вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008 |
(1 - 54)
Dec 13 2016, 20:18
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 009 Код DATE: 12-8-2016 HOTFIX VERSION: 009 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1212577 PSPICE MODELEDITOR IBIS translation fails without any information in log file 1311687 PSPICE MODELEDITOR Timeout error while translating IBIS model 1327174 PSPICE MODELEDITOR Log file should list error details during IBIS Translation 1499665 ALLEGRO_EDITOR INTERACTIV Offset Move depends on move setting. 1516093 ALLEGRO_EDITOR PADS_IN Pads library translator does not translate slot orientation 1565795 ALLEGRO_EDITOR UI_GENERAL Search does not work in the Defined Variables window 1568817 ALLEGRO_EDITOR UI_GENERAL Padstack editor not accepting comma as decimal separator with system locale set as LANG ru_RU.UTF-8 1569272 ALLEGRO_EDITOR PLACEMENT Get the error message 'E- (SPMHDB-394): Placement cannot be completed ... 'after creating Place Replicate circuit 1577379 CONCEPT_HDL CORE Packager-XL gives different results when run from DE-HDL and ADW Flow Manager 1578523 ALLEGRO_EDITOR PAD_EDITOR Library Padstack Browser does not refresh preview 1578533 ALLEGRO_EDITOR PAD_EDITOR New Padstack Editor does not automatically update the geometry 1581129 CONSTRAINT_MGR UI_FORMS Unable to dock the Electrical worksheet in Constraint Manager 1582103 ALLEGRO_EDITOR PADS_IN PADS Library Import creates additional filled shape not present in source data 1591027 ADW LIBDISTRIBUTION Library Distribution redistributes previously distributed models 1592026 CIS VIEW_DATABASE_PA View database part does not work from schematic pages of an externally referenced design 1593389 CAPTURE GEN_BOM Include files in Tools - BOM not working 1593404 SIP_LAYOUT EDIT_ETCH Slide command moves via toward the object 1595872 CIS PART_MANAGER Capture CIS Part Manager PCB Footprint update case-sensitivity issue 1596955 ALLEGRO_EDITOR EDIT_ETCH Scribble mode is not working as per expectation. 1600936 ALLEGRO_EDITOR INTERACTIV Pin DataTips differ between 16.6 and 17.2 1605961 ALLEGRO_EDITOR COLOR Wildcards not working in the Filter Nets field of the Color Dialog window 1606392 ALLEGRO_EDITOR PLACEMENT Filmmask not shown when component is attached to cursor 1607016 ADW TDA TDO crashes after LRM update during check-in hierarchy 1608059 CONCEPT_HDL CREFER Removing crefs from top-level design also removes .csb files from lower-level blocks 1608278 CAPTURE OTHER Crystal Reports: User is prompted for ODBC password to create a BOM report 1610377 CAPTURE PROPERTY_EDITOR Discrepancies between the NET_SPACING_TYPE property (or any other property) text and the actual property 1610456 ALLEGRO_EDITOR DATABASE Strip design and selecting user defined subclasses results in database corruption. 1612793 CONCEPT_HDL OTHER Pattern-based auto-distribution of split symbols not working if there are spaces before commas 1613442 CONCEPT_HDL CORE Signal names are not horizontally centered when the wires are added using different methods 1613559 ASDA IMPORT_DEHDL_SHE custom variables from the BOM Tables are not getting imported 1614093 CONCEPT_HDL CORE Import Design window has artificial 64 char limit for path - prevents access to some locations 1614372 CONCEPT_HDL EDIF300 OFFPAGE symbol is exported as PageBorder in EDIF300 schematic 1615075 APD LOGIC Netlist-In wizard fails to import the net names, but gives a successful completion Info message 1616131 ALLEGRO_EDITOR PLACEMENT While placing a module, the Mirror command in the right-click pop-up menu is not working 1617377 ALLEGRO_EDITOR UI_GENERAL Visibility pane does not retain the correct layer view 1617404 ALLEGRO_EDITOR UI_GENERAL axlUIMenuChange does not work as expected in 17.2 1619412 ALLEGRO_EDITOR INTERACTIV Script to create new padstacks from existing padstack is putting in wrong values for a regular pad 1621842 ALLEGRO_EDITOR PLACEMENT mechanical symbol without placebound will not place in QuickPlace 1621874 ASDA PRINT Print - Save as PDF uses the default printer options only 1621887 ALLEGRO_EDITOR INTERACTIV Getting a 'Could not satisfy the snap condition' message when using the Snap pick to option 1622680 ALLEGRO_EDITOR PADS_IN Import PADS fails with the 'ERROR: *NET* section found. Translation of netlist is not allowed.' message 1623832 ADW COMPONENT_BROWSE Incorrect part placement on schematic in Design Entry HDL 16.6-S073 1624813 CAPTURE GENERAL The Value property is always left aligned when placing a symbol on the schematic 1624953 ALLEGRO_EDITOR UI_GENERAL Custom views in 17.2 do not return to original 1625000 ASDA CANVAS_EDIT File - Save Project does not provide any indication of saving or progress bar 1625163 CONSTRAINT_MGR OTHER There is no status for the analyze command in the Constraint Manager in 17.2 1626647 PSPICE ENVIRONMENT Capture crashes when loading a design with two hyphens in sim profile name 1628357 CONSTRAINT_MGR OTHER Constraint Manager shows differences if exporting and importing constraints on the same board. 1628409 ALLEGRO_EDITOR PAD_EDITOR Pad Stack Editor does not remember last used directory 1631443 CONCEPT_HDL ERCDX ERC reports warning due to lower-case value of some properties in chips.prt 1632195 SCM OTHER 'No known page border found' error in cref.log 1632365 CONSTRAINT_MGR OTHER Select command is disabled in the right-click pop-up menu from Constraint Manager in SPB 17.2 1632462 ALLEGRO_EDITOR 3D_CANVAS 3D View (new) and PCB Editor crash when checking collisions 1632590 ALLEGRO_EDITOR 3D_CANVAS PCB Editor crashes when 3D View is open and more 16.6 boards are opened 1633433 CONSTRAINT_MGR UI_FORMS Expand - Collapse feature for multiple objects not working correctly 1633454 ADW TDA TDO crashes if DAO throws an exception 1633526 PSPICE AA_PPLOT Spaces in Simulation Profile cause error in Parametric Plotter 1633608 ALLEGRO_EDITOR COLOR 'Retain objects custom color' should not enabled as default. 1636216 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas (Unsupported prototype) is not mapping step model when assigned to device 1636899 ALLEGRO_EDITOR 3D_CANVAS The new 3D Viewer is not taking the Package Height set on the PLACE_BOUND layer into account when displaying it. 1638185 CAPTURE DATABASE Opening CIS database locks all part libraries none of which are open 1639409 ASDA CANVAS_EDIT Handling of MAKE_BASE property from DE-HDL designs imported into SDA 1639541 CONSTRAINT_MGR OTHER PCB Editor 17.2 crashes when making changes in Constraint Manager 1639613 APD STREAM_IF The stream out command has created sharp angles in the GDSII output file 1640061 ASDA HIERARCHY Incorrect message received when invalid characters are specified for subdesign suffix 1641118 F2B DESIGNVARI Some DNI parts are not identified in the variant view due to the BLOCK 1641410 ASDA CONSTRAINT_MANAG No errors or issues reported when incorrect topology is applied to a net or an Xnet 1642891 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes randomly while working on Constraint Manager 1643003 CAPTURE PROJECT_MANAGER Start page shows latest as S004 after installing S005 1643532 ALLEGRO_EDITOR OTHER Strip design command fails to delete symbol text in the attached design 1645529 ASDA CONSTRAINT_MANAG Unable to delete the diff pair from the nets 1645639 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes when the XNET_PINS property value has a trailing comma character 1646354 CONSTRAINT_MGR CONCEPT_HDL Cannot select Design Instance/Block Filter from the View menu in Constraint Manager 1646612 PCB_LIBRARIAN CORE Generate Symbol option crashes Part Developer 1646932 ALLEGRO_EDITOR MANUFACT Manufacture - Auto Rename Refdes keeps defaulting to Use Default Grid even if another is chosen 1647190 APD REPORTS 'Sorted by Bond Finger' report shows incorrect wire bond connection 1647673 ASDA EXPORT_PCB Two Physical folders are seen after installation of QIR 1647729 ALLEGRO_EDITOR SKILL axlFillet returns t when fillet is not added. 1647779 CONSTRAINT_MGR OTHER 'Software Version' in the cmDiffUtility viewer does not show the correct version 1647843 ALLEGRO_EDITOR ARTWORK Misleading information in command window when artwork import fails 1648575 CAPTURE OTHER Suppress warning setting must be written in capture.ini file 1649060 CONSTRAINT_MGR CONCEPT_HDL Rename dcfx to dcf process results in error in log file and dcf not updated 1650106 ALLEGRO_EDITOR 3D_CANVAS 3D canvas rotates mirrored components in unmirrored angle 1650238 SIP_LAYOUT WIREBOND When performing 'Adjust Min DRC', the reference bond finger should not move. 1650734 APD SHAPE Shape on L1 does not flood properly 1650793 CONSTRAINT_MGR CONCEPT_HDL Conflict of XNET_PINS definition between the chips and the SIGNAL_MODEL is not handled correctly 1650801 ALLEGRO_EDITOR SCHEM_FTB Running Export Physical with Update PCB enabled in Project Manager crashes netrev.exe 1651011 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D viewer shows mechanical symbol mirrored 1651063 ALLEGRO_EDITOR CROSS_SECTION Cross-section preview is incorrect 1651066 ALLEGRO_EDITOR DATABASE Pins not connecting even after running the Tools - Derive Connectivity command 1651700 ALLEGRO_EDITOR SKILL Running axlXSectionModify() on a layer removes the value of the material 1651925 ALLEGRO_EDITOR ARTWORK Searching for a macro in the artwork data file: Count for the macro does not match the actual count in the output 1652230 CONCEPT_HDL CORE The master.tag and vlog004u.sir files are not created in the entity directory on saving symbols 1653080 CONCEPT_HDL ERCDX Difference in results from SPB16.6 in 'erc.rpt' when logic_data is renamed as worklib in SPB17.2 on RHEL6.5 1653422 ADW LIBIMPORT Classifications not linked to a Part Number or Cell Model are removed during Library Import 1653526 ALLEGRO_EDITOR DATABASE Via padstack keepout is not displayed on the canvas when pads suppression is enabled. 1653951 ALLEGRO_EDITOR CROSS_SECTION Cross Section Editor changes lost despite selecting No to the 'All changes will be lost ...' message 1656224 ADW FLOW_MGR Copy Project wizard no longer allows dashes in the 'Name of new project folder' field 1656581 ALLEGRO_EDITOR OTHER PDF generated for layer with shape shows undesired voids if film is mirrored and Filled Shape is not selected 1656608 APD REPORTS Incorrect calculation in the metal usage report 1656726 CONCEPT_HDL CORE Interface command always disabled in the Wire menu 1656841 CONSTRAINT_MGR UI_FORMS Incorrect layer information is displayed in the Edit Via List dialog when a filter is applied 1657220 ALLEGRO_EDITOR SKILL axlXSectionGet() returns Primary list of layers and not All stackups 1657257 SIP_LAYOUT EXTRACT When using extracta, custom layer names not getting retained 1658440 ALLEGRO_EDITOR PAD_EDITOR The location of a drill in the .pad file is different from the .dra file 1658445 CONSTRAINT_MGR CONCEPT_HDL When DCF file is converted to ASCII, no further updates are allowed. 1659473 SIP_LAYOUT WIREBOND When moving wirebonds they are jumping instead of sliding 1659498 ALLEGRO_EDITOR INTERACTIV Unable to turn off line on Etch Wire for Jumpers 1659644 CONCEPT_HDL OTHER Predefined nets are not listed if 16.6 design is being opened in 17.2 1660475 CONSTRAINT_MGR UI_FORMS The CTRL+V shortcut is not working in the Export Constraints window in Constraint Manager 17.2 1660492 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes when using multiple desktops on Windows 10 1661133 CONSTRAINT_MGR ANALYSIS PCB Editor crashes if comma is used in the Value field for Analysis Mode 1661307 CONSTRAINT_MGR CONCEPT_HDL Prevent creation of diff pairs on VOLTAGE nets 1661357 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes when using Route - Connect 1661874 ASDA DESIGN_CORRUPTIO Unable to delete the ZERO part from the schematic page 1662799 ADW SRM Mechanical symbols are not being displayed in the Mechanical tab of Symbol Rollback Manager 1664797 SIG_INTEGRITY GUI Unnecessary coupled interconnect models were generated during View Waveform. 1664858 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes during Auto Interactive trunk route. 1664911 ALLEGRO_EDITOR OTHER PCB Editor freezes after DRC Update is performed 1666329 CONSTRAINT_MGR OTHER SCM Import Physical process crashes cmfeedback 1666551 ALLEGRO_EDITOR ARTWORK Import Artwork, Mirror option separates imported artwork to different XY locations 1666723 ECW TDO-SHAREPOINT TDO login is not working with Site Minder because of incorrect characters in the Site Minder login form HTML 1667068 ALLEGRO_EDITOR SHAPE Update shape removing the shape voiding 1669828 F2B DESIGNVARI Variant Editor crashes on Windows 10 T540 P laptops but works fine on Windows 10 desktops 1670221 ALLEGRO_EDITOR DATABASE Non-recoverable corruption error is reported when saving the board after adding a layer 1672134 ALLEGRO_EDITOR ZONES TDP needs FIXED component override
Jan 9 2017, 13:17
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 010Код DATE: 01-6-2017 HOTFIX VERSION: 010 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1524700 F2B DESIGNVARI Variant file cannot be loaded 1597787 CONCEPT_HDL MARKERS Save As in Marker dialog causes DE-HDL to crash 1599843 CONCEPT_HDL INTERFACE_DESIGN Moving NG causes extra elements or moving 1620017 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053) when $PART_NUMBER property for components has a value 1632977 CONCEPT_HDL INTERFACE_DESIGN Connectivity error when moving NG members 1635941 ALLEGRO_EDITOR INTERFACES Shape created by IPC 2581 for negative film is not same as the shape on board 1656357 CONCEPT_HDL CORE Pasting a signal name across pages causes the name to overlap with the wire segment 1657346 CONCEPT_HDL PDF Wire Pattern set to two-dot chain line in a schematic appears as a solid line in the PDF output 1658048 ALLEGRO_EDITOR COLOR color_lastgroup is not working in SPB 17.2 1658874 CONCEPT_HDL CORE 'Insert (n) Pages' command does not work when the CONFIRM_WRITE directive is ON 1659030 RF_PCB LIBRARY Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols 1659097 CONCEPT_HDL CORE mouse stroke fails to be enabled on startup with left moust button (LMB) 1659532 CONCEPT_HDL CORE About Import Design command with the CONFIRM_WRITE directive 1659929 CONSTRAINT_MGR UI_FORMS Using wildcards in filename for Import Constraints does not work in 17.2 1660200 ALLEGRO_EDITOR UI_GENERAL Move by Sym Pin # edit box is obfuscated 1662821 ALLEGRO_EDITOR OTHER Cross section chart does not show stack vias in 17.2 1663641 CONCEPT_HDL COPY_PROJECT File - Copy Project in Project Manager creates two designs if there are dashes in the design name 1665652 ALLEGRO_EDITOR SHAPE Critical fillet and shape issues in 17.2 1665918 CONCEPT_HDL CHECKPLUS Error (100) Program Internal Error "Create_flat_node" with checkplus run 1667056 ASI_PI GUI Power Feasibility Editor does not list capacitors connected to selected nets/parts 1668137 ALLEGRO_EDITOR SCRIPTS PCB Editor crashing when running Script Replay 1669651 CONCEPT_HDL CREFER CreferHDL values are invisible 1669707 CONCEPT_HDL CORE Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property 1670339 ALLEGRO_EDITOR OTHER Small shapes define on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass. 1670564 ALLEGRO_EDITOR MANUFACT exported gerber file can't import in brd 1670687 ALLEGRO_EDITOR NC nclegend.log reports missing columns which are present in the NC Legend 1670811 PSPICE AA_MC AA MC Plot settings options 1671428 ALLEGRO_EDITOR UI_FORMS Display origin checkbox position changes in Step Mapping dialog 1671728 CONCEPT_HDL CORE Option requested to reload preferred_projects.txt without re-opening DE-HDL 1671901 ALLEGRO_EDITOR UI_GENERAL Toolbar and menus are locked or greyed out 1672477 ALLEGRO_EDITOR DRC_CONSTR DRC generated by Dynamic fillets 1673499 ALLEGRO_EDITOR DATABASE Would you please check on the drill table title issue of backdrill design in v172. 1673681 ALLEGRO_EDITOR UI_GENERAL F1 for Help not working in PCB Editor 17.2 1675499 ALLEGRO_EDITOR DATABASE Running the Gloss command causes PCB Editor to crash... 1676480 ALLEGRO_EDITOR MANUFACT Creating Variant Assy_Bot Drawing showing Variant Assy Top Drawing 1677431 ALLEGRO_EDITOR DATABASE Get ERROR(SPMHA1-141): Invalid sector row. Contact cadence customer support when opening DRA File 1677651 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crash on design after successful packaging 1677672 CONCEPT_HDL CORE Whitespaces in URL links are not resolved correctly on Linux with Firefox 1680837 ALLEGRO_EDITOR SHAPE Updating the shape makes the shape disconnect from Thru pins of same net 1681059 ALLEGRO_EDITOR SHAPE Shape Voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners. 1682312 SIG_INTEGRITY LICENSING Allegro Sigrity SI/PI Product Choices window is blank after installing 17.2-s009 hotfix
Jan 23 2017, 17:27
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 011Код DATE: 01-20-2017 HOTFIX VERSION: 011 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1618986 CONCEPT_HDL CORE Information required about the DONT_FORCE_ORIGIN_ONGRID directive 1629696 PSPICE PROBE After successfully exporting traces to csv, PSpice crashes on a subsequent attempt to export traces 1667213 CAPTURE NETLIST_ALLEGRO Tools - Create Netlist stops responding on Windows10 1667599 APD OTHER Wire Bond operations taking longer than expected to complete 1667678 MODEL_EDITOR PARSE Signal model assignment creates ESpice models that do not pass Model Integrity checks 1670120 ALLEGRO_EDITOR UI_GENERAL In 17.2, the Static Phase meter shows up in the middle of the screen instead of the lower right corner 1670927 ALLEGRO_EDITOR DRAFTING Using zcopy to create a Route Keepin results in database errors 1675359 ALLEGRO_EDITOR ARTWORK Subclass ETCH/WIRE is added to artwork definition though the visibility of 'ALL Layers' is turned off 1675619 ALLEGRO_EDITOR MANUFACT Differences observed in IPC-D-356A between releases 16.6 and 17.2 1676161 ADW FLOW_MGR Operation load JNI code failed error while opening project in SPB 17.2 1677405 CONCEPT_HDL OTHER When moving a wire with a dot, the dot is not removed directly 1678061 PSPICE SLPS Simulating an SLPS co-simulation with a Fixed-step solver with a value smaller than 1E-4 results in a crash 1679347 PSPICE SLPS SLPS crashes when co-simulating without opening OrCAD Capture or PSpice 1680113 ALLEGRO_EDITOR SHAPE Irregular void created on dynamic shapes 1680802 ALLEGRO_EDITOR DATABASE A 16.3 database locked with disabled export of design data should be view only in 16.6 1681129 ALLEGRO_EDITOR DATABASE Match Groups in the DE-HDL design are not getting transferred to the board file 1681514 ALLEGRO_EDITOR UI_GENERAL Opening the Dynamic Shapes State report hangs PCB Editor in 17.2 Hotfix 009 1681727 CAPTURE NETGROUPS In 17.2, Capture crashes when closing a design that has assigned Netgroups 1682297 ALLEGRO_EDITOR DATABASE Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version 1682447 CONSTRAINT_MGR CONCEPT_HDL Extraction issue on differential pairs in the given design 1682454 CONSTRAINT_MGR CONCEPT_HDL Design with NO_XNET_CONNECTION property on parts is exported to PCB Editor; many other components get the property 1682469 CONSTRAINT_MGR CONCEPT_HDL Creating a CSet from an existing CSet leads to invalid CSet names in Constraint Manager connected to DE-HDL 1683919 ECW TDO-SHAREPOINT Site Minder integration for login from TDA not working after SSL certificate update 1684111 ALLEGRO_EDITOR SHAPE Dynamic Shape not voiding overlapped static shape 1684508 ALLEGRO_EDITOR AUTOVOID Allegro PCB Editor stops responding when deleting a via 1685540 ALLEGRO_EDITOR OTHER If text is attached to an object, the object is also printed in the PDF 1685810 ALLEGRO_EDITOR PAD_EDITOR In 17.2, Padstack Editor does not save adjacent layer information for BOTTOM pads 1685986 ALLEGRO_EDITOR PADS_IN PADS Translator-generated output shows incorrect unit for the soldermask oversize option 1686127 ALLEGRO_EDITOR SHAPE The void of shape missed in artwork. 1686791 ALLEGRO_EDITOR OTHER Searchable property unavailable on bottom layer pins in the generated PDF
Feb 13 2017, 18:33
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 012Код DATE: 02-3-2017 HOTFIX VERSION: 012 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1659641 ADW FLOW_MGR Documentation Editor does not invoke when a .brd file is opened from EDM Flow Manager 1661632 CONCEPT_HDL OTHER Page skipped in DE-HDL when navigating using the Page Up and Page Down keys 1668325 ALLEGRO_EDITOR SHAPE Updating shapes to smooth creates erratic voids. 1670082 CONSTRAINT_MGR ANALYSIS Inconsistency in Constraint Analysis Modes - Electrical in OrCAD PCB Designer Professional 17.2 1674231 ECW METRICS Re-upload for local metric packets that failed on first attempt is not working when Pulse server name contains dots 1674338 APD SHAPE Shape is not clearing slivers that are smaller than the 'Minimum aperture for gap width' of '18 um' 1675677 ADW DBEDITOR DBeditor Issue-Searching by using the Properties method 1677489 CONCEPT_HDL CREFER CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers 1679351 ALLEGRO_EDITOR REPORTS Missing Fillets Report is not showing missing fillets on the bottom layer 1681002 ALLEGRO_EDITOR OTHER 17.2 STEP output fails to produce an output similar to 16.6 1682287 ALLEGRO_EDITOR EDIT_ETCH Auto-interactive Delay tune (AiDT) rips lines that have been routed 1682900 ALLEGRO_EDITOR PLACEMENT Moving a symbol by snapping to segment vertex with 17.2 Hotfix 009 crashes PCB Editor 1684117 CONCEPT_HDL CONSTRAINT_MGR Property deleted from Constraint Manager is not getting updated in the DE-HDL canvas 1686803 ALLEGRO_EDITOR INTERFACES PCB Editor crashes if the 'ipc2581_group_drills' variable is set. 1687816 ALLEGRO_EDITOR PLOTTING Export PDF Vector text option does not work 1688287 CONSTRAINT_MGR DATABASE PCB Editor crashing while adding a net to a net group. 1689881 ALLEGRO_EDITOR DFA Record and replay script for loading DFA spreadsheet not working 1690958 ALLEGRO_EDITOR SKILL SKILL command axlDBDelLock is not working as explained in the documentation 1692166 APD DATABASE DB Doctor returns 'ERROR(SPMHDB-252): A corrupt database pointer was detected' for a specific design 1693431 ALLEGRO_EDITOR SKILL Running axlXSectionModify and axlXSectionSet results in warnings and corrupts multi-zone cross-section 1693719 ALLEGRO_EDITOR MANUFACT Incorrect suppressed holes information in the drill file created 1693846 ALLEGRO_EDITOR MANUFACT PCB Editor crashes when running the gloss command 1694151 CONCEPT_HDL CORE Rename Signal for unnamed net added the sig_name at the incorrect position with small text size. 1694867 ALLEGRO_EDITOR SHAPE Void is deleted by the shape merge command 1695131 ALLEGRO_EDITOR SKILL PCB Editor crashes when using the axlSpreadsheetDefineCell SKILL function
Feb 19 2017, 18:31
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 013 Код Fixed CCRs in SPB 17.2 HF013 02-17-2017 ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ 1567741 ADW COMPONENT_BRO The PPL_list never gets read when using a saveconf.ctr located in the global site.cpm 1697109 ALLEGRO_EDITOR ARTWORK Artwork not showing padstacks for the soldermask layer 1682297 ALLEGRO_EDITOR DATABASE Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version 1697309 ALLEGRO_EDITOR DATABASE PCB Editor 17.2 uprev changes NC pins from non-plated to plated 1698624 ALLEGRO_EDITOR DATABASE Opening 16.6 board in 17.2 converts non-plated holes to plated 1697092 ALLEGRO_EDITOR OTHER axlDBViaStack crashes PCB Editor session and corrupts the board 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1696637 ALLEGRO_EDITOR UI_GENERAL Padstack Editor uses Region and Language settings for the decimal symbol 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1616138 ALTM_TRANSLATOR PCB_EDITOR Board file imported from third-party tool to PCB Editor has the shapes but not the components 1666020 ALTM_TRANSLATOR PCB_EDITOR Board converted from a third-party tool to PCB Editor has missing components 1690448 CAPTURE CORRUPT_DESIG Corrupt design: nets in this design are not displayed when running Edit - Browse - Nets 1690455 CAPTURE CORRUPT_DESIG Corrupt design: all the nets in this design are not displayed when running Edit - Browse - Nets 1684180 CONCEPT_HDL CORE Message should indicate that the user needs to reload the design after setting SET STICKY_OFF 1695987 CONCEPT_HDL CORE $PN placement in DE-HDL during part development is not following mouse placement 1688287 CONSTRAINT_MGR DATABASE PCB Editor crashing while adding a net to a net group. 1675013 ORBITIO ALLEGRO_SIP_I Failed to import brd file 1698968 SIP_LAYOUT 3D_VIEWER 3D viewer shows keepin and not design outline. 1699884 SIP_LAYOUT ASSY_RULE_CHE SiP Layout crashes on using Assembly Rules Checker 1689969 SIP_LAYOUT DIE_EDITOR SiP Layout crashes when moving dies using relative coordinates 1696239 SIP_LAYOUT DIE_EDITOR When using the Die-stack Editor to move and stretch wires, SiP Layout crashes 1695372 SIP_LAYOUT REPORTS Running the Metal Usage reports fails on the Primary side.
