> linphone. ARM., Кросскомпиляция.
jacuba
сообщение Apr 5 2011, 04:57
Из: Пермь
Пользователь №: 63 861
Добрый день, возникла следующая проблема:
при попытке скомпилировать linphone на машине с i686 для машины с ARM-архитектурой:
$cd linphone-3.4.3
$sudo ./configure --prefix=/home/user/armbuild --host=i686-pc-linux --target=arm-linux --disable-static --disable-glib --enable-gnome_ui=no --disable-manual --enable-alsa --with-speex=/home/user/speex
Конфигурация проходит успешно, но в конце получаю предупреждение:
configure: WARNING: ortp-0.15.0 breaks compatibility with older releases, because value returned by rtp_session_recvm_with_ts() has
changed. See the API documentation in doc/ for further readings.
Linphone build configuration ended.
* GTK interface will be compiled.
* Console interface will be compiled.
Now type 'make' to compile, and then 'make install' as root to install it.
После этого делаю sudo make и получаю ошибку:
CCLD   mediastream
../src/.libs/libmediastreamer.so: undefined reference to `speex_echo_cancellation'
../src/.libs/libmediastreamer.so: undefined reference to `speex_echo_state_init'
../src/.libs/libmediastreamer.so: undefined reference to `speex_preprocess_state_destroy'
../src/.libs/libmediastreamer.so: undefined reference to `speex_preprocess_state_init'
../src/.libs/libmediastreamer.so: undefined reference to `speex_echo_ctl'
../src/.libs/libmediastreamer.so: undefined reference to `speex_echo_state_destroy'
../src/.libs/libmediastreamer.so: undefined reference to `speex_preprocess_ctl'
../src/.libs/libmediastreamer.so: undefined reference to `speex_preprocess_run'
collect2: ld returned 1 exit status
make[4]: *** [mediastream] Ошибка 1
make[4]: Leaving directory `/home/user/linphone-3.4.3/mediastreamer2/tests'
make[3]: *** [all-recursive] Ошибка 1
make[3]: Leaving directory `/home/user/linphone-3.4.3/mediastreamer2'
make[2]: *** [all] Ошибка 2
make[2]: Leaving directory `/home/user/linphone-3.4.3/mediastreamer2'
make[1]: *** [all-recursive] Ошибка 1
make[1]: Leaving directory `/home/user/linphone-3.4.3'
make: *** [all] Ошибка 2
Собственно это и вызывает затруднение, откуда такая ошибка и как можно от нее избавиться?
Заранее благодарен.
Petka
сообщение Apr 5 2011, 06:44
Пользователь №: 7 886
Очевидно в библиотеке speex отсутствуют такие функции. Либо не та версия библиотеки, либо вы её неправильно собрали.
P.S. тему лучше перенести в OpenSource раздел
jacuba
сообщение Apr 5 2011, 08:22
Из: Пермь
Petka, спасибо за ответ,
ранее я скачивал speex отсюда и собирал следующим образом:
$cd ../speex-1.1.11.1
$./configure --prefix=/home/user/armbuild --host=i686-pc-linux --target=arm-linux
--disable-static --enable-fixed-point --enable-arm-asm
$make
$make install
Сейчас я поставил пакеты: libogg-ocaml, libogg-ocaml-dev, libspeex-ocaml, libspeex-ocaml-dev, libspeexdsp-dev из репозитариев - проблема решилась. Большое спасибо.
