> сделать файл .hex в AVR-GCC
Диm
сообщение Jan 16 2007, 17:49
Пользователь №: 17 614
есть программка написанная в AVR-GCC in assembler mode надо из неё сделать только .нех файл
с уважением,Дмитрий
;  Copyright (C) 2000 Jesper Hansen <jesperh@telia.com>.
;  This program is free software; you can redistribute it and/or
;  modify it under the terms of the GNU General Public License
;  as published by the Free Software Foundation; either version 2
;  of the License, or (at your option) any later version.
;  This program is distributed in the hope that it will be useful,
;  but WITHOUT ANY WARRANTY; without even the implied warranty of
;  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
;  GNU General Public License for more details.
;  You should have received a copy of the GNU General Public License
;  along with this program; if not, write to the Free Software Foundation,
;  Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
;Description
; Poor-mans DDS Synthesizer
; Author = Jesper Hansen
; Target = AT90S2313
; Date   = 2001-02-15
; Code is written for use with AVR-GCC in assembler mode
; flag:  -x assembler-with-cpp
; PB0..7 = D/A Data out
; PD0        RXD
; PD1        TXD
; PD2..6    not used
; Output frequency (using 24 bit accumulator) :
;    f = deltaPhase * fClock/2^24
;   fClock is in this case the CPU clock divided by the
;    number of cycles to output the data ( 9 cycles )
;    f = r24/r25/r26 * (11059200/9)/16777216
;    f = r24/r25/r26 * 0.073242188
;    fMax (theoretical) = 0.5 * fClock
; start of code
#include <io2313.h>
    .section     .text
    .org 0
        rjmp    RESET
    .org 14
        rjmp    RX_COMPLETE_INT
; data tables
; force table to begin at 256 byte boundary
    .org 0x100
sine:    ; 256 step sinewave table
    .byte    0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,
0xae
    .byte    0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,
0xd8
    .byte    0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,
0xf5
    .byte    0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,
0xff
    .byte    0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,
0xf7
    .byte    0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,
0xdc
    .byte    0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,
0xb3
    .byte    0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,
0x83
    .byte    0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,
0x51
    .byte    0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,
0x27
    .byte    0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,
0x0a
    .byte    0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,
0x00
    .byte    0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,
0x08
    .byte    0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,
0x23
    .byte    0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,
0x4c
    .byte    0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,
0x7c
sawtooth:; 256 step sawtoothwave table
    .byte    0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0c,0x0d,0x0e,
0x0f
    .byte    0x10,0x11,0x12,0x13,0x14,0x15,0x16,0x17,0x18,0x19,0x1a,0x1b,0x1c,0x1d,0x1e,
0x1f
    .byte    0x20,0x21,0x22,0x23,0x24,0x25,0x26,0x27,0x28,0x29,0x2a,0x2b,0x2c,0x2d,0x2e,
0x2f
    .byte    0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x3b,0x3c,0x3d,0x3e,
0x3f
    .byte    0x40,0x41,0x42,0x43,0x44,0x45,0x46,0x47,0x48,0x49,0x4a,0x4b,0x4c,0x4d,0x4e,
0x4f
    .byte    0x50,0x51,0x52,0x53,0x54,0x55,0x56,0x57,0x58,0x59,0x5a,0x5b,0x5c,0x5d,0x5e,
0x5f
    .byte    0x60,0x61,0x62,0x63,0x64,0x65,0x66,0x67,0x68,0x69,0x6a,0x6b,0x6c,0x6d,0x6e,
0x6f
    .byte    0x70,0x71,0x72,0x73,0x74,0x75,0x76,0x77,0x78,0x79,0x7a,0x7b,0x7c,0x7d,0x7e,
0x7f
    .byte    0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,
0x8f
    .byte    0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,
0x9f
    .byte    0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9,0xaa,0xab,0xac,0xad,0xae,
0xaf
    .byte    0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9,0xba,0xbb,0xbc,0xbd,0xbe,