Mar 5 2017, 19:29
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 014 Код Fixed CCRs: SPB 17.2 HF014 03-4-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1691828 ADW COMPONENT_BRO Part Information Manager displays incorrect data related to attributes on relationships 1700963 ALLEGRO_EDITOR DATABASE Running the 'slide' command results in the cline segment losing connectivity 1685502 ALLEGRO_EDITOR INTERFACES The Export - PDF command fails to export the TOP etch subclass with error code SPMHGE-268 1644643 ALLEGRO_EDITOR MANUFACT The NC drill legend does not match the drill customization data 1700557 ALLEGRO_EDITOR MANUFACT DXF output does not contain drill figure data 1660252 ALLEGRO_EDITOR NC NC Drill file generated with errors 1677775 ALLEGRO_EDITOR NC Merging of drills not retained in database. 1701554 ALLEGRO_EDITOR SHAPE Shape spacing clearance is not updated unless the shape vertex is deleted 1704669 ALLEGRO_EDITOR SHAPE Route Keepin is not getting created at a specific location 1685995 ALLEGRO_EDITOR SKILL All film sequence numbers are returned as 0 when using the SKILL function axlGetParam 1621336 ALLEGRO_EDITOR UI_GENERAL Changing the color visibility does not refresh the screen color immediately 1668817 ALLEGRO_EDITOR UI_GENERAL Changing the visibility or the color on the canvas in release 17.2-2016 takes longer than release 16.6 1671268 ALLEGRO_EDITOR UI_GENERAL Visibility Window: There is a noticeable lag when enabling etch, via, and pin on a specific layer one by one 1690691 ALLEGRO_EDITOR UI_GENERAL Reports not generating if the 'allegro_html_qt' environment variable is disabled 1709903 ALLEGRO_EDITOR UI_GENERAL Toggling layer visibility does not change the display until the mouse pointer is moved 1647596 APD EXPORT_DATA Allegro Package Designer crashes when trying to export board-level components 1688035 APD OTHER Significant difference seen in the percentage of metal between the Metal Usage reports of positive and negative layers 1690777 CONCEPT_HDL CHECKPLUS Rules Checker returns an error when the value of the PACK_TYPE property is in lowercase 1695987 CONCEPT_HDL CORE $PN placement in DE-HDL during part development is not following mouse placement 1700873 CONCEPT_HDL CORE With duplicate part table files, running the Assign Power Pins command crashes DE-HDL without any message 1702703 CONCEPT_HDL CORE Location of $PN in DE-HDL Symbol Editor is not as precise as it was in 17.2 Hotfix 011 1705999 CONCEPT_HDL CORE Signal naming is not working correctly in SPB 17.2 1677489 CONCEPT_HDL CREFER CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers 1698259 CONSTRAINT_MGR CONCEPT_HDL Unstable $LOCATION property in release 17.2-2016 1702537 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors reported after removing the signal models on an upreved design 1703981 CONSTRAINT_MGR TECHFILE Importing a technology file (.tcf) results in packaging errors 1673115 ECW INTEGRATION Import from external data sources (Integrations) truncates input values to 128 characters 1699395 FSP FPGA_SUPPORT Selecting a QSF part name in the FPGA Properties window crashes FSP 1704353 INSTALLATION DOWNLOAD_MGR Selecting 'View' in Download Manager results in error, 'Object Reference not set to an instance of an object' 1705265 INSTALLATION DOWNLOAD_MGR Problem installing OrCAD Library Builder from Download Manager 1646635 PDN_ANALYSIS PCB_PI PCB Editor uses 'powerdc.exe' to launch PowerDC instead of the 'powerdc' script
Mar 27 2017, 18:54
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 015 Код DATE: 03-16-2017 HOTFIX VERSION: 015 ================================================================= CCRID Product ProductLevel2 Title ================================================================= 1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol 1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model 1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function 1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file 1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting Padstack Editor results in incorrectly scaled forms 1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design 1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated in 30 degrees 1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled. 1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used 1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places 1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value 1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically 1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad 1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout 1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file 1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084 1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position 1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer 1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation 1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates 1712964 SIP_LAYOUT SYMBOL SiP Layout crashes when using Renumber Pins in Symbol Edit application mode
Apr 10 2017, 19:03
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 016 Код Fixed CCRs: SPB 17.2 HF016 04-6-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1567741 ADW COMPONENT_BRO The PPL_list never gets read when using a saveconf.ctr located in the global site.cpm 1623832 ADW COMPONENT_BRO Incorrect part placement on schematic in Design Entry HDL 16.6-S073 1673128 ADW COMPONENT_BRO Directive is saved in project CPM 1673510 ADW COMPONENT_BRO Lifecycle status color column is not sorted correctly in Component Browser search results 1691828 ADW COMPONENT_BRO Part Information Manager displays incorrect data related to attributes on relationships 1604734 ADW DATABASE Parts displaying non-key properties and values in the Component Browser in ADW 1585203 ADW DBEDITOR Optimize check-in of footprints with multiple padstacks 1675677 ADW DBEDITOR Database Editor (dbeditor) hangs while searching by property 1142957 ADW DSN_FLOW No Help available for schematic design verification 1609186 ADW DSN_MIGRATION ADW Design Migration utility should handle ADW board reference projects and manage atdm.ini 1656224 ADW FLOW_MGR Copy Project wizard no longer allows dashes in the 'Name of new project folder' field 1659641 ADW FLOW_MGR Documentation Editor does not invoke when a .brd file is opened from EDM Flow Manager 1676161 ADW FLOW_MGR Opening a project in release 17.2 flags the 'Operation load JNI code failed' error 1591757 ADW GENERIC_UI Running 'Create Test Schematic' in ADW Flow Manager results in Error SPCOCN-1736 1591027 ADW LIBDISTRIBUTI Library Distribution redistributes previously distributed models 1588111 ADW LIBIMPORT Library Import fails with Java errors while processing .csv files 1653422 ADW LIBIMPORT Classifications not linked to a Part Number or Cell Model are removed during Library Import 1632223 ADW LRM Checking in a hierarchy causes a crash 1618173 ADW SRM SRM does not automatically run when a .brd file is opened from EDM Flow Manager in release 17.2 Hotfix 003 1618832 ADW SRM SRM marks parts as updated even when they are not updated 1662799 ADW SRM Mechanical symbols are not being displayed in the Mechanical tab of Symbol Rollback Manager 1633454 ADW TDA TDO crashes if DAO throws an exception 1628403 ADW TDO-SHAREPOIN Objects remain checked out after multiple failed 'check-in hierarchy' attempts 1632462 ALLEGRO_EDITOR 3D_CANVAS 3D View (new) and PCB Editor crash when checking collisions 1632590 ALLEGRO_EDITOR 3D_CANVAS PCB Editor crashes when 3D View is open and more 16.6 boards are opened 1636216 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas (Unsupported prototype) is not mapping Step model when assigned to a device 1636899 ALLEGRO_EDITOR 3D_CANVAS The new 3D Viewer is not taking the Package Height set on the PLACE_BOUND layer into account when displaying it. 1642367 ALLEGRO_EDITOR 3D_CANVAS Component height is not correct in new 3D Viewer 1642668 ALLEGRO_EDITOR 3D_CANVAS The new 3D canvas does not show STEP model of the drawing (.dra) 1650106 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas: Symbols are mirrored at incorrect angles 1651011 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D viewer shows mechanical symbol mirrored 1653247 ALLEGRO_EDITOR 3D_CANVAS New interactive 3D Viewer shows wrong placement 1658275 ALLEGRO_EDITOR 3D_CANVAS Components on the bottom side are shifted in the new 3D view 1635858 ALLEGRO_EDITOR ARTWORK Get 'WARNING: Null REGULAR-PAD specified for padstack' messages in log file when generating artwork for all layers 1639244 ALLEGRO_EDITOR ARTWORK When importing an artwork, a sub-folder is created with the value of the ads_sdart environment variable 1647843 ALLEGRO_EDITOR ARTWORK Misleading information in command window when artwork import fails 1651925 ALLEGRO_EDITOR ARTWORK Searching for a macro in the artwork data file: Count for the macro does not match the actual count in the output 1658173 ALLEGRO_EDITOR ARTWORK ARTWORK: Value of Scale factor for output. 1661760 ALLEGRO_EDITOR ARTWORK Import artwork to Design Outline layer does not give error in Allegro prompt. 1666551 ALLEGRO_EDITOR ARTWORK Import Artwork: Mirror option separates imported artwork to different XY locations 1675359 ALLEGRO_EDITOR ARTWORK Subclass ETCH/WIRE is added to artwork definition though the visibility of 'ALL Layers' is turned off 1697109 ALLEGRO_EDITOR ARTWORK Artwork not showing padstacks for the soldermask layer 1684508 ALLEGRO_EDITOR AUTOVOID Allegro PCB Editor stops responding when deleting a via 1605961 ALLEGRO_EDITOR COLOR Wildcards not working in the Filter Nets field of the Color Dialog window 1633608 ALLEGRO_EDITOR COLOR Dehighlight command: The 'Retain Objects Custom Color' option should not be enabled by default 1658048 ALLEGRO_EDITOR COLOR color_lastgroup is not working in SPB 17.2 1667778 ALLEGRO_EDITOR COLOR Add option to set FORM mini dehl_retain_color to NO 1669462 ALLEGRO_EDITOR COLOR Changes made to the Visibility tab are not reflected in the Color Dialog window 1641265 ALLEGRO_EDITOR CROSS_SECTION The differential impedance value for a layer is not getting updated 1648149 ALLEGRO_EDITOR CROSS_SECTION Getting warning when calculating impedance in mixed stackup 1651063 ALLEGRO_EDITOR CROSS_SECTION Cross-section preview is incorrect 1653951 ALLEGRO_EDITOR CROSS_SECTION Cross Section Editor changes lost despite selecting No to the 'All changes will be lost ...' message 1671441 ALLEGRO_EDITOR CROSS_SECTION Enhancement request for cross section dialog box 1673320 ALLEGRO_EDITOR CROSS_SECTION Diff impedance calculation fails 1690021 ALLEGRO_EDITOR CROSS_SECTION How to keep settings of expanded/compressed columns in the Xsection 1703831 ALLEGRO_EDITOR CROSS_SECTION Calculation of Diff Z0 fails in flex designs 1711484 ALLEGRO_EDITOR CROSS_SECTION ShowAll Column does not retain its status 1607250 ALLEGRO_EDITOR DATABASE A board file created in release 16.5 crashes when opened in 16.6 Hotfix 69 1610456 ALLEGRO_EDITOR DATABASE Selecting user-defined subclasses when using strip design results in database corruption 1633707 ALLEGRO_EDITOR DATABASE Cannot remove Route_Keepout associated with a pin 1638251 ALLEGRO_EDITOR DATABASE Unplated hole changed to plated hole after uprev from release 16.6 to 17.2 1651066 ALLEGRO_EDITOR DATABASE Pins not connecting even after running the Tools - Derive Connectivity command 1653526 ALLEGRO_EDITOR DATABASE Via padstack keepout is not displayed on the canvas when pads suppression is enabled. 1670221 ALLEGRO_EDITOR DATABASE Non-recoverable corruption error is reported when saving the board after adding a layer 1672841 ALLEGRO_EDITOR DATABASE ERROR(SPMHDB-153): Table corrupt; current/maximum mismatch 1673499 ALLEGRO_EDITOR DATABASE Drill table title issues of backdrill designs in release 17.2 1673613 ALLEGRO_EDITOR DATABASE COVERLAY_TOP not present in the Non-conductor section of Color Dialog window 1675499 ALLEGRO_EDITOR DATABASE Running the Gloss command causes PCB Editor to crash 1677431 ALLEGRO_EDITOR DATABASE Get ERROR(SPMHA1-141): Invalid sector row. Contact cadence customer support when opening DRA File 1680802 ALLEGRO_EDITOR DATABASE Release 16.3 database locked by disabling export of design data should be view-only in release 16.6 1681129 ALLEGRO_EDITOR DATABASE Match Groups in DE-HDL design are not getting transferred to the board file 1682297 ALLEGRO_EDITOR DATABASE Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version 1688123 ALLEGRO_EDITOR DATABASE Drill Plating Issue 1697309 ALLEGRO_EDITOR DATABASE In release 17.2, PCB Editor uprev changes NC pins from non-plated to plated 1698624 ALLEGRO_EDITOR DATABASE Opening a 16.6 board in release 17.2 converts non-plated holes to plated 1700963 ALLEGRO_EDITOR DATABASE Running the 'slide' command results in the cline segment losing connectivity 1701995 ALLEGRO_EDITOR DATABASE When upreving a 16.6 brd to release 17.2, lines drawn on OUTLINE are translated to CUTOUT and not DESIGN_OUTLINE 1710772 ALLEGRO_EDITOR DATABASE Mirror command not working on zones 1713335 ALLEGRO_EDITOR DATABASE Defining Adjacent_layer_keepout_above and/or Adjacent_layer_keepout_below and then saving the .dra file giving error 1689881 ALLEGRO_EDITOR DFA Record and replay script for loading DFA spreadsheet not working 1693289 ALLEGRO_EDITOR DFA File - Save As script does not save the DFA file 1670927 ALLEGRO_EDITOR DRAFTING Using zcopy to create a Route Keepin results in database errors 1488909 ALLEGRO_EDITOR DRC_CONSTR Test Via causes net scheduling verification to fail 1644004 ALLEGRO_EDITOR DRC_CONSTR Unreported DRCs from dynamic copper to line and dynamic copper to SMT pin 1651425 ALLEGRO_EDITOR DRC_CONSTR The .brd file crashes when moving text controlled with minimum metal to metal constraints 1663494 ALLEGRO_EDITOR DRC_CONSTR Reported Mechanical Pin to conductor spacing DRC constraint value is incorrect leading to false DRCs 1672477 ALLEGRO_EDITOR DRC_CONSTR Although Allow DRC is not selected, DRC generated by dynamic fillets 1596955 ALLEGRO_EDITOR EDIT_ETCH Scribble mode not showing correct finish point in single trace mode 1639483 ALLEGRO_EDITOR EDIT_ETCH Manually routing discrete components with incorrect constraints causes PCB Editor to crash 1661357 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes when using Route - Connect 1664858 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes during Auto Interactive trunk route. 1682287 ALLEGRO_EDITOR EDIT_ETCH Auto-interactive Delay tune (AiDT) rips lines that have been routed 1687049 ALLEGRO_EDITOR EDIT_ETCH Create a Via Structure disconnects nets 1704296 ALLEGRO_EDITOR EDIT_ETCH Asymmetrical fanout created for BGA Quadrant style 1686873 ALLEGRO_EDITOR EDIT_SHAPE Merge static shapes deletes both the shapes selected. 1629925 ALLEGRO_EDITOR GRAPHICS Errors reported and no layout data drawn in PCB Editor in release 17.2 Hotfix 003 on Ubuntu 14.04 1619412 ALLEGRO_EDITOR INTERACTIV Script to create new padstacks from existing padstack is putting in wrong values for a regular pad 1621887 ALLEGRO_EDITOR INTERACTIV Getting a 'Could not satisfy the snap condition' message when using the Snap pick to option 1628895 ALLEGRO_EDITOR INTERACTIV Shape Edit mode: An error message is required when attempting to edit a Shape with the FIXED property 1659498 ALLEGRO_EDITOR INTERACTIV Unable to turn off line on Etch Wire for Jumpers 1666379 ALLEGRO_EDITOR INTERACTIV Place replicate is not working on the attached test case 1668282 ALLEGRO_EDITOR INTERACTIV Grid display incorrect for repeated grids 1675531 ALLEGRO_EDITOR INTERACTIV Design Entry CIS: Cross Probing with PCB Editor and Constraint Manager is not working 1694470 ALLEGRO_EDITOR INTERACTIV Update description of variable padstack_nowarning_display 1696855 ALLEGRO_EDITOR INTERACTIV Mixed grid setting is not displayed correctly on Define Grid screen. 1698192 ALLEGRO_EDITOR INTERACTIV Deleting and replacing a component causing database corruption in Hotfix 009 1703671 ALLEGRO_EDITOR INTERACTIV An error occurs when defining grids with zero increment value 1703812 ALLEGRO_EDITOR INTERACTIV Crash during move when using the 'snap pick to' option set to symbol origin 1719276 ALLEGRO_EDITOR INTERACTIV Setting variable grid for 'All Etch' displays an error in the Define Grid form 1635941 ALLEGRO_EDITOR INTERFACES Shape created by IPC 2581 for negative film does not match the shape on the board 1639845 ALLEGRO_EDITOR INTERFACES Step file not generated when board is exported to a folder with special characters in name 1641339 ALLEGRO_EDITOR INTERFACES DXF_IN does not show all the subclasses available in the design 1648183 ALLEGRO_EDITOR INTERFACES Allegro STEP Export: Using the 'step_3D_copper' variable, pads not exported in the same plane as traces and shapes 1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol 1663422 ALLEGRO_EDITOR INTERFACES Shape loses group membership after importing through sub-drawing 1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model 1685502 ALLEGRO_EDITOR INTERFACES The Export - PDF command fails to export the TOP etch subclass with error code SPMHGE-268 1686803 ALLEGRO_EDITOR INTERFACES PCB Editor crashes if the 'ipc2581_group_drills' variable is set. 1633647 ALLEGRO_EDITOR MANUFACT Variant issue: Create Assembly Drawing command not creating filled shapes for keying pegs in attached design 1637959 ALLEGRO_EDITOR MANUFACT Thieving uses different clearance values around the route keepin. 1644643 ALLEGRO_EDITOR MANUFACT The NC drill legend does not match the drill customization data 1646932 ALLEGRO_EDITOR MANUFACT Manufacture - Auto Rename Refdes keeps defaulting to Use Default Grid even if another is chosen 1670564 ALLEGRO_EDITOR MANUFACT Exported Gerber file cannot be imported in brd 1675619 ALLEGRO_EDITOR MANUFACT Differences observed in IPC-D-356A between releases 16.6 and 17.2 1676480 ALLEGRO_EDITOR MANUFACT Creating Variant Assy_Bot Drawing showing Variant Assembly Top Drawing 1693719 ALLEGRO_EDITOR MANUFACT Incorrect suppressed holes information in the drill file created 1693846 ALLEGRO_EDITOR MANUFACT PCB Editor crashes when running the gloss command 1700557 ALLEGRO_EDITOR MANUFACT DXF output does not contain drill figure data 1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function 1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file 1716431 ALLEGRO_EDITOR MANUFACT Test points generation stops due to an error 1660252 ALLEGRO_EDITOR NC NC Drill file generated with errors 1670687 ALLEGRO_EDITOR NC nclegend.log reports missing columns which are present in the NC Legend 1677775 ALLEGRO_EDITOR NC Merging of drills not retained in database. 1607956 ALLEGRO_EDITOR OTHER Unable to generate the model index file from the command line using the mkdeviceindex utility 1623112 ALLEGRO_EDITOR OTHER Switch Release unable to identify the 16.6 release when it is installed in the All Users mode 1641994 ALLEGRO_EDITOR OTHER DB Doctor: Incorrect spelling of 'eliminated' in the log file messages 1642597 ALLEGRO_EDITOR OTHER Importing .tdp file: Footprints not included in the .tdp file are updated in the design 1643532 ALLEGRO_EDITOR OTHER Strip design command fails to delete symbol text in the attached design 1652930 ALLEGRO_EDITOR OTHER Command-line version of switchversion not working 1656581 ALLEGRO_EDITOR OTHER PDF generated for layer with shape shows undesired voids if film is mirrored and Filled Shape is not selected 1660496 ALLEGRO_EDITOR OTHER SiP Layout crashes when trying to generate abstract level view by using export chips and connectivity 1662821 ALLEGRO_EDITOR OTHER Cross section chart does not show stack vias in release 17.2 1664911 ALLEGRO_EDITOR OTHER PCB Editor freezes after DRC Update is performed 1670339 ALLEGRO_EDITOR OTHER Small shapes defined on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass. 1681002 ALLEGRO_EDITOR OTHER STEP output in release 17.2 is different from release 16.6 1685464 ALLEGRO_EDITOR OTHER The 'alias ~S save' command is not recognized when set in the local env file 1685540 ALLEGRO_EDITOR OTHER If text is attached to an object, the object is also printed in the PDF 1686791 ALLEGRO_EDITOR OTHER Searchable property unavailable on bottom layer pins in the generated PDF 1696486 ALLEGRO_EDITOR OTHER STEP export results vary between releases 16.6 and 17.2 1697092 ALLEGRO_EDITOR OTHER axlDBViaStack crashes PCB Editor session and corrupts the board 1706623 ALLEGRO_EDITOR OTHER axlBackdrillGet crashes for invalid argument 1622680 ALLEGRO_EDITOR PADS_IN Import PADS fails with the 'ERROR: *NET* section found. Translation of netlist is not allowed.' message 1685986 ALLEGRO_EDITOR PADS_IN PADS Translator-generated output shows incorrect unit for the soldermask oversize option 1578533 ALLEGRO_EDITOR PAD_EDITOR New Padstack Editor does not automatically update the geometry 1586957 ALLEGRO_EDITOR PAD_EDITOR In Pad Editor, selecting a pad geometry is not showing up in the Design Layers tab 1610984 ALLEGRO_EDITOR PAD_EDITOR Geometry set in tabs not read, only initial value set in Start page is used 1614015 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor in release 17.2 does not auto fill geometry in design layers 1628409 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor does not remember the last used directory 1636012 ALLEGRO_EDITOR PAD_EDITOR Keepout should not be allowed if antipad is not defined for outer layers 1641973 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor: Path to the previously opened .pad file is not seeded in the File - Open dialog on a fresh launch 1642789 ALLEGRO_EDITOR PAD_EDITOR In release 17.2, 'Units' and 'Decimal Places' in Padstack Editor are not updated as per the .pad file 1646914 ALLEGRO_EDITOR PAD_EDITOR The 'Save' button is grayed out in Padstack Editor 1657553 ALLEGRO_EDITOR PAD_EDITOR No possibility to specify Padstack Editor default library path at invocation 1657609 ALLEGRO_EDITOR PAD_EDITOR Changing Tolerance field in Padstack Editor does not activate the Save button 1658440 ALLEGRO_EDITOR PAD_EDITOR The location of a drill in the .pad file is different from the .dra file 1662225 ALLEGRO_EDITOR PAD_EDITOR Padstack editor dialog message doesn't match available options 1667062 ALLEGRO_EDITOR PAD_EDITOR Padstack editor does not retain the decimal places from the previous session 1672774 ALLEGRO_EDITOR PAD_EDITOR Pad Editor graphics appear to show offset incorrectly 1674157 ALLEGRO_EDITOR PAD_EDITOR Update Symbols does not update Pad Type Information 1675438 ALLEGRO_EDITOR PAD_EDITOR Drill hole size warning for the SMD pad 1684376 ALLEGRO_EDITOR PAD_EDITOR Pad Editor issues with settings, such as decimal places, layers, and so on 1685810 ALLEGRO_EDITOR PAD_EDITOR In release 17.2, Padstack Editor does not save adjacent layer information for BOTTOM pads 1690376 ALLEGRO_EDITOR PAD_EDITOR Variable padstack_nowarning_display fails to suppress warnings 1694649 ALLEGRO_EDITOR PAD_EDITOR Change Cancel button to No in warning generated when updating padstacks in design layout 1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting Padstack Editor results in incorrectly scaled forms 1620814 ALLEGRO_EDITOR PARTITION Etch and Via are not imported with the partition 939242 ALLEGRO_EDITOR PLACEMENT Cross probing between Capture and PCB Editor is inconsistent 1103945 ALLEGRO_EDITOR PLACEMENT Place Replicate Create does not include the etch connected to pin 1233019 ALLEGRO_EDITOR PLACEMENT Allow cross probe object selection apart from highlighting during place replicate 1569272 ALLEGRO_EDITOR PLACEMENT Get the error message 'E- (SPMHDB-394): Placement cannot be completed ... ' after creating Place Replicate circuit 1606392 ALLEGRO_EDITOR PLACEMENT Filmmask not shown when component is attached to cursor 1633581 ALLEGRO_EDITOR PLACEMENT On mirroring a part, the cursor moves to the origin of the board 1633601 ALLEGRO_EDITOR PLACEMENT Place>Via Arrays>Boundary command: Via arrangement pattern deteriorated in Hotfix 004 as compared to Hotfix 003 1643078 ALLEGRO_EDITOR PLACEMENT PCB Editor flags an error message when a module is placed at a specific angle 1682900 ALLEGRO_EDITOR PLACEMENT Moving a symbol by snapping to segment vertex in release 17.2 Hotfix 009 crashes PCB Editor 1696932 ALLEGRO_EDITOR PLACEMENT Inconsistency with Snap pick to when selecting Segment Midpoint 1687816 ALLEGRO_EDITOR PLOTTING Export PDF Vector text option does not work 1654500 ALLEGRO_EDITOR REPORTS In release 17.2 Hotfix 006, display of Netin (back anno.) report fails when variable ads_sdreport is set 1679351 ALLEGRO_EDITOR REPORTS Missing Fillets Report is not showing missing fillets on the bottom layer 1623904 ALLEGRO_EDITOR SCHEM_FTB Logic import fails, but no error mentioned in the netrev.lst file 1643992 ALLEGRO_EDITOR SCHEM_FTB Export Physical fails with the 'netrev.exe has stopped working' error 1650801 ALLEGRO_EDITOR SCHEM_FTB Running Export Physical with Update PCB enabled in Project Manager crashes netrev.exe 1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design 1668137 ALLEGRO_EDITOR SCRIPTS PCB Editor crashes on running Script Replay 1496199 ALLEGRO_EDITOR SHAPE Overlapping route keepouts result in a broken shape. 1607954 ALLEGRO_EDITOR SHAPE Dynamic Shape not updating correctly 1611446 ALLEGRO_EDITOR SHAPE Inconsistent break in shape when creating voids in a design in 16.6 Hotfix 69 1625610 ALLEGRO_EDITOR SHAPE Modifying a shape boundary leads to other shapes losing their voids 1626001 ALLEGRO_EDITOR SHAPE Shape to route keepout DRCs reported for dynamic shapes in the attached design 1644406 ALLEGRO_EDITOR SHAPE Alternate symbol placement results in illegal parent identifier error 1653400 ALLEGRO_EDITOR SHAPE Dynamic shape does not void a via. 1665652 ALLEGRO_EDITOR SHAPE Critical fillet and shape issues in release 17.2 1667068 ALLEGRO_EDITOR SHAPE Update shape removing the shape voiding 1668262 ALLEGRO_EDITOR SHAPE dynamic shape does not void custom route keepout with arc 1668325 ALLEGRO_EDITOR SHAPE Updating shapes to smooth creates erratic voids. 1680113 ALLEGRO_EDITOR SHAPE Irregular void created on dynamic shapes 1680837 ALLEGRO_EDITOR SHAPE Updating the shape makes the shape disconnect from Thru pins of same net 1681059 ALLEGRO_EDITOR SHAPE Shape voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners. 1682569 ALLEGRO_EDITOR SHAPE Variable 'dv_squarecorners' not working correctly. 1684111 ALLEGRO_EDITOR SHAPE Dynamic Shape not voiding overlapped static shape 1686127 ALLEGRO_EDITOR SHAPE The void of shape missed in artwork. 1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated by 30 degrees 1694867 ALLEGRO_EDITOR SHAPE Void is deleted by the shape merge command 1696240 ALLEGRO_EDITOR SHAPE SKILL error when merging polygons 1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled. 1701554 ALLEGRO_EDITOR SHAPE Shape spacing clearance is not updated unless the shape vertex is deleted 1704669 ALLEGRO_EDITOR SHAPE Route Keepin is not getting created at a specific location 1709968 ALLEGRO_EDITOR SHAPE In release 17.2, DB Doctor reports error in shape when no error was reported in release 16.6 for the same shape 1596780 ALLEGRO_EDITOR SKILL PCB Editor crashes after doing SRM update and save 1623935 ALLEGRO_EDITOR SKILL On running the SKILL function, axlSectionModify, Shield and Etch Factor are not updated 1632505 ALLEGRO_EDITOR SKILL In release 17.2 Hotfix 004, PCB Editor crashes after SRM update and save 1647729 ALLEGRO_EDITOR SKILL When a fillet insert fails, the 'axlFillet' function returns 't' instead of nil 1651700 ALLEGRO_EDITOR SKILL Running axlXSectionModify() on a layer removes the value of the material 1651701 ALLEGRO_EDITOR SKILL Cannot set the etch factor value in the cross-section using the axlXSectionModify() skill command 1657220 ALLEGRO_EDITOR SKILL axlXSectionGet() returns Primary list of layers and not All stackups 1658419 ALLEGRO_EDITOR SKILL PCB Editor crashes after running SRM 1658948 ALLEGRO_EDITOR SKILL axlIsLayerNegative() is not working in release 17.2 1670956 ALLEGRO_EDITOR SKILL axlIsLayerNegative() always returns nil 1685995 ALLEGRO_EDITOR SKILL All film sequence numbers are returned as 0 when using the SKILL function axlGetParam 1687239 ALLEGRO_EDITOR SKILL Problem with skill function axlCNSGetPhysical - incorrect parse string 1690958 ALLEGRO_EDITOR SKILL SKILL command axlDBDelLock is not working as explained in the documentation 1692345 ALLEGRO_EDITOR SKILL The axlGetParm documentation example for deleting an artwork record is incorrect. 1693431 ALLEGRO_EDITOR SKILL Running axlXSectionModify and axlXSectionSet results in warnings and corrupts multi-zone cross-section 1695131 ALLEGRO_EDITOR SKILL PCB Editor crashes when using the axlSpreadsheetDefineCell SKILL function 1707878 ALLEGRO_EDITOR SKILL Object rat_t does not work with axlDBPinPairLength. 