> прерывание pwm dspic30f2023
pipka
сообщение Oct 16 2009, 07:10
Пользователь №: 29 465
Здравствуйте, помогите разобраться почему не срабатывает прерывание ШИМ.
код(MPLAB C30):
#include <p30f2023.h>
#include "functions.h"
_FOSCSEL(FRC_PLL); //FRC with PLL
_FOSC(CSW_FSCM_OFF & FRC_HI_RANGE & OSC2_IO & HS_EC_DIS); //Clock switching is disabled,FCKSM is disabled
_FWDT(FWDTEN_OFF); //Watchdog timer off
_FPOR(PWRT_OFF); //Power-on Reset
_FICD(ICS_PGD);
int main(void)
init();
while(1)
void __attribute__((interrupt,no_auto_psv)) _PWM1Interrupt(void)
IFS1bits.PWM1IF=0;
asm volatile ("nop");
void init (void)
OSCTUNbits.TUN=0b0000;
TRISA=0b0000000000000000;
TRISB=0b0000000000000000;
TRISD=0b0000000000000000;
TRISE=0b0000000000000000;
TRISF=0b0000000000000000;
PORTA=0b0000000000000000;
PORTB=0b0000000000000000;
PORTD=0b0000000000000010;
PORTE=0b0000000000000000;
PORTF=0b0000000000000000;
LATA=0b0000000000000000;
LATB=0b0000000000000000;
LATD=0b0000000000000010;
LATE=0b0000000000000000;
LATF=0b0000000000000000;
// PWM1 //
PTCONbits.PTEN=0b00;
PTCONbits.PTSIDL=0b00;
PTCONbits.SESTAT=0b00;
PTCONbits.SEIEN=0;
PTCONbits.EIPU=0b00;
PTCONbits.SYNCPOL=0b00;
PTCONbits.SYNCOEN=0b00;
PTCONbits.SYNCEN=0;
PTCONbits.SYNCSRC=0b00;
PTCONbits.SEVTPS=0b0000;
PTPER=30960;
PDC1=15480;
PWMCON1bits.FLTSTAT=0b00;
PWMCON1bits.CLSTAT=0b00;
PWMCON1bits.TRGSTAT=0b00;
PWMCON1bits.FLTIEN=0b00;
PWMCON1bits.CLIEN=0b00;
PWMCON1bits.TRGIEN=0;
PWMCON1bits.ITB=0b00;
PWMCON1bits.MDCS=0b00;
PWMCON1bits.DTC=0b10;
PWMCON1bits.XPRES=0b00;
PWMCON1bits.IUE=0b00;
FCLCON1bits.FLTMOD=0b11;
FCLCON1bits.CLMODE=0;
DTR1=0b000000000000;
IOCON1bits.PENH=1;
IOCON1bits.PENL=1;
IOCON1bits.POLH=1;
IOCON1bits.POLL=1;
IOCON1bits.PMOD=0b00;
IOCON1bits.OVRENH=0;
IOCON1bits.OVRENL=0;
PTCONbits.PTEN=1;
//настройка прерываний//
INTCON1bits.NSTDIS=1;
SRbits.IPL=0;
IPC4bits.PWM1IP=6; //interrupt priority for PWM
IFS1bits.PWM1IF=0;
IEC1bits.PWM1IE=1;
Vlad27
сообщение Oct 16 2009, 12:25
Из: Полоцк Беларусь
Пользователь №: 7 227
По какому событию ждете прерывания?
pipka
сообщение Oct 16 2009, 12:41
Прерывание жду по обнулению регистра PTMR после достижения значения, записанного в регистр PTPER.
Vlad27
сообщение Oct 16 2009, 13:54
Из: Полоцк Беларусь
Как я понял из дейтшита, источником внутреннего прерывания может быть Special Event Comparison Register
для primary time base и триггеры для каждого из PWM модулей. Т.е., надо разрешить прерывания по
триггеру (TRIGIEN=1) и прописать значение сравнения в TRIG1 в данном случае.
pipka
сообщение Oct 19 2009, 05:40
Как я понял это триггеры для запуска АЦП.
"The PWM module also features an additional ADC trigger
output for each PWM generator. This feature is very
useful when the PWM generators are operating in
Independent Time Base mode."
pipka
сообщение Oct 19 2009, 07:10
RSS Текстовая версия Сейчас: 28th July 2025 - 14:22
