> Cortex от Cypress
Axel
сообщение Jun 21 2009, 18:52
Пользователь №: 1 188
В конце года Cypress обещает новые PSoCи с Cortex'ом. Параметры и набор периферии выглядят прилично:
Features
�� 32-bit ARM Cortex-M3 CPU Core
�� Flash program memory, up to 256 KB (100,000 write cycles)
�� Up to 64 KB SRAM memory
�� 2 KB EEPROM memory, 1 million cycles, 20 year retention
�� Low voltage, ultra low power
�� Wide operating voltage range: 1.7V to 5.5V
�� High efficiency boost from 0.5V
�� 500 μA at 1 MHz, 2 mA at 6 MHz
�� Four sleep modes including:
• 300 nA hibernate mode with RAM retention
• 2 μA sleep mode with real time clock, low voltage reset
interrupt, and watchdog timeout
�� Versatile IO system
�� 28 to 72 IO (62 GPIO, 8 SIO, 2 USBIO)
�� Any GPIO to any digital or analog peripheral routability
�� 1.2 to 5.5V interface voltages
�� Maskable, independent IRQ on any pin or port
�� Schmitt trigger TTL inputs
�� LCD direct drive up to 46x16 segments
�� All GPIO configurable as open drain high/low, pull up/down,
high Z, or strong output
�� Configurable GPIO pin state at power on reset (POR)
�� 25 mA sink on SIO
�� Digital peripherals
�� 16 to 24 programmable PLD-based Universal Digital Blocks
(UDB)
�� Full CAN 2.0b 16 RX, 8 TX buffers
�� Full-Speed (FS) USB 2.0 12 Mbps peripheral
�� Up to four 16-bit configurable timer/counter/PWM blocks
�� Library of standard peripherals
• 8, 16, 24, and 32-bit timers, counters, and PWMs
• SPI, UART, I2C™
• Many others available in catalog
�� Library of advanced peripherals
• Cyclic Redundancy Check (CRC)
• Pseudo Random Sequence (PRS) generator
• LIN Bus 2.0
• Quadrature decoder
�� Custom peripheral creation using Verilog
�� Analog peripherals
�� 0.2% internal voltage reference across -40°C to 85°C
�� Configurable Delta-Sigma ADC with 12 to 20-bit resolution
• Sample rates up to 192 ksps
• Programmable gain stage: x0.25 to x16
• 12-bit mode, 192 ksps, 70 dB SNR, 1.5 bit INL/DNL
• 16-bit mode, 48 ksps, 90 dB SNR, 1 bit INL/DNL
�� Two SAR ADCs, each 12-bit at 1 Msps
�� 80 MHz, 24-bit fixed point digital filter block (DFB) to
implement FIR and IIR filters
�� Up to four 8 MHz, 8-bit V/IDACs, configurable up to 12 bits
�� Four comparators with 30 ns response time
�� Four uncommitted opamps with 25 mA drive capability
�� Up to four switch capacitor blocks configurable to:
• Analog mixer
• Transimpedance amplifier
• Programmable gain amplifier x1 to x50
Даташит есть (preliminary). Выложить не могу laughing.gif , но желающим вышлю.
Ответов (1 - 19)
oll
сообщение Jun 22 2009, 03:50
Пользователь №: 9 463
надо - oleg_micromed(собака)datasvit.net
Спасибо
sensor_ua
сообщение Jun 22 2009, 05:18
Пользователь №: 4 387
Интересно было бы ознакомиться sensorua[!]gmail.com
aka Vit
Rst7
сообщение Jun 22 2009, 05:34
Йа моск ;)
Из: Kharkiv-city
Пользователь №: 6 610
Интересно. Если можно - rst7.cbsie[ю]gmail.com
Кстати, а какой ценник обещают?
zltigo
сообщение Jun 22 2009, 06:02
Из: Riga, Latvia
Пользователь №: 1 244
Цитата(Axel @ Jun 21 2009, 21:52) *
􀂇 Up to four 16-bit configurable timer/counter/PWM blocks
Если не сложно, адрес в личке.
sergvks
сообщение Jun 22 2009, 06:15
Пользователь №: 7 117
Цитата(zltigo @ Jun 22 2009, 10:02) *
Зря вы так. Это ведь эти блоки можно соединять как угодно в один (например 16+16=32).
-=Sergei=-
сообщение Jun 22 2009, 06:18
Пользователь №: 985
Спасибо
И мне И мне, если не затруднит.
shumilin.sergei(злой сабак)ic-design точка ру
Спасибо!
etoja
сообщение Jun 22 2009, 07:30
Пользователь №: 1 952
А почему на их сайте ничего нет? Одни 8-битники. ARMов они никогда не делали.
proba
сообщение Jun 22 2009, 07:54
Пользователь №: 5 526
значит будут делать,
http://www.msc-ge.com/frame/en/produkte/el...s/3389-www.html
как и многие другие , например тошиба.
http://www.toshiba-components.com/microcon...ler/Cortex.html
(15mw @ 40MHz - реально ли ? )
MrYuran
сообщение Jun 22 2009, 08:16
Беспросветный оптимист
Из: Н.Новгород
Пользователь №: 33 646
Давно интересует вопрос, насколько качественная аналоговая периферия у сайпресса?