1626716 ALLEGRO_EDITOR UI_FORMS Z-Copy menu is not available with OrCAD PCB designer Professional license 1671428 ALLEGRO_EDITOR UI_FORMS Display origin checkbox position changes in Step Mapping dialog 1565795 ALLEGRO_EDITOR UI_GENERAL Search does not work in the Defined Variables window 1568817 ALLEGRO_EDITOR UI_GENERAL Padstack editor not accepting comma as decimal separator with system locale set as LANG ru_RU.UTF-8 1588769 ALLEGRO_EDITOR UI_GENERAL Alt+key shortcuts are not available in release 17.2 1589396 ALLEGRO_EDITOR UI_GENERAL Option needed in release 17.2 to change the placement of the Find, Visibility, and Options tabs similar to releases 16.x 1598061 ALLEGRO_EDITOR UI_GENERAL Adjust menus to allow side by side view 1599901 ALLEGRO_EDITOR UI_GENERAL Color Dialog box is not updating according to visibility tab. 1602563 ALLEGRO_EDITOR UI_GENERAL Shortcuts to menu items not working in release 17.2 1603776 ALLEGRO_EDITOR UI_GENERAL Alt key not working with menu commands 1609794 ALLEGRO_EDITOR UI_GENERAL PCB Editor: Shortcut keys to menus are not available in release 17.2 1611293 ALLEGRO_EDITOR UI_GENERAL If the Command window is floating, it cuts off text from the bottom half of the last line. 1611516 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts have no response 1611652 ALLEGRO_EDITOR UI_GENERAL New artwork film not appearing in the drop-down list for Visibility Tab 1614763 ALLEGRO_EDITOR UI_GENERAL Cannot scroll to the bottom of an undocked command window in PCB Editor 1617377 ALLEGRO_EDITOR UI_GENERAL Visibility pane does not retain the correct layer view 1617404 ALLEGRO_EDITOR UI_GENERAL axlUIMenuChange does not work as expected in release 17.2 1618205 ALLEGRO_EDITOR UI_GENERAL New Artwork film added is not updated in Visibility - View 1619873 ALLEGRO_EDITOR UI_GENERAL Command Window scrollbar does not reach its end 1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously 1621336 ALLEGRO_EDITOR UI_GENERAL Changing the color visibility does not refresh the screen color immediately 1624617 ALLEGRO_EDITOR UI_GENERAL Dialog box title under Setup > Outlines > Design Outline... Design is misspelled as "Desgin" 1624953 ALLEGRO_EDITOR UI_GENERAL Custom views in release 17.2 do not return to original 1631646 ALLEGRO_EDITOR UI_GENERAL Visibility pane not retaining the correct layer view 1633726 ALLEGRO_EDITOR UI_GENERAL Visibility tab not dynamically updating the view list when artwork film changes 1636864 ALLEGRO_EDITOR UI_GENERAL Domain Selection for Visibility does not work with Hotfix 004 unless you save and reopen the board file 1637062 ALLEGRO_EDITOR UI_GENERAL The last line of the floating command window in release 17.2 is hidden behind the command window frame 1642645 ALLEGRO_EDITOR UI_GENERAL Cannot scroll to the bottom of an undocked command window in PCB Editor 1645335 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes in Hotfixes 004 and 005 if ODE and Allegro Manufacturing options are installed 1646228 ALLEGRO_EDITOR UI_GENERAL Running the axlUIMenuInsert command to add a submenu after running the axlUIMenuFind command crashes the tool 1647520 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes after installing release 17.2 Hotfix 005 1647541 ALLEGRO_EDITOR UI_GENERAL Release 17.2 Hotfix 005: PCB Editor crashes immediately after launch 1650044 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts are not working properly in release 17.2 1651912 ALLEGRO_EDITOR UI_GENERAL Inconsistent response when using the Alt key 1652423 ALLEGRO_EDITOR UI_GENERAL Using the F1 key does not display the help document 1654600 ALLEGRO_EDITOR UI_GENERAL Spelling Mistake in "Design Outline" dialog box, Setup->Outlines->Design Outline, misspelled as "Desgin" 1654777 ALLEGRO_EDITOR UI_GENERAL Reports UI does not work properly when writing a report file. 1655500 ALLEGRO_EDITOR UI_GENERAL Visibility selection ignored after color change 1655514 ALLEGRO_EDITOR UI_GENERAL Artwork Film is available in the View section only after you restart PCB Editor 1660200 ALLEGRO_EDITOR UI_GENERAL Symbol pin # box is unclear 1660492 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes when using multiple desktops on Windows 10 1663819 ALLEGRO_EDITOR UI_GENERAL In release 17.2, SKILL function, axlOpenDesign(), does not work as expected 1668817 ALLEGRO_EDITOR UI_GENERAL Changing the visibility or the color on the canvas in release 17.2-2016 takes longer than release 16.6 1670120 ALLEGRO_EDITOR UI_GENERAL In release 17.2, Static Phase meter shows up in the middle of the screen instead of the lower-right corner 1671268 ALLEGRO_EDITOR UI_GENERAL Visibility Window: There is a noticeable lag when enabling etch, via, and pin on a specific layer one by one 1671334 ALLEGRO_EDITOR UI_GENERAL Design outline is not shown in 'World View' window 1671901 ALLEGRO_EDITOR UI_GENERAL Move command followed by object selection grays out or locks toolbar and menus 1672148 ALLEGRO_EDITOR UI_GENERAL Add option in release 17.2 to change the placement of the Find, Visibility, and Options tabs similar to earlier release 1673681 ALLEGRO_EDITOR UI_GENERAL F1 for Help not working in PCB Editor in release 17.2 1679418 ALLEGRO_EDITOR UI_GENERAL On choosing Edit - Move, the 'Symbol pin #' box is obfuscated 1679761 ALLEGRO_EDITOR UI_GENERAL Choosing Edit - Spin hides 'Symbol pin #' partially 1681514 ALLEGRO_EDITOR UI_GENERAL Opening the Dynamic Shapes State report hangs PCB Editor in release 17.2 Hotfix 009 1686887 ALLEGRO_EDITOR UI_GENERAL Hyper Text no longer selects coordinates for easy copy 1687286 ALLEGRO_EDITOR UI_GENERAL In 17.2 Hotfix 009, the Static Phase meter shows up in the middle of the screen instead of the lower-right corner 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1690691 ALLEGRO_EDITOR UI_GENERAL Reports not generating if the 'allegro_html_qt' environment variable is disabled 1692416 ALLEGRO_EDITOR UI_GENERAL Underscores in menu commands denoting shortcuts are missing in release 17.2 1693968 ALLEGRO_EDITOR UI_GENERAL Batch process that uses SKILL is taking too long to process files and generate reports 1696637 ALLEGRO_EDITOR UI_GENERAL Padstack Editor uses Region and Language settings for the decimal symbol 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1702420 ALLEGRO_EDITOR UI_GENERAL Unable to maximize reports viewer in 17.2 1703065 ALLEGRO_EDITOR UI_GENERAL Menu shortcuts do not work as expected 1703107 ALLEGRO_EDITOR UI_GENERAL Scripting using regional settings for decimal separator 1707547 ALLEGRO_EDITOR UI_GENERAL Release 17.2: The Alt key function is not working in PCB Editor 1709280 ALLEGRO_EDITOR UI_GENERAL Alt+Function key not working in release 17.2. 1709903 ALLEGRO_EDITOR UI_GENERAL Toggling layer visibility does not change the display until the mouse pointer is moved 1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used 1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places 1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value 1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically 1636097 ALLEGRO_EDITOR ZONES Technology Dependent Packaging footprints not updating in the design 1636185 ALLEGRO_EDITOR ZONES Import Placement not placing Technology Dependent Packaging (TDP) footprints in a zone 1639896 ALLEGRO_PROD_TOOLB CORE MFG collector does not move files to subdirectories 1608804 ALTM_TRANSLATOR DE_HDL Translation issues in symbols with multiple physical pins mapping to a single logical function 1658525 ALTM_TRANSLATOR DE_HDL Invalid characters in pin names 1658536 ALTM_TRANSLATOR DE_HDL All cell names should be generated in lowercase letters 1609962 ALTM_TRANSLATOR PCB_EDITOR Errors reported during design translation 1616138 ALTM_TRANSLATOR PCB_EDITOR Board file imported from third-party tool to PCB Editor has the shapes but not the components 1666020 ALTM_TRANSLATOR PCB_EDITOR Board converted from a third-party tool to PCB Editor has missing components 1649222 APD ASSY_RULE_CHE Allegro Package Designer stops responding on running the Acute Angle Metal DRC 1692166 APD DATABASE DB Doctor returns 'ERROR(SPMHDB-252): A corrupt database pointer was detected' for a specific design 1661562 APD DRC_CONSTRAIN The wrong space calculation on finger to trace 1647596 APD EXPORT_DATA Allegro Package Designer crashes when trying to export board-level components 1615075 APD LOGIC Netlist-In wizard fails to import the net names, but gives a successful completion Info message 1623666 APD OTHER Incorrect vector pin syntax appears in the chips file written using 'RF Module - Export chips & connectivity' 1647154 APD OTHER Disconnected Clines not working 1667599 APD OTHER Wire Bond operations taking longer than expected to complete 1688035 APD OTHER Significant difference seen in the percentage of metal between the Metal Usage reports of positive and negative layers 1647190 APD REPORTS 'Sorted by Bond Finger' report shows incorrect wire bond connection 1656608 APD REPORTS Incorrect calculation in the metal usage report 1650734 APD SHAPE Shape on L1 does not flood properly 1674338 APD SHAPE Shape is not clearing slivers that are smaller than the 'Minimum aperture for gap width' of '18 um' 1682398 APD SHAPE Deleting islands causes out of date shapes 1640611 APD SKILL Launching XtractIM from SiP Layout with the attached design crashes both SiP Layout and XtractIM 1639613 APD STREAM_IF The stream out command has created sharp angles in the GDSII output file 1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad 1625000 ASDA CANVAS_EDIT File - Save Project does not provide any indication of saving or progress bar 1638112 ASDA CANVAS_EDIT Unable to rename multiple selected buses using the 'Assign Name' command 1639409 ASDA CANVAS_EDIT When importing a DE-HDL design, the MAKE_BASE property should be removed from the nets 1645571 ASDA CANVAS_EDIT Various routing inconsistencies with synonym bodies on the canvas 1656336 ASDA CANVAS_EDIT Presence of illegal characters in the net name removes the entire net name 1667176 ASDA CANVAS_EDIT Unable to add the port symbol in a specific scenario 1641410 ASDA CONSTRAINT_MA No errors or issues reported when incorrect topology is applied to a net or an Xnet 1641473 ASDA CONSTRAINT_MA Importing a tech file into SDA makes the tool unresponsive 1645529 ASDA CONSTRAINT_MA Unable to delete differential pairs on nets 1661350 ASDA CONSTRAINT_MA Unable to create physical & spacing class from the docked CM 1653109 ASDA DESIGN_CORRUP SDA not pulling latest library information for part 1661874 ASDA DESIGN_CORRUP Unable to delete the ZERO part from the schematic page 1647673 ASDA EXPORT_PCB After installing release 17.2-2016 Hotfix 009, two folders named 'physical' are created for a design 1646086 ASDA IMPORT_BLOCK Importing a DE-HDL design into SDA results in error 'IMPSHT-42 Alias cannot be created' 1613559 ASDA IMPORT_DEHDL_ Custom variables from the BOM Tables are not getting imported 1645557 ASDA IMPORT_DEHDL_ Importing a DE-HDL design into SDA adds the COMMENT_BODY attribute to nets 1625209 ASDA IMPORT_PCB File Import from PCB Editor shows board differences 1647580 ASDA IMPORT_PCB SDA - File Import from PCB Editor has duplicated RefDes on schematic. 1652753 ASDA MISCELLANEOUS Tcl command window should display correct casing for autocompleted command 1654973 ASDA MISCELLANEOUS If there is a casing mismatch in the Tcl command name, correct command is not picked from the list 1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout 1652718 ASDA PAGE_MANAGEME Page numbering on the page border does not update correctly when pages are moved, added, deleted 1621874 ASDA PRINT Print - Save as PDF uses the default printer options only 1699454 ASDA TABLE In the table object, cursor skips a cell on the first use of the TAB key 1702702 ASDA TABLE Copy-pasting table objects to a new page fills the headers and rows in black 1667056 ASI_PI GUI Power Feasibility Editor does not list capacitors connected to selected nets/parts 1623113 ASI_SI GUI Aggressor waveforms are not displayed in the Waveform viewer after running a crosstalk simulation 1668877 CAPTURE ANNOTATE Using Ctrl+drag does not preserve the reference designator value 1690448 CAPTURE CORRUPT_DESIG Corrupt design: nets in this design are not displayed when running Edit - Browse - Nets 1690455 CAPTURE CORRUPT_DESIG Corrupt design: all the nets in this design are not displayed when running Edit - Browse - Nets 1665454 CAPTURE NETGROUPS Incremental copy for alias does not work anymore. 1681727 CAPTURE NETGROUPS In release 17.2, Capture crashes when closing a design that has assigned NetGroups 1667213 CAPTURE NETLIST_ALLEG Tools - Create Netlist stops responding on Windows 10 1608278 CAPTURE OTHER Crystal Reports: User is prompted for ODBC password to create a BOM report 1634598 CAPTURE OTHER The ‘OrCAD_Capture_CIS_option’ license not released even after selecting another product option 1636090 CAPTURE OTHER Capture crashes after switching from release 17.2 Hotfix 003 to 004 due to some Tcl files 1648575 CAPTURE OTHER The setting to suppress warnings must be added in the capture.ini file 1650029 CAPTURE OTHER Crash while archiving a newly created PSpice project without adding simulation profile 1659602 CAPTURE OTHER Saving CIS BOM via TCL command window 1678715 CAPTURE OTHER Capture.ini [WebResourcesMenu] is not working in release 17.2 1619449 CAPTURE PROJECT_MANAG Search not working in a PSpice project 1643003 CAPTURE PROJECT_MANAG Release 17.2-2016 Hotfix 005: The Start page shows incorrect release number of the latest release 1670133 CAPTURE PROJECT_MANAG Start Page showing wrong Software Version 1670766 CAPTURE PROJECT_MANAG autoreference does not work properly 1676095 CAPTURE PROJECT_MANAG (SID:22758) OrCAD Capture Start Page reporting wrong hotfix installed 1610377 CAPTURE PROPERTY_EDIT Discrepancies between the NET_SPACING_TYPE property (or any other property) text and the actual property 1658315 CAPTURE TCL_INTERFACE Inserting text with double quotes is not working as expected in PDF created from Capture 1642601 CIS OTHER Design Entry CIS: SQL server password is required each time the tool is launched 1595872 CIS PART_MANAGER Capture CIS Part Manager PCB Footprint update case-sensitivity issue 1592026 CIS VIEW_DATABASE View database part does not work from schematic pages of an externally referenced design 1665918 CONCEPT_HDL CHECKPLUS Error (100) Program Internal Error 'Create_flat_node' with checkplus run 1690777 CONCEPT_HDL CHECKPLUS Rules Checker returns an error when the value of the PACK_TYPE property is in lowercase 1622715 CONCEPT_HDL CONSTRAINT_MG Extracting an XNet crashes DE-HDL 1642012 CONCEPT_HDL CONSTRAINT_MG Schematic-defined net groups without any members cannot be deleted in Constraint Manager 1684117 CONCEPT_HDL CONSTRAINT_MG Property deleted from Constraint Manager is not getting updated in the DE-HDL canvas 1712279 CONCEPT_HDL CONSTRAINT_MG Differential pairs are dropped from Net Classes when upreved to release 17.2-2016 1663641 CONCEPT_HDL COPY_PROJECT File - Copy Project in Project Manager creates two designs if there are dashes in the design name 1665449 CONCEPT_HDL COPY_PROJECT Copy project fails with error COPYPROJ-77 1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file 1577379 CONCEPT_HDL CORE Packager-XL gives different results when run from DE-HDL and ADW Flow Manager 1582276 CONCEPT_HDL CORE Need the ability to delete an image placed on the DE-HDL canvas 1594101 CONCEPT_HDL CORE No error or warning issued on specifying an incorrect unit for voltage 1618986 CONCEPT_HDL CORE Information required about the DONT_FORCE_ORIGIN_ONGRID directive 1623231 CONCEPT_HDL CORE Unable to make the Attributes form part of the standard display in DE-HDL 1632504 CONCEPT_HDL CORE DE-HDL core dumps during Save Hierarchy on Linux 1642015 CONCEPT_HDL CORE Pin exists on block but no corresponding port exists in the underlying schematic 1649829 CONCEPT_HDL CORE Project Manager: A delay is observed before the submenus of the File and Tools menus appear 1652230 CONCEPT_HDL CORE The master.tag and vlog004u.sir files are not created in the entity directory on saving symbols 1656357 CONCEPT_HDL CORE Pasting a signal name across pages causes the name to overlap with the wire segment 1656726 CONCEPT_HDL CORE Interface command always disabled in the Wire menu 1658874 CONCEPT_HDL CORE 'Insert (n) Pages' command does not work when the CONFIRM_WRITE directive is ON 1659097 CONCEPT_HDL CORE Mouse strokes are not enabled on startup in the Pre-select mode 1659532 CONCEPT_HDL CORE Need csa files when Import Design command is used with the CONFIRM_WRITE directive 1661778 CONCEPT_HDL CORE Advanced Find will not find pins with the SIG_NAME property attached 1666084 CONCEPT_HDL CORE All user-defined properties are not listed in the Customize columns in Variant Editor 1667043 CONCEPT_HDL CORE Incorrect information in cpm.log file 1669707 CONCEPT_HDL CORE Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property 1670659 CONCEPT_HDL CORE SIGNAME text off grid when pasting copy using ctrl+v. 1671728 CONCEPT_HDL CORE Option requested to reload preferred_projects.txt without re-opening DE-HDL 1677672 CONCEPT_HDL CORE Whitespaces in URL links are not resolved correctly on Linux with Firefox 1684180 CONCEPT_HDL CORE Message should indicate that the user needs to reload the design after setting SET STICKY_OFF 1694151 CONCEPT_HDL CORE Rename Signal for unnamed net added the sig_name at the incorrect position with small text size. 1695987 CONCEPT_HDL CORE $PN placement in DE-HDL during part development is not following mouse placement 1697732 CONCEPT_HDL CORE Warning (SPCOCN-922): The object is being placed towards the left edge of the schematic. Ensure that the objects are pla 1697955 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1700873 CONCEPT_HDL CORE With duplicate part table files, running the Assign Power Pins command crashes DE-HDL without any message 1702703 CONCEPT_HDL CORE Location of $PN in DE-HDL Symbol Editor is not as precise as it was in 17.2 Hotfix 011 1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084 1705999 CONCEPT_HDL CORE Signal naming is not working correctly in SPB 17.2 1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position 1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1711635 CONCEPT_HDL CORE The arrow keys do not work as expected in Windows mode 1713091 CONCEPT_HDL CORE Difference in the behavior of 'Add Signal Name' in DE-HDL between releases 16.6 and 17.2 1669651 CONCEPT_HDL CREFER CreferHDL values are invisible 1677489 CONCEPT_HDL CREFER CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers 1614372 CONCEPT_HDL EDIF300 OFFPAGE symbol is exported as PageBorder in EDIF300 schematic 1631443 CONCEPT_HDL ERCDX ERC reports warning due to lower-case value of some properties in chips.prt 1653080 CONCEPT_HDL ERCDX Difference in results from SPB16.6 in 'erc.rpt' when logic_data is renamed as worklib in SPB17.2 on RHEL6.5 1599843 CONCEPT_HDL INTERFACE_DES Moving end part of a NetGroup adds extra elements 1632977 CONCEPT_HDL INTERFACE_DES Connectivity error when moving NetGroup members 1597787 CONCEPT_HDL MARKERS Save As in Marker dialog causes DE-HDL to crash 1659644 CONCEPT_HDL OTHER Predefined nets are not listed if a design from release 16.6 is opened in release 17.2. 1661632 CONCEPT_HDL OTHER Page skipped in DE-HDL when navigating using the Page Up and Page Down keys 1677405 CONCEPT_HDL OTHER When moving a wire with a dot, the dot is not removed directly 1708820 CONCEPT_HDL OTHER In a board cache flow, component bodies are missing when importing another board cached flow project. 1657346 CONCEPT_HDL PDF Wire Pattern set to two-dot chain line in a schematic appears as a solid line in the PDF output 1661133 CONSTRAINT_MGR ANALYSIS PCB Editor crashes if comma is used in the Value field for Analysis Mode 1670082 CONSTRAINT_MGR ANALYSIS Inconsistency in Constraint Analysis Modes - Electrical in OrCAD PCB Designer Professional in release 17.2-2016 1609817 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes on opening project 1623888 CONSTRAINT_MGR CONCEPT_HDL Ambiguous and inaccurate mapping errors reported when an ECSet is applied to a differential pair object 1636404 CONSTRAINT_MGR CONCEPT_HDL Release 17.2 Hotfix 004: In DE-HDL Constraint Manager, invalid voltage units are allowed without any error or warning 1639928 CONSTRAINT_MGR CONCEPT_HDL The '-filterFile' argument is not recognized when cmDiffUtility is run as a command line operation 1642891 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes randomly while working on Constraint Manager 1645639 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes when the XNET_PINS property value has a trailing comma character 1646354 CONSTRAINT_MGR CONCEPT_HDL Cannot select Design Instance/Block Filter from the View menu in Constraint Manager 1649060 CONSTRAINT_MGR CONCEPT_HDL Renaming dcfx to dcf does not update the dcf file and results in an error in the log file 1650793 CONSTRAINT_MGR CONCEPT_HDL Conflict of XNET_PINS definition between the chips and the SIGNAL_MODEL is not handled correctly 1657048 CONSTRAINT_MGR CONCEPT_HDL Unable to navigate through the search results in the CM Reports 1661307 CONSTRAINT_MGR CONCEPT_HDL Prevent creation of differential pairs on VOLTAGE nets 1677651 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crash on design after successful packaging 1682447 CONSTRAINT_MGR CONCEPT_HDL Extraction issue on differential pairs in design 1682454 CONSTRAINT_MGR CONCEPT_HDL If a design with NO_XNET_CONNECTION property on parts is exported to PCB Editor, many other components get the property 1698259 CONSTRAINT_MGR CONCEPT_HDL Unstable $LOCATION property in release 17.2-2016 1702537 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors reported after removing the signal models on an upreved design 1718073 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors on an upreved design in release 17.2: Pins in XNet and CSet do not match 1688287 CONSTRAINT_MGR DATABASE PCB Editor crashing while adding a net to a net group. 1717336 CONSTRAINT_MGR DATABASE Netclass members change during logic import; it's a toggle switch 1718514 CONSTRAINT_MGR ECS_APPLY Extracted topology does not use the PINUSE overrides specified on the canvas 1682885 CONSTRAINT_MGR INTERACTIV Constraint Manager worksheet switching does not work correctly in Linux 1625163 CONSTRAINT_MGR OTHER Status indicator for the Analyze command is missing in Constraint Manager in release 17.2 1628357 CONSTRAINT_MGR OTHER Constraint Manager shows differences if exporting and importing the same constraints on the same board 1631114 CONSTRAINT_MGR OTHER SKILL functions axlCnsPurgeAll and axlCNSDelete delete spacing constraint sets but not deleting names 1632365 CONSTRAINT_MGR OTHER Select command is disabled in the right-click pop-up menu from Constraint Manager in SPB 17.2 1639541 CONSTRAINT_MGR OTHER In release 17.2, PCB Editor crashes when updating Constraint Manager 1647779 CONSTRAINT_MGR OTHER 'Software Version' in the cmDiffUtility viewer does not show the correct version 1666329 CONSTRAINT_MGR OTHER SCM Import Physical process crashes cmfeedback 1669523 CONSTRAINT_MGR OTHER Select is disabled in Constraint Manager when a command is active in PCB Editor 1670802 CONSTRAINT_MGR OTHER Selecting a list of nets using the shift key does not work in Spacing and Physical domain 1670922 CONSTRAINT_MGR OTHER Title of the Layer Remove window is Constraint Manager 1678235 CONSTRAINT_MGR OTHER Select option grayed out in Constraint Manager if a command is active in PCB Editor 1680917 CONSTRAINT_MGR OTHER In release 17.2, nets cannot be selected in Constraint Manager when a PCB Editor command is active 1691125 CONSTRAINT_MGR OTHER Highlight command no longer selects the net in CM 1703791 CONSTRAINT_MGR OTHER Cross highlighting and assigning color to nets between PCB Editor and CM does not work 1703981 CONSTRAINT_MGR TECHFILE Importing a technology file (.tcf) results in packaging errors 1633433 CONSTRAINT_MGR UI_FORMS Expand - Collapse feature for multiple objects not working correctly 1649603 CONSTRAINT_MGR UI_FORMS Expand and Collapse commands do not work when multiple objects are selected 1654931 CONSTRAINT_MGR UI_FORMS Expand, collapse only works on one of the multiple selected objects. 1656841 CONSTRAINT_MGR UI_FORMS Incorrect layer information is displayed in the Edit Via List dialog when a filter is applied 1660475 CONSTRAINT_MGR UI_FORMS In release 17.2, the CTRL+V shortcut is not working in the Export Constraints window in Constraint Manager. 1668794 CONSTRAINT_MGR UI_FORMS Incorrect via name shown when filtering via list 1678305 CONSTRAINT_MGR UI_FORMS Unable to use the CM worksheet customization (wcfx) from the CDS_SITE area 1679909 CONSTRAINT_MGR UI_FORMS Incorrect layer order getting saved when defining BB vias in Constraint Manager PCSet 1691906 CONSTRAINT_MGR UI_FORMS Display Issue: When you use the filters, the horizontal scroll bars are duplicated 1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer 1606682 ECW ADMINISTRATIO ECWBackup and ECWRestore fail when data is 1GB or more 1673115 ECW INTEGRATION Import from external data sources (Integrations) truncates input values to 128 characters 1677893 ECW INTEGRATION Integrations list update is not working as per scheduled time 1652707 ECW METRICS Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart 1654512 ECW METRICS Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart 1668953 ECW METRICS IE11 Swedish only: Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart 1677443 ECW METRICS Queued up metric packets on Pulse server are not processed if there are any packets related to a deleted project 1666723 ECW TDO-SHAREPOIN TDO login is not working with Site Minder because of incorrect characters in the Site Minder login form HTML 1683919 ECW TDO-SHAREPOIN Site Minder integration for login from TDA not working after SSL certificate update 1524700 F2B DESIGNVARI Variant file cannot be loaded 1632844 F2B DESIGNVARI Part is simultaneously defined as Pref and DNI in Variant Editor with no error 1641118 F2B DESIGNVARI Some DNI parts are not identified in the variant view due to the BLOCK 1669828 F2B DESIGNVARI Variant Editor crashes on some Windows 10 systems 1620017 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053) when $PART_NUMBER property for components has a value 1644131 F2B PACKAGERXL Option needed to package a DE-HDL design with PTF errors into a board file 1663676 F2B PACKAGERXL Physical net name (PNN) errors in the log file 1655377 FLOWS PROJMGR Project Manager crashes at launch on Windows 10 1699395 FSP FPGA_SUPPORT Selecting a QSF part name in the FPGA Properties window crashes FSP 1621390 GRE CORE Design crashes during the Spatial Planning phase 1669583 GRE DETAIL AiDT always fails push when there is a connect shape attached to the cline being tuned 1648817 GRE IFP_INTERACTI Allegro PCB Editor stops responding on adding netgroups to a nested netgroup 1704353 INSTALLATION DOWNLOAD_MGR Selecting 'View' in Download Manager results in error: 'Object Reference not set to an instance of an object' 1705265 INSTALLATION DOWNLOAD_MGR Problem installing OrCAD Library Builder from Download Manager 1686350 INSTALLATION SPB InstallDiagnose fails to repair some errors 1667678 MODEL_EDITOR PARSE Signal model assignment creates ESpice models that do not pass Model Integrity checks 1619610 ORBITIO ALLEGRO_SIP_I Some mechanical pins appear rotated by 90 degrees when imported 1630458 ORBITIO ALLEGRO_SIP_I Import OrbitIO Database file (.oio) in SiP: Bill of Materials report does not include standard dies 1635593 ORBITIO ALLEGRO_SIP_I Importing .sip file reports undefined argument error while processing shapes 1675013 ORBITIO ALLEGRO_SIP_I Failed to import brd file 1646612 PCB_LIBRARIAN CORE Generate Symbol option crashes Part Developer 1672369 PCB_LIBRARIAN EXPLORER Cannot create a New library build in Library Explorer. 1634392 PCB_LIBRARIAN OTHER Launching Library Explorer without -proj option makes it crash 1646635 PDN_ANALYSIS PCB_PI PCB Editor uses 'powerdc.exe' to launch PowerDC instead of the 'powerdc' script 1670811 PSPICE AA_MC Advanced Analysis MC plot window options need to be changed 1633526 PSPICE AA_PPLOT Spaces in Simulation Profile cause error in Parametric Plotter 1626647 PSPICE ENVIRONMENT Capture crashes when loading a design with two hyphens in sim profile name 1631034 PSPICE ENVIRONMENT When simulating the design in release 17.2, Capture crashes but works with release 16.6 1648284 PSPICE ENVIRONMENT PSpice project crashes when a design is opened in release 17.2 1663336 PSPICE MODELEDITOR Ibis translation not supporting paths with spaces 1629696 PSPICE PROBE After successfully exporting traces to csv, PSpice crashes on a subsequent attempt to export traces 1647402 PSPICE PROBE Unable to print on Windows 10 as no plots are displayed in the Probe window 1678061 PSPICE SLPS Simulating an SLPS co-simulation with a Fixed-step solver with a value lower than 1E-4 results in a crash 1679347 PSPICE SLPS SLPS crashes when co-simulating without opening OrCAD Capture or PSpice 1659030 RF_PCB LIBRARY Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols 1631792 SCM OTHER The NC net has re-attached itself to another net, RIGHT_LEFT_N, in the design 1632195 SCM OTHER 'No known page border found' error in cref.log 1679376 SIG_EXPLORER OTHER Topology created in OrCAD PCB SI license cannot be reopened with the same license 1626546 SIG_INTEGRITY FIELD_SOLVERS Extra RL elements in via spice circuit model generated by Via Model Generator 1664797 SIG_INTEGRITY GUI Unnecessary coupled interconnect models were generated during View Waveform. 1682312 SIG_INTEGRITY LICENSING Allegro Sigrity SI/PI Product Choices window is blank after installing release 17.2 Hotfix 009 1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation 1698968 SIP_LAYOUT 3D_VIEWER 3D viewer shows keepin and not design outline. 1699884 SIP_LAYOUT ASSY_RULE_CHE SiP Layout crashes on using Assembly Rules Checker 1666484 SIP_LAYOUT CROSS_SECTION On converting a design from release 16.6 to release 17.2, a Dielectric thickness of ‘0.2032’ is added to another layer. 1689969 SIP_LAYOUT DIE_EDITOR SiP Layout crashes when moving dies using relative coordinates 1696239 SIP_LAYOUT DIE_EDITOR When using the Die-stack Editor to move and stretch wires, SiP Layout crashes 1643557 SIP_LAYOUT DIE_GENERATOR The dies in the design are not updated on importing die text files 1687988 SIP_LAYOUT DIE_GENERATOR 'compose die from geometry' does not retain the user-defined padstack name 1715016 SIP_LAYOUT DIE_GENERATOR Using Die Text-In wizard to replace a die reconnects wire bonds to the wrong die in stack-up 1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates 1593404 SIP_LAYOUT EDIT_ETCH Slide command moves via toward the object 1657257 SIP_LAYOUT EXTRACT When using extracta, custom layer names not getting retained 1641435 SIP_LAYOUT IMPORT_DATA Need SiP Stream mapping layer count to match Virtuoso stream layer mapping count 1620601 SIP_LAYOUT MANUFACTURING Need the ability to create LINES with round end caps in the same way as the LINES appear in the database 1638094 SIP_LAYOUT OTHER Cross Section Editor not reading updated information 1647098 SIP_LAYOUT OTHER Cadence SIP RF Layout GXL crashes when a symbol is copied and rotated 90 degrees 1705963 SIP_LAYOUT PADSTACK_EDIT Pad Designer: "None" changing spontaneously into "Circle 0.000" in a pad stack definition and unable to save 1695372 SIP_LAYOUT REPORTS Running the Metal Usage reports fails on the Primary side. 1713767 SIP_LAYOUT REPORTS Reports in release 17.2 for the Verilog Port Name are adding incorrect data that was not found in release 16.6 1696218 SIP_LAYOUT SKILL SiP Layout crashes on reassigning nets 1712964 SIP_LAYOUT SYMB_EDIT_APP SiP Layout crashes when using Renumber Pins in Symbol Edit application mode 1695885 SIP_LAYOUT UI_GENERAL Visibility Tab check box: unchecked "All" disables access to "Shp" check box 1623823 SIP_LAYOUT WIREBOND NO_WIREBOND property is ignored by Add/Edit Non-Standard 1641483 SIP_LAYOUT WIREBOND SiP Layout - Modify the wirebond report generation for Start and End height when using a DISCRETE class footprint 1650238 SIP_LAYOUT WIREBOND When performing 'Adjust Min DRC', the reference bond finger should not move. 1659473 SIP_LAYOUT WIREBOND When moving wirebonds they are jumping instead of sliding 1639838 SIP_RF DIEEXPORT Enhance the error message, SIP-1507, to include that overlapping pins within tolerance are included during die export 1653894 SIP_RF DIEEXPORT Redundant error message for die export, when view name is other than "layout" 1681332 SIP_RF OTHER Running die export causes Virtuoso to crash 1679336 SPECCTRA LICENSING Min/Max Propagation Delay cannot be routed by PCB Router using OrCAD PCB Designer Professional 1641879 XTRACTIM GUI XtractIM crashes on extracting a SiP design if 'SI Ignore' is selected for a die stack layer in Cross Section Editor
