> RTC на LPC 2478 - ошибка: structure has no member named `class_dev', uClinux
andybeg
сообщение Nov 13 2010, 08:24
Пользователь №: 22 954
пытаюсь включить поддержку RTC, делаю как прописано у EA
5.13.1 Configuration
Real Time Clock support is enabled at the following place in the configuration tree:
Device Drivers->Real Time Clock->RTC class
In the Embedded Artists configuration, support for setting the Linux system time from the
RTC source has also been enabled.
Device Drivers->Real Time Clock->Set system time from RTC on startup
In the configuration tree it is possible to select which RTC interface to use for user-domain
applications. All the three alternatives have been enabled in the Embedded Artists
configuration.
Device Drivers->Real Time Clock->sysfs
Device Drivers->Real Time Clock->proc
Device Drivers->Real Time Clock->dev
Finally the hardware support must also be enabled.
Device Drivers->Real Time Clock->NXP LPC2XXX RTC support
при компиляции получаю ошибку
drivers/rtc/rtc-lpc22xx.c: In function `lpc22xx_rtc_interrupt':
drivers/rtc/rtc-lpc22xx.c:278: ошибка: structure has no member named `class_dev'
static irqreturn_t lpc22xx_rtc_interrupt(int irq, void *dev_id)
struct platform_device *pdev = dev_id;
struct rtc_device *rtc = platform_get_drvdata(pdev);
unsigned long events = 0;
unsigned char ilr = REG_RTC_ILR & 0x07;
#ifdef CONFIG_RTC_DEBUG
printk(KERN_INFO "%s(%d) irl=%x\n", __FUNCTION__, ilr);
#endif
if (ilr) { /* this interrupt is shared! Is it ours? */
if (ilr & 0x01) { // RTCCIF counter increment interrupt
events |= (RTC_UF | RTC_IRQF);
if (ilr & 0x02) { // RTCALF alarm interrupt
events |= (RTC_AF | RTC_IRQF);
if (ilr & 0x04) { // RTCSF sub-second interrupt
events |= (RTC_PF | RTC_IRQF);
REG_RTC_ILR = ilr;
rtc_update_irq(&rtc->class_dev, 1, events);<<============= строка 278
printk("%s(): num=%ld, events=0x%02lx\n", __FUNCTION__,
events >> 8, events & 0x000000FF);
#endif
return IRQ_HANDLED;
return IRQ_NONE; /* not handled */
сталкивался кто с таким?
нашел определение функции , которой передаётся не существующий параметр структуры и вижу что должен передаваться указатель на структуру
extern void rtc_update_irq(struct rtc_device *rtc,
unsigned long num, unsigned long events);
убрав параметр `class_dev' на который ругался компилятор удачно прошёл процесс, убедился что RTC идёт, по старту линукс их понимаю считывает, но устройство /dev/rtc не создаётся, потому что
/> hwclock --systohc --debug
hwclock 2.4c/util-linux-2.11a
hwclock: Open of /dev/rtc failed, errno=2: No such file or directory.
No usable clock interface found.
Cannot access the Hardware Clock via any known method.
Сообщение отредактировал andybeg - Nov 13 2010, 14:50
Ответов (1 - 6)
sasamy
сообщение Nov 13 2010, 14:01
Пользователь №: 41 858
Как у вас в uclinux создаются файлы устройств ? Попробуйте вручную создать
#mknod /dev/rtc c 254 0
или может создан файл устройства с именем rtc0, тогда
#ln -s /dev/rtc0 /dev/rtc
Сообщение отредактировал sasamy - Nov 13 2010, 14:08
andybeg
сообщение Nov 13 2010, 14:45
создаю? я в настройке uClinux прописываю драйвер
в rc скрипте прописал mknod /dev/rtc c 254 0
и получил
/> ln -s /dev/rtc0 /dev/rtc
/dev/rtc: Read-only file system
но установка часов попрежнему вылетает с ошибкой
/> hwclock --debug --systohc
но часы на плате идут, показывают
/> date
Tue Jul 3 20:19:53 1951
Сообщение отредактировал andybeg - Nov 13 2010, 14:47
sasamy
сообщение Nov 13 2010, 15:30
К сожалению (или счастью ? smile.gif с uclinux не имел дел но на обычном linux часы будут идти и без драйвера rtc.
andybeg
сообщение Nov 13 2010, 15:32
я немного не о том - при пропадении питания время не сбрасывается, что может говорить о том что риал тайм клок работает
sasamy
сообщение Nov 13 2010, 15:35
Какое-то неравильное время - отчсчет ведется от 1970 года.
kurtis
сообщение Nov 13 2010, 17:55
Пользователь №: 6 205
и получил
Если у вас rootfs по умолчанию монтируется как read-only, то вы ничего туда записать (создать) не сможете.
попробуйте перед созданием нода сделать
mount -o remount,rw / (или куда там у вас монтируется rootfs), может поможет.
RSS Текстовая версия Сейчас: 18th July 2025 - 05:31
Страница сгенерированна за 0.01415 секунд с 7
