Подсчет СRC |
Nov 17 2005, 06:19
Познающий...
Из: г. Иркутск
Пользователь №: 8 125
У меня тут правда на Си пример подсчета CRC8, но он очень простой и я думаю его не трудно перевести на ассембелр. Сам давно не работал с асмом. Если Вы не знаете Си, то прошу меня извинить, другого у меня не было. Код const unsigned char crc_table[256] = { 0x00,0x5E,0xBC,0xE2,0x61,0x3F,0xDD,0x83,0xC2,0x9C,0x7E,0x20,0xA3,0xFD,0x1F,0x41, 0x9D,0xC3,0x21,0x7F,0xFC,0xA2,0x40,0x1E,0x5F,0x01,0xE3,0xBD,0x3E,0x60,0x82,0xDC, 0x23,0x7D,0x9F,0xC1,0x42,0x1C,0xFE,0xA0,0xE1,0xBF,0x5D,0x03,0x80,0xDE,0x3C,0x62, 0xBE,0xE0,0x02,0x5C,0xDF,0x81,0x63,0x3D,0x7C,0x22,0xC0,0x9E,0x1D,0x43,0xA1,0xFF, 0x46,0x18,0xFA,0xA4,0x27,0x79,0x9B,0xC5,0x84,0xDA,0x38,0x66,0xE5,0xBB,0x59,0x07, 0xDB,0x85,0x67,0x39,0xBA,0xE4,0x06,0x58,0x19,0x47,0xA5,0xFB,0x78,0x26,0xC4,0x9A, 0x65,0x3B,0xD9,0x87,0x04,0x5A,0xB8,0xE6,0xA7,0xF9,0x1B,0x45,0xC6,0x98,0x7A,0x24, 0xF8,0xA6,0x44,0x1A,0x99,0xC7,0x25,0x7B,0x3A,0x64,0x86,0xD8,0x5B,0x05,0xE7,0xB9, 0x8C,0xD2,0x30,0x6E,0xED,0xB3,0x51,0x0F,0x4E,0x10,0xF2,0xAC,0x2F,0x71,0x93,0xCD, 0x11,0x4F,0xAD,0xF3,0x70,0x2E,0xCC,0x92,0xD3,0x8D,0x6F,0x31,0xB2,0xEC,0x0E,0x50, 0xAF,0xF1,0x13,0x4D,0xCE,0x90,0x72,0x2C,0x6D,0x33,0xD1,0x8F,0x0C,0x52,0xB0,0xEE, 0x32,0x6C,0x8E,0xD0,0x53,0x0D,0xEF,0xB1,0xF0,0xAE,0x4C,0x12,0x91,0xCF,0x2D,0x73, 0xCA,0x94,0x76,0x28,0xAB,0xF5,0x17,0x49,0x08,0x56,0xB4,0xEA,0x69,0x37,0xD5,0x8B, 0x57,0x09,0xEB,0xB5,0x36,0x68,0x8A,0xD4,0x95,0xCB,0x29,0x77,0xF4,0xAA,0x48,0x16, 0xE9,0xB7,0x55,0x0B,0x88,0xD6,0x34,0x6A,0x2B,0x75,0x97,0xC9,0x4A,0x14,0xF6,0xA8, 0x74,0x2A,0xC8,0x96,0x15,0x4B,0xA9,0xF7,0xB6,0xE8,0x0A,0x54,0xD7,0x89,0x6B,0x35} ;
//Вычисляет и возвращает crc8 //byte - очередной байт, для которого считаем контрольныю сумму //crc8 - байт самой контрольной суммы void do_crc_8(unsigned char byte, unsigned char *crc8) { *crc8=crc_table[(*crc8^byte)]; }
Выбор.
Nov 17 2005, 06:37
Познающий...
