> EPSC
artem79
сообщение Jan 15 2010, 10:06
Из: Казань
Пользователь №: 24 091
Добрый день.
Сталкнулся с проблемой загрузки программы во флаш.
Имеется след. система. EP2C5 - SRAM - EPCS. в качестве памяти программ используется SRAM. В отладчике все работает.
Пытаюсь загрузить во флэш через flash-programmer выдает следующее:
CODE
#!/bin/sh
# This file was automatically generated by the Nios II IDE Flash Programmer.
# It will be overwritten when the flash programmer options change.
cd H:/Nios_60/software/count_binary_0/Debug
# Creating .flash file for the FPGA configuration
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="H:/Nios_60/nios_uart.sof" --outp
ut="nios_uart.flash"
Info: *******************************************************************
Info: Running Quartus II Convert_programming_file
Info: Command: quartus_cpf --no_banner --convert --device=EPCS128 --option=nios_
uart.opt H:/Nios_60/nios_uart.sof nios_uart.pof
Info: Quartus II Convert_programming_file was successful. 0 errors, 0 warnings
Info: Peak virtual memory: 73 megabytes
Info: Processing ended: Fri Jan 15 12:40:07 2010
Info: Elapsed time: 00:00:05
Info: Total CPU time (on all processors): 00:00:05
Info: Command: quartus_cpf --no_banner --convert nios_uart.pof nios_uart.rpd
Info: Peak virtual memory: 71 megabytes
Info: Processing ended: Fri Jan 15 12:40:16 2010
Info: Elapsed time: 00:00:08
Info: Total CPU time (on all processors): 00:00:07
# Programming flash with the FPGA configuration
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00201000 --sidp=0x0
0202068 --id=477433320 --timestamp=1263547010 --instance=0 "nios_uart.flash"
Using cable "ByteBlasterMV [LPT1]", device 1, instance 0x00
Resetting and pausing target processor: OK
Reading System ID at address 0x00202068: verified
No EPCS layout data - looking for section [EPCS-EF3013]
Unable to use EPCS device
Leaving target processor paused
# Creating .flash file for the project
"$SOPC_KIT_NIOS2/bin/elf2flash" --epcs --after="nios_uart.flash" --input="count_
binary_0.elf" --output="epcs_flash_controller_0.flash"
# Programming flash with the project
0202068 --id=477433320 --timestamp=1263547010 --instance=0 "epcs_flash_controlle
r_0.flash"
Такое ощущение что флэшку не видит. Может кто сталкивался????? Работаю в QuartusII 9.0.
Сообщение отредактировал Omen_13 - Jan 19 2010, 20:31
Причина редактирования: Оформление
3 страниц V   1 2 3 >
Ответов (1 - 14)
vadimuzzz
сообщение Jan 15 2010, 14:41
Пользователь №: 6 988
а систему в SOPC-билдере не пересобирали? обычно такое бывает, когда в процессе пересборки адреса поменялись, а в скрипте остались старые.
artem79
сообщение Jan 26 2010, 06:59
Из: Казань
Перепробывал разные варианты. пересобирал и т.д. Установил sp2 на quartus 9.0 & nios II 9.0. Ни чего не помагает пишет:
No EPCS layout data - looking for section [EPCS-EF3013].
Загрузка EPCS4 из quartusa (*.jic) проходит без ошибок. Проект рабочий.
vadimuzzz
сообщение Jan 26 2010, 07:15
а флеш точно EPCS или аналог? точное название микросхемы скажите, похоже надо override сделать
Stewart Little
сообщение Jan 26 2010, 07:51
Лентяй
Пользователь №: 843
Попробуйте все-таки с USB Вlaster'ом.
По крайней мере выясните, в чем там дело - в самодельном байтбластере или нет.
Чтобы слова не расходились с делом, нужно молчать и ничего не делать...
artem79
сообщение Jan 26 2010, 08:33
Из: Казань
Пробовал USB-Blaster, но опять самодельный. Из квартуса и кристал и флзш определяется, шьется . С ниосом тоже самое.
Проверить фирменным пока нет возможности.
