> PCI Express board on Spartan 3 or Virtex 2 pro
keshu
сообщение Dec 30 2005, 05:55
Пользователь №: 12 621
Hi,
Anyone has developed PCI Express Board (x1 or x4 link) on spartan 3 or Virtex2pro?
I want to develop this board, x1 link, 256MB DDR II SSDRAM, USB2.0 controller, 2 Spartan3 2000 or VirtexIIpro 50, 10/100/1G ethernet PHY, Audio processing.
des00
сообщение Dec 30 2005, 06:31
Вечный ламер
Из: Томск
Пользователь №: 3 453
Цитата(keshu @ Dec 30 2005, 00:55) *
Hi,
Good day!
IMHO PCI-E is imposible to made base'd on Spartan 3 only, becouse as far as I know there is not SERDES block's. It can be maded based on Virtex2pro, Virtex4FX, or using special PCI-X bridge.
if you find outsorces developer for you project, i have great interest about video/audio processing.
I'd like to be in groop of developer's for dooing this project But I need time to think have i enouth time o not. sad.gif(
You can find me by forum's mail.
truly yours des00
Link
сообщение Dec 30 2005, 22:55
Пользователь №: 11 671
I designed 1x/2x/4x lanes PCI-Express controller on Virtex 2 Pro , it will be soon tested for compatibility with PCI-Express on PC motherboard.
keshu
сообщение Jan 2 2006, 08:24
des00,
True, you are right that I need to have a SerDes block (or PMA). For that I plan to make use of Philips x1 standalone PIPE compliant PHY ASIC.
link: can you share few of your project high lights with all of us.
Thanks,
Keshu
Link
сообщение Jan 4 2006, 06:39
Unfortunately I can't share sources of the designed core, i just can help in some questions while designing.
keshu
сообщение Jan 5 2006, 13:33
Hi Link,
I have following questions regarding design
1. What is the data path width? and the frequency of operation of your core?
2. Can you core which is actually configured as x4 work well if placed in x1 slot. That is will it behave as x1?
3. How have you implemented the LTSSM module?
4. How is scrambler/descrambler implemented?
5. What are the memory used in your core.
6. Do you core implements ASPM and PCI PM
7. You are putting your core on Virtex II, now Rocket IO does not support electrical Idle signal, becaon, lane to lane deskew. How have to taken care in your design abt this?
alex_k
сообщение Feb 9 2006, 14:56
Пользователь №: 3 067
To Link, my english is very bad that is why very sorry. May be you russian undersand better. I try.
Я так понял что вы разработали собственное ядро pci express для virtex2pro. У нашей конторы есть довольно давний и как я понимаю (я не руководитель) давольно серьезный интерес к такого рода весчи. В связи с чем вопрос если руководству стало бы моя инфа (относительно вас) интересна, можно ли с вами связаться на вопрос о покупке ... (сколько стоит фирменное я ориентировочно знаю и эта цена по понятным причинам совершенно не приемлема пока еще так не разбагатели). Сейчас разрабатываем спецсистемы в формате compact pci, но хотим освоить compact pci express. На конструктив (разъемы и т.д.) уже закуплена соответствующая спецификация. Нет ядра. Если вам это интересно отзовитесь (возможно мое руководство заитерисует и какая нибудь другие формы сотрудничества, пока излагаю только свои мысли точку зрения руководства не знаю, но знаю одно о pci express разговоры идут и довольно часто. Сейчас делаем систему compact pci так на ней уже заложены для других нужд разъемы compact pci express. Извиняюсь что так много написал, перерыв себе устроил...
Link
сообщение Feb 10 2006, 09:41
2 Keshu
1. 64 bit internal data path, frequency depends on lane number. 125 MHz for 4-lane, 62.5 MHz - for 2 lane, 31.25 - for 1 lane mode.
2. Yes.
3. 4. It's difficult to describe by words. Maybe you mean something concrete ?
5. V2Pro Dual Port BlockRAM components.
6. No
7. lane to lane deskew supported. The other does not.
Xilinx has it's logical core based on V2Pro, so they say it's compatible with PCI-Express specification.
2 alex_k
Ядру еще предстоит пройти проверку на совместимость стандарту, в том числе в режимах 1x, 4x, если удасться то 2x, и т.д. Соответственно модели в течении какого-то времени будут меняться. Пока ядро работает в режиме 1x. Если по прежнему интересует приобретение ядра, могу связаться с начальством по этому вопросу..
Сообщение отредактировал Link - Feb 10 2006, 09:47
alex_k
сообщение Feb 10 2006, 12:19
to Link.
Узнал у начальства - сказали не беспокоить, дело это не ближайшего будущего, надо текущую систему добить, так что извини за беспокойство...
RSS Текстовая версия Сейчас: 21st July 2025 - 08:08
Страница сгенерированна за 0.01397 секунд с 7
