> ICCAVR 6.31 vs ICCAVR 7.22С, Компилируется в ICCAVR 6.31 не компилируется в ICCAVR 7.22С
Artym
сообщение Apr 18 2014, 06:45
Из: 48°00'N 37°48'E
Пользователь №: 636
Добрый день!
Проект который прекрасно компилируется в ICCAVR 6.31 не компилируется в ICCAVR 7.22С
Вылетает:
CODE
C:\iccv7avr\bin\imakew -f BI_TP.mak
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  System.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  display.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  IntHandle.c
!W D:\Tp_slave\IntHandle.c(11):[warning] old-style function definition for `T1Hnd'
!W D:\Tp_slave\IntHandle.c(16):[warning] old-style function definition for `T3Hnd'
!W D:\Tp_slave\IntHandle.c(22):[warning] old-style function definition for `RxcHnd'
!W D:\Tp_slave\IntHandle.c(27):[warning] old-style function definition for `TxcHnd'
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  keyboard.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  Timers.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  UART.c
    iccavr -c -e -D__ICC_VERSION=722 -D__BUILD=0 -DATMega128  -l -g -MLongJump -MHasMul -MEnhanced -Wf-use_elpm  BI06.c
    iccavr -o BI_TP -g -nb:0 -e:0x20000 -ucrtatmega.o -bfunc_lit:0x8c.0x20000 -dram_end:0x10ff -bdata:0x100.0x10ff -dhwstk_size:16 -beeprom:0.4096 -fcoff -S2 @BI_TP.lk   -lcatm128
  ROM 3% full. 4446 out of 131072 bytes used.
  RAM 633 bytes used (does not include stack usage).
can't open input file BI_TP.hex
C:\iccv7avr\bin\imakew.exe: Error code 1
Done: there are error(s). Exit code: 1. Fri Apr 18 08:53:57 2014
Переопределил функции
Warning-и перестали вылазить. Но ошибка вылазит все равно.
CODE
Done: there are error(s). Exit code: 1. Fri Apr 18 09:14:48 2014
В чем может быть проблема? Спасибо.
Прикрепленный файл  modbus_slave.zip ( 13.95 килобайт ) Кол-во скачиваний: 10
Ответов (1 - 6)
Xenia
сообщение Apr 18 2014, 07:36
Группа: Модератор FTP
Пользователь №: 35 237
Думаю, что ошибка:
"can't open input file BI_TP.hex"
не связана с компиляцией.
Убейте старый файл BI_TP.hex и повторите еще разик.
Artym
сообщение Apr 18 2014, 08:17
Из: 48°00'N 37°48'E
Пользователь №: 636
QUOTE (Xenia @ Apr 18 2014, 10:36) *
Думаю, что ошибка:
Эта операция проделана несколько раз, HEX изначально в исходниках нет.
Опробовано на Windows 7 x64 SP1 и Windows XP SP2
+ сейчас скачал ICCAVR 8 , таже беда.
Палыч
сообщение Apr 18 2014, 08:52
Из: г. Новочеркасск
Пользователь №: 16 954
Menu -> Project -> Options -> Paths -> Output directory
Указан путь к каталогу, который "не нравится" моему транслятору. Попробуйте заменить на какое-либо другое место для выходного файла.
P.S. Кстати и другие пути на вкладке "Paths" тоже вызывают большое сомнение в их правильности...
Artym
сообщение Apr 18 2014, 10:12
Из: 48°00'N 37°48'E
Пользователь №: 636
QUOTE (Палыч @ Apr 18 2014, 11:52) *
Пути я менял и делал, как в проекте, и новые папки и так и сяк, но не получается, похоже здесь что-то глобальное и не я один такой
CODE
http://www.cqham.ru/forum/archive/index.php/t-5895-p-10.html
Vladimir-dl7pga
29.04.2012, 20:24
Вот, натолкнулся на такой сайт http://www.microsyl.com и там, среди различных проектов - частотомер с LCD дисплеем от Nokia 3310 : http://www.microsyl.com/index.php/2010/03/23/frequancy-meter/
Вроде всё ок!, но попытки откомпилировать проект сначала с ICCAVR v8 demo, затем ICCAVR v7 demo к успеху не привели, повылезало море ошибок. Попросил автора прислать HEX файл (для коллекции), на что он моментально откликнулся и прислал ... исходники, те же самые, что можно скачать с его вэбсайта. Покопавшись в инете, нашёл ICCAVR v6.31A demo, установил его под LinuxMint 12.1 как аппликацию для WINE. И смотри-ка, с этой версией удалось откомпилировать проект (та же программа, установленная под виндой заартачилась при компиляции).
Наверно вопрос придется задать сюда - support@imagecraft.com
Палыч
сообщение Apr 18 2014, 10:43
Из: г. Новочеркасск
После того, как я прописал "правильные" пути во вкладке "Paths" и установил во вкладке "Compiler" формат выходного файла "Coff/Hex" (ранее там стоял "Coff"), Ваш проект собрался "на ура!". Дело в том, что при переходе с V6 на V7 файл проекта не конвертируется правильно средой - нужно "ручками" поправить...
Artym
сообщение Apr 18 2014, 13:15
Из: 48°00'N 37°48'E
Пользователь №: 636
QUOTE (Палыч @ Apr 18 2014, 13:43) *
ОГРОМНОЕ СПАСИБО! Получилось.
RSS Текстовая версия Сейчас: 23rd July 2025 - 17:14
Страница сгенерированна за 0.01426 секунд с 7
