> Проблема UART на Kinetis K70
Jenya7
сообщение Oct 13 2016, 13:35
Пользователь №: 71 075
странная проблема с UART.
сначала инициализация.
CODE
void UART_Init (UART_MemMapPtr uartch, int sysclk, int baud)
register uint16_t sbr, brfa;
uint8_t temp;
if (uartch == UART2_BASE_PTR)
PORTE_PCR16 = PORT_PCR_MUX(0x3);
PORTE_PCR17 = PORT_PCR_MUX(0x3);
SIM_SCGC4 |= SIM_SCGC4_UART2_MASK;
/* Make sure that the transmitter and receiver are disabled while we change settings. */
UART_C2_REG(uartch) &= ~(UART_C2_TE_MASK| UART_C2_RE_MASK );
/* Configure the UART for 8-bit mode, no parity */
UART_C1_REG(uartch) = 0; /* We need all default settings, so entire register is cleared */
/* Calculate baud settings */
sbr = (uint16_t)((sysclk*1000)/(baud * 16));
/* Save off the current value of the UARTx_BDH except for the SBR field */
temp = UART_BDH_REG(uartch) & ~(UART_BDH_SBR(0x1F));
UART_BDH_REG(uartch) = temp | UART_BDH_SBR(((sbr & 0x1F00) >> 8));
UART_BDL_REG(uartch) = (uint8_t)(sbr & UART_BDL_SBR_MASK);
/* Determine if a fractional divider is needed to get closer to the baud rate */
brfa = (((sysclk*32000)/(baud * 16)) - (sbr * 32));
/* Save off the current value of the UARTx_C4 register except for the BRFA field */
temp = UART_C4_REG(uartch) & ~(UART_C4_BRFA(0x1F));
UART_C4_REG(uartch) = temp | UART_C4_BRFA(brfa);
/* Enable receiver and transmitter */
UART_C2_REG(uartch) |= (UART_C2_TE_MASK | UART_C2_RE_MASK | UART_C2_RIE_MASK);
//errors – FOR DEBUG ONLY
UART_C3_REG(uartch) |= UART_C3_PEIE_MASK | UART_C3_FEIE_MASK | UART_C3_NEIE_MASK | UART_C3_ORIE_MASK;
NVIC_EnableIRQ(UART2_RX_TX_IRQn);
//FOR DEBUG ONLY
NVIC_EnableIRQ(UART2_ERR_IRQn );
void UART2_RX_TX_IRQHandler(void)
if ((UART_S1_REG(channel) & UART_S1_RDRF_MASK))
uint8_t chr = UART2->D;
UART_SendByte(UART2, chr);
void UART2_ERR_IRQHandler(void)
uint32_t st = UART2_BASE_PTR->S1;
так я посылаю строку на терминал
void UART_SendByte (UART_MemMapPtr channel, char ch)
   /* Wait until space is available in the FIFO */
   while(!(UART_S1_REG(channel) & UART_S1_TDRE_MASK));
   /* Send the character */
   UART_D_REG(channel) = (uint8_t)ch;
void UART_SendString(UART_MemMapPtr uartChannel, const char *p)
   while(*p)
      UART_SendByte(uartChannel, *p++);
в main.c
UART_Init (UART2, 60000, 115200);
UART_SendString(UART2, "HELLO EVERYBODY\0");
While (1)
на терминале вижу мусор. но если ввожу задержку
void UART_SendString(UART_MemMapPtr uartChannel, uint8_t *p)
    while(*p)
        //~100us
        for (int i = 0; i < 10000; i++)
            asm("NOP");
на терминале вижу коректную строку.
также если печатаю попадаю в UART2_ERR_IRQHandler с ошибкой Framing Error .
очень похоже на Framing Error вопрос откуда она береться.
Сообщение отредактировал Jenya7 - Oct 13 2016, 13:36
Kabdim
сообщение Oct 13 2016, 14:04
Из: Зеленоград
Пользователь №: 83 842
С процом незнаком, но... включения фифо нигде не вижу.
Jenya7
сообщение Oct 13 2016, 14:11
так я без фифо.
у них фифо дурацкий. нету отдельного флага на принятие чара и достижения заданного уровня фифо. один флаг на все и крутись как хочешь.
хотя...сейчас посмотрел. есть Receive Buffer/FIFO Empty Flag. можно и его использовать.
но по любому фифо выключен и не должен влиять на посылку.
Сообщение отредактировал Jenya7 - Oct 13 2016, 14:21
mantech
сообщение Oct 13 2016, 19:19
Из: Киров
Пользователь №: 73 143
Цитата(Jenya7 @ Oct 13 2016, 17:11) *
так я без фифо.
Может не в тему, с их кинетисами не работал, но в МХ серии уарт с выключенным фифо у меня отказывался нормально работать, пришлось включить и установить прерывание по 1 входящему символу.
Kabdim
сообщение Oct 14 2016, 08:19
Из: Зеленоград
Опять же вангование на основе чтения доки, но кмк там описано, что UART_S1_REG(channel) & UART_S1_TDRE_MASK флаг работает только с фифо. Такое ощущение что без фифо он всегда 1, вследствие чего в регистр пихается новое значение до отправки старого. Проверьте пожалуйста.
Jenya7
сообщение Oct 14 2016, 23:22
А вы знаете вы таки правы. Надо проверять Transmit Complete Flag (UART_S1_TC_MASK). Тогда все работает. Снимаю шляпу.
Kabdim
сообщение Oct 17 2016, 07:46
Из: Зеленоград
RSS Текстовая версия Сейчас: 19th July 2025 - 20:33
Страница сгенерированна за 0.01397 секунд с 7
