Исправления которые войдут в 8 версию для 900-ки |
Mar 10 2011, 07:25
Из: Днепр
Пользователь №: 7 988
Кстати по просьбе товарищей которые хотели переключаемый режим RI - обратите внимание на пункт 29 - команда CRIPULSE
Есть и не очень хорошая новость - в связи с обнаруженой критической ошибкой в приеме DTMF, будет выпущена дополнительная сборка 8 версии после устранения данной ошибки. SIMCOM извиняется и постарается сделать это как можно скорее.
Обновленые даташиты выложу на сайт сразу по получению.
НОВОЕ 1. Added "AT+SLEDS" command to configure the flicker frequency of network lights in the status of unregistered, registered or PPP. 2. Added the value "UR" to the parameter <exunsol> of "AT+EXUNSOL" command to support unsolicited result code.
ИСПРАВЛЕНИЯ 1. Solved the problem of not reporting "NO ANSWER" in the case of calling the other side who was busy when user set ATS7=15. 2. Solved the problem that voltage alarm urc was only reported in a logical serial port in MUX mode. 3. Modified the format of returning information when setting "AT+CENG=3". 4. Solved the reset problem when user input wrong value of parameter to change the frequency band. 5. Added AT+CGAS command to increase the speed of GPRS attachment since it is not necessary to re-attach each time. 6. Fixed the bug that executing ATA command can not pull RI to high level in MUX mode. 7. Solved the problem that USSD information reported was incorrect found by Indian customer. 8. Fixed the bug that the local time converted by the time NITZ reported was wrong and ”CI” of operator’s name was wrong. 9. Optimized the SIDETONE function. 10. Solved the problem that it would take a long time for network indicator light to flash for some SIM cards when user powered on the module in roaming status. 11. Solved the problem that unrecognizable code would be reported when user executed the CLCC or CLIP command to get information of an incoming call whose name was saved in the phonebook in UCS2 mode previously. 12. Solved the problem that there is no response returned from serial port if user executes the following steps: 1. Plug out the SIM card and then dial emergency number. 2. Plug in the SIM card then execute "AT+CFUN=0" command. 13. Limited the scope of input parameters of "AT+CRLP" command. 14. Fixed the bug of CLCC, CLIP, CMGR command that Chinese name and English name could not display in UCS2 mode if user sets CSCS to UCS2 mode. 15. Modified the CPBW command when CSCS was set to HEX mode, the name could be written up to 28 characters. 16. Limited the scope of input parameters of AT+CALD command. 17. Modified the error response of AT command "AT+CSTA=", the error response should be "ERROR" instead of "OK". 18. Solved the problem that the responses of reading empty record in phone book via CPBR command were not consistent. 19. Modified the response of test command of EXUNSOL by adding the parameter value "UR". 20. Solved the problem that the module can not register to the network successfully with SIM card of Orange operator when user sets "AT+CBAND="ALL_BAND"" 21. Added the content "resource limitation" of error code 99. 22. Solved the problem that the calling record of some special number can not be saved in recent call lists. 23. Solved the problem that the CSD connection can not be established successfully anymore after user dials a number in call record list in CSD mode. 24. Solved the problem that "CALL READY" will not report in some special conditions when URC presentation was enabled by executing CIURC command. 25. Исправления касаются служебной команды - информация NDA 26. Solved the problem that CTS varied when user sent or received AT command with no flow control. 27. Limited the scope of inputting parameter when executing HTTPREAD and HTTPDATA command in writing mode. 28. Solved the problem that Shenzhen customer can not originate a phone call or send SMS after a successful call. 29. Altered the RI pin status when the module reported "RING" of incoming CSD call. If CRIPULSE is set to 1, it presents RI pulse otherwise it is continuously in high level. 30. Solved the problem that there was no ring back tone if user dialed a number of MAXIS sim card through the CELECOM sim card in Malaysia. 31. Solved the problem which happened after user sent a sms via AT command accidentally that the module would "freeze" for about 50 seconds before it replied, during that time, the module did not respond to any commands. 32. Supported GPRS multislot class 2, user is allowed to set class 2 by executing CGMSCLASS command. 33. Solved the problem that SIM PIN2 couldn’t be modified. 34. Solved the problem that the module couldn’t attach to the GPRS network if it had activated GPRS previously and then restarted manually. 35. Solved the problem raised by Shenzhen customer that some special SIM card could not be recognized by the module. 36. Improved the CENG function to show more neighbor cells.