jacuba
сообщение Apr 6 2011, 11:27
Из: Пермь
появилась еще одна проблема: при компиляции speex получаю следующее сообщение
root@debian:/home/user/arm1/speex-1.2beta2# make
make  all-recursive
make[1]: Entering directory `/home/user/arm1/speex-1.2beta2'
Making all in libspeex
make[2]: Entering directory `/home/user/arm1/speex-1.2beta2/libspeex'
/bin/bash ../libtool --mode=link arm-unknown-linux-uclibcgnueabi-gcc  -g -O2   -o testenc  testenc.o libspeex.la -lm
arm-unknown-linux-uclibcgnueabi-gcc -g -O2 -o .libs/testenc testenc.o  ./.libs/libspeex.so -lm
testenc.o: In function `fprintf':
/usr/include/bits/stdio2.h:98: undefined reference to `__fprintf_chk'
./.libs/libspeex.so: undefined reference to `__printf_chk'
make[2]: *** [testenc] Ошибка 1
make[2]: Leaving directory `/home/user/arm1/speex-1.2beta2/libspeex'
make[1]: Leaving directory `/home/user/arm1/speex-1.2beta2'
гугл ничего про это не знает
уважаемые, помогите разобраться.
Сообщение отредактировал jacuba - Apr 6 2011, 11:28
Petka
сообщение Apr 6 2011, 11:50
Похоже неправильно сконфигурировали speex для кросс-компиляции. При сборке вместо uclibc тянутся хэдеры локальной (хостовой) машины, а на ней наверняка glibc.
jacuba
сообщение Apr 7 2011, 06:01
Из: Пермь
Проблема решилась путем установки компилятора в /usr
Теперь при попытки конфигурирования самого libphone получаю сообщение:
# ./configure --prefix=/usr --host=arm-linux --with-gnu-ld --disable-static \
        --disable-glib --with-osip=$ARM_INSTALL_TREE/usr \
    --with-readline=$ARM_INSTALL_TREE/usr \
        SPEEX_CFLAGS="-I$ARM_INSTALL_TREE/usr/include" \
        SPEEX_LIBS="-L$ARM_INSTALL_TREE/usr/lib -lspeex "
checking eXosip2/eXosip.h usability... no
checking eXosip2/eXosip.h presence... no
checking for eXosip2/eXosip.h... no
configure: error: Could not find eXosip2 headers !
Делаю вывод, что хидеры не могут быть найдены потому что их просто нет.
Принимаю решение установить libexosip. Скачиваю и распаковываю.
# cd ../libeXosip2-3.5.0/
#  make
eXosip.c: In function `_eXosip_transaction_init':
eXosip.c:76: error: `osip_srv_record_t' undeclared (first use in this function)
eXosip.c:76: error: (Each undeclared identifier is reported only once
eXosip.c:76: error: for each function it appears in.)
eXosip.c:76: error: parse error before "record"
eXosip.c:84: error: `record' undeclared (first use in this function)
eXosip.c:88: error: `OSIP_SUCCESS' undeclared (first use in this function)
eXosip.c:90: warning: implicit declaration of function `osip_transaction_set_srv_record'
eXosip.c: In function `eXosip_transaction_find':
eXosip.c:106: error: `OSIP_SUCCESS' undeclared (first use in this function)
eXosip.c:110: error: `OSIP_NOTFOUND' undeclared (first use in this function)
eXosip.c: In function `_eXosip_retry_with_auth':
eXosip.c:130: error: `OSIP_BADPARAMETER' undeclared (first use in this function)
eXosip.c:134: error: `OSIP_UNDEFINED_ERROR' undeclared (first use in this function)
eXosip.c:154: warning: passing arg 1 of `osip_list_get' from incompatible pointer type
eXosip.c:160: error: `OSIP_SYNTAXERROR' undeclared (first use in this function)
eXosip.c:1430: warning: passing arg 1 of `osip_list_add' from incompatible pointer type
eXosip.c: In function `eXosip_update_top_via':
eXosip.c:1464: warning: passing arg 1 of `osip_list_get' from incompatible pointer type
eXosip.c:1470: error: `OSIP_SYNTAXERROR' undeclared (first use in this function)
eXosip.c:1487: error: `OSIP_SUCCESS' undeclared (first use in this function)
make[2]: *** [eXosip.lo] Ошибка 1
make[2]: Leaving directory `/root/arm1/libeXosip2-3.5.0/src'
make[1]: Leaving directory `/root/arm1/libeXosip2-3.5.0'
какова причина возникновения этих ошибок? Прошу у вас помощи.
