SCAN-CHAINS |
Jan 14 2008, 10:04
Из: ARM
Пользователь №: 10 424
Цитата(-=Vitaly=- @ Jan 14 2008, 11:25)  Здравствуйте!
Хочу сгенерировать скан-цепочки типа multiplexed_flip_flip в DC. Есть 2 вопросика.
1. У меня в дизайне есть клок CLK, он же будет использоваться для скан-цепочки. это опция -clock_mixing no_mux?
2. На что влияет опция -methodology например full_scan?
Спасибо! 1. У меня в дизайне есть клок CLK, он же будет использоваться для скан-цепочки. это опция -clock_mixing no_mux? -clock_mixing don't have option "no_mux" the right is no_mix. no_mix is the default: and it means that all cells must be clocked by the same edge of the same clock. You have one clock if all triggers are working with the same egdes you have no problem. Otherwies if you want both types of triggers (rise edge and fall edge) to be included in scan chain use "-clock_mixing mix_edges". 2. На что влияет опция -methodology например full_scan? This is from user guide: In the full-scan methodology, DFT Compiler replaces all sequential cells in your design with their scannable equivalents during scan insertion. If a sequential cell cannot be made scannable because of test design rule violations or because you have explicitly excluded the cell from the scan chain, DFT Compiler classifies the cell as a black box sequential cell during test design rule checking. Black box sequential cells lower fault coverage results. See “Scan Design Techniques” for more information on sequential cell classifications. Because it is a more predictable methodology, full scan typically provides higher fault coverage in a shorter period of time than partial scan. Full scan also provides improved diagnostic capabilities compared to partial scan. Because full scan substitutes scannable equivalents for all sequential cells, however, it increases design area and decreases design performance. Integration with synthesis minimizes the area and performance impact of full scan. In most cases, performance can be maintained in a full-scan design, but at the cost of additional area. Maybe it will help you.
G.
Jan 14 2008, 12:06
Пользователь №: 19 991
Делюсь простеньким скриптом, может кому надо: Код #Top-level synthesis script with adding scan chain #Reads in core and lower level designs, #compiles, adds scan. #read lower-level designs remove_design -all set TOP_LEVEL div
analyze -f verilog ./src/$TOP_LEVEL.v elaborate $TOP_LEVEL
link create_clock SCLK -period 60 -waveform {0 50}
#Prevent changes to pads #set_dont_touch BDR* #set_dont_touch IBUF* #set scan parameters & check test rules
# Use if exist scan-chain set test_default_scan_style multiplexed_flip_flop set_scan_configuration -style multiplexed_flip_flop -clock_mixing no_mix -chain_count 1 set_dft_signal -view existing_dft -type ScanClock -port SCLK -timing {45 55} set_dft_signal -view existing_dft -type reset -port RSTB -active_state 0 set_dft_signal -view existing_dft -type ScanDataIn -port SCAN_IN set_dft_signal -view existing_dft -type ScanDataOut -port SCAN_OUT set_dft_signal -view existing_dft -type ScanEnable -port SCAN_EN -active_state 1 create_test_protocol dft_drc
compile_ultra -scan preview_dft #=============================================================================== =================================
# Use for automatic scan-chain generation #set test_default_scan_style multiplexed_flip_flop #set_scan_configuration -style multiplexed_flip_flop -clock_mixing no_mix -chain_count 1 #set_dft_signal -view existing_dft -type ScanClock -port SCLK -timing {45 55} #set_dft_signal -view existing_dft -type reset -port RSTB -active_state 0 #set_dft_signal -view spec -type ScanDataIn -port SCAN_IN #set_dft_signal -view spec -type ScanDataOut -port SCAN_OUT #set_dft_signal -view existing_dft -type ScanEnable -port SCAN_EN -active_state 1 #create_test_protocol #dft_drc
#compile_ultra -scan #preview_dft #insert_dft
change_names -rules verilog -hier write -hier -format verilog -output ./synth/dc_$TOP_LEVEL.v
Jan 15 2008, 09:31
Из: ARM
Цитата(-=Vitaly=- @ Jan 14 2008, 14:35)  Спасибо, помогло. А если в исходном верилоге заложена ручками скан-цепочка надо ли указывать синтезатору что она есть или нет? Если да, то чем это чревато.  да, чтобы скан-цепочка была опознана DFTC исползуй эти команды: set_scan_state scan_existing set_scan_path
G.
