> Сборка arm-elf- toolchain, Не удается собрать newlib
Bulya
сообщение Oct 28 2009, 12:37
Из: Харьков
Пользователь №: 40 874
Здравствуйте.
Собираю
binutils-2.20, gcc-4.3.4, newlib-1.17.0
с ключами
--target=arm-elf --enable-interwork --enable-multilib --enable-languages="c,c++" --with-gnu-as --with-gnu-ld
--disable-shared --disable-nls --disable-newlib-supplied-syscalls --disable-newlib-io-float
компиляция newlib прекращается с ошибками в linux-syscalls0.S
.../newlib-1.17.0/libgloss/arm/linux-syscalls0.S:37: Error: missing expression -- `swi'
.../newlib-1.17.0/libgloss/arm/linux-syscalls0.S:102: Error: missing expression -- `swi'
linux-syscalls0.S:
CODE
#include "linux-syscall.h"
#if __thumb__
# define FUNC(name) .type name, %function; .thumb_func; name:
# define SET .thumb_set
#else
# define FUNC(name) .type name, %function; name:
# define SET .set
#endif
#define GLOBAL(name) .global name; FUNC(name)
#define SIZE(name) .size name, .-name
#if __thumb__
# define SYSCALL0(name) \
GLOBAL(_ ## name); \
mov r12, r7; \
mov r7, #SYS_ ## name; \
swi; \
mov r7, r12; \
b _set_errno; \
SIZE(_ ## name)
/* static int _syscall3(int a, int b, int c, int number); */
FUNC(_syscall3)
push { r7 }
mov r7, r3
swi
pop { r7 }
b _set_errno
SIZE(_syscall3)
# define SYSCALL3(name) \
mov r3, #SYS_ ## name; \
b _syscall3; \
SIZE(_ ## name)
# define SYSCALL6(name) \
push { r4 - r5, r7 }; \
ldr r4, [sp, #12]; \
ldr r5, [sp, #16]; \
swi; \
pop { r4 - r5, r7 }; \
b _set_errno; \
SIZE(_ ## name)
# define SYSCALL4(name) SYSCALL6(name)
#else /* __thumb__ */
# define SYSCALL4(name) \
swi #SYS_ ## name; \
b _set_errno; \
SIZE(_ ## name)
push { r4 - r5 }; \
ldr r4, [sp, #8]; \
ldr r5, [sp, #12]; \
pop { r4 - r5 }; \
b _set_errno; \
SIZE(_ ## name)
#define SYSCALL0(name) SYSCALL3(name)
#define SYSCALL3(name) SYSCALL4(name)
#endif /* __thumb__ */
#define SYSCALL1(name) SYSCALL3(name)
#define SYSCALL2(name) SYSCALL3(name)
#define SYSCALL5(name) SYSCALL6(name)
SYSCALL1(alarm)
SYSCALL1(brk)
SYSCALL1(chdir)
SYSCALL2(chmod)
SYSCALL3(chown)
SYSCALL1(close)
SYSCALL1(dup)
SYSCALL2(dup2)
SYSCALL3(execve)
SYSCALL1(exit)
SYSCALL3(fcntl)
SYSCALL2(fstat)
SYSCALL2(ftruncate)
SYSCALL3(getdents)
SYSCALL0(getegid)
SYSCALL0(geteuid)
SYSCALL0(getgid)
SYSCALL2(getgroups)
SYSCALL1(getpgid)
SYSCALL0(getpgrp)
SYSCALL0(getpid)
SYSCALL0(getuid)
SYSCALL2(gettimeofday)
SYSCALL3(ioctl)
SYSCALL2(kill)
SYSCALL3(lchown)
SYSCALL2(link)
SYSCALL3(lseek)
SYSCALL2(lstat)
SYSCALL2(mkdir)
SYSCALL3(mknod)
SYSCALL2(nanosleep)
SYSCALL3(open)
SYSCALL0(pause)
SYSCALL1(pipe)
SYSCALL3(read)
SYSCALL3(readlink)
SYSCALL4(reboot)
SYSCALL1(rmdir)
SYSCALL5(select)
SYSCALL2(setpgid)
SYSCALL1(setgid)
SYSCALL0(setsid)
SYSCALL1(setuid)
SYSCALL3(sigprocmask)
SYSCALL2(socketcall)
SYSCALL2(stat)
SYSCALL1(stime)
SYSCALL2(symlink)
SYSCALL1(sync)
SYSCALL1(sysinfo)
SYSCALL1(times)
SYSCALL2(truncate)
SYSCALL1(umask)
SYSCALL1(uname)
SYSCALL1(unlink)
SYSCALL2(utime)
SYSCALL0(vfork)
SYSCALL4(wait4)
SYSCALL3(write)
т.е. передача номера прерывания через регистр r7 (в __thumb__), а не в инструкции swi вызывает ошибку.