Из: г. Иркутск
Цитата А можно просто в двух словах изложить алгоритм подсчета, как он делается... К сожалению я не знаю алгоритм, сам выдрал пример из инета. На всякий случай даю дизассемблированный текст, то что для меня создал IAR: Код crc_table: \ 00000000 5E00E2BC3F61 DB 0, 94, 188, 226, 97, 63, 221, 131, 194, 156, 126, 32, 163, 253, 31 \ 83DD9CC2207E \ FDA31F \ 0000000F 9D4121C3FC7F DB 65, 157, 195, 33, 127, 252, 162, 64, 30, 95, 1, 227, 189, 62, 96 \ 40A25F1EE301 \ 3EBD60 \ 0000001E DC827D23C19F DB 130, 220, 35, 125, 159, 193, 66, 28, 254, 160, 225, 191, 93, 3, 128 \ 1C42A0FEBFE1 \ 035D80 \ 0000002D 3CDEBE6202E0 DB 222, 60, 98, 190, 224, 2, 92, 223, 129, 99, 61, 124, 34, 192, 158 \ DF5C63817C3D \ C0229E \ 0000003C 431DFFA11846 DB 29, 67, 161, 255, 70, 24, 250, 164, 39, 121, 155, 197, 132, 218, 56 \ A4FA7927C59B \ DA8438 \ 0000004B E56659BBDB07 DB 102, 229, 187, 89, 7, 219, 133, 103, 57, 186, 228, 6, 88, 25, 71 \ 6785BA3906E4 \ 195847 \ 0000005A FBA526789AC4 DB 165, 251, 120, 38, 196, 154, 101, 59, 217, 135, 4, 90, 184, 230, 167 \ 3B6587D95A04 \ E6B8A7 \ 00000069 1BF9C6457A98 DB 249, 27, 69, 198, 152, 122, 36, 248, 166, 68, 26, 153, 199, 37, 123 \ F82444A6991A \ 25C77B \ 00000078 643AD886055B DB 58, 100, 134, 216, 91, 5, 231, 185, 140, 210, 48, 110, 237, 179, 81 \ B9E7D28C6E30 \ B3ED51 \ 00000087 4E0FF2102FAC DB 15, 78, 16, 242, 172, 47, 113, 147, 205, 17, 79, 173, 243, 112, 46 \ 937111CDAD4F \ 70F32E \ 00000096 92CC8DD3316F DB 204, 146, 211, 141, 111, 49, 178, 236, 14, 80, 175, 241, 19, 77, 206 \ ECB2500EF1AF \ 4D13CE \ 000000A5 72906D2CD133 DB 144, 114, 44, 109, 51, 209, 143, 12, 82, 176, 238, 50, 108, 142, 208 \ 0C8FB05232EE \ 8E6CD0 \ 000000B4 0D53B1EFAEF0 DB 83, 13, 239, 177, 240, 174, 76, 18, 145, 207, 45, 115, 202, 148, 118 \ 124CCF91732D \ 94CA76 \ 000000C3 AB2817F50849 DB 40, 171, 245, 23, 73, 8, 86, 180, 234, 105, 55, 213, 139, 87, 9, 235 \ B45669EAD537 \ 578BEB09 \ 000000D3 36B58A6895D4 DB 181, 54, 104, 138, 212, 149, 203, 41, 119, 244, 170, 72, 22, 233 \ 29CBF47748AA \ E916 \ 000000E1 55B7880B34D6 DB 183, 85, 11, 136, 214, 52, 106, 43, 117, 151, 201, 74, 20, 246, 168 \ 2B6A97754AC9 \ F614A8 \ 000000F0 2A7496C84B15 DB 116, 42, 200, 150, 21, 75, 169, 247, 182, 232, 10, 84, 215, 137, 107 \ F7A9E8B6540A \ 89D76B \ 000000FF 35 DB 53 12 0x00,0x5E,0xBC,0xE2,0x61,0x3F,0xDD,0x83,0xC2,0x9C,0x7E,0x20,0xA3,0xFD,0x1F, 0x41, 13 0x9D,0xC3,0x21,0x7F,0xFC,0xA2,0x40,0x1E,0x5F,0x01,0xE3,0xBD,0x3E,0x60,0x82, 0xDC, 14 0x23,0x7D,0x9F,0xC1,0x42,0x1C,0xFE,0xA0,0xE1,0xBF,0x5D,0x03,0x80,0xDE,0x3C, 0x62, 15 0xBE,0xE0,0x02,0x5C,0xDF,0x81,0x63,0x3D,0x7C,0x22,0xC0,0x9E,0x1D,0x43,0xA1, 0xFF, 16 0x46,0x18,0xFA,0xA4,0x27,0x79,0x9B,0xC5,0x84,0xDA,0x38,0x66,0xE5,0xBB,0x59, 0x07, 17 0xDB,0x85,0x67,0x39,0xBA,0xE4,0x06,0x58,0x19,0x47,0xA5,0xFB,0x78,0x26,0xC4, 0x9A, 18 