Apr 12 2017, 21:29
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 017 Код Fixed CCRs: SPB 17.2 HF017 04-13-2017 ===================================================================== CCRID Product ProductLevel2 Title ===================================================================== 1732877 ALLEGRO_EDITOR SKILL axlXSectionGet fails in 17.2 HF016
May 9 2017, 00:32
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 018 Код Fixed CCRs: SPB 17.2 HF018 04-23-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1721773 ADW ADW_UPREV adw_uprev updates all versions in history log to the new version. Should only insert note about uprev. 1684346 ADW LIBDISTRIBUTI lib_dist_client fails for new release 17.2-2016 design server 1696632 ADW LIBDISTRIBUTI lib_dist_client fails on release 17.2 Designer Server having release 16.6 Master Server 1705224 ADW LIBDISTRIBUTI Cannot migrate Library Footprint Models having subdirectory to release 17.2-2016 1721017 ADW LIBDISTRIBUTI adwserver -install fails intermittently during Master Library Server or MLR distribution 1711373 ALLEGRO_EDITOR COLOR Cannot interact with Allegro PCB Editor when Color dialog is open 1710772 ALLEGRO_EDITOR DATABASE Mirror command not working on zones 1725621 ALLEGRO_EDITOR DATABASE PCB Editor crashes when moving a group of components or clines 1699796 ALLEGRO_EDITOR EDIT_ETCH AiDT fails and reports there are no timing constraints even when propagation delay is set 1726483 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashing when converting corners to arcs 1726678 ALLEGRO_EDITOR INTERFACES IDX copper layer export does not export all pin pads 1691036 ALLEGRO_EDITOR MANUFACT Fillet not centered on trace 1732304 ALLEGRO_EDITOR MANUFACT Countersink does not have drill figure on NCCOUNTERDRILL-1 subclass 1719564 ALLEGRO_EDITOR OTHER Cannot open PDF published in release 17.2-2016 in third-party software 1723065 ALLEGRO_EDITOR OTHER PDF out does not print the outline correctly 1729247 ALLEGRO_EDITOR OTHER Cannot delete shape on Route Keepout layer 1722747 ALLEGRO_EDITOR PAD_EDITOR Option to enable 'Connect by Touch' in Pad Editor 1731643 ALLEGRO_EDITOR PAD_EDITOR Changes to secondary drill are not saved on padstack update 1727303 ALLEGRO_EDITOR REPORTS The 'Shape Dynamic State' report has changed to 'Shape Dynamic Status' in release 17.2-2016 1695879 ALLEGRO_EDITOR SHAPE Dynamic shape priority error creates shorts. 1713014 ALLEGRO_EDITOR SHAPE Incorrect behavior of donut shaped pads at certain rotations 1588769 ALLEGRO_EDITOR UI_GENERAL Alt+key shortcuts are not available in release 17.2 1602563 ALLEGRO_EDITOR UI_GENERAL Shortcuts to menu items not working in release 17.2 1603776 ALLEGRO_EDITOR UI_GENERAL Alt key not working with menu commands 1611516 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts have no response 1647271 ALLEGRO_EDITOR UI_GENERAL Preselection is not working for docked Find window 1650044 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts are not working properly in release 17.2 1651912 ALLEGRO_EDITOR UI_GENERAL Inconsistent response when using the Alt key 1679964 ALLEGRO_EDITOR UI_GENERAL Many dialog boxes are blurred in Allegro PCB Editor 1692416 ALLEGRO_EDITOR UI_GENERAL Underscores in menu commands denoting shortcuts are missing in release 17.2 1693055 ALLEGRO_EDITOR UI_GENERAL Reports with html links end with an extra > at the end 1693968 ALLEGRO_EDITOR UI_GENERAL Batch process that uses SKILL is taking too long to process files and generate reports 1698840 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016 Waive DRC report, selected coordinates of a Waived DRC remain blue 1703065 ALLEGRO_EDITOR UI_GENERAL Menu shortcuts do not work as expected 1707547 ALLEGRO_EDITOR UI_GENERAL Release 17.2: The Alt key function is not working in PCB Editor 1709280 ALLEGRO_EDITOR UI_GENERAL Alt+Function key not working in release 17.2. 1711203 ALLEGRO_EDITOR UI_GENERAL Color does not change for selected coordinates in reports and Show Element 1711724 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, custom interactive menus stop responding when invoking another custom command 1715613 ALLEGRO_EDITOR UI_GENERAL With undocked Options window there is a mix up of entered text and funckey 1719301 ALLEGRO_EDITOR UI_GENERAL Selected coordinates do not change color in reports and Show Element 1724197 ALLEGRO_EDITOR UI_GENERAL Short cuts and hot keys not working in PCB Editor in release 17.2-2016 1728724 ALLEGRO_EDITOR UI_GENERAL Funckey is not working in release 17.2-2016 1673703 ALLEGRO_PROD_TOOLB OTHERS Design compare not reporting the Top and Bottom layer differences 1704474 ALLEGRO_PROD_TOOLB OTHERS When using Productivity Toolkit - PCB Design Compare, 'Override undefined width' is incorrectly applied 1571035 ALTM_TRANSLATOR CAPTURE Circles in third-party schematics not getting translated into Capture 1588911 ALTM_TRANSLATOR CAPTURE Capture crashes when translating, project and libraries are empty 1589394 ALTM_TRANSLATOR CAPTURE Schematic getting shifted off the page after translation 1631294 ALTM_TRANSLATOR CAPTURE Errors while translating third-party design when original design is in metric units 1663176 ALTM_TRANSLATOR CAPTURE Only first sheet of design getting translated from third-party schematic into Capture 1694363 ALTM_TRANSLATOR CAPTURE Capture is unable to translate third-party designs 1539739 ALTM_TRANSLATOR CORE Capture crashes on importing a third-party project 1542860 ALTM_TRANSLATOR CORE Capture crashes on clicking Translate after selecting a third-party design 1551642 ALTM_TRANSLATOR CORE Unable to import third-party schematics into Capture 1572929 ALTM_TRANSLATOR CORE Footprint names getting altered during translation 1568436 ALTM_TRANSLATOR PCB_EDITOR Unable to translate third-party layout data into PCB Editor 1629256 ALTM_TRANSLATOR PCB_EDITOR Getting empty symbol and devices folders when importing into PCB Editor 1664120 ALTM_TRANSLATOR PCB_EDITOR Import from third-party to PCB Editor is not translating data correctly 1701537 ALTM_TRANSLATOR PCB_EDITOR Import does not complete and reports errors 1698706 APD DIE_GENERATOR When using Compose Symbol from Geometry, circle from DXF cannot generate to pin 1714528 APD DIE_GENERATOR Getting 'illegal pad pointer' warning when creating die from geometry 1714532 APD DIE_GENERATOR Compose Die from Geometry creates incorrect pad shapes 1734310 APD MULTI_USER Symphony server mode malfunctions when die layer present. 1725506 APD SHAPE In release 17.2-2016 Hotfix 015, void is not generated in Artwork for BC7 layer causing short 1724395 APD WIREBOND Running axlBondWireDelete returns error message 1726609 ASDA CANVAS_EDIT Paste should not be allowed in the Current Refdes column of the Change Refdes form 1719754 CONCEPT_HDL ARCHIVER Path stored in the compressed file starts from /home instead of the current working directory 1726570 CONCEPT_HDL CHECKPLUS Checkplus crashes on Windows 10 1697977 CONCEPT_HDL CONSTRAINT_MG Differential pair disappears when it is packaged 1679575 CONCEPT_HDL CORE Page numbers are duplicated in Hierarchy Viewer when editing page names 1697732 CONCEPT_HDL CORE Pasting a signal name results in warning (SPCOCN-922) if the wire is too close to the edge of the page border 1711564 CONCEPT_HDL CREFER CRefer crashes while processing a hierarchical design containing subdesigns 1730736 CONCEPT_HDL OTHER Crash on generating BOM from design 1608350 CONSTRAINT_MGR CONCEPT_HDL Name of buffer model is not passed from Constraint Manager of DE-HDL to SigXplorer 1715803 CONSTRAINT_MGR CONCEPT_HDL Extract a net from constraint manager to SigXplorer, the models assigned are not displayed in SigXplorer 1718073 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors on an upreved design in release 17.2: Pins in XNet and CSet do not match 1720886 CONSTRAINT_MGR CONCEPT_HDL SigXplorer does not extract assigned model from the schematic 1718514 CONSTRAINT_MGR ECS_APPLY Extracted topology does not use the PINUSE overrides specified on the canvas 1722306 GRE CORE Boards with Total Etch Length constraint only should not include z-axis when budgeting pin pairs 1710049 PSPICE SIMULATOR Functions are not taking parameters in correct order 1693021 SIG_INTEGRITY OTHER PINUSE is not updated correctly at model assignment with specific steps 1730854 SIP_LAYOUT SYMB_EDIT_APP Cannot delete all the die pin from a symbol using the Symbol Edit application mode
May 14 2017, 15:16
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 019 Код Fixed CCRs: SPB 17.2 HF019 05-6-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1701785 ADW ADWSERVER Getting 'Unable to locate tools.jar' error while using 'Copy Projects' 1706782 ADW ADW_UPREV Design uprev failed with error 'ERROR (FM-107): Failed to run adw_uprev' 1508159 ADW FLOW_MGR Flow Manager 'Open Last Project' option points to a deleted project 1690903 ADW FLOW_MGR Flow Manager library project list empty after 'Remove From List' 1705224 ADW LIBDISTRIBUTI Cannot migrate Library Footprint Models having subdirectory to release 17.2-2016 1672037 ALLEGRO_EDITOR EDIT_ETCH Add ZigZag Pattern crashes PCB Editor 1695711 ALLEGRO_EDITOR EDIT_ETCH In release 17.2-2016, Fiber Weave Effect - Add ZigZag Pattern crashes in Windows 10 1706522 ALLEGRO_EDITOR INTERFACES DFX import displays error message '*Error* eval: undefined function - cloneID' but imports outline 1716336 ALLEGRO_EDITOR INTERFACES DXF file is not correctly imported into PCB Editor 1720290 ALLEGRO_EDITOR INTERFACES Incorrect rotation of padstack after dxf import 1724683 ALLEGRO_EDITOR INTERFACES DXF OUT: incorrect Rounded/Chamfered rectangle pad rotation 1732587 ALLEGRO_EDITOR INTERFACES Format/content of ipc356 files exported in release 17.2-2016 different from release 16.6 1737516 ALLEGRO_EDITOR INTERFACES IDX Import works differently for placed and unplaced parts 1715152 ALLEGRO_EDITOR SCRIPTS Clicking Layout in Project Manager fails to load PCB Editor and gives message 'Word too long' 940699 ALLEGRO_EDITOR SHAPE Update shape to smooth fails to void a few clines. 1706581 ALLEGRO_EDITOR SHAPE Dynamic shape void clearance errors with vias 1638300 ALLEGRO_EDITOR UI_GENERAL Version information set in $cdsversion truncated on title bar for some tools 1697732 CONCEPT_HDL CORE Pasting a signal name results in warning (SPCOCN-922) if the wire is too close to the edge of the page border 1729510 CONCEPT_HDL CORE Changing the name of a split block adds pages that are part of the page gaps 1721065 CONSTRAINT_MGR CONCEPT_HDL Physical import errors on changing plane to conductor in stack-up 1734875 CONSTRAINT_MGR OTHER 'Create Spacing CSet' crashes tool from existing CSet context and grayed out in design context 1473104 ECW PART_LIST_MAN Pulse does not filter capacitor values correctly 1736580 PCB_LIBRARIAN SYMBOL_EDITOR Grids are not displayed correctly in Symbol Editor 1738955 PCB_LIBRARIAN SYMBOL_EDITOR Need ability to edit Symbol Properties 1735215 PSPICE FRONTENDPLUGI PSpice part search customization CDN_PSPICE_ODBC_SRC environment variable is not working 1733198 PSPICE PROBE Probe crashes when exporting trace expressions with multiple plots to CSV files 1737060 SIG_INTEGRITY SIGNOISE signoise fails for the AllegroSigrity_HS_Base_Suite option in release 17.2-2016 and release 16.6-2015 1707443 SIP_LAYOUT WIREBOND Moving bondfingers violates spacing constraint
May 22 2017, 21:40
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 020 Код Fixed CCRs: SPB 17.2 HF020 05-21-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1737443 ADW DBEDITOR Revising the schematic model classification for one category causes all parts in the library to be revised 1734123 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas crashes Allegro PCB Designer in 17.2 S016 1742084 ALLEGRO_EDITOR DATABASE Running DB Doctor on DRA files with custom pad shapes resets some of the custom padstack shapes in release 17.2 1739397 ALLEGRO_EDITOR INTERACTIV In release 17.2, running the SKILL function axlImportXmlDBRecords causes Allegro PCB Editor to crash 1724588 ALLEGRO_EDITOR MANUFACT Backdrill Route keepout suppressing existing Route Keepouts 1740036 ALLEGRO_EDITOR MANUFACT Generating the cross-section chart does not provide information about the overall board thickness 1743726 ALLEGRO_EDITOR OTHER IDF file export: In release 17.2, only one design outline is exported as against multiple board outlines in release 16.6 1744467 ALLEGRO_EDITOR OTHER The 'logical_op_new' variable is not displayed in User Preferences Editor 1729350 ALLEGRO_EDITOR REPORTS Net loop report is not working. 1713014 ALLEGRO_EDITOR SHAPE Incorrect behavior of donut shaped pads at certain rotations 1739870 ALLEGRO_EDITOR SHAPE The artwork is different from the PCB in release 17.2 Hotfix 17 1698869 ALLEGRO_EDITOR SKILL PCB Editor crashes when trying to open another .brd file after running SRM on first .brd file 1739307 ALLEGRO_EDITOR SKILL axlCNSDFAExport fails after first run 1743385 ALLEGRO_EDITOR SKILL SKILL APIs for STEP model mapping are not available in release 17.2 Hotfix 17 or 18 1685826 ALLEGRO_EDITOR UI_GENERAL Reports when opened from Status Form disappear behind PCB Editor canvas when clicking on canvas 1687797 ALLEGRO_EDITOR UI_GENERAL Cannot open two HTML windows, one after the other, while using SKILL function 1696229 ALLEGRO_EDITOR UI_GENERAL Setting the 'allegro_html' environment variable in User Preferences Editor overwrites existing popup text windows 1708636 ALLEGRO_EDITOR UI_GENERAL In SPB 17.2 release, keyboard focus automatically shifts to the newly opened dialog box 1711367 ALLEGRO_EDITOR UI_GENERAL Launching two report windows using SKILL is not working in 17.2 1742856 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor crashes if Project Manager is open for a design in release 17.2 Hotfix 18 1729519 APD SHAPE shape degassing does not generate all voids to cover entire shape 1711375 CONCEPT_HDL CORE Copy-paste of schematic between two instances of DE-HDL is not working as expected 1737230 CONCEPT_HDL CORE On the Linux platform, copying of schematic objects does not work between designs of releases 16.6 and 17.2 1741375 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol 1743992 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol 1736093 CONSTRAINT_MGR CONCEPT_HDL Incorrect topology extraction and mapping errors related to MUX parts 1743518 CONSTRAINT_MGR CONCEPT_HDL Lag observed in expanding and collapsing the net classes in Constraint Manager 1730159 FSP ALLEGRO_INTEG FSP diff engine does not read PF Thevenin connections in FSP 1664070 ORBITIO ALLEGRO_SIP_I Display pads of SMD components on correct layer 1709319 ORBITIO USABILITY OrbitIO issues an error about Device template while importing brd with Bundles 1741150 PSPICE ENVIRONMENT Need a way to prevent the 'pspSimSetting.js' file from being overwritten by a hotfix installation in 17.2 1735354 PSPICE SIMULATOR Access to custom nom.lib is not working as expected 1716523 SIP_LAYOUT COLOR Tool crashes on using the PageUp, PageDown, and Tab keys in the Color dialog box.
Jun 6 2017, 17:04
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 021 Код Fixed CCRs: SPB 17.2 HF021 06-3-2017 ====================================================================== ====================================================================== CCRID Product ProductLevel2 Title ====================================================================== ====================================================================== 1401318 ADW DBEDITOR Bulk Edit - Previously modified cells do not turn blue when selected 1621446 ADW DBEDITOR Bulk Edit - sorting highlights incorrect cells to mark them as changed 1743997 ADW LIB_FLOW Match file for standard models is incorrect 1746052 ALLEGRO_EDITOR DATABASE PCB Editor crashes when applying no drc property 1736067 ALLEGRO_EDITOR DRC_CONSTR Interlayer checks not reporting DRCs between cline and mask layer 1738587 ALLEGRO_EDITOR EDIT_ETCH Line width changing on slide for ETCH - Conductor (Not on a NET) 1745277 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes on using the slide command 1747942 ALLEGRO_EDITOR EXTRACT Fabmaster Out does not export arc in pad_shape 1737202 ALLEGRO_EDITOR GRAPHICS Setting the variable display_raster_ops 1744042 ALLEGRO_EDITOR GRAPHICS Unused pad suppression is not working on few nets 1703848 ALLEGRO_EDITOR INTERFACES IPC 2581 fails with error 'E- (SPMHGE-268)' and the log file is empty 1743899 ALLEGRO_EDITOR MANUFACT Glossing dangling vias crashes PCB Editor 1744467 ALLEGRO_EDITOR OTHER The 'logical_op_new' variable is not displayed in User Preferences Editor 1748520 ALLEGRO_EDITOR OTHER TDP fails to load on an empty database 1748581 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor crashes when changing default pad geometry 1751469 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor crashes/freezes when browsing for a shape symbol 1725948 ALLEGRO_EDITOR SHAPE Shape differences after conversion from release 16.6 to release 17.2-2016 1729306 ALLEGRO_EDITOR SHAPE Seting shape_rki_autoclip variable causes no void to be generated 1698876 ALLEGRO_EDITOR UI_GENERAL Tabs are large and text is compressed in release 17.2-2016 1698883 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, enlarging icons makes selection boxes/text unreadable on 4K monitors 1707933 ALLEGRO_EDITOR UI_GENERAL axlUIMenuFind not locating menu as per x_location 1741460 ALLEGRO_EDITOR UI_GENERAL Right-click, context menu options grayed in some cases after choosing Edit - Copy 1747588 ALLEGRO_EDITOR UI_GENERAL Interacting with PCB Editor by sending messages is not working 1747488 APD EDIT_ETCH Route connect is improperly affecting existing routes in locked high speed via structures 1750182 APD STREAM_IF The stream out settings are not saved 1752067 ASI_SI GUI Links to differential waveforms do not work in Sigrity SI report 1752131 CONCEPT_HDL COMP_BROWSER Symbol view in part manager doesn't match the symbol version 1754116 CONCEPT_HDL COMP_BROWSER Default Symbol selected is n°2 instead of n°1 in component Browser 1754949 CONCEPT_HDL COMP_BROWSER Part Information Manager displays preview window with the wrong symbol and missing footprint 1721334 CONCEPT_HDL CORE dsreportgen not able to resolve gated part on schematic 1750916 CONCEPT_HDL CORE DE-HDL crashes when trying to uprev a project in release 17.2-2016 1711487 CONCEPT_HDL INFRA Restrict opening of release 16.6 designs from a release 17.2-2016 design using File - View Design 1746915 CONSTRAINT_MGR CONCEPT_HDL Unable to copy a Physical and Spacing CSet generated from the Constraint Automation flow 1743523 CONSTRAINT_MGR DATABASE Suppress warning pop-ups from the constraint automation script 1746941 CONSTRAINT_MGR UI_FORMS 'Go to Source' from DRC tab is not working in release 17.2-2016 1753010 ECW METRICS Metrics not getting collected due to old license in use 1713052 FSP GUI Pin/Port Name and Group Name are not aligned properly in FPGA Port and Use Pin Mapping for DeviceInstance 1719099 FSP GUI Net naming wrong after building block 1719105 FSP GUI Tabular sorting not working in FPGA System Planner 1720479 PSPICE ENVIRONMENT Probe window does not open consistently on Windows 10 systems 1723411 PSPICE ENVIRONMENT Probe window does not open consistently on Windows 10 systems 1746628 PSPICE ENVIRONMENT PSpice Simulation Manager displays same message for all simulations in release 17.2-2016, Hotfix 016 1745976 SIG_INTEGRITY GEOMETRY_EXTR Arcs with coplanar waveguides are extracted with incorrect spacing 1690820 SIP_LAYOUT PLATING_BAR Cannot add fillets to pads with plating bars in release 17.2-2016 1725042 SIP_LAYOUT PLATING_BAR Creating a plating bar removes dynamic fillets 1747534 SIP_LAYOUT SHAPE Moving fiducial crashes SiP Layout
Jun 19 2017, 15:37
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 022 Код Fixed CCRs: SPB 17.2 HF022 06-16-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1755789 ADW DBEDITOR Checking in HSS Block returns 'Failed to create archive' 1731459 ADW FLOW_MGR Cannot open LRM from Flow Manager 1731460 ADW FLOW_MGR Cannot open LRM from Flow Manager 1744081 ADW FLOW_MGR Error regarding configuration file when trying to open Workflow Manager 1756727 ADW LIBIMPORT EDM Library Import fails with java exceptions when merging classifications 1743763 ADW SRM Find filter is grayed out when Allegro PCB Editor is opened from EDM Flow Manager 1748399 ALLEGRO_EDITOR DATABASE In release 17.2-2016, end caps not visible for certain clines in PCB Editor 1748522 ALLEGRO_EDITOR INTERACTIV A component mirrored using the 'funckey' command jumps to (0,0) position when the 'move' command is used on it 1734983 ALLEGRO_EDITOR INTERFACES Secondary step model does not stay mapped after drawing is reopened 1753704 ALLEGRO_EDITOR REFRESH Refreshing symbols crashes PCB Editor 1493721 ALLEGRO_EDITOR SHAPE Voids on negative planes are not adhering to constraints 1711242 ALLEGRO_EDITOR SHAPE Route keep out leads to partly unfilled shapes with gaps 1726865 ALLEGRO_EDITOR UI_GENERAL Pop-up Mirror command does not mirror at cursor position 1752987 ALLEGRO_EDITOR UI_GENERAL axlUIViewFileCreate zoom to xy location not working while in user created form. 1755638 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, zoom operations using mouse button not working when axlShellPost() is run 1719792 ALLEGRO_PROD_TOOLB CORE Productivity Toolbox Z-DRC hangs or crashes PCB Editor 1624869 ALTM_TRANSLATOR CAPTURE A structure file is required to translate a third-party schematic to OrCAD Capture 1707416 ALTM_TRANSLATOR CAPTURE Missing components and pins in the OrCAD Capture schematic translated from a third-party tool 1708825 ALTM_TRANSLATOR CAPTURE The third-party translator fails to translate the schematic 1719200 ALTM_TRANSLATOR CAPTURE The third-party translator fails to translate all the pages of a schematic 1546070 ALTM_TRANSLATOR CORE Third-party to DE-HDL schematic translation fails 1700508 ALTM_TRANSLATOR CORE Third-party PCB translator does not work in release 17.2-2016 1699340 ALTM_TRANSLATOR DE_HDL Unable to import third-party schematic into DE-HDL using Import menu in PCB Editor 1630379 ALTM_TRANSLATOR PCB_EDITOR Third-party translator is not importing clines and vias 1708615 ALTM_TRANSLATOR PCB_EDITOR All items of third-party PCB not imported in release 17.2-2016 1758296 APD DXF_IF DXF OUT: Rounded rectangle pads mirrored incorrectly 1756040 APD IMPORT_DATA The 'die text in' command ignores values after the decimal point 1727206 APD SHAPE Merging two shapes results in an incorrect shape 1753682 CONCEPT_HDL CONSTRAINT_MG Constraint Manager stops responding while cross probing DE-HDL 1721334 CONCEPT_HDL CORE dsreportgen not able to resolve gated part on schematic 1747559 CONCEPT_HDL CORE Copying a logic symbol without a part table entry results in ERROR(SPCODD-53) 1749644 CONCEPT_HDL CORE In release 17.2-2016 Hotfix 019, 'align components' is not working on Windows 8 and DE-HDL crashes 1746910 CONCEPT_HDL GLOBALCHANGE Global Component Change unable to identify part data when using schematic pick option 1743572 FLOWS PROJMGR Project Manager displays incorrect values in Project Setting 1724124 FSP DESIGN_EXPLOR Provide TCL command to filter design connectivity window 1719105 FSP GUI Tabular sorting not working in FPGA System Planner 1755750 PCB_LIBRARIAN GRAPHICAL_EDI In release 17.2-2016, unable to delete _N pins in PDV Symbol Editor 1722993 PCB_LIBRARIAN IMPORT_CSV Part Developer crashes while importing part information stored in a .csv file 1758856 SIP_LAYOUT 3D_VIEWER Correct the spelling error in the 3D Viewer Design Configuration window 1755179 SIP_LAYOUT ARTWORK PCB Editor crashes when creating Gerber files 1743511 SIP_LAYOUT MANUFACTURING Package Design Integrity shows non-redundant padstacks in the Redundant Padstacks check
Aug 11 2017, 22:41
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 024 Код Fixed CCRs: SPB 17.2 HF024 07-28-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1762143 ADW COMPONENT_BRO Part placed using the 'Add' button does not populate 'PART_NAME' property 1765790 ADW PART_BROWSER Fail to extract component part number and footprint information 1757719 ADW TDA TDO and Windchilll Work Group Manager out of sync at times 1760607 ALLEGRO_EDITOR DATABASE Value for number of decimal places changes in Pad Designer in release 17.2-2016 1775160 ALLEGRO_EDITOR DFA Loading DFA spreadsheet crashes PCB Editor in release 17.2-2016 1765984 ALLEGRO_EDITOR OTHER Cannot view System Info 1729350 ALLEGRO_EDITOR REPORTS Net loop is not listed in report 1725242 ALLEGRO_EDITOR SHAPE 'Same net shape to hole spacing' is only detecting the DRC and not voiding the shape 1754402 ALLEGRO_EDITOR SHAPE Illegal arc radius error (SPMHA1-85) 1762888 ALLEGRO_EDITOR SHAPE Border line missing for some crosshatch (xhatch) shape voids 1769188 ALLEGRO_EDITOR SHOW_ELEM 'Show Element' with the 'Groups' option used on certain modules crashes PCB Editor 1767690 ALLEGRO_EDITOR TESTPREP PCB Editor crashes when running automatic Testprep 1737337 ALLEGRO_EDITOR UI_FORMS Pinned Show Element window closes when opening new design in release 17.2-2016 1736642 ALLEGRO_PROD_TOOLB INTEGRATION Cannot change accuracy to 4 for 'Change Width' in Productivity Toolbox 1685216 ALTM_TRANSLATOR CAPTURE Third-party translator placing symbols off grid 1738679 ALTM_TRANSLATOR CAPTURE Connectivity loss in imported schematic 1738705 ALTM_TRANSLATOR CAPTURE Connectivity loss in imported schematic 1748583 ALTM_TRANSLATOR CAPTURE Crash on importing design using third-party translator 1679310 ALTM_TRANSLATOR PCB_EDITOR Third-party translator should fix off-centered connections 1686845 ALTM_TRANSLATOR PCB_EDITOR Third-party translator does not place parts after successful translation 1723141 ALTM_TRANSLATOR PCB_EDITOR Placement outlines are rotated in third-party translator 1723164 ALTM_TRANSLATOR PCB_EDITOR Third-party translator creates board with missing data: vias, traces, and so on 1723190 ALTM_TRANSLATOR PCB_EDITOR Third-party translator changes design origin 1750496 ALTM_TRANSLATOR PCB_EDITOR Third-party board with arc tracks not correctly converted to arc clines 1769624 APD DATABASE Attempted symbol delete crashes APD 1727206 APD SHAPE Merging two shapes results in an incorrect shape 1707756 ASDA VARIANT_MANAG Scrolling in Create Variant closes tool 1753699 CM RELEASE installDebugger() does not work in release 17.2-2016 as SKILL kit is not installed 1741534 CONCEPT_HDL CORE DE-HDL freezes when selecting a net that contains many connections 1752687 CONCEPT_HDL CORE The move command changes the connectivity of the schematic 1763525 CONCEPT_HDL CORE Genview crashes when generating split symbols 1766797 CONCEPT_HDL CORE Schematic not refreshed after using the clear xnet overrides feature 1770852 F2B PACKAGERXL ERROR(SPCOPK-1138): A hard location was found on instances of different physical part types 1754473 FSP DE-HDL_SCHEMA Provide an option to generate symbols with custom attributes 1748106 FSP OTHER Create protocol from existing protocol error message needs clarity 1724201 FSP SYMBOL_EDITOR Unable to change 'Pin Direction' in symbol editor 1772429 ORBITIO ALLEGRO_SIP_I Import - OrbitIO: Translator cannot create bundle in PCB Editor 1725759 SIG_INTEGRITY OTHER PCB shape/plane capacitance 1760924 SIP_LAYOUT DIE_STACK_EDI Package height of die .dra file reset to 110um when placed 1764385 SIP_LAYOUT MODULES Embedded components are unplaced in created modules (.mdd) 1733679 SIP_LAYOUT OTHER 'metal density scan' does not use select window 1763707 SIP_LAYOUT OTHER SiP Layout exits with error message in release 17.2-2016 1763515 SIP_RF DIEEXPORT Virtuoso writes incorrect width for 45 degree path segments in XDA file 1772397 TDA DEHDL DE-HDL crashes if license is not available for team design
