> Flash override на Q11, на Q91 работало, а тут нет...
alexPec
сообщение Jul 16 2012, 10:26
Пользователь №: 15 968
Доброго дня всем!
В Q91 создавал файл nios2-flash-override для M25P32:
[EPCS-202016]
sector_size=65536
sector_count=64
В Q91 все работало ок. Программировал флешку без проблем.
Скопировал то же в Q11.1, нужную флешку не находит.
Вот лог:
Info: 16.07.2012 14:11:18 - (FINE) sof2flash: Starting
Info: Info: *******************************************************************
Info: Info: Running Quartus II 32-bit Convert_programming_file
Info: Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=D:/altera_proj/research/rotator/flash/rotator_epcs_flash_controller_0.opt D:/altera_proj/research/rotator/rotator.sof D:/altera_proj/research/rotator/flash/rotator_epcs_flash_controller_0.pof
Info: Info: Quartus II 32-bit Convert_programming_file was successful. 0 errors, 0 warnings
Info:     Info: Peak virtual memory: 130 megabytes
Info:     Info: Processing ended: Mon Jul 16 14:11:22 2012
Info:     Info: Elapsed time: 00:00:03
Info:     Info: Total CPU time (on all processors): 00:00:02
Info: Info: Command: quartus_cpf --no_banner --convert D:/altera_proj/research/rotator/flash/rotator_epcs_flash_controller_0.pof D:/altera_proj/research/rotator/flash/rotator_epcs_flash_controller_0.rpd
Info:     Info: Peak virtual memory: 124 megabytes
Info:     Info: Processing ended: Mon Jul 16 14:11:25 2012
Info: 16.07.2012 14:11:25 - (FINE) sof2flash: Done
Info: Reading override file "C:/altera/q11_1/nios2eds/bin/nios2-flash-override"
Info: Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Info: Resetting and pausing target processor: OK
Info: Reading System ID at address 0x000120C8: verified
Info: Processor data bus width is 32 bits
Info: Looking for EPCS registers at address 0x00011800 (with 32bit alignment)
Info:   Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
Info:   Not here: reserved fields are non-zero
Info: Looking for EPCS registers at address 0x00011900 (with 32bit alignment)
Info:   Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C
Info: Looking for EPCS registers at address 0x00011A00 (with 32bit alignment)
Info:   Initial values: 108001C4 1004D0FA 002EE03A 003F9C06 002EE03A 003F9506
Info: Looking for EPCS registers at address 0x00011B00 (with 32bit alignment)
Info:   Initial values: 00000000 00000000 00000000 00000000 00000000 00000000
Info:   Not here: SPI_SLAVE_SEL has 0 valid bits (should be between 1 and 16)
Info: Looking for EPCS registers at address 0x00011C00 (with 32bit alignment)
Info:   Initial values: 00000016 00000016 00000260 00000000 00000016 00000001
Info: No EPCS registers found: tried looking at addresses
Info:      0x00011800, 0x00011900, 0x00011A00, 0x00011B00 and 0x00011C00
Info: Leaving target processor paused
Error: Error code: 8 for command: $SOPC_KIT_NIOS2/bin/nios2-flash-programmer "D:/altera_proj/research/rotator/flash/rotator_epcs_flash_controller_0.flash" --base=0x11800 --epcs --sidp=0x120C8 --id=0x0 --timestamp=1342376592 --device=1 --instance=0 '--cable=USB-Blaster on localhost [USB-0]' --program --verbose
Видно что оверрайд находит, а потом ступор. Может чего-то я забыл сделать ?
Чем вылечить?
UPD: Пардон, перезапустил комп, все заработало. Вопрос снимается
RSS Текстовая версия Сейчас: 23rd August 2025 - 10:43
Страница сгенерированна за 0.0131 секунд с 7