0x65,0x3B,0xD9,0x87,0x04,0x5A,0xB8,0xE6,0xA7,0xF9,0x1B,0x45,0xC6,0x98,0x7A, 0x24, 19 0xF8,0xA6,0x44,0x1A,0x99,0xC7,0x25,0x7B,0x3A,0x64,0x86,0xD8,0x5B,0x05,0xE7, 0xB9, 20 0x8C,0xD2,0x30,0x6E,0xED,0xB3,0x51,0x0F,0x4E,0x10,0xF2,0xAC,0x2F,0x71,0x93, 0xCD, 21 0x11,0x4F,0xAD,0xF3,0x70,0x2E,0xCC,0x92,0xD3,0x8D,0x6F,0x31,0xB2,0xEC,0x0E, 0x50, 22 0xAF,0xF1,0x13,0x4D,0xCE,0x90,0x72,0x2C,0x6D,0x33,0xD1,0x8F,0x0C,0x52,0xB0, 0xEE, 23 0x32,0x6C,0x8E,0xD0,0x53,0x0D,0xEF,0xB1,0xF0,0xAE,0x4C,0x12,0x91,0xCF,0x2D, 0x73, 24 0xCA,0x94,0x76,0x28,0xAB,0xF5,0x17,0x49,0x08,0x56,0xB4,0xEA,0x69,0x37,0xD5, 0x8B, 25 0x57,0x09,0xEB,0xB5,0x36,0x68,0x8A,0xD4,0x95,0xCB,0x29,0x77,0xF4,0xAA,0x48, 0x16, 26 0xE9,0xB7,0x55,0x0B,0x88,0xD6,0x34,0x6A,0x2B,0x75,0x97,0xC9,0x4A,0x14,0xF6, 0xA8, 27 0x74,0x2A,0xC8,0x96,0x15,0x4B,0xA9,0xF7,0xB6,0xE8,0x0A,0x54,0xD7,0x89,0x6B, 0x35}; 28 29 //Вычисляет и возвращает crc8
\ In segment CODE, align 2, keep-with-next 30 void do_crc_8(unsigned char byte, unsigned char *crc8) \ do_crc_8: 31 { 32 *crc8=crc_table[(*crc8^byte)]; \ 00000000 .... LDI R20, LOW(crc_table) \ 00000002 .... LDI R21, (crc_table) >> 8 \ 00000004 01F9 MOVW R31:R30, R19:R18 \ 00000006 8160 LD R22, Z \ 00000008 E010 LDI R17, 0 \ 0000000A 2706 EOR R16, R22 \ 0000000C 0F40 ADD R20, R16 \ 0000000E 1F51 ADC R21, R17 \ 00000010 01FA MOVW R31:R30, R21:R20 \ 00000012 9104 LPM R16, Z \ 00000014 01F9 MOVW R31:R30, R19:R18 \ 00000016 8300 ST Z, R16 33 } \ 00000018 9508 RET
Сообщение отредактировал haker_fox - Nov 17 2005, 06:54
Выбор.
Nov 17 2005, 07:39
Пользователь №: 8 064
Держи еще такой вариант. ;------------------- CRC FOR N BYTES ; var in : FSR (pointer to 1-st byte), crc_byte_count (# bytes) ; var out: crc_my ; var local: W, R0, R1 crc_n clrf crc_my crc_byte MOVLF .8,crc_bit_count movf INDF0,W movwf R1 crc_bit xorwf crc_my, W movwf R0 movlb 0x0F bcf STATUS,C movlb 0x00 rrcf R0, W movf crc_my, W movlb 0x0F btfsc STATUS,C xorlw 18h movlb 0x00 movwf R0 rrcf R0, W movwf crc_my rrcf R1 movf R1, W decfsz crc_bit_count goto crc_bit movlb 0x0F infsnz FSR0L incf FSR0H movlb 0x00 decfsz crc_byte_count goto crc_byte return ;------------------- CRC END Это правда для мелкочипов было, так что movlb можешь игнорировать. Идея CRC заключается в генерации выходного кода на основе полинома. так же как в генераторах псевдослучайного воздействия есть наиболее подходящие полиномы дающие наилучьшее кодирование... или наибольший отлов ошибок... В 8-битном это 0x18 Данный вариант сократит код, но удлинит время обработки.
Nov 17 2005, 08:11
Цитата(Pyku_He_oTTyda @ Nov 17 2005, 11:56)  А как вручную подсчитать CRC для ключа с номером "00000ССА061Е", на калькуляторе у меня что то не совпало с оригинальным  1. 00h 00h 2. 00h 00h 3. 0Ch A3h 4. CAh F9h 5. 06h 35h 6. 1Eh 03h Оригинал то какой ??? и чего они там пишут по поводу начального значения и полинома ?
