> Использование С++ в WinAVR
ermilovd
сообщение Jan 26 2009, 10:02
Из: Пермь
Пользователь №: 43 767
Подскажите Плиз, Можно ли писать на С++ для WinAVR? Если это возможно, то выложите простенький рабочий пример использования классов с WinAVR.
Ответов (1 - 3)
Petka
сообщение Jan 26 2009, 10:34
Пользователь №: 7 886
http://www.nongnu.org/avr-libc/user-manual...l#faq_cplusplus
Can I use C++ on the AVR?
Basically yes, C++ is supported (assuming your compiler has been configured and compiled to support it, of course). Source files ending in .cc, .cpp or .C will automatically cause the compiler frontend to invoke the C++ compiler. Alternatively, the C++ compiler could be explicitly called by the name avr-c++.
However, there's currently no support for libstdc++, the standard support library needed for a complete C++ implementation. This imposes a number of restrictions on the C++ programs that can be compiled. Among them are:
* Obviously, none of the C++ related standard functions, classes, and template classes are available.
* The operators new and delete are not implemented, attempting to use them will cause the linker to complain about undefined external references. (This could perhaps be fixed.)
* Some of the supplied include files are not C++ safe, i. e. they need to be wrapped into
extern "C" { . . . }
(This could certainly be fixed, too.)
* Exceptions are not supported. Since exceptions are enabled by default in the C++ frontend, they explicitly need to be turned off using -fno-exceptions in the compiler options. Failing this, the linker will complain about an undefined external reference to __gxx_personality_sj0.
Constructors and destructors are supported though, including global ones.
When programming C++ in space- and runtime-sensitive environments like microcontrollers, extra care should be taken to avoid unwanted side effects of the C++ calling conventions like implied copy constructors that could be called upon function invocation etc. These things could easily add up into a considerable amount of time and program memory wasted. Thus, casual inspection of the generated assembler code (using the -S compiler option) seems to be warranted.
Сергей Борщ
сообщение Jan 26 2009, 13:48
Из: Рига, Латвия
Пользователь №: 17 095
Можно. Вот пример. Вот тут написано, как оживить работу с динамической памятью (new, delete).
Legotron
сообщение Jan 26 2009, 16:59
инопланетянин
Из: Питер
Пользователь №: 23 832
Вопрос вдогонку, кто-нибудь пользуется библиотекой AVR C++ Lib?
http://sourceforge.net/projects/avr-cpp-lib/
Какие мнения?
RSS Текстовая версия Сейчас: 24th July 2025 - 19:47
Страница сгенерированна за 0.01357 секунд с 7
