Вышел новый Keil для 51 семейства, Вер. 8.05f |
Jan 10 2007, 12:18
Из: г.Киев
Пользователь №: 101
C51 Version 8.06 Release [Device Support]
Infineon XC800 Devices: added debugging and flash programming support for new Infineon XC800 devices (XC866-1FR, XC856) with ULINK and Infineon DAS server. Enhanced: Infineon XC800 startup code START_XC.A51 V1.02 that supports pdata addressing (C51: USING PDATA VARIABLES ON INFINEON XC800). SST SmartCards: [Device Simulation] Corrected: interrupt vector for 2nd UART on Philips P89LPC952 was incorrectly configured in simulator and target dialog. Enhanced: VTREG PPAGE is initialized to 0 on all Philips LPC900 devices to allow simulation of MOVX @Ri without configuration. Corrected: a problem with AT89S8252 EEPROM simulation. Corrected: a problem with the baudrate generation on Atmel devices with X2 feature (the baudrate was displayed incorrect). Corrected: a problem with code banking on Mentor M8051EW core. [Cx51 Compiler] Corrected: code that is not used (i.e. with macros) is removed, even when it creates other side effects. Corrected: unexpected error message for syntactical correct statement. struct st2 { unsigned char uc1; unsigned char uc2; }; struct st1 { struct st2 st2; unsigned char u1; unsigned char u2; }; struct st1 st;
void main (void) { (&st.st2)->uc1 = 0; // gives error, but should be Ok. } [ULINK and ULINK2 Support] Added: support for ULINK2 for the Infineon XC800 and ST uPSD series. Added: device support for Infineon XC886, XC888, and XC856.
2 страниц
1 2 >
(1 - 21)
Jan 10 2007, 12:53
Из: г.Киев
Пользователь №: 101
Отправил в личку.
Jan 10 2007, 20:04
Пользователь №: 8 834
мне тоже дай пожалуйста newhdd@yandex.ru , и откудо найти лекарство????
Прошивка это душа микроконтроллера!
Jan 15 2007, 11:22
Пользователь №: 13 317
Ссылочку, если можно... И Если есть у кого лекарство, дайте плз =)
Jan 19 2007, 16:12
Пользователь №: 19 667
Цитата(vladnick @ Jan 19 2007, 10:52)  Если можно, дайте ссылочку. А тебе-то какую ссылочку... На местном FTP имеется (в \upload\). Вчера вечером, по крайней мере, лежало все одной кучкой.
Jan 20 2007, 10:11
Цитата(ivstech @ Jan 19 2007, 19:36)  На сахаре как называется? Посмотрел, вроде нет там такого. А с FTP скачать не могу, нет доступа в свои. ivstech(сбк)yandex.ru Keil_lic-v3.2.rar это там называется. Плохо смотрел.
Jan 20 2007, 20:00
Пользователь №: 5 442
Цитата(K_AV @ Jan 19 2007, 16:12)  Цитата(vladnick @ Jan 19 2007, 10:52)  Если можно, дайте ссылочку.
А тебе-то какую ссылочку... На местном FTP имеется (в \upload\). Вчера вечером, по крайней мере, лежало все одной кучкой. Спасибо. Не посмотрел.java script:emoticon(':smile3046:', 'smid_24')
Jan 23 2007, 17:44
Из: Украина/Киев
Пользователь №: 20 145
Цитата(Bovolk @ Jan 22 2007, 20:13)  Триал на 51 скачал с сайта Keil, где-то 20 Мег. Этот "Keil_lic-v3.2.rar" к нему подойдет? Или мне нужно не триал? Тогда, дайте ссылочку, пожалуйста? bovolk(на)hotmail(тчк)com. Спасибо! Почему-то подумал, что нужна Full версия. Проект от 2-й версии отлично скомпилировался. Компилятор лишь понаходил больше предупреждений, которые легко вычистил.
Feb 27 2007, 09:22
Пользователь №: 25 701
на ихнем сайте-нужна не майлбоксовая почта. такой у меня нет! Поделитесь ссылочкой, аль самим файлом! keil c51
Сообщение отредактировал Arsenal_PC - Feb 27 2007, 09:36
Feb 28 2007, 20:37
Пользователь №: 25 599
Arsenal_PC Я на майл.ру бота заводил и выкачивал, Keil uV ARM toolchain правда. Всё там можно. А ссылки постоянной на keil.com быть не может. Они там "динамические" все нынче.
Mar 3 2007, 15:04
Пользователь №: 25 422
Добрый день! Необходимо накодить для ат89с5131. Для этого походу придется применять Keil. Дайте плз линк на сам кейл и лекарство к нему, а то долгое время поиска к результатам непривело.
Mar 23 2007, 17:56
Пользователь №: 20 282
Цитата(NoS85 @ Mar 3 2007, 16:04)  Добрый день! Необходимо накодить для ат89с5131. Для этого походу придется применять Keil. Дайте плз линк на сам кейл и лекарство к нему, а то долгое время поиска к результатам непривело. Когда-то давно (пару лет назад) я действовал следующим образом - помогло. Сработает ли сейчас - не знаю (но думаю, что сработает). Скачивайте последнюю демо-версию.
pack.zip ( 43.74 килобайт )
Mar 30 2007, 09:56
Почему бы не задать этот вопрос, будучи пользователем evaluation version ? Зарегиться, снять с сайта, дня через два спросить ...
