> не компилится под IAR 6.21, STboard
MK2
сообщение Oct 1 2011, 11:29
Пользователь №: 60 535
Установил последний IAR 6.21. Перестало все компилироваться. Даже стандартные примеры из StdPeriph_Lib
пишет:
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __get_PSP(void)" (declared at line 52 of "E:\PRODJECT\Embedded Workbench 6.0\arm\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1084
inc\c\intrinsics.h")
Error[Pe147]: declaration is incompatible with "__interwork __softfp void __set_PSP(unsigned long)" (declared at line 53 of "E:\PRODJECT\Embedded Workbench 6.0\arm\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1094
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __get_MSP(void)" (declared at line 50 of "E:\PRODJECT\Embedded Workbench 6.0\arm\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1104
Error[Pe147]: declaration is incompatible with "__interwork __softfp void __set_MSP(unsigned long)" (declared at line 51 of "E:\PRODJECT\Embedded Workbench 6.0\arm\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1114
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __REV16(unsigned long)" (declared at line 173 of "E:\PRODJECT\Embedded Workbench  E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1124
6.0\arm\inc\c\intrinsics.h")
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __RBIT(unsigned long)" (declared at line 174 of "E:\PRODJECT\Embedded Workbench 6.0\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1134
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __STREXB(unsigned char, unsigned char *)" (declared at line 181 of "E:\PRODJECT\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1175
Embedded Workbench 6.0\arm\inc\c\intrinsics.h")
Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __STREXH(unsigned short, unsigned short *)" (declared at line 182 of "E:\PRODJECT\ E:\My Document\STM32F207\stm32vldiscovery_package\Libraries\CMSIS\CM3\CoreSupport\core_cm3.h 1186
Error while running C/C++ Compiler
startup_stm32f10x_md_vl.s
stm32f10x_flash.c
.................................. ну и остальное в таком же духе что то ему CMSISкие файлы не нравятся
облазил всю справку но нигде не нашел эту ошибку "Error[Pe147]: declaration is incompatible with"
может надо что-то в настройках проекта поменять?
aba
сообщение Oct 1 2011, 13:32
Пользователь №: 66 698
Слишком мало информации, "перестало всё компилется" из этого ничего не понятно. Под какой процессор проект и компилился ли он раньше в другой среде?
Судя по названию путей - это демопример для STM32VLDiscovery. Тут у вас банально не совпадение типов, там в описании ошибки написано в каком файле впервые встречается такая декларация. Приведите типы в обеих файлах к одинаковому виду и будет вам счастие.
MK2
сообщение Oct 1 2011, 16:11
раньше юзал IAR for ARM v. 6.10 32K Kickstart Edition все нормально было, плата дискавери но еще F207 через неё прошиваю
типы и вправду не совпадают в файле core_cm3.h объявление:
extern uint32_t __get_PSP(void);
extern void __set_PSP(uint32_t topOfProcStack);
extern uint32_t __get_MSP(void);
extern void __set_MSP(uint32_t topOfMainStack);
extern uint32_t __REV16(uint16_t value);......................
а в файле Embedded Workbench 6.0\arm\inc\c\intrinsics.h
__intrinsic unsigned long __get_PSR( void );
__intrinsic unsigned long __get_IPSR( void );
__intrinsic unsigned long __get_MSP( void );
__intrinsic void          __set_MSP( unsigned long );
__intrinsic unsigned long __get_PSP( void );
__intrinsic void          __set_PSP( unsigned long );
__intrinsic unsigned long __get_PRIMASK( void );
__intrinsic void          __set_PRIMASK( unsigned long );
__intrinsic unsigned long __get_CONTROL( void );
__intrinsic void          __set_CONTROL( unsigned long );
в иаре есть встроенные примеры StdPeriph_Lib. открыл их все компилируется но файл core_cm3.h у них совсем другой, отличается что идет в комплекте с StdPeriph_Lib
MK2
сообщение Oct 6 2011, 14:52
Хреновый это какой-то IAR, откачюсь обратно на 6.10
На другой машине такая же история, так что хорошо подумайте прежде чем его ставить 6.21
Сообщение отредактировал MK2 - Oct 6 2011, 14:53
Xenia
сообщение Oct 6 2011, 14:58
Группа: Модератор FTP
Пользователь №: 35 237
Возможно, что последняя версия 6.21.4 окажется лучше - в ней исправляли какие-то ошибки версии 6.21.1.
Tran
сообщение Oct 6 2011, 18:01
Пользователь №: 70
Это действительно различия в интринсиках. Я в своё время не поленился, исправил uint32_t на unsigned long, всё скомпилилось, но не заработало sm.gif
Настоящее чревато будущим.
pesicot
сообщение Oct 8 2011, 20:41
Пользователь №: 67 619
Столкнулся с такой же проблемой.
Release note for IAR ARM 6.21
A special note on CMSIS integration:
If your application source code include CMSIS header files explicitly, then you should not check the Use CMSIS check-box Project>Options...>General Options>Library Configuration>Use CMSIS. Some of the Cortex-M application examples includes CMSIS source files explicitly, do not check the said check-box in these projects.
Нужно:
  • Установить Project>Options...>General Options>Library Configuration>Use CMSIS
  • Удалить из проекти и из его папки файлы core_cm3.c и core_cm3.h.
Во вложении рабочий проект для STM32-Discovery под IAR ARM 6.21
Danis
сообщение Oct 18 2011, 06:12
Twilight Zone
Из: Челябинск
Пользователь №: 44 990
Тоже было такое: Error[Pe147]: declaration is incompatible with "__interwork __softfp unsigned long __get_PSP(void)"
устранил:
клик
Magic Friend
MK2
сообщение Oct 19 2011, 19:44
Спасибо большое жалко только уже снес ИАР, пришлось потом даже 6.10 потом удалить, его походу 6.2 подкосил((. А ведь ставил в настройках Use , только файлы CMSIS не додумался удалить))
Жалко IAR думал поюзать поставляемы с ним стеки, но как-то уже на кейловские RL-ARM прижились )
RSS Текстовая версия Сейчас: 24th July 2025 - 09:29
Страница сгенерированна за 0.01703 секунд с 7