(60 - 74)
Mar 29 2011, 06:05
Из: Днепр
Надежда есть всегда.  Законы Мерфи помните? - Если прибор заработал с первой попытки, значит Вы чего-то не учли. Так что работать заставим. Теперь по поводу когда. 19 апреля выставка в Москве и МТ-систем проводит семинар с участием симкомовцев. У меня уже есть симкомовские материалы с презентацией модуля, с новым фирмваре, который они представят на семинаре. Значит прошивка появится как минимум на неделю раньше. Главное чтобы не первого апреля
Mar 29 2011, 19:49
Из: СПБ
Пользователь №: 60 836
Цитата(sobr @ Mar 29 2011, 18:22)  19 апреля в Москве будет две выставки, на какой из них? по слухам китаезы из симкома приедут только на "Новую Электронику". А лично я буду и на Экспе и на Новой выступать. Если кто захочет познакомиться, то пожалуйста Из интересных тем по Telit будут: автомобильные модули под ЭРА-ГЛОНАСС, модули GSM-R (железнодорожная тематика), ну и про новые модули 3,5G стандарта HSDPA Class 33 на скорость 14,5Mbit/sec. Еще может быть затронем 433 и 868Мгц MESH радиомодули на новейшем чипе от Texas Instruments, если успеем. Ну про ценовую и техническую "убийцу" сим900 - модуль Telit GL868-Dual тоже огласим  BR,
Mar 29 2011, 20:18
Пользователь №: 63 984
Прошивка, пожалуйста, сообщите мне sim900 DTMF? cyberspys@hotmail.com
Как получить доступ к FTP. У меня нет пароля. Мне нужно sim900 testdtmf. cyberspys@hotmail.com
Mar 30 2011, 06:10
Из: Днепр
Дожились - быстрее в форуме спросить чем на сайт организатора зайти  Семинар - http://mt-system.ru/index.php?id=86378>>>>Ну про ценовую и техническую "убийцу" сим900 - модуль Telit GL868-Dual тоже огласим В некоторых моментах 868 навороченее. Но всем ли эти навороты нужны, вот в чем вопрос. А по цене не спешите говорить "гоп". Да и не видно пока его массово что-то. Вобщем скажу прямо - на сегодня Telit единственный с кем интересно конкурировать. Да и дистрибьюторы Telit, в отличии от других, народ корректный. По наворотам думаю догоним к концу года. SIMCOM сейчас внимательно изучает возможности прошивки R10. И есть предварительный список что будет в 900-й добавляться. Ну а за остальное клиенты рублем проголосуют.
Apr 6 2011, 11:43
Из: Николаев
Пользователь №: 21 853
Цитата(CADiLO @ Mar 29 2011, 12:30)  Материалы после семинара я выложу на сайт. Выложите? Любопытство одолевает, что же было на семинаре..
Apr 6 2011, 18:22
Из: Николаев
Цитата(ssokol @ Apr 6 2011, 20:51)  ... я думаю будут азиаточки, вино... что значит "будут"? я думал речь шла о семинаре который БЫЛ 31 марта и давно закончился..
Apr 7 2011, 05:02
Из: г. Рыбинск, Ярославская область
Пользователь №: 35 028
Цитата(Transistor @ Apr 6 2011, 21:22)  что значит "будут"? я думал речь шла о семинаре который БЫЛ 31 марта и давно закончился..  Семинар состоится 19 апреля 2011 года В ЭКСПОЦЕНТРЕ, 7 павильон, 1 конференц-зал с 13:00 до 15:00. Проводится совместно с представителями компании SIMCom. Программа семинара 1. Приветственное слово представителей компании SIMCom. 2. Презентация GPS модулей SIMCom: SIM18 (SiRF IV) и SIM08 (ST Ericsson) 3. 3G решения SIM5215, SIM5216, SIM5218, SIM5220 и презентация нового 3G модема SIM5320. 4. Обзор текущей линейки GSM модемов серии SIM900 5. Ответы производителя на вопросы. Так что все еще впереди... можете успеть.
May 11 2011, 09:42
Из: Николаев
Цитата(CADiLO @ Apr 7 2011, 09:25)  ...Материалы просили не выкладывать до окончания семинара проводимого МТ-Систем.... Ненавязчиво напомню..  Уже, думаю, можно выкладывать.
