Имеется МК ATSAM3S4B, JTAG, модемный кабель(c тремя линиями DCD, TD и RD). Скачал с
офф сайта пакет программ для IAR, зашил (через J-Mem посмотрел, все записалось). Запускаю Terminal, должно было быть выведено
* -- USART Synchronous Mode Example xxx --
* -- xxxxxx-xx
* -- Compiled: xxx xx xxxx xx:xx:xx --
* -- Menu Choices for this example --
* -- [0-3]:Select clock frequency of master --
* -- i: Display configuration info
* -- w: Write data block .--
* -- r: Read data block.--
* -- s: Switch between master and slave mode.--
* -- m: Display this menu again.--
* --USART1 in MASTER mode--
но ничего не происходит, пробывал еще через HyperTerminal. Значит это аппаратная ошибка? Как проверить доходят ли команды до МК?
CODE
#include "board.h"
#include <stdio.h>
#include <stdbool.h>
#include <string.h>
* Local definition
/** size of the receive buffer used by the PDC, in bytes.*/
#define BUFFER_SIZE 2000
/** USART1 synchronous master*/
#define SYNC_MASTER 1
/** USART1 synchronous slave*/
#define SYNC_SLAVE 0
/** USART1 is reading*/
#define STATE_READ 0
/** USART1 is writing*/
#define STATE_WRITE 1
#define FREQ_OPTIONS_NUM 4
* Local variables
/** Pins to configure for the application.*/
const Pin pins[] = { BOARD_PIN_USART_RXD,
BOARD_PIN_USART_TXD,
PIN_USART1_SCK,
/** Transmit buffer. */
char
Buffer[BUFFER_SIZE]=
"DESCRIPTION of this example: \n\r \
**************************************************************************\n\r\
* This application gives an example of how to use USART in synchronous mode.\n\r\
* Synchronous operations provide a high speed transfer capability. The\n\r\
* transfer under this mode needs a pair of master and slave, which is\n\r\
* determined by which one offers the clock source.\n\r\
* \n\r\
* The example initialized USART1 as master by default. To enable the\n\r\
* communication between each side of the connection. The user should change\n\r\
* the mode of another side to slave through user interface. If well configured,\n\r\
* transfer could be started by typing 'r' and 'w' from terminal application.\n\r\
* This example also leaves the interface to select the clock frequency.\n\r\
* \n\r\
* The meaning of each input character could be found in items of the main menu.\n\r\
* \n\r\
END of DESCRIPTION \n\r\
/** buffer for receiving */
char pRecvBufferUSART1[BUFFER_SIZE]= { 0 };
/** reception done*/
volatile bool recvDone = false;
/** sending done*/
volatile bool sentDone = false;
/** mode for usart1 and spi ,0 means usart1 as master 1 for
another state*/
uint8_t transfer_mode = SYNC_MASTER;
/** state of reading or writing*/
uint8_t state = STATE_WRITE;
/** clock frequency*/
uint32_t frequency[FREQ_OPTIONS_NUM]={1000000UL,4000000UL,10000000UL,16000000UL};
/** present freqency index in list frequency[]*/
uint8_t freq_index = 0;
* Local functions
/* \brief USART1 IRQ handler
* Interrupt handler for USART. After reception is done,set recvDone to true,
* and if transmission done, set sentDone to true.
void USART1_IrqHandler(void)
uint32_t status;
/* Read USART status */
status = BOARD_USART_BASE->US_CSR;
/* Receive buffer is full */
if ((status & US_CSR_RXBUFF) == US_CSR_RXBUFF && state == STATE_READ) {
recvDone = true;
USART_DisableIt(USART1, US_IDR_RXBUFF);
if ((status & US_CSR_TXBUFE) == US_CSR_TXBUFE && state == STATE_WRITE){
sentDone = true;
USART_DisableIt(USART1, US_IDR_TXBUFE);
* \brief Configures USART in synchronous mode,8N1
* \param mode 1 for master, 0 for slave
static void _ConfigureUsart( uint8_t isMaster, uint32_t freq )
uint32_t mode = US_MR_USART_MODE_NORMAL | US_MR_USCLKS_MCK
| US_MR_CHMODE_NORMAL | US_MR_CLKO
| US_MR_SYNC | US_MR_MSBF
| US_MR_CHRL_8_BIT | US_MR_NBSTOP_1_BIT| US_MR_PAR_NO;
if ( !isMaster )
mode = US_MR_USART_MODE_NORMAL | US_MR_USCLKS_SCK
| US_MR_CHMODE_NORMAL
/* Enable the peripheral clock in the PMC */
PMC_EnablePeripheral( BOARD_ID_USART );
/* Configure the USART in the desired mode @USART_SPI_CLK bauds*/
USART_Configure( BOARD_USART_BASE, mode, freq, BOARD_MCK );
/* enable USART1 interrupt */
NVIC_EnableIRQ( USART1_IRQn );
/* Enable receiver & transmitter */
USART_SetTransmitterEnabled( BOARD_USART_BASE, 1 );
USART_SetReceiverEnabled( BOARD_USART_BASE, 1 );
* \brief Display main menu.
