> Как подсчитать занимаемые ресурсы проекта в ПЛИС?, Зайлинкс в слайсах и лутах
Гвоздик
сообщение Aug 7 2007, 15:12
Из: Чебоксары
Пользователь №: 1 289
Собрал два модуля, смотрю отчеты использования ресурсов ПЛИС Xilinx XC5VSX50T-3FF1136 в ISE 9.1i. Как правильно подсчитать общий занимаемый объем (считать Slice LUT'ы + Slice registers или порознь)?
Таблицы занимаемых ресурсов обоих модулей привожу ниже:
Device Utilization Summary
Slice Logic Utilization Used Available Utilization Note(s)
Number of Slice Registers 11,421 32,640 34%
    Number used as Flip Flops 11,419
    Number used as Latch-thrus 2
Number of Slice LUTs 17,240 32,640 52%
    Number used as logic 17,156 32,640 52%
        Number using O6 output only 16,268
        Number using O5 output only 366
        Number using O5 and O6 522
    Number used as exclusive route-thru 84
Number of route-thrus 644 65,280 1%
    Number using O6 output only 442
    Number using O5 output only 194
    Number using O5 and O6 8
Slice Logic Distribution
Number of occupied Slices 6,667 8,160 81%
Number of LUT Flip Flop pairs used 20,263
    Number with an unused Flip Flop 8,842 20,263 43%
    Number with an unused LUT 3,023 20,263 14%
    Number of fully used LUT-FF pairs 8,398 20,263 41%
    Number of unique control sets 362
IO Utilization
Number of bonded IOBs 45 480 9%
    IOB Flip Flops 1
Specific Feature Utilization
Number of BUFG/BUFGCTRLs 2 32 6%
    Number used as BUFGs 2
Number of DSP48Es 93 288 32%
Total equivalent gate count for design 226,962
Additional JTAG gate count for IOBs 2,160
и второй модуль:
Number of Slice Registers 2,274 32,640 6%
    Number used as Flip Flops 2,274
Number of Slice LUTs 2,145 32,640 6%
    Number used as logic 2,132 32,640 6%
        Number using O6 output only 1,887
        Number using O5 output only 72
        Number using O5 and O6 173
    Number used as Memory 3 12,480 1%
        Number used as Shift Register 3
            Number using O6 output only 3
    Number used as exclusive route-thru 10
Number of route-thrus 83 65,280 1%
    Number using O6 output only 79
    Number using O5 and O6 3
Number of occupied Slices 1,360 8,160 16%
Number of LUT Flip Flop pairs used 3,651
    Number with an unused Flip Flop 1,377 3,651 37%
    Number with an unused LUT 1,506 3,651 41%
    Number of fully used LUT-FF pairs 768 3,651 21%
    Number of unique control sets 244
IO Utilization
Number of bonded IOBs 211 480 43%
    IOB Flip Flops 113
Number of BlockRAM/FIFO 2 132 1%
    Number using BlockRAM only 2
Total primitives used
        Number of 18k BlockRAM used 4
Total Memory used (KB) 72 4,752 1%
Number of BUFG/BUFGCTRLs 3 32 9%
    Number used as BUFGs 3
Total equivalent gate count for design 296,974
Additional JTAG gate count for IOBs 10,128
Поместится ли оба модуля в ПЛИС и каков общий размер проекта? Какие показатели нужно складывать? Буду рад совету
Ответов (1 - 4)
Rendom
сообщение Aug 7 2007, 17:22
Пользователь №: 27 538
Судя по приведенным цифрам все должно влезть. Но занимаемый обьем в кристале 2 модулей в 99% случаев отличается от простого сумирования ресурсов потребляемых каждым модулем, т.к:
1. Часть выполняемых функций модулей может дублироваться и при разводке 2 одинаковые функции могут быть заменены на 1 с выхода которой данные поступают на несколько испоьзующих ее блоков. (простой пример: в обоих модулях используется деление одной и той же тактовой частоты в 2 раза и при обьеденении этих 2х модулей вместо использования двух триггеров будет использован 1).
2. Так же возможно совместное использование ресурсов одних и тех же LUT обоими модулями, что так же приведет к сокращению используемых ресурсов.
Насколько я помню архитектуру FPGA здесь в отличии от CPLD обьединение 2х модулей не может привести к резкому возрастанию общего числа ресурсов по сравнению с простым суммированием.
ps. А вообще наиболее простой и надежный способ оценить точное занимаемое место в кристале это подключить в проект оба блока в виде 2х черных ящиков и провести place and route.
Гвоздик
сообщение Aug 8 2007, 07:42
Из: Чебоксары
Спасибо за совет. Два модуля в один собирать не стал, потому что сигналы с одного модуля будут подключаться не напрямую, а через логику связи с первым модулем. Пока еще не знаю сам как (второй модуль писал не я). А если собрать все вместе, то синтезатор может выбросить ненужные блоки, объеем получится недостоверный (хотя если все наружу вывести, то все вроде бы должно быть тип-топ).
Весь вопрос-то и в том, что подсчитывать у обоих модулей:
1. Number of Slice Registers (1) + Number of Slice Registers(2)
2. Number of Slice LUTs(1) + Number of Slice LUTs(2)
Или
Number of Slice Registers (1) + Number of Slice LUTs(1) + Number of Slice Registers(2) + Number of Slice LUTs(2)?
Т.е. я хочу выяснить общий занимаемый объем в процентах от объема ПЛИС.
Rendom
сообщение Aug 8 2007, 15:24
cyclop
сообщение Aug 13 2007, 07:41
Из: Moscow
Пользователь №: 2 291
Цитата(Гвоздик @ Aug 8 2007, 11:42) *
...А если собрать все вместе, то синтезатор может выбросить ненужные блоки, объеем получится недостоверный (хотя если все наружу вывести, то все вроде бы должно быть тип-топ).
Верно. А ещё можно воспользоваться синтезатором типа Synplify, который рисует две схемы (RTL и вентильного уровня); там сразу будет видно, что синтезировалось. И в log-файле он даёт потребление ресурсов.
RSS Текстовая версия Сейчас: 21st July 2025 - 11:21
Страница сгенерированна за 0.01475 секунд с 7
