute angle DRC 792039 CONSTRAINT_MGR OTHER Doing a File->Import->Worksheet Customization from Constraint Manager will change the working directory. 796517 CONCEPT_HDL COMP_BROWSER Component Browser showing wrong symbol 801944 SCM UI SCM dropping terminators and pull-ups when renaming signals (copy - paste special) 804627 PSPICE PROBE Printet text labels have wrong location 810814 CONSTRAINT_MGR OTHER T-point does not create when import DCF file. 811032 ALLEGRO_EDITOR EDIT_ETCH Enable enhanced pad entry to support pads as shapes 812643 SIP_FLOW CONSTRAINT_MGR Physical Constraint values disappear after entering constraint mode 812835 CONSTRAINT_MGR INTERACTIV CM Custom Fomula - "Analyze" on the header of Actual does not analyze pinpairs 813435 SIP_LAYOUT DIE_ABSTRACT_IF Invalid parameter passed to ICP utility API 814060 CONCEPT_HDL CORE Read only library becomes writeable when updated 814347 ALLEGRO_EDITOR ARTWORK It seems like not work ”detailed text checking” on 16.3. 814451 ALLEGRO_EDITOR DATABASE Allegro get crash when run dbdoctor 814496 CAPTURE ANNOTATE Lower level part refdes resets to ? 815150 SIP_RF OTHER sip layout export chips output is not correct 816034 ALLEGRO_EDITOR MANUFACT Backdrill Passes not work from bottom 816065 APD DATABASE Export Libraries with no library dependencies selected creates package symbol without pins. 816426 ALLEGRO_EDITOR SHAPE Dynamic shape not updated when component is unplaced 816616 SCM SYSTEM_OBJECT codesign incorrectly maps primary and secondary codesign object 816686 ALLEGRO_EDITOR TESTPREP Probe Spacing rounds off 3 place decimal to 2 places 816917 SIG_INTEGRITY LIBRARY Issue for loading interconn.iml 816986 ALLEGRO_EDITOR MANUFACT Mfg>NC>Backdrill analysis with passes set at Bottom layer is automatically switching to top, hence failing! 817473 CAPTURE NETLIST_ALLEGRO Backslash (\) is considered as illegal character for netname but it was allow in SPB 16.30.010 817606 SIP_LAYOUT WIREBOND When moving Bondfingers the Via's are sliding too when they should not.
Евграфов Александр/ Alexander Evgraphov Skype: alexander.evgraphov
Dec 12 2010, 09:31
Пользователь №: 24 387
Спасибо, sergun53! Это действительно работающая ссылка! До этого скачивал с http://top-varez.info/program/14378-cadenc...e-08112010.html. Так получил, что "Program too big to fit in memory". После скачивания по ссылкам, выложенным sergun53, хотфикс 018 встал нормально. Но не забывайте полечить!
Dec 13 2010, 06:38
Из: Могилев
Пользователь №: 7 095
Цитата(Uree @ Dec 13 2010, 00:59)  При генерации карты сверловки все значки отображаются просто точками. Вроде как не смертельно, но нормальный набор файлов для завода сделать не получается. ... Странно. У меня вроде бы все нормально...
ЗЫ Да, вижу в герберах действительно точки...