EPCS4N
9905X
Stewart Little
сообщение Jan 26 2010, 08:38
Лентяй
Пользователь №: 843
Ну тогда надо искать косяк на плате. Вот здесь http://www.niosforum.com/pages/forum.php?cat_id=5 было описание похожей проблемы - дело оказалось в том, что бластер запитывался от 5 вольт вместо 3,3-х :
FYI, I have discovered the source of this problem. I had a failure in my breakout board that was shorting the 3.3V JTAG line to 5V. Amazingly, this has not appeared to cause any permanent damage to the FPGA or supporting electronics. Once the breakout problem was fixed, I am now able to reprogram succesfully again.
vadimuzzz
сообщение Jan 26 2010, 08:44
Цитата(artem79 @ Jan 26 2010, 14:33) *
EPCS4N
9905X
попробуйте так:
создайте файл <nios2_install>/bin/nios2-flash-override.txt
и добавьте в него:
[EPCS-EF3013] # EPCS4N
sector_size = 65536
sector_count = 4
еще выхлоп флеш-программера с ключом --debug приведите.
artem79
сообщение Jan 26 2010, 09:23
Из: Казань
После сохдания файла ниос вроде начал программировать, но не может верифицировать. Соответственно девайс не работает.
CODE
#!/bin/sh
cd G:/Nios_60/software/count_binary/Debug
"$SOPC_KIT_NIOS2/bin/sof2flash" --epcs --input="G:/Nios_60/nios_uart.sof" --outp
uart.opt G:/Nios_60/nios_uart.sof nios_uart.pof
Info: The Active Serial/Parallel mode CONF_DONE pin error check is disabled
Info: Peak virtual memory: 72 megabytes
Info: Processing ended: Tue Jan 26 12:26:01 2010
Info: Elapsed time: 00:00:03
Info: Total CPU time (on all processors): 00:00:03
Info: Peak virtual memory: 70 megabytes
Info: Processing ended: Tue Jan 26 12:26:06 2010
Info: Total CPU time (on all processors): 00:00:04
"$SOPC_KIT_NIOS2/bin/nios2-flash-programmer" --epcs --base=0x00201800 --cable='U
SB-Blaster [USB-0]' --sidp=0x00202068 --id=874152530 --timestamp=1264497173 "ni
os_uart.flash"
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
: Checksumming existing contents
00000000 : Verifying existing contents
00010000 : Verifying existing contents
00000000 : Reading existing contents
00010000 : Reading existing contents
Checksummed/read 45kB in 1.1s
00000000 ( 0%): Erasing
00010000 (50%): Erasing
Erased 128kB in 0.2s (640.0kB/s)
00000000 ( 0%): Programming
00010000 (50%): Programming
Programmed 84KB +44KB in 2.6s (49.2KB/s)
Did not attempt to verify device contents
binary.elf" --output="epcs_flash_controller.flash"
SB-Blaster [USB-0]' --sidp=0x00202068 --id=874152530 --timestamp=1264497173 "ep
Checksummed/read 41kB in 0.9s
00010000 ( 0%): Erasing
Erased 64kB in 0.1s
00010000 ( 0%): Programming
Programmed 24KB +40KB in 1.0s (64.0KB/s)
Причина редактирования: Оформление кода
vadimuzzz
сообщение Jan 26 2010, 09:38
по логам - все нормально, верификация проходит (стирает, где надо).
стелайте дамп флешки (ключ --read=filename), сравните с исходным.
да, еще: как именно не работает?
если питание выкл/вкл флеш-программер видит чип?
если видит, значит sof загрузился
Stewart Little
Лентяй
Пользователь №: 843
Скорее, FlashProgrammer не пытается верифицировать - Did not attempt to verify device contents
После завершения программирования попробуйте предернуть сброс ниоса, ну или питание на плате - есть подозрение, что все заработает.
artem79
сообщение Jan 26 2010, 09:55
Из: Казань
Получается что не исполняется сама программа. посве выкл/вкл Чип видит. Если из ниоса сделать run то начинает работать.
vadimuzzz
сообщение Jan 26 2010, 10:03
вектор сброса не забыли на EPCS нацелить?
artem79
сообщение Jan 26 2010, 10:18
Из: Казань
reset - epcs_flash_controller
exception - sram
programm memory - sram
stack memory - sram
vadimuzzz
сообщение Jan 26 2010, 10:36
непонятно.. надо как-нибудь дамп sram сделать после подачи питания. память on-chip или внешняя?
3 страниц V   1 2 3 >
RSS Текстовая версия Сейчас: 26th July 2025 - 16:57
Страница сгенерированна за 0.01487 секунд с 7
