> Ошибка маппинга
D-Luxe
сообщение Feb 25 2011, 17:27
Из: Пенза
Пользователь №: 55 642
Во время синтеза проекта в среде EDK мэппер выкинул следующие ошибки.
# Starting program map
# map -o system_map.ncd -pr b -ol high -timing system.ngd system.pcf
Release 10.1 - Map K.39 (nt)
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
PMSPEC -- Overriding Xilinx file <c:/Xilinx/10.1/ISE/virtex4/data/virtex4.acd>
with local file <c:/Xilinx/10.1/ISE/virtex4/data/virtex4.acd>
Using target part "4vfx20ff672-11".
Mapping design into LUTs...
ERROR:MapLib:979 - LUT3 symbol "ip_header_0/ip_header_0/RFF_DATA_OUT<20>1"
   (output signal=IP_TO_R_RFF_DATA<20>) has input signal
   "ip_header_0/ip_header_0/bytes4_cnt<4>" which will be trimmed. See Section 5
   of the Map Report File for details about why the input signal will become
   undriven.
   "ip_header_0/ip_header_0/remove4bytes" which will be trimmed. See Section 5
   undriven.
ERROR:MapLib:979 - LUT4 symbol "ip_header_0/ip_header_0/write_packet1" (output
   signal=IP_TO_R_WR_REQ) has input signal
   "ip_header_0/ip_header_0/bytes4_cnt<4>1" which will be trimmed. See Section 5
   undriven.
ERROR:MapLib:978 - LUT3 symbol "ip_header_0/ip_header_0/RFF_DATA_OUT<20>1"
   (output signal=IP_TO_R_RFF_DATA<20>) has an equation that uses input pin I0,
   which no longer has a connected signal. Please ensure that all the pins used
   in the equation for this LUT have signals that are not trimmed (see Section 5
   of the Map Report File for details on which signals were trimmed).
   (output signal=IP_TO_R_RFF_DATA<20>) has an equation that uses input pin I1,
ERROR:MapLib:978 - LUT4 symbol "ip_header_0/ip_header_0/write_packet1" (output
   signal=IP_TO_R_WR_REQ) has an equation that uses input pin I3, which no
   longer has a connected signal. Please ensure that all the pins used in the
   equation for this LUT have signals that are not trimmed (see Section 5 of the
Error found in mapping process, exiting...
Errors found during the mapping phase.  Please see map report file for more
details.  Output files will not be written.
Design Summary
Number of errors   :   6
Number of warnings :   2
ERROR:Xflow - Program map returned error code 2. Aborting flow execution...
В чем причина?
Нелегко оказаться на верном пути, но куда труднее его пройти.
(с) Уилл Роджерс
Ответов (1 - 1)
Mad_max
сообщение Feb 26 2011, 11:16
Из: Зеленоград
Пользователь №: 23 811
Ну там же все написано.
В отчете мапера 5 секция - removed logic.
Там некоторые цепи были удалены, и далее мапер счел, что паровоз дальше так не полетит.
Хотя по идее это должно быть предупреждением, а не ошибкой.
Посмотрите 5 секцию, что там было удалено, а далее уже смотрите по дизайну, почему так произошло.
RSS Текстовая версия Сейчас: 21st July 2025 - 23:59
Страница сгенерированна за 0.01343 секунд с 7