Nov 17 2005, 08:32
Из: Великие Луки
Пользователь №: 7 360
CRC ASSEMBLY LANGUAGE PROCEDURE
DO_CRC: CRC_LOOP: ZERO: PUSH ACC PUSH B PUSH ACC MOV B,#8 XRL A,CRC RRC A MOV A,CRC JNC ZERO XRL A,#18H RRC A MOV CRC,A POP ACC RR A PUSH ACC DJNZ B,CRC_LOOP POP ACC POP B POP ACC RET CRC GENERATION
To validate the data transmitted from the DS1990A, the bus master may generate a CRC value from the data as it is received. This generated value is compared to the value stored in the last eight bits of the DS1990A. The bus master computes the CRC over the 8-bit family code and all 48 ID number data bits, but not over the stored CRC value itself. If the two CRC values match, the transmission is error-free. An example of how to generate the CRC using assembly language software is shown in Table 1. This assembly language code is written for the DS5000 Soft microcontroller which is compatible with the 8031/51 Microcontroller family. The procedure DO_CRC calculates the cumulative CRC of all the bytes passed to it in the accumulator. It should be noted that the variable CRC needs to be initialized to 0 before the procedure is executed. Each byte of the data is then placed in the accumulator and DO-CRC is called to update the CRC variable. After all the data has been passed to DO_CRC, the variable CRC will contain the result. The equivalent polynomial function of this software routine is:
CRC = x^8+ x^5+ x^4+ 1
Андрей Смирнов
Nov 17 2005, 08:35
Из: St.-P
Пользователь №: 5 462
Есть хорошая статья про CRC. Многое становится понятно.
Nov 17 2005, 10:05
Пользователь №: 2 265
Цитата(Pyku_He_oTTyda @ Nov 17 2005, 08:59)  Подскажите, как правильно посчитать на ассемблере контрольную сумму ключа I-BUTTON? Например так: ldi tempA,$18 ldi tempC,8 ; Счетчик бит rk_CRCloop: ;----------------- Вычисление CRC байта -------------- mov tempD,current_byte eor tempD,tempB ror tempD mov tempD,tempB brcc rk_zero eor tempD,tempA rk_zero: ror tempD mov tempB,tempD lsr current_byte dec tempC brne rk_CRCloop rjmp rk_NEXTbyte_loop
Nov 17 2005, 10:46
Пользователь №: 10 240
CRC8 на С, не табличная версия: Код void Update_CRC(char in, char *crc) { #define POLYNOMIAL 0x1D // x^8 + x^4 + x^3 + x^2 + 1 *crc = *crc ^ in; for (unsigned char i=0; i<8; i++) { *crc = (*crc & 0x80)? (*crc << 1) ^ POLYNOMIAL : (*crc << 1); } }
Сообщение отредактировал Antony Ugolev - Nov 17 2005, 10:46
Remember about the Main...
Nov 18 2005, 00:29
Пользователь №: 5 069
Цитата Подскажите, как правильно посчитать на ассемблере контрольную сумму ключа I-BUTTON? .... Тему не закрываю... ... Жаль нет готового исходника, апнота например А это не поможет: на сайте http://www.elin.ru/1-Wire/01.htm среди кучи всего, лежит: " Основные положения 1-Wire-интерфейса iButton and MicroLAN Standards. - Основополагающее описание стандарта 1-Wire (Dallas Semiconductor, Engl.), 1,06М, 24.10.99" вот выдержка из оглавления: "... APPENDIX 1 UNDERSTANDING AND USING CYCLIC REDUNDANCY CHECKS WITH...125 iButton PRODUCTS Introduction Background Description Dallas Semiconductor One-Wire CRC CRC-16 Computation for RAM Records in iButtons ..." По моему там дается и рассчетный и табличный методы определения CRC. Но сам я к сожалению в этом деле разбираюсь слабо. 2005 11 18 Александр laksus mail.ru
Nov 18 2005, 07:47
Пользователь №: 9 459