Сообщение отредактировал jacuba - Apr 7 2011, 06:03
Petka
сообщение Apr 7 2011, 06:41
1) ИМХО --prefix НЕ надо при кросс-компиляции прописывать в /usr пропишите куда-нить в личный /home аналогично ARM_INSTALL_TREE
2) при компиляции (make) не выдавались-ли сообщения о ненайденых incude ?
jacuba
сообщение Apr 7 2011, 07:32
Из: Пермь
кхм... Наверно вот здесь и таится ошибка.
Но я все равно не понимаю, как это исправить.
In file included from eXosip.c:25:
eXosip2.h:56:24: osip2/osip.h: Нет такого файла или каталога
eXosip2.h:57:31: osip2/osip_dialog.h: Нет такого файла или каталога
In file included from ../include/eXosip2/eXosip.h:28,
                 from eXosip2.h:59,
                 from eXosip.c:25:
../include/eXosip2/eX_setup.h:29:38: osipparser2/osip_message.h: Нет такого файла или каталога
                 from eXosip2.h:59,
                 from eXosip.c:25:
../include/eXosip2/eX_setup.h:107: error: parse error before "osip_proxy_authenticate_t"
../include/eXosip2/eX_setup.h:107: warning: no semicolon at end of struct or union
../include/eXosip2/eX_setup.h:111: error: parse error before '}' token
../include/eXosip2/eX_setup.h:200: error: parse error before '*' token
../include/eXosip2/eX_setup.h:269: error: parse error before '*' token
In file included from ../include/eXosip2/eXosip.h:29,
                 from eXosip2.h:59,
                 from eXosip.c:25:
../include/eXosip2/eX_register.h:28:37: osipparser2/osip_parser.h: Нет такого файла или каталога
                 from eXosip2.h:59,
                 from eXosip.c:25:
Petka
сообщение Apr 7 2011, 08:05
Посмотрите с какими ключами зачускается компилятор перед выдачей таких ошибок. В ключе "-I" должны содержаться пути к необходимым хедерам. Проверьте наличие этих хедеров. Сконфигурируйте библиотеку так, что бы при компиляции эти пути указывали на необходимые каталоги.
jacuba
сообщение Apr 11 2011, 09:51
Из: Пермь
При конфигурации самого linphon получаю сообщение:
# ./configure --prefix=/root/armbuild --host=arm-linux --disable-static --disable-glib --enable-gnome_ui=no --disable-manual --enable-ipv6 --enable-alsa --with-osip=/armbuild/usr --with-speex=/armbuild/usr
checking for eXosip2/eXosip.h... yes
checking for eXosip_subscribe_remove in -leXosip2... no
configure: error: Could not find eXosip2 library with version >= 3.0.2 !
Начинаю ставить libeXosip2-3.0.3
Прошу меня проверить:
# cd libeXosip2-3.0.3
#  ./configure --host=arm-linux --prefix=/armbuild
Entering directory `/home/user/Загрузки/libeXosip2-3.0.3/src'
if /bin/bash ../libtool --tag=CC --mode=compile arm-linux-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I../include -I/armbuild/include  -Wall -Wcast-align -Wchar-subscripts -Wformat -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -DOSIP_MT -DENABLE_DEBUG -g -DENABLE_TRACE -g   -pthread -g  -MT eXosip.lo -MD -MP -MF ".deps/eXosip.Tpo" -c -o eXosip.lo eXosip.c; \
        then mv -f ".deps/eXosip.Tpo" ".deps/eXosip.Plo"; else rm -f ".deps/eXosip.Tpo"; exit 1; fi
mkdir .libs
arm-linux-gcc -DHAVE_CONFIG_H -I. -I. -I.. -I.. -I../include -I/armbuild/include -Wall -Wcast-align -Wchar-subscripts -Wformat -Winline -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wpointer-arith -DOSIP_MT -DENABLE_DEBUG -g -DENABLE_TRACE -g -pthread -g -MT eXosip.lo -MD -MP -MF .deps/eXosip.Tpo -c eXosip.c  -fPIC -DPIC -o .libs/eXosip.o
eXosip2.h:56:24: osip2/osip.h: No such file or directory
eXosip2.h:57:31: osip2/osip_dialog.h: No such file or directory
osip2/osip.h лежал в /armbuild/include, на всякий случай я скопировал всю папку osip2 в /usr/include
Правильно ли я сделал?