Jan 15 2008, 14:15
Цитата(grigorik @ Jan 15 2008, 11:31)  да, чтобы скан-цепочка была опознана DFTC исползуй эти команды:
set_scan_state scan_existing set_scan_path Спасибо, а в каком месте их использовать. У меня при попытке написать Код set_dft_signal -view existing_dft -type ScanDataIn -port SCAN_IN set_scan_path -scan_data_in SCAN_IN my_chain DFT сообщает, что порт SCAN_IN is not type of ScanDataIn в чем проблема? при это при команде report_dft_signal он показывает табличку где этот сигнал есть и ему присвоен тип ScanDataIn И можно ли до Тетрамакса оценить покрытие тестом в DC?
Сообщение отредактировал -=Vitaly=- - Jan 15 2008, 14:47
Jan 15 2008, 15:02
Из: ARM
Цитата(-=Vitaly=- @ Jan 15 2008, 18:15)  Спасибо, а в каком месте их использовать. У меня при попытке написать Код set_dft_signal -view existing_dft -type ScanDataIn -port SCAN_IN set_scan_path -scan_data_in SCAN_IN my_chain DFT сообщает, что порт SCAN_IN is not type of ScanDataIn в чем проблема? при это при команде report_dft_signal он показывает табличку где этот сигнал есть и ему присвоен тип ScanDataIn И можно ли до Тетрамакса оценить покрытие тестом в DC? после read_verilog, constraints не нужно set_dft_signal -view existing_dft -type ScanDataIn -port SCAN_IN попробуй так set_scan_path my_chain \ -view existing \ -scan_data_in [get_ports SCAN_IN] \ -scan_data_out [get_ports SCAN_OUT] \ -scan_enable [get_ports SCAN_EN \ -infer_dft_signals create_test_protocol -infer_clock -infer_async report_dft_signal -view existing оценить покрытие тестом в DC dft_drc -coverage_estimate
G.
Jan 15 2008, 16:12
Цитата(grigorik @ Jan 15 2008, 17:02)  после read_verilog, constraints
оценить покрытие тестом в DC dft_drc -coverage_estimate Огромное спасибо! Заработало, правда синтезит странно все обычные флопы поменяло на флопы со сканом и повесило на вход SE этих флопов логический 0  , а мой скан енейбл SCAN_EN замешало на комбинационную логику. Это проблема в коде или в скрипте? Код /*Functional description*/ /*disabled reset in SCAN mode*/ wire rb=RSTB | SCAN_EN;
/*Create logic finding */ always@(divisor) begin max=0; for(i=7;i>0;i=i-1) if(divisor[i]==1'b1 && i>max) max=i; end wire [7:0] tmp_div=divisor<<(7-max); /*Division*/ always@(negedge rb or posedge SCLK) begin if(!rb) begin cur_divident<=8'd0; cur_divisor<=8'd0; bit_count<=3'd0; result<=7'd0; end else casex(SCAN_EN) 1'b1:begin cur_divident<={cur_divident[7:0],SCAN_IN}; cur_divisor<={cur_divisor[6:0],cur_divident[8]}; bit_count<={bit_count[1:0],cur_divisor[7]}; result<={result[5:0],bit_count[2]}; end 1'b0:if(we) begin cur_divident<=9'd255-tmp_div; cur_divisor<=tmp_div>>1; bit_count<=8-max; result<=7'd0; end else if (bit_count!=0) begin if (cur_divident[8]==1'b0) begin cur_divident <= cur_divident-cur_divisor; result[bit_count-1'b1]<=1'b1; end else begin result[bit_count-1'b1]<=1'b0; cur_divident <= cur_divident+cur_divisor; end bit_count<=bit_count-1; cur_divisor<= cur_divisor>>1; end default: cur_divident<={8{1'bx}}; endcase end assign SCAN_OUT=result[6];
endmodule
Jan 16 2008, 09:35
Из: ARM
думаю из-за этой части
G.