Например, что-то навроде AD8551, ads1241 и AD7705 можно соорудить?
И почему для Programmable gain amplifier x1 to x50 нужны блоки конденсаторов (Up to four switch capacitor blocks), а не резисторов?
И какова точность коэффициента усиления?
Или всё равно придется внешние резисторы для ОС ставить?
Выглядит заманчиво, если весь усилительно-преобразовательный модуль на одной мелкосхеме забацать, пусть даже с минимальной обвязкой
etoja
сообщение Jun 22 2009, 09:40
Цитата(proba @ Jun 22 2009, 11:54) *
На их родном сайте http://www.cypress.com ничего нет.
А www.msc-ge.com - это "одна баба сказала ..."
Axel
сообщение Jun 22 2009, 11:25
Информация достоверная, можно сказать из первых рук... ЕVB с PSoC3 у меня уже есть, плату с PSoC5 обещали через пару месяцев. По ценам - предположительно $7-8 (максимальная конфигурация в больших количествах). Всем пожелавшим разошлю вечером - сейчас со временем туго.
miv
сообщение Jun 22 2009, 11:57
Из: С-Петербург
Пользователь №: 8 055
и сюда если не сложно !
imakurin[собака].gmail.com
sensor_ua
сообщение Jun 22 2009, 13:05
Нашлась такая инфа https://materials.proxyvote.com/Approved/23...ductor-2009.pdf
Взято отсюда http://www.psocdeveloper.com/forums/viewto...=42&p=27431
aka Vit
etoja
сообщение Jun 22 2009, 13:57
Так анонс этой микросхемы приведён в годовом отчёте Кипариса (Cypress Annual Report), который делается для привлечения инвесторов
и связи с реальной работой не имеет.
VAI
сообщение Jun 23 2009, 04:30
Сообщение #16
Пользователь №: 37
И я хотел бы ознакомится с даташитом.
v572028(собак)yandex.ru
Если зайца бить, его можно и спички научить зажигать
Сколько дурака не бей - умнее не будет. Зато опытнее
Altemir
сообщение Jun 23 2009, 13:49
Сообщение #17
Из: Россия, Поволжье
Пользователь №: 16 686
Оценку их периферии можно по семейству PSoC посмотреть. Вроде народ хвалил.
Это можно посмотреть на их сайте, там неплохие апноты и доки были по тому же PSoC и как они работают. Ещё есть книга "Аналоговая электроника на операционных усилителях (А.Дж. Пейтон, В. ​Волш)", где это описано.
Кратко: как известно, реактивное сопротивление конденсатора зависит от частоты, соответственно, если по определённой схеме (см. на сайте кипариса) перключать конденсатор с заданной частотой, то можно в эквиваленте получить "резистор", сопротивление которого зависит от этой частоты.
У меня есть старая документация по PSoC, но один файл презентации весит почти 10метров. Доступа к фтп нет sad.gif
Опять же - см. по PSoC-у, там и АЧХ таких усилителей приводилась, насколько я помню, и даже какие-то экселевские файлы и среды для расчётов были. Если они пытаются сделать гибрид своего семества CY8C2xxx с кортексовским ядром, то получился бы неплохой продукт, имхо.
З.Ы. А ещё Anadigm занимается ПАИСами. Тоже неплохие штуки делают.
Сообщение отредактировал Altemir - Jun 23 2009, 14:00
Dog Pawlowa
сообщение Oct 21 2009, 08:23
Сообщение #18
Пользователь №: 18 823
По некоторой информации, образцы кристаллов CY8C55 раздаются по указаниям больших боссов CYPRESS.
На следующей неделе встреча заинтересованных лиц.
Если у кого есть технические вопросы, которыми можно сразить боссов наповал, показав наши коллективные технические знания и глубокое понимание всех аспектов, буду признателен.
Пока в списке, практически не читая даташит, неясные моменты такие:
- среда программирования и отладки (будет ли IAR или Keil поддерживать этот кристалл). Кстати, можно ли в ИАРе выбрать абстрактный CortexM3 без привязки к конкретной модели.
- Гибкость DMA и источники запросов DMA (например, в STM32 не все хорошо)
- Достаточность конфигурируемой цифровой периферии.
К сожалению, с PSoC не работал, если кто скажет про ограничения PSoC3, будет здорово.
Уходя, оставьте свет...
QED
сообщение Oct 21 2009, 09:40
Сообщение #19
Пользователь №: 53 103
CMSIS IAR поддерживает. Так же как Keil и GCC.
Или Вы что то другое имеете в виду?
Dog Pawlowa
сообщение Dec 2 2009, 17:15
Сообщение #20
Итак, лежат у меня две платки для сайпрессовского старкита с кристаллами, отмаркированными CY8C55 с датой изготовления 0937.
При подаче питания дисплей старткита выводит, что все ОК.
А в душе уже зародилось мысль о том, что это все какая-то афера. Обещанной техподдержки нет, исходники тестовой программы сайпресс не дает. Программатор кристалл не видит.
Что же, может и к лучшему. Меньше работы...
RSS Текстовая версия Сейчас: 27th July 2025 - 15:38
Страница сгенерированна за 0.0152 секунд с 7
