> Проблемы с двоичным семафором, задача не получает семафор
Vovan4ik
сообщение Apr 6 2012, 09:15
Из: Чебоксары
Пользователь №: 65 449
В main создаю семафор, в прерываниях использую xSemaphoreGiveFromISR(), в задаче-обработчике использую xSemaphoreTake() и принудительное переключение контекста vPortYieldFromISR()
возникает проблема в этом месте
signed portBASE_TYPE xQueueGenericSendFromISR( xQueueHandle pxQueue, const void * const pvItemToQueue, signed portBASE_TYPE *pxHigherPriorityTaskWoken, portBASE_TYPE xCopyPosition )
signed portBASE_TYPE xReturn;
unsigned portBASE_TYPE uxSavedInterruptStatus;
/* Similar to xQueueGenericSend, except we don't block if there is no room
in the queue. Also we don't directly wake a task that was blocked on a
queue read, instead we return a flag to say whether a context switch is
required or not (i.e. has a task with a higher priority than us been woken
by this post). */
uxSavedInterruptStatus = portSET_INTERRUPT_MASK_FROM_ISR();
if( pxQueue->uxMessagesWaiting < pxQueue->uxLength )
traceQUEUE_SEND_FROM_ISR( pxQueue );
prvCopyDataToQueue( pxQueue, pvItemToQueue, xCopyPosition );
/* If the queue is locked we do not alter the event list. This will
be done when the queue is unlocked later. */
if( pxQueue->xTxLock == queueUNLOCKED )
if( !listLIST_IS_EMPTY( &( pxQueue->xTasksWaitingToReceive ) ) )
if( xTaskRemoveFromEventList( &( pxQueue->xTasksWaitingToReceive ) ) != pdFALSE )
/* The task waiting has a higher priority so record that a
context switch is required. */
*pxHigherPriorityTaskWoken = pdTRUE;
else
/* Increment the lock count so the task that unlocks the queue
knows that data was posted while it was locked. */
++( pxQueue->xTxLock );
xReturn = pdPASS;
else
traceQUEUE_SEND_FROM_ISR_FAILED( pxQueue );
xReturn = errQUEUE_FULL;
portCLEAR_INTERRUPT_MASK_FROM_ISR( uxSavedInterruptStatus );
return xReturn;
uxMessagesWaiting больше uxLength и возвращается xReturn = errQUEUE_FULL;
что делать????
Из Курница написано:
- errQUEUE_FULL — означает, что дан­ные не записаны в очередь, так как очередь заполнена. Если определена продолжительность тайм-аута (пара­метр xTicksToWait не равен «О» или portMAX_DELAY), то возврат значения errQUEUE_FULL говорит о том, что тайм-аут завершен и свободное место в очереди так и не появилось.
в моем случае последнее, почему свободное место в очереди не появилось??
вот какие значения, откуда ? это же двоичный семафор, или я не так понимаю откуда такие значения
RSS Текстовая версия Сейчас: 25th July 2025 - 22:12
Страница сгенерированна за 0.01411 секунд с 7