0xbf
    .byte    0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9,0xca,0xcb,0xcc,0xcd,0xce,
0xcf
    .byte    0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9,0xda,0xdb,0xdc,0xdd,0xde,
0xdf
    .byte    0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9,0xea,0xeb,0xec,0xed,0xee,
0xef
    .byte    0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfe,
0xff
triangle:; 256 step trianglewave table
    .byte    0x00,0x02,0x04,0x06,0x08,0x0a,0x0c,0x0e,0x10,0x12,0x14,0x16,0x18,0x1a,0x1c,
0x1e
    .byte    0x20,0x22,0x24,0x26,0x28,0x2a,0x2c,0x2e,0x30,0x32,0x34,0x36,0x38,0x3a,0x3c,
0x3e
    .byte    0x40,0x42,0x44,0x46,0x48,0x4a,0x4c,0x4e,0x50,0x52,0x54,0x56,0x58,0x5a,0x5c,
0x5e
    .byte    0x60,0x62,0x64,0x66,0x68,0x6a,0x6c,0x6e,0x70,0x72,0x74,0x76,0x78,0x7a,0x7c,
0x7e
    .byte    0x80,0x82,0x84,0x86,0x88,0x8a,0x8c,0x8e,0x90,0x92,0x94,0x96,0x98,0x9a,0x9c,
0x9e
    .byte    0xa0,0xa2,0xa4,0xa6,0xa8,0xaa,0xac,0xae,0xb0,0xb2,0xb4,0xb6,0xb8,0xba,0xbc,
0xbe
    .byte    0xc0,0xc2,0xc4,0xc6,0xc8,0xca,0xcc,0xce,0xd0,0xd2,0xd4,0xd6,0xd8,0xda,0xdc,
0xde
    .byte    0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xee,0xf0,0xf2,0xf4,0xf6,0xf8,0xfa,0xfc,
0xfe
    .byte    0xff,0xfd,0xfb,0xf9,0xf7,0xf5,0xf3,0xf1,0xef,0xef,0xeb,0xe9,0xe7,0xe5,0xe3,
0xe1
    .byte    0xdf,0xdd,0xdb,0xd9,0xd7,0xd5,0xd3,0xd1,0xcf,0xcf,0xcb,0xc9,0xc7,0xc5,0xc3,
0xc1
    .byte    0xbf,0xbd,0xbb,0xb9,0xb7,0xb5,0xb3,0xb1,0xaf,0xaf,0xab,0xa9,0xa7,0xa5,0xa3,
0xa1
    .byte    0x9f,0x9d,0x9b,0x99,0x97,0x95,0x93,0x91,0x8f,0x8f,0x8b,0x89,0x87,0x85,0x83,
0x81
    .byte    0x7f,0x7d,0x7b,0x79,0x77,0x75,0x73,0x71,0x6f,0x6f,0x6b,0x69,0x67,0x65,0x63,
0x61
    .byte    0x5f,0x5d,0x5b,0x59,0x57,0x55,0x53,0x51,0x4f,0x4f,0x4b,0x49,0x47,0x45,0x43,
0x41
    .byte    0x3f,0x3d,0x3b,0x39,0x37,0x35,0x33,0x31,0x2f,0x2f,0x2b,0x29,0x27,0x25,0x23,
0x21
    .byte    0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x11,0x0f,0x0f,0x0b,0x09,0x07,0x05,0x03,
0x01
square:    ; 256 step squarewave table
    .byte    0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00
0x00
0x00
0x00
0x00
0x00
0x00
0x00
    .byte    0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xff
0xff
0xff
0xff
0xff
0xff
0xff
0xff
; code
RESET:
        ldi        r16, RAMEND
        out        SPL, r16    ; setup stack pointer
        ldi        r16,0x05    ; set uart speed to 115.2 kbps
        out        UBRR,r16
        ldi        r16,0x98    ; enable RXint and enable tx/rx
        out        UCR,r16
        sei                    ; global enable interrupts
        ser        r16            ;
        out        DDRB,r16    ; set all PORTB bits as output
    ; set sinewave output as default
        ldi        r31,hi8(sine); setup Z pointer hi
        ldi        r30,lo8(sine); setup Z pointer lo
    ; clear accumulator
        ldi     r29,0x00    ; clear accumulator
        ldi     r28,0x00    ; clear accumulator
    ; setup adder registers
        ldi     r24,0x55    ; setup adder value
        ldi     r25,0x35    ; to 1 kHz
        ldi     r26,0x00    ;
; main loop
;    r28,r29,r30 is the phase accumulator
;      r24,r25,r26 is the adder value determining frequency
;     add value to accumulator
;    load byte from current table in ROM
;    output byte to port
;    repeat
LOOP1:
        add        r28,r24        ; 1
        adc        r29,r25        ; 1
        adc        r30,r26        ; 1
        lpm                    ; 3
        out        PORTB,r0    ; 1
        rjmp    LOOP1        ; 2 => 9 cycles
; communication functionality
; get char in r16
get_char:
        in         r16,USR        ; wait for a byte to be ready
        sbrs    r16,7        ; ready ?
        rjmp    get_char    ; no, wait some more
        in        r16,UDR        ; get the byte
        ret                    ; and return
; send char in r16
send_char:
        push    r16            ; save r16
send_c2:
        in         r16,USR        ; wait for the transmitter to be ready
        sbrs    r16,5        ; ready ?