по прежнему получаю кучу сообщений типа:
eXosip.c:83: warning: implicit declaration of function `osip_transaction_init'
eXosip.c:83: error: `transaction' undeclared (first use in this function)
eXosip.c:83: error: (Each undeclared identifier is reported only once
eXosip.c:83: error: for each function it appears in.)
eXosip.c:83: error: `ctx_type' undeclared (first use in this function)
eXosip.c:83: error: `osip' undeclared (first use in this function)
eXosip.c:83: error: `message' undeclared (first use in this function)
eXosip.c: At top level:
eXosip.c:101: error: parse error before "osip_transaction_t"
eXosip.c:102: warning: no previous prototype for `eXosip_transaction_find'
eXosip.c:105: error: `transaction' undeclared (first use in this function)
eXosip.c:106: warning: implicit declaration of function `osip_list_eol'
eXosip.c:106: error: invalid use of incomplete typedef `eXosip_t'
eXosip.c:108: error: `osip_transaction_t' undeclared (first use in this function)
eXosip.c:108: error: `tr' undeclared (first use in this function)
eXosip.c:110: error: parse error before ')' token
eXosip.c:124: error: parse error before "osip_transaction_t"
eXosip.c:127: error: `osip_transaction_t' undeclared (first use in this function)
eXosip.c:127: error: `out_tr' undeclared (first use in this function)
eXosip.c:128: error: `tr' undeclared (first use in this function)
eXosip.c:129: error: `osip_message_t' undeclared (first use in this function)
eXosip.c:129: error: `msg' undeclared (first use in this function)
eXosip.c:130: error: `osip_event_t' undeclared (first use in this function)
eXosip.c:130: error: `sipevent' undeclared (first use in this function)
eXosip.c:134: error: `osip_via_t' undeclared (first use in this function)
eXosip.c:134: error: `via' undeclared (first use in this function)
eXosip.c:137: error: `ptr' undeclared (first use in this function)
eXosip.c:140: error: `jd' undeclared (first use in this function)
eXosip.c:152: error: `retry' undeclared (first use in this function)
eXosip.c:155: warning: implicit declaration of function `osip_message_clone'
eXosip.c:158: warning: implicit declaration of function `OSIP_TRACE'
eXosip.c:474: error: `osip_transaction_t' undeclared (first use in this function)
eXosip.c:474: error: `out_tr' undeclared (first use in this function)
eXosip.c:476: warning: implicit declaration of function `osip_list_get'
eXosip.c:476: error: dereferencing pointer to incomplete type
eXosip.c:478: error: dereferencing pointer to incomplete type
eXosip.c:480: error: dereferencing pointer to incomplete type
eXosip.c:482: error: dereferencing pointer to incomplete type
eXosip.c:492: error: `OSIP_ERROR' undeclared (first use in this function)
eXosip.c:500: error: invalid use of incomplete typedef `eXosip_t'
eXosip.c:500: error: dereferencing pointer to incomplete type
eXosip.c:1138: error: dereferencing pointer to incomplete type
eXosip.c:1143: error: dereferencing pointer to incomplete type
eXosip.c:1144: error: dereferencing pointer to incomplete type
eXosip.c:1164: warning: implicit declaration of function `osip_message_get_www_authenticate'
eXosip.c:1165: warning: implicit declaration of function `osip_message_get_proxy_authenticate'