Aug 28 2017, 17:39
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 025 Код Fixed CCRs: SPB 17.2 HF025 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1258913 ADW ADWSERVER Copy project message: Unable to locate tools.jar 1760866 ADW ADWSERVER Metrics dashboard in Allegro EDM Configuration Manager does not show updated SPB 17.2 hotfix 1055946 ADW ADW_UPREV Set PTF_SUBTYPE SEARCHABLE to false and default value to exclamation mark 1508163 ADW COMPONENT_BRO Manufacturers Part tab disappears on clicking anything other than the part number in the left tree 1774164 ADW COMPONENT_BRO In release 17.2-2016 Hotfix 22, DE-HDL crashes on using Generate View 1345018 ADW DBEDITOR Database Editor does not catch empty mandatory properties if no changes are made to the part 1586858 ADW DBEDITOR 'Access Denied' Error while opening Datasheet Model using Launch Viewer in Database Editor 1754185 ADW DBEDITOR Max Height value in DBEditor is different from PCB Editor 1719260 ADW FLOW_MGR Configuration error on a fresh install of EDM in release 17.2-2016 Hotfix 014 1743730 ADW LIBDISTRIBUTI .lis file error in install_model while using MLR. 1757178 ADW LIBIMPORT back-end libimport failed, crash and existing flashmodel not found 1648609 ADW SRM PCB Editor stops responding when launched with -s option in release 16.6-2015 Hotfix 078 1731152 ADW TDA TDO coredumps after a new object has been checked in as minor and deleted. 1766998 ADW TDA TDO-ASA: Cannot enable the project for team design until a component is added to the new ASA/SCM design 1695240 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D View of a package symbol not showing the correct mapped STEP file attached to the package symbol 1698148 ALLEGRO_EDITOR 3D_CANVAS Allegro 3D Viewer crashes on Windows 10 1738655 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas crashes on Windows 10 1750001 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D Canvas crashes on selecting in symbol view 1751796 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas shows component placed at wrong layer for Embedded components 1768775 ALLEGRO_EDITOR 3D_CANVAS Allegro 3D canvas closes when Update Symbol is done and cannot be re-invoked 1695025 ALLEGRO_EDITOR ARTWORK Artwork film show shorts. 1708674 ALLEGRO_EDITOR COLOR Dehighlight all should disable the check boxes in the color dialog/nets 1735522 ALLEGRO_EDITOR COLOR In release 17.2-2016, PCB Editor crashes when not being able to write the CVSettings.xml file. 1764475 ALLEGRO_EDITOR COLOR Allegro PCB Editor hangs when selecting OK on the Color Dialog form 1718438 ALLEGRO_EDITOR CROSS_SECTION User interface is inconsistent for the Mask Layer Subclass site file editor. 1765387 ALLEGRO_EDITOR CROSS_SECTION Cross Section Editor does not retain or remove layers added/removed from Setup-->Subclasses 1714910 ALLEGRO_EDITOR DATABASE PCB Editor crashes with blank allegro.jrl file when a release 16.6 board is opened in release 17.2-2016 Hotfix 013 1769534 ALLEGRO_EDITOR DATABASE DBDoctor unable to delete invalid subclass 1775705 ALLEGRO_EDITOR DATABASE Updating stackup in PCB Editor does not change backdrill status to 'Out-of-Date backdrills' 1778608 ALLEGRO_EDITOR DATABASE Rigid Flex design: Components with pads defined on the TOP and BOTTOM layers are not placed on the correct layer 1778644 ALLEGRO_EDITOR DATABASE Allegro PCB Editor crashes while trying to place dimensions 1698695 ALLEGRO_EDITOR DRC_CONSTR Line to Mech-Pin DRC not displayed 1705214 ALLEGRO_EDITOR DRC_CONSTR Shape to drill DRCs not getting void and 'cns_show' does not report constraint value 1722841 ALLEGRO_EDITOR DRC_CONSTR Inconsistent soldermask to soldermask DRCs on vias as compared to board geometry/soldermask 1736116 ALLEGRO_EDITOR DRC_CONSTR Shape Voiding and DRC error on layer with no hole or pad definition 1744248 ALLEGRO_EDITOR DRC_CONSTR Release 16.6 to 17.2-2016 DML Independent Flow does not resolve differential pair pin pairs Correctly 1776848 ALLEGRO_EDITOR DRC_CONSTR Negative plane island DRC reported in release 17.2-2016 Hotfix 23 1730806 ALLEGRO_EDITOR EDIT_ETCH Element 'vias_allowed' is not valid for content model adding high speed via structures 1745332 ALLEGRO_EDITOR EDIT_ETCH In release 17.2-2016, PCB Editor crashes when starting Add ZigZag Pattern 1765555 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes during contour routing 1644401 ALLEGRO_EDITOR INTERACTIV PCB Editor crashes on running the z-copy command 1657621 ALLEGRO_EDITOR INTERACTIV Copy cline and via cause redundant vias 1688556 ALLEGRO_EDITOR INTERACTIV Limitations with editpad boundary 1704901 ALLEGRO_EDITOR INTERACTIV Changes cannot be done when 'Design outline' is selected 1710731 ALLEGRO_EDITOR INTERACTIV The Edit > Change command does not select or change the text on a block 1714855 ALLEGRO_EDITOR INTERACTIV Placing two objects on the Design_Outline subclass causes PCB Editor to crash 1725736 ALLEGRO_EDITOR INTERACTIV Edit>Change cannot change silkscreen line to a different class, but works in preselect mode 1728004 ALLEGRO_EDITOR INTERACTIV Text cannot be edited if the Design_Outline subclass is in the selection box 1728794 ALLEGRO_EDITOR INTERACTIV The Oops command and the Esc key do not work when moving components in the Temp Group mode 1738070 ALLEGRO_EDITOR INTERACTIV Copying shape after Shape Operations results in error 'E- (SPMHDB-72): Current active shape must be filled first' 1750696 ALLEGRO_EDITOR INTERACTIV Add notch angle option fails to update if changed while add notch command is active. 1755240 ALLEGRO_EDITOR INTERACTIV Copy via does not work 1777416 ALLEGRO_EDITOR INTERACTIV Running shape operations results in database corruption 1715835 ALLEGRO_EDITOR INTERFACES When IDX is imported in PCB Editor, all the shapes are created on package keepout on all subclasses 1744111 ALLEGRO_EDITOR INTERFACES Pads rotating 90 degree when exporting DXF file from Allegro PCB Editor 1736045 ALLEGRO_EDITOR MENTOR Third-party import crashes PCB Editor with error stating that .SAV file will be created 1751914 ALLEGRO_EDITOR MULTI_USER Find Filter options get disabled while creating symbols 1770811 ALLEGRO_EDITOR MULTI_USER In release 17.2-2016, axlTriggerSet('exit 'routine) causes a crash while exiting 1736545 ALLEGRO_EDITOR OTHER Spelling mistake in description of no_dynamic_zoom variable in user preferences Editor 1761610 ALLEGRO_EDITOR OTHER Dynamic shape is not voiding as expected. 1702535 ALLEGRO_EDITOR PAD_EDITOR After modifying a padstack in Pad_Editor, the Update to Design function fails to update the dra file 1713461 ALLEGRO_EDITOR PAD_EDITOR Padstack editor default geometry not working when cell is preselected 1715702 ALLEGRO_EDITOR PAD_EDITOR Donut shape is lost on cutting the pad shape of the donut pad 1720300 ALLEGRO_EDITOR PAD_EDITOR Multi-drill staggered pattern: Different hole placement for first and second rows for releases 16.6 and 17.2-2016 1724896 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor shows flash symbol for regular pad on selecting 'Shape Symbol' 1714839 ALLEGRO_EDITOR PLACEMENT Selecting an alternate symbol (alt_symbol) in a group, in the Placement Edit mode, removes the symbol from the group 1781502 ALLEGRO_EDITOR PLACEMENT Quickplace by room crashes Allegro PCB Editor 1699690 ALLEGRO_EDITOR SCHEM_FTB 'view_pcb directive' no longer working as expected 1758796 ALLEGRO_EDITOR SCHEM_FTB PCB Editor launched from Project Manager does not read the relative paths specified in the view_pcb directive 1761101 ALLEGRO_EDITOR SCHEM_FTB On saving a board after import logic in PCB Editor, the file is saved in the cpm location and not in the physical folder 1761394 ALLEGRO_EDITOR SCHEM_FTB Working directory for PCB Editor changes after import logic 1714922 ALLEGRO_EDITOR SCRIPTS Running script in the non-graphic mode runs the tool graphically 1726550 ALLEGRO_EDITOR SHAPE Shape failed to connect to pin 1754945 ALLEGRO_EDITOR SHAPE In release 17.2-2016, Delete islands fails to add DYN_DELETED_ISLAND to voids on Windows 10 systems 1766280 ALLEGRO_EDITOR SHAPE SPMHGE-300 Polygon operation failed because of an internal error 1768307 ALLEGRO_EDITOR TECHFILE Properties defined in the technology files are not being imported in a new design 1771584 ALLEGRO_EDITOR TECHFILE The tech file import command does not update user-defined property immediately 1730104 ALLEGRO_EDITOR UI_FORMS Change description of Title bar option variables in User Preferences 1749272 ALLEGRO_EDITOR UI_FORMS etchlen_ignore_pinvia variable needs to be updated 1649254 ALLEGRO_EDITOR UI_GENERAL Using wildcard to open padstack file generates error SPMHA1-161 in Padstack Editor in release 17.2-2016 1685985 ALLEGRO_EDITOR UI_GENERAL Funckey not working for Display - Measure 1687073 ALLEGRO_EDITOR UI_GENERAL Show Measure command shifts focus to Search field in result window after selecting first element 1699272 ALLEGRO_EDITOR UI_GENERAL File Viewer not displaying HTML files correctly when 'allegro_html_qt' is enabled 1711321 ALLEGRO_EDITOR UI_GENERAL Database settings do not change on changing color settings using the SKILL function axlDBDisplayControl() 1728468 ALLEGRO_EDITOR UI_GENERAL The Show Element window takes the focus away from the PCB Editor window 1733690 ALLEGRO_EDITOR UI_GENERAL Performance issues in Visibility dialog if called repeatedly in release 17.2-2016, Hotfix 017 1734176 ALLEGRO_EDITOR UI_GENERAL Unable to sort padstacks to open in the padstack editor using wildcards 1735733 ALLEGRO_EDITOR UI_GENERAL RAVEL checks slower in release 17.2-2016, Hotfix 017 1737545 ALLEGRO_EDITOR UI_GENERAL axlVisibleSet is slower in release 17.2-2016 1744655 ALLEGRO_EDITOR UI_GENERAL SKILL code with axlVisibleSet slower in release 17.2-2016 compared to 16.6 1759380 ALLEGRO_EDITOR UI_GENERAL axlLayerPriority API changes layer visibility and colors 1775071 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, dialog boxes are not displayed in the right order on using SKILL 1708554 APD GRAPHICS MCM shape lines are almost short and different with DXF and Gerber files 1678824 APD SHAPE Updating dynamic shape fails to void all elements on layer L2. 1742335 ASDA COMPONENT_BRO Libraries missing from new Component Browser 1779777 ASDA CONNECTIVITY_ SDA: Net name and physical net name are different 1721919 ASDA CROSSPROBE Cross-probing a net from the .brd file highlights the entire bus in the schematic 1714313 ASDA EDIT_OPERATIO Filter does not work correctly in the Change RefDes form 1730809 ASDA FORMAT_OBJECT Image transparency slider does not update the number in the combo box correctly 1747397 ASDA GRAPHICS Pop-up DRC descriptions are too small and cannot be read 1640061 ASDA HIERARCHY Incorrect message received when invalid characters are specified for subdesign suffix 1723535 ASDA MISCELLANEOUS Clicking in the Command window should place the cursor at the last line to avoid editing previously run commands 1699936 ASDA PAGE_MANAGEME Page gaps created while moving pages 1737180 ASDA VARIANT_MANAG Deleted variants are removed from the variant.lst file but displayed in SDA 1763247 ASDA VARIANT_MANAG Changes in Variant Editor are not reflected on the schematic page. 1733971 CAPTURE CONNECTIVITY Auto connect to bus not working in the attached design 1236010 CAPTURE DATABASE Capture is very slow in processing designs. 1518560 CAPTURE DATABASE Large schematics are slow to respond 1705592 CAPTURE DATABASE Capture hangs when switching between schematics that contain nested netgroups 1770687 CAPTURE GENERAL In release 17.2-2016 Hotfix 021 and 022, selecting Help - Learning PSpice throws Java Script error 1692435 CAPTURE HELP Version Info Window is empty 1767374 CAPTURE NETLIST_ALLEG Capture crashes on canceling the netlisting process 1719613 CAPTURE OTHER Moving a wire in OrCAD Capture CIS or Allegro Design Entry CIS results in design crash 1746663 CAPTURE OTHER Capture slows down significantly in release 17.2-2016 Hotfix 017 and 018 1709179 CAPTURE PROPERTY_EDIT Unable to delete unwanted properties associated with Ground and VCC nets. 1714121 CAPTURE SCHEMATIC_EDI Mirroring and moving a symbol resets the position of a newly added pin property 1729861 CIS OTHER The 'Refresh Part Types' icon is alternated with 'Refresh Symbols From Libs' icon 1333600 CONCEPT_HDL COMP_BROWSER Sort the sections numerically in Part Information Manager 1758761 CONCEPT_HDL COMP_BROWSER Incorrect Version showing in Component Browser in 17.2 1769591 CONCEPT_HDL COMP_BROWSER Modify Component / Project Information Manager (PIM), parts take longer to load in EDM 1479711 CONCEPT_HDL CORE Mirroring symbols causes alignment issues 1696208 CONCEPT_HDL CORE Display issue with the grid visibility after a save hierarchy 1698802 CONCEPT_HDL CORE Pin number overlap with the pin stub when the component is mirrored. 1708917 CONCEPT_HDL CORE nconcepthdl crashes on a design with a core dump 1744815 CONCEPT_HDL CORE Deleting a page crashes DE-HDL 1751863 CONCEPT_HDL CORE 'Move' does not move body but only properties of selected part 1763556 CONCEPT_HDL CORE Component Alignment and other graphical feature not working in Windows 10 1725121 CONSTRAINT_MGR CONCEPT_HDL Audit report of ECSets reflects some gaps in certain columns 1758740 CONSTRAINT_MGR CONCEPT_HDL Extracted topology does not populate the gather control used in the ECSet 1759580 CONSTRAINT_MGR CONCEPT_HDL Class to Class assignments are incorrectly displayed in the 'CSet Assignment Matrix' 1759590 CONSTRAINT_MGR CONCEPT_HDL Unable to create bookmarks in Constraint Manager 1764597 CONSTRAINT_MGR CONCEPT_HDL Copying constraints from a SKILL-defined CSet copies the automation flag/attribute ('A' in UI), as well. 1771427 CONSTRAINT_MGR CONCEPT_HDL Decimal units specified in the precision settings are not applied correctly 1700402 CONSTRAINT_MGR DATABASE Parallelism violation DRC not reported until cline is moved 1700370 CONSTRAINT_MGR OTHER Constraint Manager: Expanded nodes collapse on restart 1735636 CONSTRAINT_MGR OTHER Inductors are extracted as resistors in the topology 1776917 CONSTRAINT_MGR OTHER Creating advanced formula causes the tool to crash 1762979 CONSTRAINT_MGR TECHFILE Constraint Manager does not retain values after importing tech file 1699275 CONSTRAINT_MGR UI_FORMS Constraint Manager: Dialog boxes opened from the File – Import menu show files and folders in incorrect order 1699312 CONSTRAINT_MGR UI_FORMS Typing *.* in the File name field does not display all the files in the Import Constraints dialog box 1742134 CONSTRAINT_MGR UI_FORMS Editing a cell from any of the constraint set in Constraint manager is filling other cells that should not be selected 1755576 CONSTRAINT_MGR UI_FORMS Constraint Manager: Physical CSet filter not working correctly 1775333 ECW DASHBOARD Activity Log is not accessible to ECAD_Integrators if they are not part of the project team 1749220 ECW OTHER Remove 'Role' column from Users web parts 1716527 ECW TDO-SHAREPOIN Allegro Pulse: Mismatch between metrics with components on schematic and components in layout 1724195 FSP SYMBOL_EDITOR Device pins are not correctly aligned after being moved in Schematic Symbol Editor 1725479 INSTALLATION DOWNLOAD_MGR Download Manager error prompts user to close downloadmanager.exe 1738952 PCB_LIBRARIAN SYMBOL_EDITOR Pin table must allow for Copy/Paste of Rows 1638740 PSPICE FRONTENDPLUGI Set minimum height for the search field in PSpice Part Search 1699822 PSPICE FRONTENDPLUGI Set minimum height for the search field in PSpice Part Search 1652265 PSPICE MODELING_APPS Cannot place PWL source from PSpice Modeling App 1685967 PSPICE MODELING_APPS Getting error when trying to place PWL source from PSpice Modeling App 1716313 PSPICE MODELING_APPS PSpice PWL Sources not working correctly in release 17.2-2016 Hotfix 014 1738747 PSPICE MODELING_APPS Inconsistent file type for PWL part in modeling application and source library 1762202 PSPICE MODELING_APPS PSpice modelling app Tcl issues 1736605 PSPICE SIMMODELS BSIM4.6 model parameters incorrectly handled by simulator 1442623 PSPICE SIMULATOR Bias points are nor correct in attached circuit 1618815 PSPICE SIMULATOR Bias Point calculation appears incomplete 1723039 PSPICE SIMULATOR PSpice crashes when curly braces are specified for the ETABLE parts 1782353 SIG_INTEGRITY SIGWAVE SigWave crashes when opening .sww file in release 17.2-2016 Hotfix 023 1745940 SIP_LAYOUT DATABASE Cutting a part of a tapered cline does not remove the connectivity on the dangling cline 1780072 SIP_LAYOUT DIE_ABSTRACT_ Export->Die Abstract File causes a crash 1736396 SIP_LAYOUT SYMB_EDIT_APP 'No such child' error message when deleting pins in symed 1769728 TDA CORE Default policy file needs to be fixed 1735682 XTRACTIM GUI XtractIM translation is incorrect: adds anti-pads
Sep 20 2017, 18:53
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 026 Код Fixed CCRs: SPB 17.2 HF026 09-15-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================
1765398 ADW DATAEXCHANGE Duplicate MPNs are created when updating MPN classification properties with data exchange 1780147 ADW DBEDITOR 'Associate Footprint from Tree' does not log the information 1790134 ALLEGRO_EDITOR DATABASE Correct spelling in Layer Function definition 1792345 ALLEGRO_EDITOR DATABASE Pastemask is added to bottom layer on backdrilled pins 1792930 ALLEGRO_EDITOR DATABASE Uprev required for all libraries and padstacks to use release 16.6 DRA in release 17.2-2016 1781203 ALLEGRO_EDITOR DFA DFA Spreadsheet Editor not starting from Windows Start menu 1797422 ALLEGRO_EDITOR DFA DFA Spreadsheet Editor not starting from Windows Start menu 1770694 ALLEGRO_EDITOR INTERFACES Incremental IDX does not place unplaced components 1776791 ALLEGRO_EDITOR INTERFACES STEP file not displayed in PCB Editor for mapping 1783515 ALLEGRO_EDITOR INTERFACES PCB Editor reading step model incorrectly 1781485 ALLEGRO_EDITOR MANUFACT Setting ipc2581attrpath results in error 'E- ipc2581attrpath: Variable not defined' 1772713 ALLEGRO_EDITOR MULTI_USER Allegro Symphony Server rejects group moves 1789853 ALLEGRO_EDITOR MULTI_USER Symphony Server rejects updates and hangs frequently 1725591 ALLEGRO_EDITOR OTHER File - Export PDF crashes on the design attached 1736324 ALLEGRO_EDITOR OTHER Export - PDF fails to export PDF 1794071 ALLEGRO_EDITOR PLACEMENT The placement of component is very slow and takes around 3 to 5 minutes per component. 1496199 ALLEGRO_EDITOR SHAPE Overlapping route keepouts result in a broken shape. 1760146 ALLEGRO_EDITOR SHAPE Void offset in Artwork but not in board for a particular instance only 1770372 ALLEGRO_EDITOR SHAPE Overlapping shapes merged in artwork shifts void causing a manufacturing short 1793419 ALLEGRO_EDITOR SHAPE Unexpected shape void in artwork in release 16.6 1796666 ALLEGRO_EDITOR SHAPE DRCs for out-of-date shape while placing single via 1786386 APD EXPORT_DATA Exported dra and pad files do not have right stackup 1765673 APD SHAPE Shape in Cu1 and Cu3 cannot void correctly 1782418 APD SHAPE Artwork is showing unnecessary horizontal lines 1778366 CONCEPT_HDL CHECKPLUS CheckPlus not printing logic design name 1723855 CONCEPT_HDL CORE Cannot use Rename Signal for unnamed wire segment if the wire has a branch to the same instance 1755174 CONCEPT_HDL CORE Unable to create XNETs on the read-only blocks 1765533 CONCEPT_HDL CORE Strokes are slow to respond in release 17.2-2016 1780253 CONCEPT_HDL CORE In Windows mode, with copy command still active and symbol on cursor, DE-HDL stops responding on pressing Delete key 1785069 CONCEPT_HDL CORE Warning box for SPCOCN-2251 needs to be resized and the text formatted correctly 1786030 CONCEPT_HDL CORE Packager fails in release 16.6 but runs successfully in release 17.2-2016 1788077 CONCEPT_HDL CORE Creating new window (new tab) in DE-HDL resets view of original window 1788591 CONCEPT_HDL CORE Wrong pin number displayed after running packager 1776774 CONCEPT_HDL CREFER CRefer crashes without error entry in log file 1328320 CONCEPT_HDL PDF Cannot select/search sig_name in published PDF 1787409 CONCEPT_HDL PDF Minus character at the end of netname causes unexpected string concatenation during PDF Publish 1758122 CONSTRAINT_MGR ANALYSIS Extracted topology for a differential pair is missing a pin-to-pin connection in the top file 1786161 CONSTRAINT_MGR CONCEPT_HDL Random crashes in release 17.2-2016 while working on the schematic editor along with Constraint Manager 1788877 CONSTRAINT_MGR DATABASE Constraint Manager API cmxlImportFile looks for sub-string during replace mode and not explicit names 1800263 CONSTRAINT_MGR OTHER DE-HDL and CM crash when deleting regions 1792000 CONSTRAINT_MGR UI_FORMS Data type of constraint not shown in GUI 1744828 FSP CAPTURE_SCHEM Button appears during 'Generate OrCAD Schematics' 1747568 ORBITIO OTHER Import of .oio file in SiP Layout takes a long time 1765229 PSPICE AA_FLOW Not able to run PSpice MC after setting Assign Tolerance 1770174 PSPICE MISC Issues with DMI Template Code Generator
Sep 26 2017, 12:41
Пользователь №: 74 440
Кто-нибудь знает, что за новая опция появилась в Allegro PCB, возможно после очередного QIR4? PA3170 - Advanced Technology Option
Сообщение отредактировал alver - Sep 26 2017, 12:50
Sep 26 2017, 17:26
нет, и официальные партнеры затрудняются сказать.
Сообщение отредактировал alver - Sep 26 2017, 17:28
Oct 9 2017, 17:30
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 027 Код Fixed CCRs: SPB 17.2 HF027 09-29-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1795353 ADW FLOW_MGR Tool unable to find project in windows_project.txt 1810386 ADW FLOW_MGR Error regarding not finding project in 'windows_project.txt' 1743732 ADW LIBDISTRIBUTI adwserver -install does not give error if it cannot connect to server. 1804378 ALLEGRO_EDITOR 3D_CANVAS Bend area issues in 3D Viewer 1795312 ALLEGRO_EDITOR DATABASE Cannot unlock symbols as status is changed to View on opening design 1803262 ALLEGRO_EDITOR DATABASE Donut pad With DYN_THERMAL_CON set to FULL_CONTACT has connectivity issues 1802183 ALLEGRO_EDITOR DFM Using mouse wheel to scroll error information in DRC Browser changes font size 1797222 ALLEGRO_EDITOR DRC_CONSTR Updating DRC results in error 'SPMHDB-403' 1792163 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes on moving components 1806640 ALLEGRO_EDITOR INTERFACES Step Mapping not working in release 17.2-2016 Hotfix 025 1807278 ALLEGRO_EDITOR INTERFACES Running 'step_export_product_asm.exe' displays 'vcruntime140.dll' missing error 1807286 ALLEGRO_EDITOR INTERFACES The facet file (.xml) for the STEP model 'modelname.step' cannot be found. 1808006 ALLEGRO_EDITOR INTERFACES Facet file for step model cannot be found 1704335 ALLEGRO_EDITOR MANUFACT Documentation Editor shows an error about backdrill while no backdrill was used in the design 1800115 ALLEGRO_EDITOR MANUFACT IPC2581 Export giving error that backdrill is out of date even though no backdrill is defined in the design 1799444 ALLEGRO_EDITOR PLACEMENT Via Array - Boundary placement fails with error 1725242 ALLEGRO_EDITOR SHAPE 'Same net shape to hole spacing' is only detecting the DRC and not voiding the shape 1804129 ALLEGRO_EDITOR SHAPE XHatch Shape not voiding properly 1805238 ALLEGRO_EDITOR SHAPE PCB Editor crashes while importing netlist 1803542 ALLEGRO_EDITOR SKILL Using axlPadstackEdit to change drill size causes via net to change in release 17.2-2016 Hotfix 025 1800774 APD STREAM_IF Only one pad in GDSII when running 'stream out' with the Flatten Geometry option 1804196 APD STREAM_IF Component is mirrored by X-axis instead of Y-axis on enabling mirror geometry 1803375 ASDA IMPORT_BLOCK Import HDL Block fails with message regarding Xnet states and DML independence 1807423 ASDA NEW_PROJECT SDA CPM file has erroneous date 1789400 CAPTURE SCHEMATIC_EDI Capture schematic opens unannotated pages on search 1801573 CONCEPT_HDL CONSTRAINT_MG Upreving release 16.6 design to 17.2-2016 adds NO_XNET_CONNECTION to some components 1810586 CONCEPT_HDL CONSTRAINT_MG DE-HDL crashes when transferring XNET properties to similar components in a read-only block 1794169 CONCEPT_HDL CORE _automodel command crashes DE-HDL if PACK_IGNORE is set 1798672 CONCEPT_HDL CORE Dashes in design name creates an extra design folder in worklib after upreving to release 17.2-2016 1802258 CONCEPT_HDL CORE Locking unlocked components results in a warning (SPCOCN-3403) 1803019 CONCEPT_HDL CORE DE-HDL crashes on backannotation 1803615 CONCEPT_HDL CORE After running 'Mark for Variant', the block cannot be changed to blue 1804029 CONCEPT_HDL CORE Visibility issues when using the LOCK functionality 1806352 CONCEPT_HDL CORE Group Mirror is causing design corruption. 1806978 CONCEPT_HDL CORE Cannot mirror a group of objects 1810387 CONCEPT_HDL CORE Mirroring groups causes erratic display and may corrupt database if project is saved 1812811 CONCEPT_HDL CORE Schematic group mirror not working 1810401 CONCEPT_HDL INFRA Add Signal Name: Cannot select suggested net name 1787409 CONCEPT_HDL PDF Minus character at the end of netname causes unexpected string concatenation during PDF Publish 1800931 CONSTRAINT_MGR OTHER Even after removing NO_XNET_CONNECTION on parallel termination, topology extracted has duplicate capacitors 1790106 CONSTRAINT_MGR SCM Cannot find the constraints file (0) in the schematic project 1787117 CONSTRAINT_MGR UI_FORMS Creating bundle in Constraint Manager crashes PCB Editor 1797384 ECW METRICS Pop-up metrics value tool tip is translucent, making values hard/impossible to read 1803226 ECW METRICS Pop-up metrics value tool tip is translucent, making values hard/impossible to read 1664059 ORBITIO ALLEGRO_SIP_I Incorrect connectivity after .brd import 1799338 SIP_LAYOUT DRC_CONSTRAIN Multi-threaded DRC fails with internal memory error even after setting shape_cache_size 1799499 SIP_LAYOUT DRC_CONSTRAIN Multi-thread DRC fails 1806585 SIP_LAYOUT DRC_CONSTRAIN Multi-threaded DRC update aborted: internal memory resource depleted 1809804 SIP_LAYOUT DRC_CONSTRAIN Error message while updating DRCs in release 17.2-2016 Hotfix 026 regarding shape_cache_size 1788770 XTRACTIM ENG Translated bump / ball conductivity is wrong (PowerDC and XtractIM)
Oct 16 2017, 20:36
