> xilinx: pci_express_blk_plus - вопросы по .usf
gosha
сообщение Dec 28 2017, 15:04
Из: Менделеево
Пользователь №: 30
Здравствуйте.
Не совсем понятно по .ucf:
На плате Virtex_5 (ML_507), pci_express endpoint
tx+-/rx+-, clk+- подключены на GTX_DUAL_X0Y1
CODE
CONFIG PART = xc5vfx70t-ff1136-1;
NET  "sys_clk_p"       LOC = "AF4";
NET  "sys_clk_n"       LOC = "AF3";
INST "refclk_ibuf"     DIFF_TERM = "TRUE";
INST "ep/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i" LOC = GTX_DUAL_X0Y1;
INST "ep/pcie_ep0/pcie_blk/pcie_ep"                       LOC = PCIE_X0Y1;
При сборке этого выдает ошибку:
QUOTE
ERROR:PhysDesignRules:2270 - Block
ep/pcie_ep0/pcie_blk/SIO/.pcie_gt_wrapper_i/GTD[0].GT_i (GTX_DUAL_X0Y1) needs
GTX_DUAL_X0Y2 instantiated: When using a GTP/GTX with a REFCLK coming from an
IBUFDS element near another GTP/GTX and forwarding that clock using dedicated
routing, each GTP in between the source and destination must be instantiated
in the correct manner (See AR 33473). If you don't instantiate these other
GTP tiles the software tools will route the REFCLK correctly, but the design
may not work in hardware.
ERROR:PhysDesignRules:1859 - The computed value for the VCO operating frequency
of PLL_ADV instance ep/pcie_ep0/pcie_blk/clocking_i/use_pll.pll_adv_i is
calculated to be 1250.000000 MHz. This falls above the operating range of the
PLL VCO frequency for this device of 400.000000 - 1000.000000 MHz. Please
adjust either the input frequency CLKIN_PERIOD, multiplication factor
CLKFBOUT_MULT or the division factor DIVCLK_DIVIDE, in order to achieve a VCO
frequency within the rated operating range for this device.
ERROR:Pack:1642 - Errors in physical DRC.
Что я делаю не так ?
Зачем указывать constrain:
Если в Virtex-5 FPGA RocketIO GTP Transceiver User Guide UG196 на блок-схеме стр 26 PCI Express Block в GTP_DUALColumn не входит.
Заранее спасибо.
RSS Текстовая версия Сейчас: 21st July 2025 - 08:16
Страница сгенерированна за 0.01346 секунд с 7