static void _DisplayMainmenu( void )
printf("-- Menu Choices for this example --\n\r");
printf("-- [0-3]:Select clock frequency of master --\n\r");
printf("-- i: Display configuration info\n\r");
printf("-- w: Write data block .--\n\r");
printf("-- r: Read data block.--\n\r");
printf("-- s: Switch between master and slave mode.--\n\r");
printf("-- m: Display this menu again.--\n\r");
* \brief Dump buffer to uart
static void _DumpInfo( char *buf, uint32_t size )
uint32_t i = 0;
while ( (i < size) && (buf[i] != 0) )
printf( "%c", buf[i++] );
* Global functions
* \brief Application entry point.
* Configures USART1 in synchronous master/slave mode start a transmission
* between two boards.
* \return Unused.
extern int main( void )
char c;
/* Disable watchdog */
WDT_Disable( WDT );
/* Configure pins */
PIO_Configure( pins, PIO_LISTSIZE( pins ) );
/* Example information log */
printf( "-- USART Synchronous Mode Example %s --\n\r", SOFTPACK_VERSION );
printf( "-- %s\n\r", BOARD_NAME );
printf( "-- Compiled: %s %s --\n\r", __DATE__, __TIME__ );
/* display main menu*/
_DisplayMainmenu();
/* configure USART1 in Master and SPI in slave mode*/
_ConfigureUsart( SYNC_MASTER, frequency[freq_index] );
printf( "--USART1 in MASTER mode--\n\r" );
while ( 1 )
c = UART_GetChar();
switch ( c )
case '0':
case '1':
case '2':
case '3':
freq_index = c - '0';
printf("-- The clock frequency is: %u\n\r", (unsigned int)frequency[freq_index] );
break;
case 'i':
case 'I':
if ( transfer_mode == SYNC_MASTER )
printf( "-- USART1 is MASTER at %u Hz.\n\r", (unsigned int)frequency[freq_index] );
else
printf( "-- USART1 is SLAVE \n\r" );
break;
case 's':
case 'S':
transfer_mode = SYNC_SLAVE;
_ConfigureUsart( SYNC_SLAVE, frequency[freq_index] );
printf( "--USART1 in SLAVE mode--\n\r" );
else
if ( transfer_mode == SYNC_SLAVE )
_ConfigureUsart(SYNC_MASTER,frequency[freq_index]);
printf("--USART1 in MASTER mode--\n\r");
break;
case 'w':
case 'W':
USART_WriteBuffer(BOARD_USART_BASE, Buffer, BUFFER_SIZE);
USART_EnableIt(BOARD_USART_BASE,US_IER_TXBUFE);
while(!sentDone);
if(sentDone){
printf(" -- %s sent done\n\r", state? "MASTER":"SLAVE" );
break;
case 'r':
case 'R':
state = STATE_READ;
if(transfer_mode == SYNC_MASTER){
printf("----USART1 MASTER Read----\n\r");
}else{
printf("----USART1 SLAVE Read----\n\r");
USART_ReadBuffer(BOARD_USART_BASE, pRecvBufferUSART1, BUFFER_SIZE);
USART_EnableIt(BOARD_USART_BASE,US_IER_RXBUFF);
while(!recvDone);
if(recvDone) {
if(strncmp(pRecvBufferUSART1,Buffer,BUFFER_SIZE)){
printf(" -F-: Failed!\n\r");
}else{
/* successfully received*/
_DumpInfo(pRecvBufferUSART1,BUFFER_SIZE);
printf("----END of read----\n\r");
memset(pRecvBufferUSART1,0,sizeof(pRecvBufferUSART1));
recvDone = false;
break;
case 'm':
case 'M':
_DisplayMainmenu();
break;
Сообщение отредактировал IgorKossak - Nov 15 2012, 15:23
Причина редактирования: [codebox] для длиного кода!!!