Что характерно, системные вызовы linux мне вообще не нужны для arm-elf.
Подскажите, пожалуйста, решение проблемы (правильную конфигурацию при сборке или правильный синтаксис системных вызовов).
Ответов (1 - 7)
klen
сообщение Oct 30 2009, 08:06
бессмертным стать можно тремя способами
Пользователь №: 16 912
неделю назад был тот же трабл. я просто ручками сделал как правильно - вынес имя системного вызова в виде непосредственно ланных как требует команда svc.
сегодня грохнул linux-syscalls0.S и обновился cvs.
собралось без матугания на тумб ветку.
сильно релиз поскорей выложить хотели. обновите дерево исходников и будет счастье.
Сообщение отредактировал Doka - Nov 14 2009, 07:14
Причина редактирования: бездумное цитирование
Bulya
сообщение Oct 30 2009, 15:07
Из: Харьков
Действительно, четыре дня назад в CVS http://sources.redhat.com/newlib/ появилась ревизия libgloss/arm/linux-syscalls0.S, в которой выбросили весь код для __thumb__.
Пропатченная библиотека собралась.
Doka
сообщение Nov 14 2009, 07:19
Electrical Engineer
Группа: СуперМодераторы
Пользователь №: 778
а о каком CVS newlib речь??.. я брал отсюда ftp://sources.redhat.com/pub/newlib/
версия newlib-1.17.0.tar.gz датирована 22.12.2008 (собирал с правкой configure.ac как описано на http://eluaproject.dreamhosters.com/en/Bui..._GCC_for_Cortex )
Блог iDoka.ru
CV linkedin.com/in/iDoka
Sources github.com/iDoka
Never stop thinking...........................
klen
сообщение Nov 14 2009, 10:55
http://ru.wikipedia.org/wiki/CVS
читать до конца
ставить CVS клиета, забирать им текщий срез дерева исходников, править и закладывать сои измения в дерево(для продвинутых smile.gif)
также читать по теме SVN,GIT,Mercurial
Doka
сообщение Nov 14 2009, 12:37
Electrical Engineer
Пользователь №: 778
читать до конца
LOL..
версия 1.17.0 согласно ftp RedHat выпущена 22.12.2008
если в системе контроля ревизий не работает автоинкремент этих самых ревизий - это уже не система контроля ревизий..
как может текущий срез называться номеров уже выпущеной (freeze) ревизии?
Блог iDoka.ru
klen
сообщение Nov 14 2009, 13:42
Цитата(Doka @ Nov 14 2009, 15:37) *
LOL..
уважаемый, Вы не до конца дочитали.
1.17.0 - это всего лишь релиз, конкретный срез который приняли как "релизный".
чтоб получить самые свежее состояние дерева исходников в Вашем случае нужно в консоли жмякнуть
cvs -z 9 -d :pserver:anoncvs@sources.redhat.com:/cvs/src co newlib
и потом перед сборкой при желании обновить дерево в тойже консоли с темже текущим путем жмякнуть
cvs update
Doka
сообщение Nov 15 2009, 10:21
Electrical Engineer
Пользователь №: 778
ну не знаю... у меня почему-то версия newlib-1.17.0 под ARM собирается..
(./configure --target=$TARGET --prefix=$PREFIX --enable-interwork --disable-newlib-supplied-syscalls --with-gnu-ld --with-gnu-as --disable-shared || exit)
Блог iDoka.ru
RSS Текстовая версия Сейчас: 27th July 2025 - 14:19
Страница сгенерированна за 0.01429 секунд с 7
