> ADC прерывания в STM32
Acvarif
сообщение Feb 6 2012, 11:54
Пользователь №: 39 850
Пытаюсь настроить ADC1 stm32f217 для работы по прерываниям (по окончании цикла преобразования).
CODE
void ADC_Config(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_CommonInitTypeDef ADC_CommonInitStructure;
DMA_InitTypeDef DMA_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
/* Enable ADC1, DMA2 and GPIO clocks ****************************************/
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
/* DMA2 Stream0 channel2 configuration **************************************/
DMA_InitStructure.DMA_Channel = DMA_Channel_0;
DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
DMA_InitStructure.DMA_BufferSize = 1;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA2_Stream0, &DMA_InitStructure);
DMA_Cmd(DMA2_Stream0, ENABLE);
/* Configure ADC1 Channel4 pin as analog input ******************************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* ADC Common Init **********************************************************/
ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
ADC_CommonInit(&ADC_CommonInitStructure);
/* ADC1 Init ****************************************************************/
ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
// Режим сканирования
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
// Непрерывное преобразование
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfConversion = 1;
ADC_Init(ADC1, &ADC_InitStructure);
/* Enable and set the ADC interrupt to the highest priority */
NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
/* ADC1 regular channel4 configuration *************************************/
ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_112Cycles);
/* Enable DMA request after last transfer (Single-ADC mode) */
ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
/* Enable ADC3 DMA */
ADC_DMACmd(ADC1, ENABLE);
/* Enable ADC3 */
ADC_Cmd(ADC1, ENABLE);
В прерываниях пока просто переключаю светодиод (для визуализации прерываний)
void ADC_IRQHandler(void)
  STM_EVAL_LEDToggle(LED2);
  /* Clear the interrupt flag. */
  ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
Не работает.
Правда в инициализации задействовано DMA (в DMA данные попадают как положено - успешно выводятся на COM1).
Но одно другого (DMA и прерывания по окончанию преобразования) вроде не должно касаться.
Гляньте код кому не лень. Может чего напутано в инициализации прерываний или в самоой void ADC_IRQHandler.
Oleg Galizin
сообщение Feb 6 2012, 15:13
Пользователь №: 26 499
Цитата(Acvarif @ Feb 6 2012, 15:54) *
Не работает.
EOCIE в регистре ADC_CR1 ?
Или что то типа
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE) согласно Вашему стилю?
Правда это все для 1 серии. Но для второй наверняка так же.
Acvarif
сообщение Feb 6 2012, 15:18
Ошибочка блин.
Не хватает.
/* Enable ADC1 Interrupt */
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
Прерывания заработали но появилась проблема с семафором FReeRTOS
CODE
STM_EVAL_LEDOn(LED2);
portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
/* ADC1 received */
if (ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == SET)
/* Give the semaphore to wakeup ADC task */
xSemaphoreGiveFromISR( s_xSemaphore, &xHigherPriorityTaskWoken );
/* Switch tasks if necessary. */
if( xHigherPriorityTaskWoken != pdFALSE )
portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
Не срабатывает он здесь
      for(;; )
        if (xSemaphoreTake( s_xSemaphore, portMAX_DELAY )==pdTRUE)
          text[1] = ADC1ConvertedValue;
          text[0] = ADC1ConvertedValue >> 8;
          netbuf_ref(buf1, text, sizeof(text));
          netconn_send(connn, buf1);
RSS Текстовая версия Сейчас: 26th August 2025 - 22:23
Страница сгенерированна за 0.01341 секунд с 7