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 028 Код Fixed CCRs: SPB 17.2 HF028 10-14-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1773530 ADW FLOW_MGR DE-HDL hangs on importing components from another design or copying and pasting components within a design 1790584 ADW FLOW_MGR SKILL code for comparing two PCB Editor .brd files does not work in EDM in release 17.2-2016 1794116 ADW FLOW_MGR LRM fails to run on project 1811532 ADW FLOW_MGR The message for missing tools.jar should not appear in adwcopyproject.log 1812109 ADW LRM Library revision manager displays errors while re-importing updated sub-blocks 1771851 ADW PCBCACHE Problem in packaging upreved imported block 1814785 ALLEGRO_EDITOR 3D_CANVAS PCB Editor crashes when a bend is created and then viewed in 3D Viewer 1800131 ALLEGRO_EDITOR DATABASE allegro_downrev_library utility fails on Windows 10 1814558 ALLEGRO_EDITOR DFM Silkscreen checks do not work if silkscreen is defined as mask in cross section 1814607 ALLEGRO_EDITOR DFM DFM check for soldermask does not include Package Geometry/ Soldermask if the soldermask is part of stackup 1813996 ALLEGRO_EDITOR EDIT_ETCH Add Connect crashes PCB Editor if clearance view is set to channel 1810832 ALLEGRO_EDITOR SCHEM_FTB Error while doing Export Physical from DE-HDL to PCB Editor 1811785 ALLEGRO_EDITOR SCHEM_FTB Import > Logic > Import Directory does not resolve the relative path to the packaged folder 1814166 ALLEGRO_EDITOR SCHEM_FTB Error message when exporting design to board using an earlier version of database 1817891 ALLEGRO_EDITOR SCHEM_FTB Error message when exporting design to board using an earlier version 1818954 ALLEGRO_EDITOR SCHEM_FTB Error message when exporting design to board using an earlier version of database 1812808 ALLEGRO_EDITOR SHAPE Artwork is different from PCB board 1814836 ALLEGRO_EDITOR SKILL Doing zcopy Xhatch pattern crashes PCB Editor in release 17.2-2016 1772218 ALLEGRO_EDITOR UI_GENERAL PCB Editor stops responding on Show Element 1778353 ALLEGRO_EDITOR UI_GENERAL Intermittent PCB Editor crashes on loading IDX in release 17.2-2016 Hotfix 020 1818077 ALLEGRO_EDITOR UI_GENERAL axlViewFileCreate disappears behind window or is blank 1807423 ASDA NEW_PROJECT SDA CPM file has erroneous date 1809597 CONCEPT_HDL CORE Problem auditing SI model in Allegro Design Entry HDL from Hotfix 025 onward, no problem in Hotfix 024 1810322 CONCEPT_HDL CORE Unable to package design if OK_NET_ONE_PIN property is set 1813436 CONCEPT_HDL CORE Read-only block import issue in same session: displays error message SPCOCD-553 1813912 CONCEPT_HDL CORE The response in DE-HDL is sometimes extremely slow 1812506 CONCEPT_HDL INTERFACE_DES Error messages during packaging followed by a success message though there are errors in design 1808677 CONSTRAINT_MGR CONCEPT_HDL Auto-generation of differential pair finds several instances of the same net 1808898 CONSTRAINT_MGR CONCEPT_HDL Unable to resolve the ECSet mapping errors if the topology has pin of PINUSE POWER & GROUND 1810320 CONSTRAINT_MGR CONCEPT_HDL DE-HDL - Constraint Manager: Cannot add group to net class if a net in group is a member of the net class 1812459 CONSTRAINT_MGR CONCEPT_HDL Auto-generation of differential pairs has issues 1796234 CONSTRAINT_MGR OTHER PCB Editor crashes on query (ALLOW_ON_ETCH_SUBCLASS) without data type defined 1811692 CONSTRAINT_MGR OTHER Constraint Manager: Set Topology Constraints - Rel Prop Delay - Pins is empty in release 17.2-2016 Hotfix 026 1816311 CONSTRAINT_MGR XNET_DIFFPAIR Extracting a differential pair into SigXplorer crashes DE-HDL 1807593 ORBITIO ALLEGRO_SIP_I Die symbol shifts when importing die from OrbitIO to SiP Layout 1800763 PSPICE SLPS Error while running co-simulation in MATLAB for PSpice-SLPS demo designs
Nov 8 2017, 17:41
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 029 Код Fixed CCRs: SPB 17.2 HF029 11-3-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1814597 ADW DBEDITOR Associate part classification is very slow in release 17.2-2016 of Allegro EDM 1733482 ADW FLOW_MGR After installing QIR3, Flow Manager prompts with Java Help question 1814789 ADW PART_BROWSER PTF shows data in old component browser but not new component browser 1808620 ALLEGRO_EDITOR DFM Missing graphics in new drc browser. 1814558 ALLEGRO_EDITOR DFM Silkscreen checks do not work if silkscreen is defined as mask in cross section 1807996 ALLEGRO_EDITOR EDIT_ETCH Route Clearance View is not using the correct spacing constraint when nets are partially routed in a region 1747929 ALLEGRO_EDITOR INTERFACES Cannot import logo/bmp on a .dra file 1820142 ALLEGRO_EDITOR INTERFACES pdf_out command not supporting UNC paths for the output pdf file 1671865 ALLEGRO_EDITOR MANUFACT Exceeding 20 characters in Artwork Control Form - General Parameters - Prefix displays 'Illegal Character(s)' error 1710032 ALLEGRO_EDITOR MANUFACT Adding Artwork prefix gives error for illegal characters 1714911 ALLEGRO_EDITOR MANUFACT ERROR: 'illegal character(s) present in name or value' while adding prefix in Artwork Control Form 1813950 ALLEGRO_EDITOR MANUFACT In the drill chart, the titles 'tolerance_drill' and 'tolerance_travel' seem to be reversed 1820970 ALLEGRO_EDITOR MANUFACT IDX_EXCLUDE and BOM_IGNORE excluding objects from IDX export 1822045 ALLEGRO_EDITOR PARTITION Shape fillet becomes static shape and loses fillet attribute after importing partition 1776181 ALLEGRO_EDITOR SHAPE Placing via arrays around a differential pair places vias only for one net 1817283 ALLEGRO_EDITOR SHAPE Allegro PCB Editor Show Measure Air Gap shows a very large number 1818077 ALLEGRO_EDITOR UI_GENERAL axlViewFileCreate disappears behind window or is blank 1815595 APD DRC_CONSTRAIN Differential pair spacing constraint not propagating to physical cset nets 1785116 APD SHAPE Big size die performance issue 1811134 APD STREAM_IF GDS stream out with 2000 precision has sharp edges along shapes. 1811882 APD VIA_STRUCTURE High-speed via structure refresh fails 1814878 ASDA DARK_THEME Part Manager: Difficult to read black text on black background 1814889 ASDA DARK_THEME Change 'updating route in progress' message color: a bright orange bar in dark theme is difficult to read 1817355 ASDA PAGE_MANAGEME Double-clicking a library in project preferences library does not move the library but changes appearance 1817964 ASDA SHORTCUTS User Preferences shortcut misspelled 1820247 CONCEPT_HDL CORE DE-HDL crashes while saving a design 1823187 CONCEPT_HDL CORE DEHDL allows editing of the locked component's refdes using change text editor 1824052 CONCEPT_HDL CORE Trying to edit on a group containing a LOCK component, deletes the packaging data on the schematic 1813987 CONSTRAINT_MGR OTHER PCB Editor crashes when Constraint Manager is closed 1816311 CONSTRAINT_MGR XNET_DIFFPAIR Extracting a differential pair into SigXplorer crashes DE-HDL 1821129 CONSTRAINT_MGR XNET_DIFFPAIR Uprev to release 17.2-2016 adds unwanted NO_XNET_CONNECTION property to discrete symbols 1814725 PSPICE PROBE PSpice Measurements crashes PSpice for a digital simulation 1808672 SIP_LAYOUT INTERACTIVE create bounding shape command options: 'Min Area' and 'Sync with shape layer' 1817458 SIP_LAYOUT MANUFACTURING Error in DXF conversion after updating SiP Layout from Hotfix 066 to 082 in release 16.6
Nov 20 2017, 18:30
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 030 Код Fixed CCRs: SPB 17.2 HF030 11-17-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1821774 ADW DBEDITOR MPN is tagged Pending Purge after deletion and lib_dist 1829549 ALLEGRO_EDITOR DRC_CONSTR Dynamic phase DRC marker displayed at the design origin 1690998 ALLEGRO_EDITOR INTERFACES Runtime error when running PDF Publisher 1805203 ALLEGRO_EDITOR INTERFACES Runtime error when exporting smart PDF on a large board with all film layers selected 1811698 ALLEGRO_EDITOR INTERFACES Runtime error while exporting PDF 1823818 ALLEGRO_EDITOR INTERFACES Cannot map some step models 1750654 ALLEGRO_EDITOR MANUFACT Cut marks cannot be generated on cut outline. 1828293 ALLEGRO_EDITOR NC Incorrect status returned for backdrill 1825401 ALLEGRO_EDITOR PADS_IN In PADS library translation, pads_lib_in fails to create Placebound_Top as a shape 1825427 ALLEGRO_EDITOR PADS_IN Symbol drawing files (.dra) created after PADS Library translation are not getting renamed to their decals 1825460 ALLEGRO_EDITOR PADS_IN Pins are moved from their correct locations during PADS Library Translation 1831200 ALLEGRO_EDITOR PLOTTING Incorrect PDF output for traces 1321314 ALLEGRO_EDITOR SHAPE Force update of dynamic shape generates thermal tie that causes net to short 1647585 ALLEGRO_EDITOR SHAPE Void around holes is not circular but of the shape of the bounding box 1830676 ALLEGRO_EDITOR SHAPE XHatch Shape not voiding properly 1821286 ALLEGRO_EDITOR SKILL Using axlSetParam to set static shape clearance parameter crashes PCB Editor 1804662 ASDA DARK_THEME Dark Theme: Change color of selected cells in Rename signals dialog so user can see they are selected 1817486 ASDA NEW_PROJECT Need to save a project with a new name, 'copyprojectas' does not seem to work 1826023 ASDA NEW_PROJECT SDA requires user to go into project settings window twice to add a library 1830632 ASDA SCRIPTING SDA crashes when you type 'find -types' in the Tcl command window 1798864 ASDA VARIANT_MANAG Retain default part visibility when substituting preferred part for variant 1798865 ASDA VARIANT_MANAG Value attribute of variant is off while printing though on for default and view 1798866 ASDA VARIANT_MANAG Variant Printing: Pin numbers printed though set to off on default part 1831836 ASDA VARIANT_MANAG Cannot delete existing variants in design 1821120 CONCEPT_HDL CORE SIGNAL_MODEL attached to a component is not displayed on the canvas in the Attributes form 1824714 CONCEPT_HDL CORE Display issue: Page border disappears when running the command _movetogrid 1822587 CONCEPT_HDL CREFER CRefer crashes on a hierarchical design using split blocks 1825461 CONSTRAINT_MGR CONCEPT_HDL Uprevving to release 17.2-2016 adds NO_XNET_CONNECTIONS on components having custom models 1825968 CONSTRAINT_MGR DATABASE cmxlGetObjects returns all the aliased nets and the physical net that goes to the netlist 1819622 CONSTRAINT_MGR XNET_DIFFPAIR Discrete with NO_XNET_CONNECTION removed from topology when extracted with Routed Interconnect 1829762 ECW PROJECT_MANAG Pulse log in: Multiple processes triggered, generating many zip file packets and corrupting many of the packets 1810296 F2B BOM BOM includes status column, nothing should ever be forced on a users BOM output 1824593 F2B PACKAGERXL PXL crashes and removes the pxl.log file from the Packaged directory 1832005 F2B PACKAGERXL Message stating 'PXL has stopped working' when packaging design 1822912 RF_PCB AUTO_PLACE rf_autoplace fails for RF component containing variable 1803731 SIP_LAYOUT DXF_IF DXF export from 'Component Geometry/Pin_Number' subclass not working in release 17.2-2016 1825478 SIP_LAYOUT SHAPE When running the Shape Islands report it is listing all the Fillets as Islands
Dec 11 2017, 15:35
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 031 Код Fixed CCRs: SPB 17.2 HF031 12-8-2017 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1746108 ADW DBADMIN Adding and then saving a custom rule set in rule manager results in corrupt rules.xml 1609983 ADW DBEDITOR dbeditor should automatically change mechanical kit names to uppercase 1807139 ADW DBEDITOR Cannot add new properties, though the new properties were shown in dbeditor 1807410 ADW LIB_FLOW Checked-in parts not available in database 1797408 ADW TDA TDO crashes without displaying exception during check-in 1804500 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas fails to show all placebounds of a .dra 1810758 ALLEGRO_EDITOR 3D_CANVAS 3D Viewer represents symbol incorrectly in hotfix 025 but as expected in hotfix 024 1795567 ALLEGRO_EDITOR EDIT_ETCH Route menu has same hot key for 'Connect' and 'Convert Fanout' 1796525 ALLEGRO_EDITOR EDIT_ETCH AiPT is not pushing dynamic shape to add bumps to resolve dynamic phase DRC 1818170 ALLEGRO_EDITOR EDIT_ETCH Fanout with Outward Via direction is shorting few pins 1712658 ALLEGRO_EDITOR INTERACTIV Add connect: Pin remains highlighted even after choosing 'Done' 1727193 ALLEGRO_EDITOR INTERACTIV Logic - Part List truncates device names to 64 characters though database allows longer names 1775484 ALLEGRO_EDITOR INTERACTIV Choosing Next with persistent snap in Show Measure disables persistent snap 1711860 ALLEGRO_EDITOR MULTI_USER Multi-user lock cannot be cancelled 1812448 ALLEGRO_EDITOR NC Crash when canceling NC Parameters dialog 1792987 ALLEGRO_EDITOR PAD_EDITOR Pad Designer does not recognize flash names longer than 31 characters 1810958 ALLEGRO_EDITOR PAD_EDITOR Padstacks with offset holes 787024 ALLEGRO_EDITOR SHAPE Improve dynamic shape voiding in regions 793232 ALLEGRO_EDITOR SHAPE Line to Shape spacing rule outside region affects shape void in region 797245 ALLEGRO_EDITOR SHAPE Line to Shape Spacing with Region not followed 865822 ALLEGRO_EDITOR SHAPE The autovoid functionality should use the true line-to-shape spacing value 912051 ALLEGRO_EDITOR SHAPE Improve dynamic shape voiding in regions 965714 ALLEGRO_EDITOR SHAPE Region constraints are not working correctly on dynamic shapes 968342 ALLEGRO_EDITOR SHAPE Shape Voiding when crossing constraint region is taking conservative value and not the actual spacing value 974734 ALLEGRO_EDITOR SHAPE Shape Voiding when crossing constraint region takes conservative value and not actual spacing value 1073908 ALLEGRO_EDITOR SHAPE Allow line to shape spacing in Region 1154787 ALLEGRO_EDITOR SHAPE Region constraints not applied correctly to dynamic shapes 1171283 ALLEGRO_EDITOR SHAPE Shape Voiding when crossing constraint region takes conservative value and not actual spacing value 1181767 ALLEGRO_EDITOR SHAPE Allow override on line to shape spacing in Constraint Region 1183792 ALLEGRO_EDITOR SHAPE Allow override on line to shape spacing in Constraint Region 1186210 ALLEGRO_EDITOR SHAPE Line to shape spacing constraint does not follow the Constraint Region value 1192312 ALLEGRO_EDITOR SHAPE Region constraints are not working correctly. 1387021 ALLEGRO_EDITOR SHAPE Improve dynamic shape voiding in Regions 1447891 ALLEGRO_EDITOR SHAPE Resolved constraint and actual air gap differ 1465383 ALLEGRO_EDITOR SHAPE Line to shape spacing constraint does not follow the Constraint Region 1583144 ALLEGRO_EDITOR SHAPE Line to shape spacing inside the constraint region does not follow region rules 1591320 ALLEGRO_EDITOR SHAPE Resolve shape to pin constraint in constraint region 1627305 ALLEGRO_EDITOR SHAPE Shape Voiding when crossing constraint region takes conservative value and not actual spacing value 1694552 ALLEGRO_EDITOR SHAPE Constraint region not working correctly 1764474 ALLEGRO_EDITOR SHAPE Line to Shape Spacing for Region should be used inside region instead of conservative value 1775119 ALLEGRO_EDITOR SHAPE Shape voiding is not following constraint rules for dynamic shapes in a constraint region 1784916 ALLEGRO_EDITOR SHAPE Shapes are not voiding to other shapes against DRC settings, creating random DRCs. 1793179 ALLEGRO_EDITOR SHAPE 'Same net shape to hole spacing' is only detecting the DRC and not voiding the shape 1803365 ALLEGRO_EDITOR SHAPE Region shape to shape constraints take precedence when shapes have multiple constraints 1800530 ALLEGRO_EDITOR UI_FORMS 3D Anchor menu missing when using new style OrCAD PCB Editor menu 1813604 ALLEGRO_EDITOR UI_FORMS 3D Anchor View is not available on OrCAD PCB Editor menu. 1784710 ALLEGRO_EDITOR UI_GENERAL During Place Replicate and saving file with same name, the warning pop-up window does not show on top 1784728 ALLEGRO_EDITOR UI_GENERAL During Place Replicate and saving file with same name, the warning pop-up window does not show on top 1721853 ASDA CANVAS_EDIT Movement of components results in shorts and inconsistent routing 1802120 ASDA CONTEXT_MENUS Ports are selected though filter is set to Components 1803832 ASDA MISCELLANEOUS Browse and select new libraries without editing cds.lib 1804643 ASDA TABLE Exception when pasting table data from third-party tool in SDA 1794004 CAPTURE LIBRARY Diode pin numbers different in Capture in release 16.6 and 17.2-2016 1735506 CAPTURE OTHER File menu is missing in Capture 1766663 CAPTURE SCHEMATICS Capture crashes during part placement 1762181 CAPTURE SCHEMATIC_EDI Crash on 'Push Occ. Prop into Instance' 1786762 CAPTURE SCHEMATIC_EDI 'Remove Occurrence Properties' and 'Push Occ. Prop into Instance' corrupt database 1759424 CIS PART_MANAGER Unable to save the link database part from part manager 1802670 CONCEPT_HDL CORE Variant commands take 6 to 10 hours to run on a block 1816798 CONSTRAINT_MGR CONCEPT_HDL CM API ACNS_DESIGN returns the design name in mixed case 1812656 CONSTRAINT_MGR DATABASE Constraint Value specified at the DEFAULT PCSet/SCSet is not shown in bold blue 1635766 CONSTRAINT_MGR UI_FORMS Worksheet views are not changed as per input 1700505 ECW PART_LIST_MAN Shopping Cart Quantity is not read or not displayed in Pulse 1797371 ECW PROJECT_MANAG Clicking on another project sometimes takes you to the default project instead of the project you click on 1843526 INSTALLATION TRIAL Trial installer should not check disk space in update licensing mode 1762148 PCB_LIBRARIAN SETUP Part Developer: Text not readable in Setup form 1770760 PCB_LIBRARIAN SYMBOL_EDITOR Symbol Editor does not remember the last size of the window 1773604 PCB_LIBRARIAN SYMBOL_EDITOR Option to switch between the new and legacy Symbol Editors 1800354 PCB_LIBRARIAN SYMBOL_EDITOR Resistor has too many lines and looks wrong in new symbol editor 1813346 PCB_LIBRARIAN SYMBOL_EDITOR Resistor looks different with multiple diagonal lines in new Symbol Editor but looks normal in DE-HDL 1815279 PCB_LIBRARIAN SYMBOL_EDITOR Unable to change Grid Settings from Lines to Dots 1738603 PSPICE DIG_SIMULATOR Release 17.2-2016 PSpice digital model: Delay defined by PINDLY is not taken into account 1802905 PSPICE ENCRYPTION Incorrect option shown in PSpiceENC syntax in usage detail 1765345 PSPICE ENVIRONMENT Custom distributions are not added to the dropdown 1784856 PSPICE ENVIRONMENT PSpice ignoring directory changes for Save check point in simulation setup session 1817805 PSPICE ENVIRONMENT Incorrect result for PSpice 'Start saving data after' 1784507 PSPICE FRONTENDPLUGI Spelling of 'Definition' in PSpice Part Search is not correct 1801790 PSPICE LIBRARIES SAC model giving errors 1738776 PSPICE SIMULATOR PSpice simulation stops before TSTOP 1795950 PSPICE SIMULATOR Simulation cannot be completed in release 17.2-2016 but is completed in release 16.6 1803407 PSPICE SIMULATOR Getting convergence error on a model 1814759 PSPICE SLPS .INC file is not working with SLPS 1715859 SIP_LAYOUT ETCH_BACK Etchback mask not overlapping each other; creating floating metal 1729523 SIP_LAYOUT INTERACTIVE When creating a bond finger solder mask the results do not match the required settings 1800069 SIP_LAYOUT INTERACTIVE Corrupt dra/psm symbol, but the reason is unclear 1756620 SIP_LAYOUT SHAPE Performance issue when moving vias. 1782928 SIP_LAYOUT SHAPE Shape merging (logical operation) shows error though measuring shows elements are correctly spaced 1816454 SIP_LAYOUT THIEVING Thieving: need thieving as a specific data type in CM to better control the filling pattern 1728026 TDA CORE Check-in should not require all child objects to be checked in specially if they are not checked-out 1823976 TDA SHAREPOINT Connection to server terminates when joining a project
Jan 15 2018, 20:45
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 032 Код Fixed CCRs: SPB 17.2 HF032 01-13-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1846603 ADW FLOW_MGR Copy project GUI not displaying correct design name after changing the project folder name 1831152 ALLEGRO_EDITOR 3D_CANVAS New 3D viewer canvas is blank 1805870 ALLEGRO_EDITOR COLOR Color file with dot (.) in the filename is not recognized for setting color from the Visibility tab 1843126 ALLEGRO_EDITOR DATABASE DBDoctor UI is taking very long 1857588 ALLEGRO_EDITOR DFM Design for Fabrication - Aspect Ratio is not taking correct drill hole size 1844313 ALLEGRO_EDITOR INTERFACES STEP output viewed in third-party tool has parts sunken into the secondary side 1801301 ALLEGRO_EDITOR MANUFACT Export IPC 2581 fails if VOLTAGE property is attached to the nets on each side of a RF component 1850078 ALLEGRO_EDITOR MANUFACT Choosing 'Manufacture - Artwork' crashes tool 1844049 ALLEGRO_EDITOR MODULES Module deletion not removing related component information. 1849665 ALLEGRO_EDITOR MULTI_USER Shape rejected by muserver 1782831 ALLEGRO_EDITOR RAVEL_CHECKS RAVEL file does not load when it is located on a network with a UNC path specified 1830442 ALLEGRO_EDITOR SCHEM_FTB Fail to import technology file with message for failure to read the configuration file 1837391 ALLEGRO_EDITOR SCHEM_FTB Capture Property cannot rewrite or update constraints in PCB Editor 1840643 ALLEGRO_EDITOR SCHEM_FTB Export physical does not work after modifying PCB cross section 1718165 ALLEGRO_EDITOR SHAPE Drill hole cannot be voided by shape 1753245 ALLEGRO_EDITOR SHAPE Update Shape retracts more than the shape to shape spacing 1827366 ALLEGRO_EDITOR SHAPE out of date shape is not flagged as out of date 1828208 ALLEGRO_EDITOR SHAPE Shape remains out of date, but status shows otherwise 1832098 ALLEGRO_EDITOR SHAPE Skip via shorts to plane at few places even after the necessary keep-outs are assigned to the via pad-stack. 1834281 ALLEGRO_EDITOR SHAPE DBDoctor creates a large number of DRCs 1842121 ALLEGRO_EDITOR SHAPE Unable to clear the Drill Hole to Shape Spacing DRC as Pin is not able void to the shape correctly. 1846010 ALLEGRO_EDITOR SHAPE Changing MCAD hole to copper spacing in Analysis Modes - Design does not make shapes out-of-date 1839119 ALLEGRO_EDITOR UI_GENERAL On some machines, PCB Editor hangs when launched with a script that uses SKILL to open a design 1828794 APD SHAPE Setting Shape Fill Xhatch Cells option to HIGH, crashes the application 1840748 CAPTURE PROJECT_MANAG Capture crashes on opening or creating designs 1785298 CONCEPT_HDL CORE Incorrect object access during variant load 1832119 CONCEPT_HDL CORE Save Hierarchy shows ERROR(SPCOCN-2010) messages but design packages without error 1833036 CONCEPT_HDL CORE nconcepthdl crashes with a core dump when running an external script 1841545 CONCEPT_HDL CORE NO_XNET_CONNECTION properties added to two-pin filters after upreving to release 17.2-2016 1842289 CONCEPT_HDL CORE Opening a schematic in release 17.2-2016 causes the .dcf file to be overwritten 1841543 CONCEPT_HDL OTHER DE-HDL crashes when changing a net name/page name/bit bus after installing release 17.2-2016, Hotfix 029 1843791 CONCEPT_HDL OTHER Table of contents listing does not update for some hierarchy blocks at the top level 1850709 CONCEPT_HDL OTHER DE-HDL crashes on editing text on canvas in release 17.2-2016, Hotfix 030 1853377 CONCEPT_HDL OTHER DE-HDL crashes on trying to edit bus tap value on Windows 10. 1857213 CONCEPT_HDL OTHER DE-HDL crashes when changing Power Property 1857214 CONCEPT_HDL OTHER In release 17.2-2016, DE-HDL crashes on using 'Change' for a $LOCATION text value on Windows 10 1821982 CONCEPT_HDL PDF Pin number shown in PDF published from DE-HDL 1848615 CONCEPT_HDL PDF PDF Publisher shows incorrect pin text values for parts 1845996 CONSTRAINT_MGR CONCEPT_HDL Confusing error message regarding 'Auto XNets Off Mode' vs 'DML Enabled' 1854190 CONSTRAINT_MGR CONCEPT_HDL 'Audit - Electrical CSets' hangs Constraint Manager after the design is upreved to release 17.2-2016 1854868 CONSTRAINT_MGR CONCEPT_HDL Match Group getting deleted after upreving the design to 17.2 and removing the signal_models 1854872 CONSTRAINT_MGR CONCEPT_HDL Additional Pin-Pairs getting created on the DiffPair after upreving to 17.2 1822624 CONSTRAINT_MGR ECS_APPLY Cannot copy PCB net schedule from a net to other nets 1854883 CONSTRAINT_MGR ECS_APPLY Match group showing 0 length for pin pairs in design upreved from release 16.6 to 17.2-2016 1855893 CONSTRAINT_MGR OTHER SigXplorer extraction crashes PCB Editor 1855917 CONSTRAINT_MGR OTHER SigXplorer extraction does not extract constraints unless the worksheet is opened once in CM 1855350 CONSTRAINT_MGR UI_FORMS Constraint Manager significantly slower in release 17.2-2016, Hotfix 031 1855860 EAGLE_TRANSLATOR PCB_EDITOR Cannot invoke a CAD translator in PCB Editor 1857745 EAGLE_TRANSLATOR PCB_EDITOR A CAD translator does not invoke in PCB Editor 1859005 EAGLE_TRANSLATOR PCB_EDITOR Eagle translator is not invoking at all 1843091 F2B DESIGNVARI Variant Editor allows mismatched JEDEC_TYPEs in release 17.2-2016 1719059 FSP DE-HDL_SCHEMA Termination resistors on buses not being drawn efficiently 1823419 FSP GUI Net Name Template not visible in Change Net Name in Windows 10 1480035 ORBITIO ALLEGRO_SIP_I Die symbols are mirrored when imported back to SiP Layout 1853331 PCB_LIBRARIAN SETUP CPM file not updated from PCB Librarian setup 1841308 PCB_LIBRARIAN SYMBOL_EDITOR Symbol not updated in Library View 1831269 SCM OTHER Blank properties of associated components are being filled with NULL 1719057 SCM SCHGEN Pins off grid for voltage nets 1719060 SCM SCHGEN Pull-ups and pull-downs showing upside down in view 1732687 SCM SCHGEN Schematic generation deletes IO ports; says it's placing them on last page, but never places them 1855932 SIG_EXPLORER OTHER For non-DML designs, SigXplorer defaulting to mils when PCB Editor design units and CM constraints are in mm 1824035 SIP_LAYOUT WLP SiP Layout DRC GUI not reading Tcl blocks in PVS DRC rule deck
Jan 30 2018, 17:53
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 033Код Fixed CCRs: SPB 17.2 HF033 01-25-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1828672 ADW ADWSERVER LDAP connection error while trying to log in to DBeditor 1840699 ADW DBEDITOR Unable to release footprint model due to older version being linked to a DE-HDL Block Model 1852402 ALLEGRO_EDITOR DATABASE Cutouts are not converted correctly when opening release 16.6 board in release 17.2-2016 1855223 ALLEGRO_EDITOR DATABASE Release 16.6. BoardOutline not fully converted to release 17.2-2016 Cutout Layer 1855252 ALLEGRO_EDITOR DATABASE Unable to open a previously saved release 17.2-2016 database 1863025 ALLEGRO_EDITOR DRC_CONSTR Shape voiding to Via pad with backdrill keepout is oversizing the Dynamic shape void by the backdrill keepout 1854087 ALLEGRO_EDITOR EDIT_ETCH Sliding arc crashes PCB Editor 1840667 ALLEGRO_EDITOR INTERACTIV Choosing 'Change Text block to' from pop-up displays message 'E- (SPMHGE-150): Text font is not defined' 1849133 ALLEGRO_EDITOR INTERACTIV On choosing 'Change Text block to' on text , 'Text font is not defined' message appears 1854695 ALLEGRO_EDITOR MANUFACT PCB Editor crashes while performing nc_route 1854634 ALLEGRO_EDITOR NC NC Drill file is generated with half the number of Drill Holes on enabling 'Optimize drill head travel' 1856773 ALLEGRO_EDITOR NC Issue with Optimize Drill head travel in hotfix 031: Missing drill holes 1860876 ALLEGRO_EDITOR NC NC route critical difference between hotfix 031 and 022: No slots found warning 1758671 ALLEGRO_EDITOR OTHER Export parameters takes long time to export and some times the process hangs 1040989 ALLEGRO_EDITOR SHAPE PCB Editor crashes while editing board outline 1328385 ALLEGRO_EDITOR SHAPE Check for missing thermal reliefs when shapes overlap 1366376 ALLEGRO_EDITOR SHAPE Thermal created for Xhatch shape overlapping another shape, but not created when solid shapes overlap 1716436 ALLEGRO_EDITOR SHAPE Acute angle trim should not violate DRC. 1822377 ALLEGRO_EDITOR SHAPE Setting shape parameter Acute angle trim control to Full round produces unwanted shape to keepout DRCs 1826436 ALLEGRO_EDITOR SHAPE Same net shape to hole spacing not voiding shape for cline of different net moved close to vias of same net shapes 1834510 ALLEGRO_EDITOR SHAPE Same Net Shape to Via Spacing does not always clear correctly 1850716 ALLEGRO_EDITOR SHAPE 'DiffPair combined void for vias added with Return Path option' does not work with fillet and pad suppression 1852814 ALLEGRO_EDITOR SHAPE Thermal reliefs are not created after placing modules. 1853453 ALLEGRO_EDITOR SHAPE Route keepout clipping of cross-hatched shapes needs to be corrected 1859391 ALLEGRO_EDITOR SHAPE Shapes are not using 'minimum aperture for gap width' for voiding after back drill update. 1859410 ALLEGRO_EDITOR SHAPE Shape to Teardrop is not using same net spacing rules 1825397 ALLEGRO_EDITOR UI_FORMS Option panel disappears in release 17.2-2016 1854070 ALLEGRO_EDITOR UI_GENERAL enable_command_window_history prevents many aliases and commands from working correctly 1855180 ALLEGRO_EDITOR UI_GENERAL Comma and dot do not work in funckey if 'enable_command_window_history' is set 1860003 ALLEGRO_EDITOR UI_GENERAL Icons and features missing or behaving differently in release 17.2-2016, Hotfix 031 1861278 ALLEGRO_EDITOR UI_GENERAL Icons and menus missing in PCB Editor in release 17.2-2016, Hotfix 031 1862292 ALLEGRO_EDITOR UI_GENERAL Layout Pins icon missing in toolbar in Symbol Editor since Hotfix 031 1793284 ALLEGRO_PROD_TOOLB CORE Limit View (V1R, V2R, COM) for OUTLINE layer. 1712701 ALTM_TRANSLATOR CAPTURE Third-party translator shows error for missing operand 1802182 ALTM_TRANSLATOR CAPTURE Imported schematic has connectivity loss 1802462 ALTM_TRANSLATOR CAPTURE Hierarchical ports placed incorrectly for imported third-party design 1823935 ALTM_TRANSLATOR CAPTURE Translating third-party schematics with hierarchical pages from Design Entry CIS 1830570 ALTM_TRANSLATOR CAPTURE Third-party to Capture translation is translating only one page out of 32 1839627 ALTM_TRANSLATOR CAPTURE Third-party translator is not importing complete schematic 1846965 ALTM_TRANSLATOR CAPTURE Cannot translate third-party schematic 1816767 ALTM_TRANSLATOR DE_HDL Error when translating third-party schematic to DE-HDL 1845601 ALTM_TRANSLATOR PCB_EDITOR Cannot operate third-party PCB translation in release 17.2-2016 Allegro Venture PCB Designer license 1841060 APD DIE_GENERATOR Cannot 'die text out' from SiP Layout or Allegro Package Designer 1793232 APD SHAPE When fillet/taper not connected to a pin, voiding process incorrectly applies shape clearance values 1846541 APD SHAPE shape degassing does not obey void to shape boundary 1863446 ASDA CONSTRAINT_MA A space in the name of a spacing or physical constraint results in the incorrect constraint set name 1859678 ASDA VARIANT_MANAG SDA - When hovering over all three buttons, under Preferred Parts in the Variant info it says (Do not install) 1815839 CONCEPT_HDL CORE Allegro Design Entry HDL crashes when entering Location data manually 1841857 CONCEPT_HDL CORE Unable to modify Components in non-windows mode 1852096 CONCEPT_HDL CORE Creating a block using top-down approach does not generate the CSB file 1857390 CONCEPT_HDL CORE DE-HDL crashes on moving symbol 1789070 CONCEPT_HDL OTHER Having folder 'allegro' in cpm root directory gives error while launching layout editor from Project Manager 1862484 CONSTRAINT_MGR CONCEPT_HDL Extracting an ECSet in SigXP is missing a t-point 1863045 CONSTRAINT_MGR CONCEPT_HDL Pin pairs deleted for a few differential pairs after upreving the design to release 17.2-2016 1863054 CONSTRAINT_MGR CONCEPT_HDL Differential Pairs are treated as invalid objects on upreved design 1863094 CONSTRAINT_MGR CONCEPT_HDL Pin-Pairs are shown duplicated in the topology for the extracted object (Diff Pair) 1831998 CONSTRAINT_MGR OTHER 'Tools - Options' settings not saved on closing Constraint Manager 1855324 CONSTRAINT_MGR OTHER Enable the option 'Expand Hierarchy' in 'Find and Replace' dialog, by default 1860847 CONSTRAINT_MGR OTHER 'Include Routed interconnect' option once enabled, should remain enabled for that board file 1843359 EAGLE_TRANSLATOR PCB_EDITOR While importing third-party PCB, many footprints do not convert, even though the log file says footprint created 1839978 SCM REPORTS dsreportgen unable to output reference designator from a lower-level hierarchical block if it has a single component 1850013 SIP_LAYOUT OTHER Environment variable 'icp_disable_cte_auto_update' needs grammatical change 1833742 SIP_LAYOUT PADSTACK_EDIT When creating Die to Die Via using Generate Padstacks, resultant pad stack has wrong Layers 1619098 SIP_LAYOUT SHAPE Acute angle of shape in design 1728628 SIP_LAYOUT SHAPE Auto-void in dynamic shape does not disappear if object is removed 1854592 SIP_LAYOUT VIA_STRUCTURE Create via structure returns an error
