> Signal cannot be synthesized, bad synchronous description., Не пойму в чем дело...
h0t
сообщение Feb 4 2012, 18:26
Пользователь №: 67 345
Добрый вечер, было уже когда-то похожая проблема но сейчас уже не помню с чем связана.
В итоге есть код:
function read_bit(signal RX, SCK:std_ulogic)  return bit is
variable read_data: Std_uLogic_Vector ( 4 downto 0);
variable current_bit : bit;
begin
    for i in 0 to 4 loop
        if(rising_edge(SCK)) then
           read_data(i) := RX;
        end if;
    end loop;
    if (read_data = "00000") then  current_bit:='0';
     elsif (read_data = "00001") then  current_bit:='0';
     elsif (read_data = "00010") then  current_bit:='0';
     elsif (read_data = "00011") then  current_bit:='0';
     elsif (read_data = "00100") then  current_bit:='0';
     elsif (read_data = "00101") then  current_bit:='0';
     elsif (read_data = "00110") then  current_bit:='0';
     elsif (read_data = "00111") then  current_bit:='1';
     elsif (read_data = "01000") then  current_bit:='0';
     elsif (read_data = "01001") then  current_bit:='0';
     elsif (read_data = "01010") then  current_bit:='0';
     elsif (read_data = "01011") then  current_bit:='1';
     elsif (read_data = "01100") then  current_bit:='0';
     elsif (read_data = "01101") then  current_bit:='1';
     elsif (read_data = "01110") then  current_bit:='1';
     elsif (read_data = "01111") then  current_bit:='1';
     elsif (read_data = "10000") then  current_bit:='0';
     elsif (read_data = "10001") then  current_bit:='0';
     elsif (read_data = "10010") then  current_bit:='0';
     elsif (read_data = "10011") then  current_bit:='1';
     elsif (read_data = "10100") then  current_bit:='0';
     elsif (read_data = "10101") then  current_bit:='1';
     elsif (read_data = "10110") then  current_bit:='1';
     elsif (read_data = "10111") then  current_bit:='1';
     elsif (read_data = "11000") then  current_bit:='0';
     elsif (read_data = "11001") then  current_bit:='1';
     elsif (read_data = "11010") then  current_bit:='1';
     elsif (read_data = "11011") then  current_bit:='1';
     elsif (read_data = "11100") then  current_bit:='1';
     elsif (read_data = "11101") then  current_bit:='1';
     elsif (read_data = "11110") then  current_bit:='1';
     elsif (read_data = "11111") then  current_bit:='1';
     end if;
    return current_bit;
end;
begin
    process (SCK,RX)
    variable current_bit:bit;
    begin
    if (falling_edge(RX)) then
            current_bit:=read_bit(RX,SCK);
            DATA <= "0000000000000000000000000000000000000000000000000000000000000000000000000000
000"&to_stdulogic(current_bit);
    end if;
    end process;
И получаю ошибку line 57: Signal read_data1<0> cannot be synthesized, bad synchronous description. The description style you are using to describe a synchronous element (register, memory, etc.) is not supported in the current software release.. Подскажите в чем дело. Тема похожая уже здесь была, я ее просматривал но осознать как подправить код не смог(. Спасибо.
P.S. про жуткий способ вычисления current_bit знаю, просто я игрался с ошибкой что-бы понять в чем дело.
Сообщение отредактировал h0t - Feb 4 2012, 18:28
svedach
сообщение Feb 4 2012, 19:08
Из: Беларусь
Пользователь №: 69 226
Я не спец, но возможно нельзя использовать rising_edge(SCK) внутри функции??
Сообщение отредактировал svedach - Feb 4 2012, 19:08
h0t
сообщение Feb 4 2012, 19:18
Да вроде можно, если вытащить функцию то это не помогает( Там что-то с сигналами связано, но вот не помню что...
gosu-art
Пользователь №: 52 939
h0t
сообщение Feb 4 2012, 19:22
Цитата(gosu-art @ Feb 4 2012, 23:18) *
Можно подробнее, я не понял что Вы имели ввиду. Это вроде же разные сигналы....
gosu-art
сообщение Feb 4 2012, 19:27
А то, что такую конструкцию в ПЛИС невозможно реализовать.
Причем у вас явно мышление "обычного" программиста - типа все операторы выполняются последовательно
h0t
сообщение Feb 4 2012, 19:36
Если поменять один из них на if (RX='0') результат будет такой же...(
у меня process
Сообщение отредактировал h0t - Feb 4 2012, 19:36
gosu-art
сообщение Feb 4 2012, 19:45
read_data(i) := RX;
end if;
end loop;
Вот эта штука - ваще атасс smile3046.gif хотя бы попробуйте пока ее вообще выкинуть
h0t
сообщение Feb 4 2012, 19:48
я писал, что над функцией я игрался что-бы понять в чем ошибка. Если я ее выкину то вопрос станет не актуальный. Прошу Вас конструктивно объяснить в чем проблема.
des00
сообщение Feb 5 2012, 08:46
Вечный ламер
Из: Томск
Пользователь №: 3 453
Проблема в том, что Вы подошли к VHDL как к языку програмирования, а что VHDL это язык ОПИСАНИЯ аппаратуры (хотя программировать на нем можно и даже запускать то, что напрограмировали в симуляторе). И пока вы не поймете разницу, делать что либо н VHDL для ПЛИС бессмысленно. Рекоменду начать с азов, хотя бы с книни "ПЛИС. Курс молодого бойца" Максфилда.
h0t
Кажется я понял что Вы имели ввиду. НО полного осознания еще ни пришло код переписал полностью по тактам только от SCK. Но если объясните подробно буду благодарен.
gosu-art
сообщение Feb 5 2012, 09:07
Завтра приду на работу попробую набросать примеры...
maksimp
сообщение Feb 5 2012, 09:36
Пользователь №: 66 023
begin
           read_data(i) := RX;
        end if;
end;
begin
    process (SCK,RX)
    begin
    end if;
    end process;
если подставить функцию на место её применения то получается
begin
    process (SCK,RX)
    begin
           read_data(i) := RX;
        end if;
    end if;
    end process;
То есть вложенные друг в друга констпукции if с срабатыванием по фронту (falling_edge или rising_edge). Этого нельзя - в ПЛИС нет схем которые умеют так работать, и синтезатор поэтому отказывается.
h0t
сообщение Feb 5 2012, 11:44
Все спасибо, осознал. Всем спасибо.
Bad0512
сообщение Feb 6 2012, 03:14
Из: Томск
Пользователь №: 27 650
А вот у меня чисто спортивный интерес : а если бы вам нужно было количество единичек посчитать к примеру в 7-ми битном слове, то вы конструкцию типа if-elseif на 128 строчек написали бы? А вдруг ошиблись бы , к примеру в 115 строчке? Попоробуйте универсальную функцию подсчёта единичек (а может даже ещё и нулей!) написать. Тем более что VHDL позволяет передавать в функцию вектор заранее не определённой длины - можно сделать под любую разрядность входных данных.
h0t
сообщение Feb 6 2012, 15:47
Сообщение #16
Да нет конечно, просто я думал что проблема в зависимости по данным массива, поэтому и сделал так, что-бы не было накопления с использованием переменной. Так что не волнуйтесь не все так плохо)))
Сообщение отредактировал h0t - Feb 6 2012, 15:48
RSS Текстовая версия Сейчас: 20th July 2025 - 01:07
Страница сгенерированна за 0.01471 секунд с 7
