> NIOS и PLL
talyankh
сообщение Aug 26 2012, 08:31
Пользователь №: 73 253
Есть такая вот система, когда ядро тактируется от плл то при заливке прошивки еклипс не видит проц. Если тактироватся непосредственно от кварца(48мгц), то все работает.
Сообщение отредактировал talyankh - Aug 26 2012, 08:33
talyankh
сообщение Aug 26 2012, 13:55
cpu0.sdc
set     cpu_0     cpu_0:*
set     cpu_0_oci     cpu_0_nios2_oci:the_cpu_0_nios2_oci
set     cpu_0_oci_break     cpu_0_nios2_oci_break:the_cpu_0_nios2_oci_break
set     cpu_0_ocimem     cpu_0_nios2_ocimem:the_cpu_0_nios2_ocimem
set     cpu_0_oci_debug     cpu_0_nios2_oci_debug:the_cpu_0_nios2_oci_debug
set     cpu_0_wrapper     cpu_0_jtag_debug_module_wrapper:the_cpu_0_jtag_debug_module_wrapper
set     cpu_0_jtag_tck     cpu_0_jtag_debug_module_tck:the_cpu_0_jtag_debug_module_tck
set     cpu_0_jtag_sysclk     cpu_0_jtag_debug_module_sysclk:the_cpu_0_jtag_debug_module_sysclk
set     cpu_0_oci_path      [format "%s|%s" $cpu_0 $cpu_0_oci]
set     cpu_0_oci_break_path      [format "%s|%s" $cpu_0_oci_path $cpu_0_oci_break]
set     cpu_0_ocimem_path      [format "%s|%s" $cpu_0_oci_path $cpu_0_ocimem]
set     cpu_0_oci_debug_path      [format "%s|%s" $cpu_0_oci_path $cpu_0_oci_debug]
set     cpu_0_jtag_tck_path      [format "%s|%s|%s" $cpu_0_oci_path $cpu_0_wrapper $cpu_0_jtag_tck]
set     cpu_0_jtag_sysclk_path      [format "%s|%s|%s" $cpu_0_oci_path $cpu_0_wrapper $cpu_0_jtag_sysclk]
set     cpu_0_jtag_sr      [format "%s|*sr" $cpu_0_jtag_tck_path]
# Set False Paths
set_false_path -from [get_keepers *$cpu_0_oci_break_path|break_readreg*] -to [get_keepers *$cpu_0_jtag_sr*]
set_false_path -from [get_keepers *$cpu_0_oci_debug_path|*resetlatch]     -to [get_keepers *$cpu_0_jtag_sr[33]]
set_false_path -from [get_keepers *$cpu_0_oci_debug_path|monitor_ready]  -to [get_keepers *$cpu_0_jtag_sr[0]]
set_false_path -from [get_keepers *$cpu_0_oci_debug_path|monitor_error]  -to [get_keepers *$cpu_0_jtag_sr[34]]
set_false_path -from [get_keepers *$cpu_0_ocimem_path|*MonDReg*] -to [get_keepers *$cpu_0_jtag_sr*]
set_false_path -from *$cpu_0_jtag_sr*    -to *$cpu_0_jtag_sysclk_path|*jdo*
set_false_path -from sld_hub:*|irf_reg* -to *$cpu_0_jtag_sysclk_path|ir*
set_false_path -from sld_hub:*|sld_shadow_jsm:shadow_jsm|state[1] -to *$cpu_0_oci_debug_path|monitor_go
PLL создаю в sopc билдере и там-же подключаю. Входная частота 48МГц, выходная 144МГц.
Еклипс пишет:
Using cable "USB-Blaster [USB-0]", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
RSS Текстовая версия Сейчас: 21st July 2025 - 15:51
Страница сгенерированна за 0.01398 секунд с 7