Feb 14 2018, 19:02
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 034Код Fixed CCRs: SPB 17.2 HF034 02-11-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1863981 ADW ADW_UPREV adw_uprev is taking a long time after installing hotfix 031 1868186 ADW DBEDITOR Configured LDAP authentication giving error on launching DBeditor after ISR31 installation 1861524 ADW LIBDISTRIBUTI Library distribution is checking for obsolete classifications every time it is run hence taking more time 1842998 ADW LIB_FLOW Footprint model check-in fails with verification checks failed error 1863047 ALLEGRO_EDITOR DATABASE The layer added above the TOP layer in SiP Layout cannot be deleted from database. 1864997 ALLEGRO_EDITOR DATABASE Opening a downreved design from 17.2 to 16.6 results in Warning(SPMHA1-230): Database has a non-recoverable corruption 1852799 ALLEGRO_EDITOR DFM Refresh symbols crashing inside constraint re-enablement code 1865732 ALLEGRO_EDITOR DFM The Thru via hole to Pad check in Annular Ring should check only the Finished hole size instead of backdrill diameter 1862977 ALLEGRO_EDITOR DRC_CONSTR Differential pair phase tolerance DRCs introduced in release 17.2-2016 DML-independent flow 1864460 ALLEGRO_EDITOR EXTRACT Running Extracta from outside using command window writes layer name for top/bottom layers incorrectly for SiP designs 1859208 ALLEGRO_EDITOR GRAPHICS Pop-up menu remains on desktop when PCB Editor is minimized 1866422 ALLEGRO_EDITOR MANUFACT Backdrill update taking a long time 1867148 ALLEGRO_EDITOR MANUFACT Backdrill update taking longer time to process. 1872127 ALLEGRO_EDITOR MANUFACT Backdrill performance issues - Additional fixes required for S034 1866577 ALLEGRO_EDITOR SHAPE Board becomes unresponsive on Shape Update or Slide Trace 1867590 ALLEGRO_EDITOR SHAPE The Shape to Pad clearance on multi drill oblong padstacks is not working correctly 1871902 ALLEGRO_EDITOR SHAPE Void issue during rotation of symbol with multi-drill padstack from hotfix S032 1866778 ALLEGRO_EDITOR UI_GENERAL Unsupported prototype 'Enable_command_window_history' is not allowing text edits using arrow keys 1865757 ASDA DESIGN_CORRUP SDA hangs when trying to save design or copy page or circuitry 1865872 ASDA DESIGN_CORRUP Corrupt design crashes on editing. 1867039 ASDA DESIGN_CORRUP Design corruption issues 1831263 CAPTURE OTHER Toolbar refresh is very slow on windows 10 after installing latest windows patch 1843595 CAPTURE OTHER Icon refresh is very slow on Windows 10 Professional after installing Hotfix 029 1845003 CAPTURE OTHER Application slow to respond after running for a long time 1847062 CAPTURE OTHER Starting OrCAD Capture redraws the toolbar icons many times. 1850816 CAPTURE OTHER Capture redraws toolbar very slowly and repeatedly 1851346 CAPTURE OTHER Capture CIS redraws toolbars repeatedly 1851354 CAPTURE OTHER Capture slows down in Hotfix 30 as tools icons are repeatedly redrawn very slowly 1851883 CAPTURE OTHER Toolbar content refresh is very slow 1852819 CAPTURE OTHER Capture refreshes toolbar again and again 1853395 CAPTURE OTHER Release 17.2-2016: Capture is refreshing toolbar icons many times at startup with latest hotfix 1853972 CAPTURE OTHER Capture starts and redraws toolbar very slowly 1854735 CAPTURE OTHER Capture toolbar reloads multiple times 1855850 CAPTURE OTHER Toolbar content refresh is very slow 1857523 CAPTURE OTHER Toolbar icons refresh multiple times and very slowly in release 17.2-2016 1859219 CAPTURE OTHER Toolbar is refreshed multiple times while starting Capture CIS 1859626 CAPTURE OTHER OrCAD Capture does not work with the latest Windows 10 update 1863341 CAPTURE OTHER Toolbar icon refresh is very slow 1865661 CAPTURE OTHER Release 17.2-2016, hotfix 032: Capture extremely slow on Windows 10 1867009 CAPTURE OTHER Slow graphics with Design Entry CIS on Windows 10. 1869160 CAPTURE OTHER OrCAD Capture poor performance (toolbar related) 1869692 CAPTURE OTHER Redrawing of toolbars on Windows 10 1870310 CAPTURE OTHER Allegro Design Entry CIS redraw issue 1870367 CAPTURE OTHER OrCAD Capture Slow Redraw 1871382 CAPTURE OTHER Schematic will not open and toolbars refreshed repeatedly 1872427 CAPTURE OTHER OrCAD Capture freeze on Windows 10 1862679 CONCEPT_HDL COMP_BROWSER Unable to input property value to search in Part Information Manager 1865039 CONCEPT_HDL CORE 'Save Hierarchy' of a release 16.6 design opened in release 17.2-2016 results in unexpected part changes 1866544 CONCEPT_HDL CORE XNET_PINS added to migrate Design as DML Independentflow does not get saved in the CSA files 1849363 SIG_INTEGRITY SIMULATION Differential impedance calculation shows ZERO when changing dielectric constant 1854195 SIP_LAYOUT UI_GENERAL After setting 'enable_command_window_history' in QIR5/Hotfix 031, Edit - Text no longer functions
Mar 19 2018, 17:17
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 036Код Fixed CCRs: SPB 17.2 HF036 03-16-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1880209 ADW DBEDITOR DBEditor quick search is resetting the check boxes in the Attributes tab 1880376 ADW DBEDITOR Allegro EDM Database Editor wildcard search functionality broken after installing hotfix 034. 1855444 ALLEGRO_EDITOR DATABASE PCB Editor crashes on creating MDD files after deleting subclasses 1863478 ALLEGRO_EDITOR DATABASE PCB Editor crashes on a specific machine when loading any .mdd file 1875544 ALLEGRO_EDITOR SCHEM_FTB Constraints are getting removed 1719683 ALLEGRO_EDITOR UI_GENERAL Incorrect display when using infinite cursor. 1765989 ALLEGRO_EDITOR UI_GENERAL Selection window does not work correctly with infinite cursor option checked 1885667 ALLEGRO_EDITOR UI_GENERAL Infinite cursor is not working correctly 1873954 ASDA IMPORT_DEHDL_ SDA: Inconsistent pin number positions on part in an imported DE-HDL project 1873883 ASDA NEW_PROJECT SDA: New project from DE-HDL creates blank Page 1 1852036 ASDA VARIANT_MANAG Design with variant cannot generate a variant BOM 1875549 CONCEPT_HDL CORE Incorrect PART_NUMBER/VALUE properties on schematic 1881848 CONCEPT_HDL OTHER License issue: Cannot open Allegro Design Authoring and unable to choose options and features 1872189 CONSTRAINT_MGR CONCEPT_HDL Pin-pairs are created for incorrect members of differential pair after ECSet is applied 1880235 CONSTRAINT_MGR UI_FORMS Ability to lock auto-generated Constraint Set in UI 1868711 CONSTRAINT_MGR XNET_DIFFPAIR Nets are dropped from XNets on the BRD file in the front-to-back flow 1879296 ECW PROJECT_MANAG Mode to remove Uprev Lock from locked webs in admin keys 1881632 PSPICE SLPS PSpice creates 'psp_input.log' during co-simulation flow 1879302 SCM OTHER SCM crashes when global nets are changed in the Block Packaging Options dialog box 1879580 TDA SHAREPOINT GetData error when opening a project in Design Data Management
Apr 3 2018, 14:46
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 037Код Fixed CCRs: SPB 17.2 HF037 03-30-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1886573 ALLEGRO_EDITOR IN_DESIGN_ANA Fail to launch Sigrity executable from release 17.2-2016 1891113 ALLEGRO_EDITOR NC Clubbing total backdrill layerwise data 1886085 ALLEGRO_EDITOR SHAPE Line to Thru Via DRC is not displayed automatically 1850888 ALLEGRO_PROD_TOOLB CORE Design Compare crashes immediately after execution 1639079 ALTM_TRANSLATOR CAPTURE Title block issues with third-party design 1722577 ALTM_TRANSLATOR CAPTURE Third-party translator does not work in Capture in release 17.2-2016 if CDSROOT is not defined 1744697 ALTM_TRANSLATOR CAPTURE Third-party translator crashes 1820160 ALTM_TRANSLATOR CAPTURE Title block does not show ghost image when selecting it for placement 1628560 ALTM_TRANSLATOR PCB_EDITOR Third-party translation to PCB Editor not working properly 1836750 ALTM_TRANSLATOR PCB_EDITOR Third-party translator fails to translate a complete design 1844423 ALTM_TRANSLATOR PCB_EDITOR Third-party translation takes a long time in release 17.2-2016 1849338 ALTM_TRANSLATOR PCB_EDITOR Third-party translated board not correct 1894607 CONCEPT_HDL CORE Closing CM during 'Save Hierarchy' crashes DE-HDL 1703351 CONSTRAINT_MGR CONCEPT_HDL SigXplorer shows invalid models instead of default models in extracted topology 1868687 CONSTRAINT_MGR CONCEPT_HDL DML-independent flow: some pin-pairs missing for Differential Pair XNets when migrating 16.6 design to 17.2 1868747 CONSTRAINT_MGR CONCEPT_HDL Additional pin-pairs created on migrating design to release 17.2-2016 DML-Independent flow 1887794 CONSTRAINT_MGR OTHER Ability to disable cross-section changes in F2B flow 1859193 MODEL_EDITOR TRANSLATION DML provided by Model Integrity has a parsing error: curve must start at time zero
May 3 2018, 12:23
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 038 Код Fixed CCRs: SPB 17.2 HF038 04-27-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1861616 ADW TDO-SHAREPOIN Team Design Option requires Allegro_ECAD_Collab_Workbench license feature 1784170 ALLEGRO_EDITOR 3D_CANVAS Allegro 3D Canvas does not show the flex zone thickness correctly 1801053 ALLEGRO_EDITOR 3D_CANVAS Moving component in 3D Canvas does not move the pads 1805038 ALLEGRO_EDITOR 3D_CANVAS Soldermask and drill not refreshed when component is moved in 3D Canvas, or on the board with Canvas open 1808579 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas displays annular ring incorrectly 1816732 ALLEGRO_EDITOR 3D_CANVAS Mismatch in shape width between board and 3D Canvas 1822778 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas does not display nets when selection is done through click drag 1838129 ALLEGRO_EDITOR 3D_CANVAS User is not able to create a pastemask layer that is visible in 3D Canvas 1842911 ALLEGRO_EDITOR 3D_CANVAS Etch shapes not visible in the 3D Canvas when invoked from a symbol drawing 1849380 ALLEGRO_EDITOR 3D_CANVAS Mirrored components placed in flex zones are not displayed in the 3D Canvas 1851898 ALLEGRO_EDITOR 3D_CANVAS STL export from 3D Viewer scales it up by 100 1853378 ALLEGRO_EDITOR 3D_CANVAS The new interactive 3D Canvas has a display issue with the off-centered drills. 1859713 ALLEGRO_EDITOR 3D_CANVAS PLACE_BOUND shape with package_height_max and package_height_min set displayed incorrectly in 3D Canvas 1880073 ALLEGRO_EDITOR 3D_CANVAS Design Outline is not displayed correctly in 3D Canvas 1880338 ALLEGRO_EDITOR 3D_CANVAS Step Model missing in interactive 3D canvas. 1881889 ALLEGRO_EDITOR 3D_CANVAS Changing the color of STEP model in STEP Mapping Window does not display this color in 3D Canvas. 1889861 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas swaps padstack from Bottom to Top 1830749 ALLEGRO_EDITOR ARTWORK Gerber 4x and 6x output do not fill the shape 1848514 ALLEGRO_EDITOR COLOR axlVisibleDesign does not interact with wirebonds 1837388 ALLEGRO_EDITOR CROSS_SECTION Cannot add solder mask to the site layer mask file 1859797 ALLEGRO_EDITOR CROSS_SECTION The Report only option does not work when choosing Setup - Cross-section - Import - IPC2581 1877858 ALLEGRO_EDITOR CROSS_SECTION Dynamic Pads Suppression option is not working correctly 1880093 ALLEGRO_EDITOR CROSS_SECTION Unused Pad Suppression options are not working correctly and are reset on opening cross-section 1886283 ALLEGRO_EDITOR CROSS_SECTION Unable to turn on 'Dynamic Unused Pads Suppression' 1890959 ALLEGRO_EDITOR CROSS_SECTION Dynamic Pads Suppression option is not working correctly 1900397 ALLEGRO_EDITOR CROSS_SECTION Dynamic Unused Pad Suppression option in Cross-section not working at one go. 1905315 ALLEGRO_EDITOR CROSS_SECTION 'Dynamic Unused Pad Suppression' cannot be turned on. 1861406 ALLEGRO_EDITOR DATABASE Refresh symbol for flex zone not mapping padstack layers correctly 1877132 ALLEGRO_EDITOR DATABASE Fail to open #Taaaaed17598.tmp file and save database 1883747 ALLEGRO_EDITOR DATABASE PCB Editor crashes on stackup modification 1860238 ALLEGRO_EDITOR DFM Applying a DFF constraint set closes PCB Editor instantly 1872780 ALLEGRO_EDITOR DFM DFF false pin to via DRCs: Copper Spacing, SMD pin Pad to Thru Via pad 1823912 ALLEGRO_EDITOR DRC_CONSTR Thru pin to Thru pin DRC between Symbol Pin to Mechanical Hole (with NO regular pad) 1828168 ALLEGRO_EDITOR DRC_CONSTR Upgrading from release 16.3 to 17.2-2016: Differences in spacing constraints 1844780 ALLEGRO_EDITOR DRC_CONSTR Mechanical Pin to Shape Air Gap value is reduced when updating shape 1845011 ALLEGRO_EDITOR DRC_CONSTR When upgrading from 16.6 to 17.2, Spacing constraints for shape to mechanical pin not being resolved properly 1861548 ALLEGRO_EDITOR DRC_CONSTR Inconsistent Micro via to Micro via drill to drill overlap DRCs 1862281 ALLEGRO_EDITOR DRC_CONSTR Mechanical Pin/hole to Shape spacing too small 1887145 ALLEGRO_EDITOR DRC_CONSTR Mechanical pin to conductor spacing setting is overriding constraint region in release 17.2-2016 1893012 ALLEGRO_EDITOR DRC_CONSTR Shape voiding not taking the shape to hole spacing rules for NPTH 1906840 ALLEGRO_EDITOR GRAPHICS Context menu stays when PCB Editor is minimized. 1738624 ALLEGRO_EDITOR INTERACTIV 'Invalid Sector' error when saving psm file for symbol that has die pads, which are copied 1800741 ALLEGRO_EDITOR INTERACTIV Search in User Preferences Editor is giving incorrect results 1812530 ALLEGRO_EDITOR INTERACTIV PCB Editor crashes when opening a file that is in an unsupported format 1812570 ALLEGRO_EDITOR INTERACTIV PCB Editor hangs when an invalid pin number value is specified as the rotation point in the symbol preselect mode 1826819 ALLEGRO_EDITOR INTERACTIV 'Route - Resize/Respace - Align Vias' menu is not available 1842645 ALLEGRO_EDITOR INTERACTIV Via align command is missing from the menu path 1845748 ALLEGRO_EDITOR INTERACTIV With 'Shape - Change Shape Type' enabled, changing visibility reverts the Shape Fill selection to dynamic copper. 1849700 ALLEGRO_EDITOR INTERACTIV Add the reason for generating DBFIX_PAD, to the dbdoctor.log. 1860934 ALLEGRO_EDITOR INTERACTIV Auto-Paste environment variable is not working as it should 1861928 ALLEGRO_EDITOR INTERACTIV Provide a Persistent snap pick option for Display - Measure 1864238 ALLEGRO_EDITOR INTERACTIV Shape place rectangle issue: Dimension of placed rectangle changes on cancelling action 1877026 ALLEGRO_EDITOR INTERACTIV Filled rectangles on ETCH/TOP and ETCH/BOTTOM are not getting copied 1881637 ALLEGRO_EDITOR INTERACTIV Radius of Shape changes when trying to place circle using Place Circle mode. 1883032 ALLEGRO_EDITOR INTERACTIV Find by Query does not find all padstacks in a symbol drawing 1855248 ALLEGRO_EDITOR INTERFACES The Technology Dependent Footprint command returns an error 1885716 ALLEGRO_EDITOR INTERFACES Increase supported STEP model size to enable the use of models larger then 500MB 1860835 ALLEGRO_EDITOR MANUFACT Display a message when backdrill_max_pth_stub is defined for vias or pins only 1869528 ALLEGRO_EDITOR MANUFACT Backdrill out of date when deleting Teardrop and Sliding cline with Teardrop 1885672 ALLEGRO_EDITOR NC NC drill is creating false backdrills when repeat code is turned on in release 17.2-2016 1895084 ALLEGRO_EDITOR NC Padstacks with backdrill data trigger backdrill out-of-date even if the board is not set up for backdrilling 1837514 ALLEGRO_EDITOR PAD_EDITOR Offset is not consistent for keepout and mask layers in padstack editor. 1842902 ALLEGRO_EDITOR PAD_EDITOR Scrolling through the .pad files in the Library Padstack Browser displays Error(SPMHA1-161) 1846504 ALLEGRO_EDITOR PAD_EDITOR COVERLAY_TOP definition lost while opening and saving a 16.6 pad in 17.2 padstack editor 1879453 ALLEGRO_EDITOR PAD_EDITOR The 'Y' tolerance in the Padstack Editor does not update when changing the units of the padstack. 1805202 ALLEGRO_EDITOR PLACEMENT Place via array adds via on differential pairs incorrectly 1806675 ALLEGRO_EDITOR PLACEMENT Place - Manually - Quickview displays the Assembly Top details only 1835177 ALLEGRO_EDITOR PLACEMENT Can place symbol even after cancelling copy by choosing 'Oops' from pop-up 1846892 ALLEGRO_EDITOR PLOTTING PCB Editor Export PDF does not show lines correct for certain component 1006328 ALLEGRO_EDITOR SHAPE Static shapes should void around corners as dynamic shapes do 1033326 ALLEGRO_EDITOR SHAPE Cannot compose lines to shape 1045089 ALLEGRO_EDITOR SHAPE Dynamic shape voiding is inconsistent for solid and xhatch shape fill type 1069959 ALLEGRO_EDITOR SHAPE Compose shape crashes PCB Editor 1085907 ALLEGRO_EDITOR SHAPE Pad does not get thermal connections to shape if outside of the shape outline by more than DRC spacing. 1143563 ALLEGRO_EDITOR SHAPE The pin void inline clearance does not seem to dynamically update the shape and requires a 'force update'. 1243688 ALLEGRO_EDITOR SHAPE shape_rki_autoclip fails to clip shape to route keepin 1269069 ALLEGRO_EDITOR SHAPE Shape void not working properly in release 16.5 hotfix 054 1327755 ALLEGRO_EDITOR SHAPE Need the ability to nest dynamic shapes on different nets partially or entirely 1417394 ALLEGRO_EDITOR SHAPE Shape not updating correctly 1430742 ALLEGRO_EDITOR SHAPE When adding fillet to an irregular pad, the fillet might not be added or be strangely shaped 1750760 ALLEGRO_EDITOR SHAPE Shape to Route Keepout DRC for a void that meets route keepout 1793898 ALLEGRO_EDITOR SHAPE Add teardrops fails to add anything with different settings 1811662 ALLEGRO_EDITOR SHAPE 'show measure' gives incorrect air gap value between two pins 1820901 ALLEGRO_EDITOR SHAPE The pins on adjacent layers are voided as Rounded Rectangle instead of Rectangular as defined in padstacks 1829570 ALLEGRO_EDITOR SHAPE Display measure airgap value is very large 1858696 ALLEGRO_EDITOR SHAPE The via to the edge of the board is not connecting to shape even with the PAD_SHAPE_TOUCH_CONNECTION property added 1873384 ALLEGRO_EDITOR SHAPE Boolean AND operation returning nil 1873860 ALLEGRO_EDITOR SHAPE Copper shape does not respect route keepout 1889312 ALLEGRO_EDITOR SHAPE Shape voided for net vias on adding 'PAD_SHAPE_TOUCH_CONNECTIONS' when enabling via suppression 1890702 ALLEGRO_EDITOR SHAPE Not able to add teardrop in release 17.2-2016 1892692 ALLEGRO_EDITOR SHAPE Thermal relief connections being added to static shapes present in the void inside Dynamic Shapes 1893492 ALLEGRO_EDITOR SHAPE 'merge shapes' results in moved void 1896543 ALLEGRO_EDITOR SHAPE Same net pin will not add thermal connection to shape if it is a rotated slot in the symdef 1897645 ALLEGRO_EDITOR SKILL axlCNSGetSpacing() returns nil if active class is non-etch. 1822364 ALLEGRO_EDITOR UI_FORMS Design Parameters dialog disappears if prmed is called while show measure is active 1834395 ALLEGRO_EDITOR UI_FORMS Setup menu of OrCAD PCB Editor is missing the Anchor 3D View command 1838941 ALLEGRO_EDITOR UI_FORMS Anchor 3D View command is not available in OrCAD PCB Editor Setup menu 1716433 ALLEGRO_EDITOR UI_GENERAL Alias keys do not work until mouse scroll key is activated 1721761 ALLEGRO_EDITOR UI_GENERAL During manual placement of symbols, hovering over symbols does not highlight them 1732915 ALLEGRO_EDITOR UI_GENERAL Alias does not work in release 17.2-2016 when switching windows 1770723 ALLEGRO_EDITOR UI_GENERAL Funckey does not work if focus is not on canvas in release 17.2-2016 1793839 ALLEGRO_EDITOR UI_GENERAL Function Key does not work if a form is opened by a previous command 1813961 ALLEGRO_EDITOR UI_GENERAL Inconsistent file formats available when saving reports 1816716 ALLEGRO_EDITOR UI_GENERAL Shortcut not working when using working layer with 'add connect' 1864321 ALLEGRO_EDITOR UI_GENERAL Funckeys not being registered after focus has moved to other window and back again in PCB Editor 1865010 ALLEGRO_EDITOR UI_GENERAL PCB Editor does not get focus when clicking shortcut after switching from any other program or application 1868708 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor, funckeys stop working intermittently in release 17.2-2016, hotfix 032 1869745 ALLEGRO_EDITOR UI_GENERAL Allegro 3D Canvas window becomes active on pointing at minimized icon on taskbar 1869860 ALLEGRO_EDITOR UI_GENERAL Hotkeys no longer functional on switching from PCB Editor to another application and then back again 1870744 ALLEGRO_EDITOR UI_GENERAL Need html extension added to Save pull down menu. 1870996 ALLEGRO_EDITOR UI_GENERAL If you switch from one active window to other, hotkeys stop working 1883507 ALLEGRO_EDITOR UI_GENERAL Hotkeys stop working after Allegro PCB Editor UI window is opened 1886981 ALLEGRO_EDITOR UI_GENERAL Focus lost from layout when switching between PCB Editor and Capture 1887519 ALLEGRO_EDITOR UI_GENERAL Release 17.2-2016, hotfix 034: Shortcuts defined using funckeys not working correctly 1887660 ALLEGRO_EDITOR UI_GENERAL Alias does not work in release 17.2-2016 when switching windows. 1891204 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes if SKILL form is closed using the Close icon ('X') 1898059 ALLEGRO_EDITOR UI_GENERAL Funckey commands are not working consistently in release 17.2-2016 1902322 ALLEGRO_EDITOR UI_GENERAL Cannot use funckey commands when cross-probing 1905906 ALLEGRO_EDITOR UI_GENERAL Issue with keys and focus when navigating between windows 1913768 ALLEGRO_EDITOR UI_GENERAL Uppercase funckey shortcuts do not work 1751586 APD OTHER axlGetMetalUsageForLayer() for etch returns value including pins and vias 1863241 APD SHAPE Fillet is left on the T-Point without Cline(center) connection. 1894438 APD STREAM_IF APD/SiP Layout: Export rounded features as circumscribed and not inscribed polygon in GDS 1812699 ASDA AUTOMATION Enhance the performance when extracting data from SDA, using TCL functions 1863436 ASDA CANVAS_EDIT alignment guides are not displayed when placing or copy a part, only when moving. They are most needed during placement 1863445 ASDA CANVAS_EDIT dark theme blue text in docked CM needs to be a different color. difficult to read 1802111 ASDA DARK_THEME Dark theme in SDA should also change the border line color and text color of grid references: they are still black 1869951 ASDA EXPORT_PCB File browser button in Export to PCB Layout flashes graphics of the window behind the form 1845831 ASDA FORMAT_OBJECT Width of the twisted pair of wire should automatically be set to 6, otherwise it is not drawn correctly 1879914 ASDA INTERNATIONAL Using French Keyboard cannot use the . (point) delimiter to set VOLTAGE property value 1865753 ASDA MISCELLANEOUS Inconsistent and non-ideal behavior in SDA product choice dialog, small box, hard to check unlike the bottom box 1863457 ASDA PACKAGER globaly unset all user assigned references 1889301 ASDA TDO SDA TDO Crashes when switching to/from Offline mode 1823203 ASDA VARIANT_MANAG Variant setting part to not present does not do anything 1823992 ASDA VARIANT_MANAG Variant Editor fails to read netlist if a net is named NC 1863451 ASDA VARIANT_MANAG variant mode can select multiple parts to add to variant but can't select multiple parts to hit reset 1863455 ASDA VARIANT_MANAG Cant resize any panales in variant view mode 1874952 ASDA VARIANT_MANAG Letter I in the alternate part icons in variant spreadsheet should be white for readability 1878401 ASDA VARIANT_MANAG SDA Variant Display - DNI marker color switches between black and red 1877239 ASDA WORKSPACE SDA DRC window is hidden if undocked and minimized 1809605 CAPTURE LIBRARY Part has pins in the incorrect order in the Connectors library 1638693 CAPTURE OTHER Capture Footprint Viewer not showing footprint. 1873612 CONCEPT_HDL COPY_PROJECT Copy project causes nets to be added to net groups and ports - fails to package due to mismatch 1779289 CONCEPT_HDL CORE Adding a component and wire and saving the design results in a 'Connectivity save failed' error 1878719 CONCEPT_HDL CORE Cannot enable or apply block variants at the top-level in a hierarchical design. 1865480 CONCEPT_HDL OTHER 'partmgr -ptfMode shoppingCart' cannot output cell name with project ptf file into shoppingCart.xml 1829966 CONSTRAINT_MGR CONCEPT_HDL DML independent flow: Export Physical audits missing signal models in release 17.2 1904458 CONSTRAINT_MGR ECS_APPLY 'Audit - ECSets' crashes DE-HDL in release 17.2-2016, Hotfix 037 1798269 CONSTRAINT_MGR OTHER Script changes '-' in layer name to '_' 1835520 CONSTRAINT_MGR OTHER Cannot add members to netclass name with parenthesis 1896638 CONSTRAINT_MGR OTHER Constraint Manager worksheets jump abruptly 1801938 CONSTRAINT_MGR UI_FORMS Add To Netclass window: Focus not on ClassSelection 1854060 CONSTRAINT_MGR UI_FORMS Using the tab key in the Manufacturing workbook jumps a cell 1881832 ECW ROLES_PERMISS Adding Users in SSO environment using PS is error prone 1864870 F2B BOM Incomplete BOM report generated 1846578 PCB_LIBRARIAN GRAPHICAL_EDI radio buttons and clickable buttons are hidden in the UI for verify rules 1854080 PCB_LIBRARIAN METADATA con2con needs to support special characters in Primitive Name 1796377 PCB_LIBRARIAN SYMBOL_EDITOR Unable to move pins using arrows when symbol is opened in Symbol Editor 1839692 PCB_LIBRARIAN SYMBOL_EDITOR Properties tab grayed out in Symbol preview window 1865657 PCB_LIBRARIAN SYMBOL_EDITOR Cannot change symbol properties using the General tab 1906888 PCB_LIBRARIAN SYMBOL_EDITOR Properties button in Symbol Pins tab of the Symbols section is inactive. 1891248 PCB_LIBRARIAN SYMBOL_EDITOR Copy and mirror arc drawing object in the new Symbol Editor results in wrong arc on opening symbol in DE-HDL 1908381 PDN_ANALYSIS PCB_STATICIRD Allegro PCB PDN Analysis crashes after performing analysis and saving result in release 17.2-2016 1825087 PSPICE AA_OPT Graph view menu does not appear when we use 'Curve Fit' in Optimizer. 1808091 PSPICE ENVIRONMENT 'orSimSetup' crashes when 'Restart Simulation' is selected 1811782 PSPICE ENVIRONMENT Setup Simulation Profile no longer enables Advanced Markers when appropriate 1834147 PSPICE ENVIRONMENT PSpice Part Search library icons not displayed if product is installed in the Program Files folder in release 17.2-2016 1841992 PSPICE FRONTENDPLUGI Getting a blank Error dialog while adding a marker 1858574 PSPICE NETLISTER PSpice simulation: Some models cannot be used after upgrading to release 17.2-2016 1865022 PSPICE NETLISTER The division operator is not recognized by PSpice in DEV expressions in release 17.2-2016 1677119 PSPICE PROBE PSpice crashes when plotting simulation message summary 1837046 PSPICE PROBE On Windows 10, PSpice crashes on clicking Yes to see message 1879387 PSPICE PROBE PSpice crashes when we choose to plot simulation message summary 1842231 PSPICE SIMULATOR Wrong results in PSpice Advanced Analysis for DC Sweep Analysis 1843446 PSPICE SIMULATOR Distribution type is not showing under Assign Tolerance window for transistor 1872630 RF_PCB ROUTING Transition taper length does not work in route- Add RF trace 1872636 RF_PCB ROUTING Inherit Width parameter in Route -RF trace only uses width of one side 1872644 RF_PCB ROUTING Regression RF trace: change in trace width not retained while routing 1901201 SIP_LAYOUT EXTRACT extracta is not retaining custom layer names 1813380 SIP_LAYOUT OTHER Layer Compare is not adding the required shapes 1852762 SIP_LAYOUT OTHER Error generated in Package Design Integrity Check when adding soldermask to my design 1886847 SIP_LAYOUT REPORTS Incorrect metal area in metal usage report 1491315 SIP_LAYOUT SHAPE Dynamic shape filling exceeds the shape boundary on running 'create bounding shape' command 1853989 SIP_LAYOUT SHAPE 'Shape - Select' and then' Move' from pop-up with ix 500 iy 0 moves shape diagonally 1868509 SPECCTRA PARSER Autorouter takes long time to invoke 1869317 SYSTEMSI ENG_PBA SystemSI PBA does not align correlation waveforms correctly on Linux platform
May 15 2018, 15:36
