> AX110xx Family кто-нибудь использовал?, Разыскивается datasheet, code examples (keil)
alexsnow
сообщение Dec 14 2006, 10:57
Пользователь №: 2 372
Есть такой контроллер AX110xx http://www.asix.com.tw/products.php?op=Pro...st&PLine=72
The AX110xx family features a single-cycle pipelined 8051/80390 core (up to 100MIPS), 128 to 512KB Flash memory, and 32KB RAM. The embedded Ethernet PHY supports Auto-MDIX, which allows either the straight-through or crossover cables to be directly connected to the device easily. The AX110xx family supports serial communication interfaces such as I2C, SPI bus, three UART (with one supporting 921.6Kbps),CAN, and 1-wire. The parallel interfaces supported include external memory interface, local bus, and Ethernet MII. The timing functions can be achieved through a watchdog timer, three general-purpose 16-bit timers, and a 5-channel programmable counter array (PCA). There are four full ports of offering total 32 controllable IO lines (GPIO). The AX110xx family all supports run-time firmware or driver update through Ethernet or UART
Если кто использовал AX110xx, то интересует datasheet, code examples (keil) и максимальная скорость
передачи данных по ethernet. мой mail alex2004@hotbox.ru
RSS Текстовая версия Сейчас: 21st July 2025 - 23:18
Страница сгенерированна за 0.08271 секунд с 7