 CRC для AVR : ;***************************************************************************** ;* ПРОЦЕДУРА ВЫЧИСЛЕНИЯ 8-БИТНОЙ CRC для микроконтроллеров AVR. * ;***************************************************************************** ; Пример использования: clr fCRC ; Перед вычислением надо обнулять fCRC. mov fTEMP,fBYTE1 ; Названия байтов к примеру. rcall DO_CRC ; В fCRC сейчас находится контрольная сумма байта fBYTE1. mov fTEMP,fBYTE2 rcall DO_CRC ; В fCRC сейчас находится контрольная сумма байтов fBYTE1 и fBYTE2. mov fTEMP,fBYTE3 rcall DO_CRC ; В fCRC сейчас находится контрольная сумма байтов fBYTE1, fBYTE2, fBYTE3. ; И так далее. ; 8-битная CRC теряет эффективность при размере пакета более 200 байт. .def SAVE_W =r16 ; .def fBIT_CNT =r17 ; Счетчик прочитанных битов. .def fTEMP =r18 ; Временный регистр только для локального использования. .def fCRC =r19 ; Контрольная сумма. ; Процедура обновления CRC (циклическая контрольная сумма). Параметр в fTEMP. DO_CRC: mov SAVE_W,fTEMP ldi fBIT_CNT,8 CRC_LOOP: eor fTEMP,CRC ror fTEMP mov fTEMP,CRC brcc ZERO ldi CRC,0x18 eor fTEMP,CRC ZERO: ror fTEMP mov CRC,fTEMP lsr SAVE_W mov fTEMP,SAVE_W dec fBIT_CNT brne CRC_LOOP ret ;----------------------------------------------------------------------------- и вот : ;---------------------------------------------------------------- crc_calc: ;вычисляем CRC текущего байта mov r16,r17 ldi r18,8 crc_loop: eor r17,r19 ror r17 brcc zero ldi r17,0x18 eor r19,r17 zero: ror r19 lsr r16 mov r17,r16 dec r18 brne crc_loop ret
Nov 18 2005, 13:28
Из: Ставрополь
Пользователь №: 7 964
Цитата(Pyku_He_oTTyda @ Nov 17 2005, 08:59)  Подскажите, как правильно посчитать на ассемблере контрольную сумму ключа I-BUTTON? Вот еще подпрограммка, использовал для подсчета CRC карточек RFID типа EM-Marine: --------------------------------------------------------------------------------------------------------- ;Программы вычисления CRC8 блока памяти начиная с указателя Z ;длиной 7 байт; использует регистры Z, R0 ;на выходе CRC8 в temp CRC8calc: clr temp ldi dly3,7 ;счетчик байт ldi dly1, 0x0C CRC8_l1: ld R0, Z+ ldi dly2,8 ;счетчик бит CRC8_l2: ror R0 ror temp brcc CRC8_l3 subi temp, 0x80 CRC8_l3: brpl CRC8_l4 eor temp, dly1 CRC8_l4: dec dly2 brne CRC8_l2 dec dly3 brne CRC8_l1 ret За основу был взят код найденный на просторах Инета, точно уже не помню откуда.
Nov 21 2005, 16:17
Из: МОСКВА
Пользователь №: 6 604
Привожу пример для Pic 18f452. Проверено на DS1991, DS1994 - работает 100% !
iButt.txt ( 524 байт )
Jul 7 2010, 10:08
Пользователь №: 2 072
Попросили оптимизировать CRC8 для ИАРа, получилось очень близко к ассемблерной вставке из avr-lib. Код /* * Polynome (X^8 + X^5 + X^4 + 1) */ static uint8_t ml_crc_buf2(const void *buf, uint8_t len, uint8_t pat);
uint8_t ml_crc_buf(const void *buf, uint8_t len) { return ml_crc_buf2(buf, len, 0x8c); }
#pragma optimize=no_inline uint8_t ml_crc_buf2(const void *buf, uint8_t len, uint8_t pat) { const char *bp = buf; uint8_t sc, crc = 0, v;
for (; len; len--) { crc ^= *bp++; for (sc = 8; sc; sc--) { v = crc; crc >>= 1; if (v & 1) crc ^= pat; } } return crc; } Результат: Код LDI R19, 140 REQUIRE ml_crc_buf2 ; // Fall through to label ml_crc_buf2 ml_crc_buf2: MOVW R31:R30, R17:R16 LDI R16, 0 TST R18 BREQ ??ml_crc_buf2_0 ??ml_crc_buf2_1: LD R17, Z+ EOR R16, R17 LDI R17, 8 ??ml_crc_buf2_2: MOV R20, R16 LSR R16 BST R20, 0 BRTC ??ml_crc_buf2_3 EOR R16, R19 DEC R17 BRNE ??ml_crc_buf2_2 DEC R18 BRNE ??ml_crc_buf2_1 ??ml_crc_buf2_0: RET