        rjmp    send_c2        ; no, wait some more
        pop        r16            ; restore r16
        out        UDR,r16        ; send char
        ret                    ; ans return
; send the current frequency to the PC
; as a 5 byte sequence :
; 'F' folowed by a 32 bit phase accumulator value
send_data:
        push    r16            ; save r16
        ldi        r16,'F'        ; flag
        rcall    send_char
        clr        r16            ; zero byte for 32-bit compatibility
        rcall    send_char    ; MSB
        mov        r16,r26
        rcall    send_char    ; high add
        mov        r16,r25
        rcall    send_char    ; mid add
        mov        r16,r24
        rcall    send_char    ; low add
        ldi        r16,0x0a
        rcall    send_char    ; terminator
        pop        r16
        ret
; add 1 to the phase accumulator
up_one:
        adiw    r24,1
        clr        r23
        adc        r26,r23
        ret
; add 10 to the phase accumulator
up_ten:
        adiw    r24,10
        clr        r23
        adc        r26,r23
        ret
; add 100 to the phase accumulator
up_hundred:
        ldi        r23,0x64
        add        r24,r23
        clr        r23
        adc        r25,r23
        adc        r26,r23
        ret
; subtract 1 from the phase accumulator
down_one:
        sbiw    r24,1
        clr        r23
        sbc        r26,r23
        ret
; subtract 10 from the phase accumulator
down_ten:
        sbiw    r24,10
        clr        r23
        sbc        r26,r23
        ret
; subtract 100 from the phase accumulator
down_hundred:
        clr        r23
        subi    r24,0x64
        sbc        r25,r23
        sbc        r26,r23
        ret
; read in 4 characters from the serial link
read_4:
        rcall    get_char    ; read and ignore bits 32..24
        rcall    get_char    ; read bits 23..16
        mov        r26,r16
        rcall    get_char    ; read bits 15..8
        mov        r25,r16
        rcall    get_char    ; read bits 7..0
        mov        r24,r16
        ret
; Interrupt routine for incoming bytes on the RS232 link
RX_COMPLETE_INT:
        push    r16
        in         r16,UDR
        cpi        r16,'+'            ; up one
        brne    tx_2
        rcall    up_one
        rjmp    tx_exit
tx_2:
        cpi        r16,'u'            ; up ten
        brne    tx_3
        rcall    up_ten
        rjmp    tx_exit
tx_3:
        cpi        r16,'U'            ; up hundred
        brne    tx_4
        rcall    up_hundred
        rjmp    tx_exit
tx_4:
        cpi        r16,'-'            ; down one
        brne    tx_5
        rcall    down_one
        rjmp    tx_exit
tx_5:
        cpi        r16,'d'            ; down ten
        brne    tx_6
        rcall    down_ten
        rjmp    tx_exit
tx_6:
        cpi        r16,'D'            ; down hundred
        brne    tx_7
        rcall    down_hundred
        rjmp    tx_exit
tx_7:
        cpi        r16,'s'            ; frequency setting
        brne    tx_8
        rcall    read_4
        rjmp    tx_exit
tx_8:
        cpi        r16,'?'            ; just force a reply
        brne    tx_9
        rjmp    tx_exit
tx_9:
        cpi        r16,'1'            ; request sinewave output
        brne    tx_10
        ldi        r31,hi8(sine)    ; setup Z pointer hi
        ldi        r30,lo8(sine)    ; setup Z pointer lo
        rjmp    tx_exit
tx_10:
        cpi        r16,'2'            ; request sawtooth output
        brne    tx_11
        ldi        r31,hi8(sawtooth); setup Z pointer hi
        ldi        r30,lo8(sawtooth); setup Z pointer lo
        rjmp    tx_exit
tx_11:
        cpi        r16,'3'            ; request triangle output
        brne    tx_12
        ldi        r31,hi8(triangle); setup Z pointer hi
        ldi        r30,lo8(triangle); setup Z pointer lo
        rjmp    tx_exit
tx_12:
        cpi        r16,'4'            ; request squarewave output
        brne    tx_13
        ldi        r31,hi8(square)    ; setup Z pointer hi
        ldi        r30,lo8(square)    ; setup Z pointer lo
        rjmp    tx_exit
; unknown command, just ignore it
tx_13:
; always reply with the current frequency
tx_exit:
        rcall    send_data
        pop        r16
        reti
; end of file
beer_warrior
сообщение Jan 16 2007, 18:24
Из: Kiev, UA
Пользователь №: 9 380
Во-первых она прекрасно собереться в любом ассемблере, а во-вторых кто будет выдергивать оттуда остатки html-кода?
Вони шукають те, чого нема,
Щоб довести, що його не існує.
defunct
сообщение Jan 16 2007, 19:18
кекс
Пользователь №: 12 326
#include "2313def.inc"
.section "Text" поменять на .CSEG
все строки
.byte & nbsp;0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,
0xdc
поменять на
.db 0xf6, ...
и можно компилить в AVR студии
Диm
сообщение Jan 17 2007, 08:49
спасибо defunct!!!
RSS Текстовая версия Сейчас: 28th July 2025 - 07:45
Страница сгенерированна за 0.01425 секунд с 7