eXosip.c:1218: error: `osip_generic_param_t' undeclared (first use in this function)
eXosip.c:1218: error: `to_tag' undeclared (first use in this function)
eXosip.c:1219: warning: implicit declaration of function `osip_from_param_get_byname'
eXosip.c:1248: error: `OSIP_INFO1' undeclared (first use in this function)
eXosip.c:1297: error: parse error before '*' token
eXosip.c:1298: warning: no previous prototype for `eXosip_update_top_via'
eXosip.c:1301: error: `osip_generic_param_t' undeclared (first use in this function)
eXosip.c:1301: error: `br' undeclared (first use in this function)
eXosip.c:1302: error: `osip_via_t' undeclared (first use in this function)
eXosip.c:1302: error: `via' undeclared (first use in this function)
eXosip.c:1302: error: parse error before ')' token
eXosip.c:1307: error: `OSIP_ERROR' undeclared (first use in this function)
eXosip.c:1312: warning: implicit declaration of function `osip_via_param_get_byname'
eXosip.c:1323: warning: implicit declaration of function `osip_build_random_number'
eXosip.c:1326: warning: implicit declaration of function `osip_strdup'
Сообщение отредактировал jacuba - Apr 11 2011, 09:55
Petka
сообщение Apr 11 2011, 12:05
Быть такого не может. вы что, прямо в корень /armbuild положили?
Даже если он там лежит компилятор не может не найти хедеров.
jacuba
сообщение Apr 12 2011, 04:47
Из: Пермь
Да, armbuild лежит прямо в корне.
Только что проверил все пути установки, понял, что хидеры linphone искал не там - поправил - частично помогло.
Спасибо, Petka, ты единственный, кто проявляет интерес к этой теме на этом форумеsm.gif
jacuba
сообщение Apr 12 2011, 06:25
Из: Пермь
Я добился того, что linphone сконфигурировался и теперь приступаю к компиляции:
# make
libtool: compile:  arm-linux-gcc -DHAVE_CONFIG_H -I. -I.. -I../include/ -D_REENTRANT -I.. -g -O2 -Wall -Werror -DORTP_INET6 -MT b64.lo -MD -MP -MF .deps/b64.Tpo -c b64.c  -fPIC -DPIC -o .libs/b64.o
b64.c: In function `b64_encode_':
b64.c:209: warning: comparison is always true due to limited range of data type
b64.c:210: warning: comparison is always true due to limited range of data type
b64.c:211: warning: comparison is always true due to limited range of data type
b64.c:212: warning: comparison is always true due to limited range of data type
make[5]: *** [b64.lo] Ошибка 1
make[5]: Leaving directory `/root/arm1/linphone-3.4.3/oRTP/src'
make[4]: *** [all-recursive] Ошибка 1
make[4]: Leaving directory `/root/arm1/linphone-3.4.3/oRTP/src'
make[3]: Leaving directory `/root/arm1/linphone-3.4.3/oRTP'
make[2]: Leaving directory `/root/arm1/linphone-3.4.3/oRTP'
make[1]: Leaving directory `/root/arm1/linphone-3.4.3'
В какую сторону копать?
Petka
сообщение Apr 12 2011, 08:39
Ключ -Werror "превращает" варнинги в ошибки.
Тут уже надо копать снова либо в конфигурацию библиотеки (судя по ошибке надо то ли включить, то ли отключить поддержку 64 бит. Хотя я не уверен.) Либо это бага в библиотеке. Можете попробовать в makefile убрать ключи "-Werror".
jacuba
сообщение Apr 12 2011, 11:02
Из: Пермь
Я открыл файл b64.c и закоментировал строки 209-212.
Данная проблема решилась. Спасибо.
RSS Текстовая версия Сейчас: 5th September 2025 - 10:12
Страница сгенерированна за 0.01538 секунд с 7