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 039 Код Fixed CCRs: SPB 17.2 HF039 05-11-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1915149 ADV_PKG_ROUTER OTHER Auto-connect fails to initialize when rats are selected, but works with bundle 1870109 ADW ADW_UPREV Most mandatory properties turned into optional properties following database uprev 1758396 ADW CONF Server Memory setting in setting.ini is lost if server is re-configured using Conf 1911591 ADW FLOW_MGR Flow Manager does not start on high latency (> 25ms) networks: displays Java Content Disabled dialog 1887861 ADW LIBIMPORT Library Consolidation reports front2back issues but does not provide information about the issues. 1778977 ADW REPORT_GENERA reportgen memory setting too high in release 17.2-2016 resulting in launch failure 1900422 ADW REPORT_GENERA Save in reportgen does not save Preferred Part List entry into .rep file 1903888 ADW REPORT_GENERA Report generator not outputting values as expected for PPL field 1916903 ADW REPORT_GENERA Reportgen -gui is not producing the expected result 1902184 ALLEGRO_EDITOR DATABASE Add connect in package symbol crashes PCB Editor when using the 'clearance_view' variable 1914793 ALLEGRO_EDITOR DATABASE Updating shape crashes Allegro PCB Editor 1905138 ALLEGRO_EDITOR DRC_CONSTR Max Via count DRC disappears on running DRC update 1848015 ALLEGRO_EDITOR MANUFACT Export Creo View cannot find the webpage on the PTC site 1850553 ALLEGRO_EDITOR MANUFACT 'File - Export - Creo View' is not working 1853960 ALLEGRO_EDITOR MANUFACT PTC Creo Interface link is broken 1862305 ALLEGRO_EDITOR MANUFACT PTC Creo interface link is not working 1878682 ALLEGRO_EDITOR MULTI_USER Delay in Symphony server session when server is started from Allegro PCB Editor 1890108 ALLEGRO_EDITOR MULTI_USER Database rejections in Symphony 1887331 ALLEGRO_EDITOR NC Milling (NC route) in Gerber tools is not the same as what it is in the board. 1898179 ALLEGRO_EDITOR RAVEL_CHECKS PCB High-Speed option required for high-speed rules when Venture license is selected 1461142 ALLEGRO_EDITOR SHAPE Pin with nearly-tangent via fails to generate void in dynamic shape, results in short. 1863467 ASDA CROSSPROBE Highlighting all parts in PCB Editor does not highlight all parts in SDA 1910974 ASDA CROSSPROBE Cross-probing between SDA and PCB Editor does not work 1904440 CONCEPT_HDL CORE SPCOCD-577 error on migrating from release 16.6 to release 17.2-2016 1909611 CONCEPT_HDL CORE DE-HDL stops responding on running '_movetogrid' and clicking 'No' 1808743 CONCEPT_HDL PDF Inconsistent display of Publish PDF hyperlinks 1894868 CONCEPT_HDL PDF XREFs getting clipped in the Published PDF 1911676 CONSTRAINT_MGR CONCEPT_HDL DE-HDL Constraint Manager crashes on selecting ECSet and then creating pin-pair option 1913968 CONSTRAINT_MGR CONCEPT_HDL Match Group pin-pairs are not created on applying ECSet to differential pair 1899638 CONSTRAINT_MGR XNET_DIFFPAIR Differential pair buffer models are extracted differently in release 17.2-2016 and release 16.6 1914116 ORBITIO ALLEGRO_SIP_I Unable to import OrbitIO file to SiP Layout 1896487 PCB_LIBRARIAN GRAPHICAL_EDI Use lower-case characters for notes and pin text in New Symbol Editor 1898008 PCB_LIBRARIAN SYMBOL_EDITOR Styling is not available for custom shape and pins. 1644787 PSPICE FRONTENDPLUGI PSpice Model Search window does not show complete library path 1785939 PSPICE FRONTENDPLUGI PSpice Part Search library browser should display path of the library directories 1855867 PSPICE FRONTENDPLUGI PSpice Model Search window does not show complete library path 1887016 PSPICE SIMULATOR Pseudotran should always be invoked first time in case autoconvergence is ON 1895752 SIG_INTEGRITY OTHER Layout Cross Section: Wrong Differential Impedance calculation (0 ohms) in RHEL Linux 7.1 or later versions 1895759 SIG_INTEGRITY OTHER Cross Section does not calculate correct differential pair impedance in Linux CENTOS 7 and gives 0 value 1909257 SIP_LAYOUT INTERACTIVE Error 'E- (SPMHGE-639): Copying component with bond wire is not allowed' when copying SMD symbols 1900970 SIP_LAYOUT SHAPE Shape does not void around SMD Pins and Vias inside pad 1885496 SIP_LAYOUT SYMB_EDIT_APP Pin Numbering: different results for release 16.6 and 17.2-2016 for the same case. 1907796 SIP_LAYOUT SYMB_EDIT_APP SKILL commands fail to change pin number in SiP Layout 1887703 SIP_LAYOUT WIREBOND On trying to add wire bond to a die, SiP Layout crashes displaying a restart message 1903081 SPECCTRA LICENSING PCB Router is failing in Linux 7.1 in release 17.2-2016 1721606 SPECCTRA ROUTE PCB Router stops responding on exit if opened in the stand-alone mode 1844366 SPECCTRA ROUTE Allegro PCB Router will not exit 1873716 SPECCTRA ROUTE PCB Router does not close if opened from Allegro PCB Editor or in the stand-alone mode 1907703 SPIF OTHER PCB Editor crashes on choosing 'File - Export - Router' in release 17.2-2016 1889059 VSDP DIEEXPORT Incorrect pin location if bump cell origin is not at lower left for rotation other than R0
May 29 2018, 21:01
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 040 Код Fixed CCRs: SPB 17.2 HF040 05-27-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1924541 ADW CONF Designer Server configuration cannot be completed 1906973 ADW DBEDITOR Rename attribute fails to preserve values in affected parts 1718524 ADW FLOW_MGR FM: Find Projects does not find any projects when Project Path contains a period 1803310 ADW FLOW_MGR EDM Find Project no longer supports dot in the project path 1916898 ADW FLOW_MGR Flow Manager does not recognize projects with a dot in the path 1887669 ADW LIBDISTRIBUTI ptfgen displaying Java errors 1897991 ADW LIBDISTRIBUTI ptfgen fails with error LIBDIST-1062 in library distribution. 1915319 ADW LIBDISTRIBUTI ptfgen should re-run with the -rewrite2db option automatically 1920309 ADW LIBDISTRIBUTI Java exceptions in the ptfgen log file 1914706 ALLEGRO_EDITOR DFM False Mask to trace DRCs 1912290 ALLEGRO_EDITOR GRAPHICS Infinite PCB cursor: symbol move results in symbol trail and disappearance of cursor and symbol 1927425 ALLEGRO_EDITOR GRAPHICS Infinite PCB Cursor disappear while moving objects on layout 1908867 ALLEGRO_EDITOR INTERACTIV PCB Editor crashes in release 17.2-2016, Hotfix 036 and 037 1906116 ALLEGRO_EDITOR IN_DESIGN_ANA Allegro Integrated Analysis and Checking: Coupling vision shows the influence of voltage net 1918161 ALLEGRO_EDITOR MULTI_USER Symphony crashing and clients disconnecting from server cannot leave session, error applying DBupdate 1919467 ALLEGRO_EDITOR MULTI_USER Random crashes while routing design in Symphony 1918702 ALLEGRO_EDITOR SHAPE Differential Pair vias not voided in a split plane 1905109 ALLEGRO_EDITOR UI_GENERAL PCB Editor randomly stops responding in release 17.2-2016 in Linux 1882365 ASDA CANVAS_EDIT SDA - body changes but not properties when changing version of a symbol 1900370 ASDA CANVAS_EDIT Version command in SDA should use placeholders from selected version 1901120 ASDA CANVAS_EDIT Choosing a different version of a placed component does not use the property placeholders as per the new symbol 1907497 ASDA GRAPHICS DNI Cross Mark much larger than Components 1895135 ASDA MISCELLANEOUS Design created in SDA has the cds.lib containing a pointer to worklib 1895139 ASDA MISCELLANEOUS Irrelevant warning related to worklib when running checkplus on SDA design 1920753 CAPTURE LIBRARY JavaScript exception reported on opening part with name containing '\' in hotfix 038 1925848 CAPTURE LIBRARY New (QIR6) Symbol Editor has Script error / SR 600037969 1916991 CAPTURE NEW_SYM_EDITO New part/symbol editor ignores grid color set in Preferences 1917090 CAPTURE NEW_SYM_EDITO New symbol editor goes into permanent pan mode on clicking the middle mouse button 1918041 CAPTURE NEW_SYM_EDITO Saves As for symbol in library from new symbol editor saving 0 byte files 1918497 CAPTURE NEW_SYM_EDITO Moving multiple items using the arrow keys results in error in new part editor 1918711 CAPTURE NEW_SYM_EDITO Unable to do a Save As from a Library part to change the name 1920889 CAPTURE NEW_SYM_EDITO Unable to edit symbol with name containing '/' 1922123 CAPTURE NEW_SYM_EDITO Save As for symbol in library from new symbol editor saving 0 byte files 1922276 CAPTURE NEW_SYM_EDITO Space between pin name and pin for names having bar 1922282 CAPTURE NEW_SYM_EDITO JavaScript exception on closing new part editor window using keyboard shortcuts 1923526 CAPTURE NEW_SYM_EDITO Unable to "Save As" in new symbol editor. 1927262 CAPTURE NEW_SYM_EDITO The File > Save As command in version 17.2-s038 differs from earlier versions 1919322 CAPTURE PART_EDITOR JavaScript exception on opening parts and creating new part using right-click 1914183 CONSTRAINT_MGR XNET_DIFFPAIR ECSet fails to map in PCB Editor but maps fine in DE-HDL 1908102 ECW DASHBOARD Some lines in Design Dashboard in Pulse are grayed out 1914812 F2B PACKAGERXL Hierarchical variable not evaluated 1639231 PSPICE ENVIRONMENT Remember last location in simulation settings 1804391 PSPICE ENVIRONMENT Libraries with uppercase extension (.LIB) not retained if added using 'Add to Profile' 1879915 PSPICE ENVIRONMENT Check points cannot be loaded from a directory with space in its name 1695306 SIP_LAYOUT STREAM_IF SiP Layout - Stream out issue: Embedded or stacked components using pad reference in more than one layer
Jun 19 2018, 07:33
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 041 Код Fixed CCRs: SPB 17.2 HF041 06-9-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1880083 ADW ADWSERVER ALM fails to connect and authenticate LDAP server 1922218 ALLEGRO_EDITOR 3D_CANVAS PCB Editor stops responding when 3D Canvas is opened for a symbol 1915838 ALLEGRO_EDITOR DFM Outline to non-signal geometry is not working for non-etch layers in design 1925263 ALLEGRO_EDITOR DFM False minimum spoke count DRC 1895486 ALLEGRO_EDITOR INTERFACES Importing IPF displays error regarding line being outside drawing extents (SPMHMF-409) 1927266 ALLEGRO_EDITOR INTERFACES Miniaturization license required when using enterprise licenses 1912186 ALLEGRO_EDITOR IN_DESIGN_ANA Coupling analysis on one net takes a long time 1916015 ALLEGRO_EDITOR NC Improve the message for reporting unsupported characters in the directory path while generating NC Drill data 1926072 ALLEGRO_EDITOR SHAPE Dynamic shape to route keepout not voiding correctly 1903202 ALLEGRO_EDITOR UI_GENERAL HTML report dialog does not handle relative links to files correctly 1880684 ALTM_TRANSLATOR CAPTURE Importing third-party schematic is not working in Capture 1870218 ALTM_TRANSLATOR DE_HDL Unable to translate a third-party design to DE-HDL 1881208 ALTM_TRANSLATOR DE_HDL Third-party to DE-HDL translation: schematic symbols missing all pins 1889909 ALTM_TRANSLATOR DE_HDL Third-party to DE-HDL and OrCAD Capture translator fails with error message or crash 1924375 ASDA NEW_PROJECT SDA new project path truncated at ellipses 1900957 ASI_SI OTHER axlLicDefaultVersion() in SKILL console crashes PCB Editor in release 17.2-2016 and works in release 16.6 1918499 CAPTURE NEW_SYM_EDITO Text in new Part Editor is always left-justified and justification cannot be changed 1921505 CAPTURE NEW_SYM_EDITO Error if property name starts with the less than character '<' 1924273 CAPTURE NEW_SYM_EDITO Error if property name starts with the less than character '<' 1924332 CAPTURE NEW_SYM_EDITO Capture reports an error when editing pin numbers where names contain the less than character '<' 1934655 CAPTURE NEW_SYM_EDITO Properties populated in older release show up blank in new Symbol Editor 1855851 CAPTURE OTHER Crystal Reports not working in release 17.2-2016 1918048 CAPTURE PART_EDITOR Unable to modify pin type and shapes for multiple pins simultaneously in new Part Editor 1919459 CAPTURE PART_EDITOR Part Editor background display color is not consistent when zoomed out/in 1920078 CAPTURE PART_EDITOR Option needed for updating pin type of multiple pins in the 'Edit all pins' menu 1922785 CAPTURE PART_EDITOR Cannot place pin array with zero in the suffix in Symbol Editor 1922831 CAPTURE PART_EDITOR Symbol Editor redraws when scrolling with non-default background and when zoomed out 1923772 CAPTURE PART_EDITOR Placing pin arrays results in error 1888897 CAPTURE SCHEMATICS Capture slowly redraws schematic page 1910087 CONCEPT_HDL CORE DE-HDL crashes when adding Current Probe to a design 1930364 CONCEPT_HDL CORE SIGNAL_MODEL properties not deleted on importing release 16.6 DML design into release 17.2-2016 non-DML design 1920716 CONSTRAINT_MGR CONCEPT_HDL Issue with the passing of physical and spacing CSets between Design Entry HDL and PCB Editor 1902591 ECW OTHER Flow Manager reports a digital certificate error when launched with Pulse 1926029 PCB_LIBRARIAN GRAPHICAL_EDI PDV Symbol Editor opens to a blank page in release 17.2-2016 1884694 PSPICE ENCRYPTION User-defined library encryption is not working as expected 1927537 SIP_LAYOUT ASSY_RULE_CHE SiP Layout crashes when running manufacturing checks on specific designs 1878733 SIP_LAYOUT CROSS_SECTION Layer Function and Manufacture fields in Cross-section Editor are grayed out for soldermask layers in SiP Layout 1900628 SIP_LAYOUT CROSS_SECTION Board thickness in Cross-section Editor does not change even after soldermask layers are added
Jul 18 2018, 07:54
Пользователь №: 4 775
А в известном месте можно взять Hotfix 42. Такая же ситуация?
Jul 18 2018, 19:59
Пользователь №: 1 623
Цитата(copov @ Jun 26 2018, 09:03)  Спасибо, сам отвечу. Косяки в символьном редакторе в Capture не исправили... P.S. Такая эта ситуация уже становится неприличной. А можете перечислить эти косяки?
На правах рекламы: Для тех, кому нужна современная профессиональная и недорогая САПР печатных плат, взамен P-CAD! Продлена промо-акция: 19.9 тысяч рублей за годовую сетевую лицензию OrCAD Standard! В лицензию входит схемный редактор OrCAD Capture, базовый редактор печатных плат на базе Allegro PCB Editor, с возможностью работы с дифференциальными парами со статическим контролем фазы, редактор правил и ограничений, 3D-просмотр со STEP-моделями, расчет импеданса, работа с микроотверстиями, и импорт-экспорт производственных файлов. Прилагается импорт проектов из P-CAD2006. Все, что нужно для трассировки типовых многослойных плат - всего за 19.9 тыс.рублей в год! Подробности: https://www.pcbsoft.ru/orcad-za-19900
Jul 18 2018, 21:40
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 043 Код Fixed CCRs: SPB 17.2 HF043 07-13-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1935813 ADW DBEDITOR Auto merging of DE-HDL and Capture Classifications is not working 1935834 ADW DBEDITOR Some DE-HDL only classifications are removed during the CSV merge process of libimport 1941570 ALLEGRO_EDITOR DATABASE PCB Editor crashes or stops responding on performing 'Info' or 'edit properties' on select pins 1942536 ALLEGRO_EDITOR DATABASE Allegro PCB Editor fails to create backdrill plunges in Zone area 1925899 ALLEGRO_EDITOR DFM PCB Editor crashes when placing components in Hotfix 039 1943113 ALLEGRO_EDITOR DFM Restore normal move/slide via performance when annular ring checking is enabled. 1940939 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashed on running the Gloss - Line and via cleanup tool 1937754 ALLEGRO_EDITOR GRAPHICS Text string disappears when selected during 'Edit - Text' if using PCB_CURSOR 1937056 ALLEGRO_EDITOR INTERFACES Cannot import IDX acceptance of third-party change to PCB Editor 1940197 ALLEGRO_EDITOR INTERFACES PCB Editor crashes when reading IDX file from third-party 1940232 ALLEGRO_EDITOR IN_DESIGN_ANA PCB Editor crashes when running Return path DRC 1916921 ALLEGRO_EDITOR PLACEMENT Property Pin_Global_Fiducial not inherited from symbol into board 1862241 ALLEGRO_EDITOR REPORTS In 'Summary Drawing Report', the listed quantity for HDI vias is incorrect under Drilling Statistics 1935448 ALLEGRO_EDITOR REPORTS Etch Detailed Length Report lists only one coordinate pair per trace 1948322 ALLEGRO_EDITOR SHAPE Allegro hangs when axlPolyOperation api is called 1795564 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, focus is lost from command window after right-click 1919247 ALLEGRO_EDITOR UI_GENERAL Infinite cursor graphics issues on move: Cursor disappears and symbol image remains at old location till refresh 1919256 ALLEGRO_EDITOR UI_GENERAL Infinite cursor graphics issue: Symbol disappears during rotate 1933526 ALLEGRO_EDITOR UI_GENERAL Panning is slow in PCB Editor in Hotfix 038 1933530 ALLEGRO_EDITOR UI_GENERAL Strokes are slower to respond in release 17.2-2016 1933536 ALLEGRO_EDITOR UI_GENERAL Third-party dialog stops responding on running commands 1782227 APD DIE_GENERATOR Ability to specify rectangular shapes in die text in 1933011 ASDA PART_MANAGER Parts changed in library with new pin names are not reported or updated by Part Manager 1924529 CAPTURE NEW_SYM_EDITO Global colors for pin name and number and part body not allowed in release 17.2-2016, Hotfix 038/039 1925846 CAPTURE NEW_SYM_EDITO Opening library or component with special characters in path throws JavaScript exception 1928905 CAPTURE NEW_SYM_EDITO Pin name justification, length, and casing incorrect for generated parts in Hotfix 038 1928965 CAPTURE NEW_SYM_EDITO Cannot move pins in Capture if Pin Name is missing 1932149 CAPTURE NEW_SYM_EDITO JavaScript exception if path to part contains special characters in Hotfix 039 1936301 CAPTURE NEW_SYM_EDITO Cannot edit symbol in new symbol editor: Displays parsing error (SPSMI-1) 1917172 CAPTURE PART_EDITOR Pin name rotating on schematic even when pin name rotate is off in symbol editor 1924456 CAPTURE PART_EDITOR Color preferences for pin, pin name, and pin number do not apply in part editor but only in schematic 1928872 CAPTURE PART_EDITOR Pin name locations are wrong and each needs to be placed manually 1929562 CAPTURE PART_EDITOR Changing pin name while adding a pin not intuitive in Symbol Editor 1932732 CAPTURE PART_EDITOR Part Editor issue: Pin name selection box too long and text not justified in Hotfix 040 1933523 CAPTURE PART_EDITOR Connection box does not appear after changing pin of a placed part in Hotfix 040 1936994 CAPTURE PART_EDITOR Error because of illegal characters in pin name and number and net name 1943074 CAPTURE PART_EDITOR Pin names rotated in Part Editor not rotated when placed on page 1943078 CAPTURE PART_EDITOR Pin name rotate not working. 1945055 CAPTURE PART_EDITOR Pin names not rotated in schematic 1925700 CAPTURE VIEWER Pin numbers and text not shown during Variant View mode anymore. 1914437 CONSTRAINT_MGR CONCEPT_HDL Constraint Difference Report appears even though there is no difference in constraint. 1935152 CONSTRAINT_MGR CONCEPT_HDL Match Groups are not formed with the correct pin pairs 1940575 SIP_LAYOUT ORBITIO_IF Need new routing flow 1923722 SIP_LAYOUT STREAM_IF Use one symbol for all instances of a Via Structure
Aug 3 2018, 16:27
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 044 Код Fixed CCRs: SPB 17.2 HF044 07-27-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1943727 ADW DBEDITOR EDM DBEditor: Cannot check in/out schematic model symbols with many linked parts 1800630 ADW FLOW_MGR Support spaces in design directory path on Windows 1951052 ADW LRM LRM stops responding on project update and removes parts from design 1891428 ADW PART_MANAGER Resistor turns into a capacitor when placed 1945194 ALLEGRO_EDITOR 3D_CANVAS 3D Viewer crashes when opening from board file. 1935558 ALLEGRO_EDITOR INTERFACES Exported STEP file missing components when viewed in free STEP viewer 1945640 ALLEGRO_EDITOR MULTI_USER Symphony client disconnects from server without any notification 1948454 ALLEGRO_EDITOR MULTI_USER Window DRC stops responding when run in Symphony 1946619 ALLEGRO_EDITOR SHAPE Pin/via with suppressed pad on shape layer and thermal connection type of none should void to drill hole. 1946708 ALLEGRO_EDITOR SHAPE Same net hole to shape voiding is incorrect. 1952213 ALLEGRO_EDITOR SHAPE Shape voiding from Thru Via when the via regular pad is not completely drilled out by Backdrill hole is not consistent 1889433 ALLEGRO_EDITOR UI_GENERAL Command window shows result at the end of a command rather than showing dynamic updates 1933503 ALLEGRO_EDITOR UI_GENERAL Extra click required to enable command window 1943692 ALLEGRO_EDITOR UI_GENERAL Funckey commands are not working 1945914 ALLEGRO_EDITOR UI_GENERAL Mouse focus lost in the command console when doing an 'undo' from the toolbar icon 1945920 ALLEGRO_EDITOR UI_GENERAL Focus lost from command window when the toolbar is used for any operation 1949922 ALLEGRO_EDITOR UI_GENERAL Focus lost from command window after save or even autosave 1947551 ALLEGRO_EDITOR WIREBOND PCB Editor crashes in wirebond edit mode 1935722 ALLEGRO_PROD_TOOLB OTHERS Panelization: Cannot place parts after migrating design from release 16.6 to 17.2-2016 1951511 APD REPORTS The result of Metal Usage Report is incorrect. 1952942 ASDA GRAPHICS Need metric (mm) support in grids in SDA 1948122 ASDA TDO If user ID has uppercase characters in teamassignmenttemplate.xml, TDO fails to join a project 1931199 CONCEPT_HDL COPY_PROJECT Stop hard coding Copy Project license inside EDM 1938153 CONCEPT_HDL OTHER Component Browser stops responding on replacing and modifying components 1770601 CONCEPT_HDL PDF Wire Pattern set to two-dot chain line not shown in PDF 1791175 PCB_LIBRARIAN CORE Allow baseline of cells with pins at symbol origin: change error to warning 1922238 PCB_LIBRARIAN CORE Unable to check in into EDM Server due to con2con error SPLBPD-323 - Origin on pin connection point 1936812 PCB_LIBRARIAN GRAPHICAL_EDI New Symbol Editor: Wrong text being updated when editing text after copy and paste 1804159 PCB_LIBRARIAN SYMBOL_EDITOR Copy and paste of pins in new symbol editor: issues with pin name, rotation, and move 1927422 PCB_LIBRARIAN SYMBOL_EDITOR Symbol outline not updated correctly in the new default graphic editor in Part Developer release 17.2-2016 1939272 PCB_LIBRARIAN SYMBOL_EDITOR Symbol Editor changes origin to bottom left, outline to invisible, shows rectangle with center rectangle at new origin 1928076 RF_PCB DISCRETE_LIBX dlibx2iff does not work with managed libraries and library-level PTF 1929574 RF_PCB DISCRETE_LIBX Discrete Library to third-party Translator does not populate the Available Parts section correctly 1850360 TDA CORE TDO crashes while changing the root design 1934388 TDA SDA SDA TDO crashes on attempting to check in a 'New Block in Shared Area'
Aug 6 2018, 22:22
Пользователь №: 102 024
ВРоде много пишут о фиксах Symbol Editor, а как на самом деле - что не исправлено? Рабочий Symbol Editor, стоит ставить?
Aug 11 2018, 22:51
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 045 Код Fixed CCRs: SPB 17.2 HF045 08-10-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1934956 ADW DBEDITOR Footprint missing from part in release 17.2-2016 1945005 ADW DSN_MIGRATION Right side of Migration dialog box is cut off 1933245 ADW FLOW_MGR 'Open last Project' button should open the last opened project 1953210 ADW LIBDISTRIBUTI Library Distribution is not distributing all symbols. No errors for the missing schematic models. 1953727 ADW LRM LRM missing two symbols when migrating from release 16.6 to 17.2-2016 1952923 ALLEGRO_EDITOR DATABASE PCB Editor crashes on trying to delete layer 1957171 ALLEGRO_EDITOR DATABASE Pastemask offset not working when creating a symbol that requires two top-paste masks 1960059 ALLEGRO_EDITOR DATABASE Stackup definition causes custom script to crash 1932864 ALLEGRO_EDITOR DFM Exporting DFM Constraints losing the association to design level 1957467 ALLEGRO_EDITOR EDIT_SHAPE Compose Shape copies lines to wrong subclass 1938536 ALLEGRO_EDITOR GRAPHICS Multiple crashes on different boards after installing hotfix 040 1954075 ALLEGRO_EDITOR SHAPE Dynamic Crosshatch shapes should be clipped inside RKI if RKI Autoclip is enabled 1957803 ALLEGRO_EDITOR SHAPE Wrong dynamic shape status 1949923 ALLEGRO_EDITOR UI_GENERAL Focus lost from command window when any command is active 1963245 ALLEGRO_EDITOR UI_GENERAL Alias behaves as Funckey in release 17.2-2016, hotfix 044 1892126 ALLEGRO_PROD_TOOLB CORE Clines disappear and then reappear suddenly on using Route - Shield Generator 1931127 ALLEGRO_PROD_TOOLB CORE ZDRC not working for Xhatch Shape 1932563 ALLEGRO_PROD_TOOLB CORE allegro_legacy_board_outline environment variable not set in PCB Design Compare. 1929855 ALLEGRO_PROD_TOOLB OTHERS Outline not exported correctly for PCB design compare if Design_Outline and Cutout exist 1956494 APD DATABASE DBDoctor removes pads 1956291 APD INTERACTIVE axlSpreadsheetSetStyleProp should accept 0 and 1 as Boolean values for protection style 1960127 ASDA ARCHIVER Using the Tcl command 'archiveproject' crashes SDA 1953718 ASDA CONSTRAINT_MA SDA Import Pin Delay fails with extra columns, does not explain why 1924498 CAPTURE SCHEMATIC_EDI Cannot place part 'B' for heterogeneous part if 'Preferences - Miscellaneous - Auto References' not set 1927129 CAPTURE SCHEMATIC_EDI unable to place heterogeneous part section directly from place part window 1928255 CAPTURE SCHEMATIC_EDI Unable to place a specific section from Place Part 1945207 CAPTURE SCHEMATIC_EDI Part selection pull-down reverts to part '1|A' when placing heterogeneous part 1945661 CAPTURE SCHEMATIC_EDI Section drop-down in Place Part window is not working 1958121 CAPTURE SCHEMATIC_EDI Preview and placement of sections of Heterogeneous parts is not correct in New Symbol Editor 1956535 CONCEPT_HDL CORE DE-HDL crashes on Import Pin Delay for a CSV file 1960922 CONCEPT_HDL CORE DE-HDL crashes on moving netgroup on Windows 10 1964016 CONCEPT_HDL CORE In DE-HDL moving around nets connected to Netgroups causes crash on Windows 10 1907040 F2B PACKAGERXL Export Physical output board file name reverts to old when changing options 1957862 ORBITIO ALLEGRO_SIP_I allegro2orbit failed to translate rounded rectangle padstack
Aug 26 2018, 16:24
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 046 Код Fixed CCRs: SPB 17.2 HF046 08-24-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1880800 ADW PART_BROWSER Server connection failure on a running SDA session. 1880895 ADW PART_BROWSER NCB - components missing from the component browser 1962336 ALLEGRO_EDITOR INTERFACES Smart PDF shows both top and bottom probe layers for a film layer with only a single probe layer (top or bottom) 1955128 ALLEGRO_EDITOR MANUFACT Need to close PCB Editor to delete xsectionChart.log generated on placing a cross-section chart 1969088 ALLEGRO_EDITOR SHAPE PCB Editor crashes on updating shapes to smooth 1963828 ASDA DESIGN_EXPLOR Unwired schematic block movement with text is not correct 1954426 ASDA OPEN_CLOSE_PR Double-clicking to paste a note crashes SDA 1965423 ASDA OPEN_CLOSE_PR Crash when working with notes in SDA 1960060 ASDA PART_MANAGER Original property differences not displayed in Part Manager on selecting a new part from CB and doing reset 1960112 ASDA PART_MANAGER Part Manager incorrectly updating part property values 1955723 ASDA ROUTING Draw Multiple Bits misses bit 0 when in reverse order. 1952963 CONCEPT_HDL CORE Variant Editor takes a long time to load 1962568 CONCEPT_HDL CORE Directive DEHDL_BROWSER_FILEPATH does not work 1939192 PCB_LIBRARIAN SYMBOL_EDITOR pin_text size and location very different between DE-HDL and Symbol Editor resulting in text overlap 1952967 SCM OTHER Error while copying a release 17.2-2016 design: message says design created in release 16.3 or an earlier version 1948999 SPIF OTHER Some place_keepout shapes and antipads not exported
Sep 13 2018, 19:54
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 047 Код Fixed CCRs: SPB 17.2 HF047 09-9-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1969527 ADW LIBIMPORT Getting java.lang.NullPointerException error on bulk import in hotfix 044 1976219 ALLEGRO_EDITOR DATABASE .SAV file not created although message reads it is producing one 1968270 ALLEGRO_EDITOR DFM PCB Editor crashes when running DRC 1978421 ALLEGRO_EDITOR DRC_CONSTR False DRCs between via and its fillet shown after editing shape boundary 1966772 ALLEGRO_EDITOR PAD_EDITOR PCB Editor and DBDoctor crash on editing DRA file: Found bad pointer, run dbdoctor 1973866 ALLEGRO_EDITOR SHAPE PCB Editor crashes when deleting a group 1818779 ALLEGRO_EDITOR UI_FORMS DialogueBox goes behind Canvas when clicked on Allegro Main Window 1880175 ALLEGRO_EDITOR UI_GENERAL Multiple Session of 17.2 PCB Editor gets mixed up in Linux 1946027 ALLEGRO_EDITOR UI_GENERAL Arrow Keys in Canvas stop responding after changing the view. 1967701 ALLEGRO_EDITOR UI_GENERAL Arrow Key panning does not work when third-party SKILL call is active 1967706 ALLEGRO_EDITOR UI_GENERAL Observe Special Characters when command is run 1971183 ALLEGRO_EDITOR UI_GENERAL Focus is lost from command line when Save icon is used 1971186 ALLEGRO_EDITOR UI_GENERAL Focus from Command line is lost when using CTRL + N 1971190 ALLEGRO_EDITOR UI_GENERAL Focus from Command line is lost when using CTRL + Alt 1971200 ALLEGRO_EDITOR UI_GENERAL Focus is lost in comand line when you save using command save 1961833 APD SHAPE Crash when changing dimension of existing via padstack in the design 1968256 ASDA EXPORT_PCB SDA crashes directly after Export to PCB 1970284 ASDA EXPORT_PCB Placing part crashes SDA