Jan 16 2008, 09:41
Цитата(grigorik @ Jan 16 2008, 11:35)  думаю из-за этой части casex(SCAN_EN) 1'b1:begin cur_divident<={cur_divident[7:0],SCAN_IN}; cur_divisor<={cur_divisor[6:0],cur_divident[8]}; bit_count<={bit_count[1:0],cur_divisor[7]}; result<={result[5:0],bit_count[2]}; end Спасибо, так а как иначе сделать скан-цепочку вручную? Каденсе понимает такую конструкцию, я говорю синтезировать с опцией -don't scan и он заменяет флопики на скан флопики, правда почему-то все кроме 2х (мистика)...
Сообщение отредактировал -=Vitaly=- - Jan 16 2008, 10:00
Jan 16 2008, 14:16
Все вроде разобрался для дизайна который выше я сделал 2 скрипта Код #Top-level synthesis script with adding scan chain remove_design -all set TOP_LEVEL div
# Use if exist scan-chain set_dft_signal -view existing_dft -type ScanClock -port SCLK -timing {45 55} set_dft_signal -view existing_dft -type reset -port RSTB -active_state 0 set_dft_signal -view existing_dft -type ScanEnable -port SCAN_EN -active_state 1 set_scan_parh my_chain -view existing -scan_master_clock SCLK -scan_enable SCAN_EN / -scan_data_in SCAN_IN -scan_data_out -SCAN_OUT -infer_dft_signals create_test_protocol -infer_clock -infer_async
report_dft_signal -view existing dft_drc
compile_ultra preview_dft
dft_drc -coverage estimate report_scan_path Этот для случая когда у вас ручная скан-цепочка, например как в моем примере. При синтезе у меня получились обычные флопы и логика которая реализует скан-цепочку, зато порядок регистров в скан-цепочке свой - это плюс, но зато больше площади занимает. Главное не написать сompile_ultra -scan, т.к синтезатор заменяет все флопы на скан-флопы и вешает на входа SE этих регистров 0, т.е использует их как обычные регистры. Теперь второй скрипт для автоматической генерации из обычного верилога без всяких заморочек. Когда в тексте отсутсвует ручное задание скан-цепочек. Код casex(SCAN_EN) 1'b1:begin cur_divident<={cur_divident[7:0],SCAN_IN}; cur_divisor<={cur_divisor[6:0],cur_divident[8]}; bit_count<={bit_count[1:0],cur_divisor[7]}; result<={result[5:0],bit_count[2]}; end Код #Top-level synthesis script with adding scan chain remove_design -all set TOP_LEVEL div
# Use for automatic scan-chain generation set test_default_scan_style multiplexed_flip_flop set_scan_configuration -style multiplexed_flip_flop -clock_mixing no_mix -chain_count 1 set_dft_signal -view existing_dft -type ScanClock -port SCLK -timing {45 55} set_dft_signal -view existing_dft -type reset -port RSTB -active_state 0 set_dft_signal -view spec -type ScanDataIn -port SCAN_IN set_dft_signal -view spec -type ScanDataOut -port SCAN_OUT set_dft_signal -view existing_dft -type ScanEnable -port SCAN_EN -active_state 1 create_test_protocol dft_drc
compile_ultra -scan preview_dft insert_dft
dft_drc -coverage estimate report_scan_path В этом случае синтезатор автоматически заменяет все флопики на флопики со сканом, на входа всех скан-флопов SE вешает сигнал SCAN_EN. Причем больше этот сигнал никуда не заходит в отличие от предыдущего варианта где он был замешан с логикой. Порядок в скан-цепочке такой как синтезатору угодно. Схема получается меньше по размеру и покрытие тестом немного выше. Огромное спасибо grigorik  . Единственное что так и осталось загадкой это как написать верилог и скрипт, чтобы был свой порядок в скан-цепочке и скан-флопы в одно и то же время. И еще может кто-то знает как посадить порт TE гейтед-клок елемента на SCAN_EN.
Сообщение отредактировал -=Vitaly=- - Jan 16 2008, 15:03
Jan 16 2008, 19:58
Из: ARM
Огромное спасибо grigorik  . Единственное что так и осталось загадкой это как написать верилог и скрипт, чтобы был свой порядок в скан-цепочке и скан-флопы в одно и то же время. И еще может кто-то знает как посадить порт TE гейтед-клок елемента на SCAN_EN. [/quote] пожалуйста!
G.
