> Прием биконов.
Jenya7
сообщение Mar 15 2015, 07:24
Пользователь №: 71 075
прибор шлет стандартный beacon header а потом 37 байт данных.
Я на стороне компьютера пытаюсь принять пакет.
CODE
private void buttonStart_Click(object sender, EventArgs e)
if (comboBoxInterfaces.SelectedIndex == -1)
MessageBox.Show("Select an Interface to capture the packets.", "WIFI Sniffer",
MessageBoxButtons.OK, MessageBoxIcon.Error);
return;
try
if (!continue_capturing)
//Start capturing the packets...
buttonStart.Text = "&Stop";
continue_capturing = true;
//For sniffing the socket to capture the packets has to be a raw socket, with the
//address family being of type internetwork, and protocol being IP
mainSocket = new Socket(AddressFamily.InterNetwork, SocketType.Raw, ProtocolType.IP);
//Bind the socket to the selected IP address
mainSocket.Bind(new IPEndPoint(IPAddress.Parse(comboBoxInterfaces.SelectedItem.ToString()), 0));
//Set the socket options
mainSocket.SetSocketOption(SocketOptionLevel.IP, //Applies only to IP packets
SocketOptionName.HeaderIncluded, //Set the include the header
true); //option to true
byte[] byTrue = new byte[4] { 1, 0, 0, 0 };
byte[] byOut = new byte[4] { 1, 0, 0, 0 }; //Capture outgoing packets
//Socket.IOControl is analogous to the WSAIoctl method of Winsock 2
mainSocket.IOControl(IOControlCode.ReceiveAll, //Equivalent to SIO_RCVALL constant
//of Winsock 2
byTrue,
byOut);
//Start receiving the packets asynchronously
mainSocket.BeginReceive(byte_data, 0, byte_data.Length, SocketFlags.None,
new AsyncCallback(OnReceive), null);
else
buttonStart.Text = "&Start";
continue_capturing = false;
//To stop capturing the packets close the socket
mainSocket.Close();
catch (Exception ex)
MessageBox.Show(ex.Message, "MJsniffer", MessageBoxButtons.OK, MessageBoxIcon.Error);
Но я вижу только TCP/UDP пакеты.
я так понимаю у меня сокет настроен неправильно. я пробовал менять SocketType и ProtocolType некоторые опции не возвращают никаких пакетов некоторые генерируют исключения. также менял SocketOptionLevel - тот же результат. может кто нибудь имел дело с приемом биконов?
RSS Текстовая версия Сейчас: 27th July 2025 - 02:50
Страница сгенерированна за 0.01329 секунд с 7
